Fedora 21 Mate Compiz X86 (32Bit) Bardzo Powolne Uruchamianie Się Systemu ?
komp2015
Dzień dobry
Mam mały problem w linux Fedora 21 Mate Compiz x86 (32bit)
otóż po zainstalowaniu kilkadziesiąt program linux fedora bardzo długo się uruachamia.
Czy ktoś mógł by mi pomóc co jest nie tak
plik boot.log
%G%G%G[[32m  OK  [0m] Started Show Plymouth Boot Screen.
[[32m  OK  [0m] Reached target Paths.
[[32m  OK  [0m] Reached target Basic System.
[[32m  OK  [0m] Found device Storage_Device boot.
[[32m  OK  [0m] Found device Storage_Device ogolne.
         Starting File System Check on /dev/disk/by-uuid/d62974df-0b60-418b-ae7d-05b810939356...
[[32m  OK  [0m] Started dracut initqueue hook.
[[32m  OK  [0m] Reached target Remote File Systems (Pre).
[[32m  OK  [0m] Reached target Remote File Systems.
[    6.547206] systemd-fsck[379]: ogolne: clean, 750414/4456448 files, 6510634/17798144 blocks
[[32m  OK  [0m] Started File System Check on /dev/disk/by-uuid/d62974df-0b60-418b-ae7d-05b810939356.
         Mounting /sysroot...
[[32m  OK  [0m] Mounted /sysroot.
[[32m  OK  [0m] Reached target Initrd Root File System.
         Starting Reload Configuration from the Real Root...
[[32m  OK  [0m] Started Reload Configuration from the Real Root.
[[32m  OK  [0m] Reached target Initrd File Systems.
[[32m  OK  [0m] Reached target Initrd Default Target.
         Starting dracut pre-pivot and cleanup hook...
[[32m  OK  [0m] Started dracut pre-pivot and cleanup hook.
         Starting Cleaning Up and Shutting Down Daemons...
         Stopping Cleaning Up and Shutting Down Daemons...
[[32m  OK  [0m] Stopped target Timers.
         Starting Plymouth switch root service...
[[32m  OK  [0m] Stopped Cleaning Up and Shutting Down Daemons.
         Stopping dracut pre-pivot and cleanup hook...
[[32m  OK  [0m] Stopped dracut pre-pivot and cleanup hook.
[[32m  OK  [0m] Stopped target Remote File Systems.
[[32m  OK  [0m] Stopped target Remote File Systems (Pre).
         Stopping dracut initqueue hook...
[[32m  OK  [0m] Stopped dracut initqueue hook.
[[32m  OK  [0m] Stopped target Initrd Default Target.
[[32m  OK  [0m] Stopped target Basic System.
[[32m  OK  [0m] Stopped target Slices.
[[32m  OK  [0m] Stopped target Paths.
[[32m  OK  [0m] Stopped target Sockets.
[[32m  OK  [0m] Stopped target System Initialization.
         Stopping Apply Kernel Variables...
[[32m  OK  [0m] Stopped Apply Kernel Variables.
         Stopping udev Coldplug all Devices...
[[32m  OK  [0m] Stopped udev Coldplug all Devices.
[[32m  OK  [0m] Stopped target Swap.
[[32m  OK  [0m] Stopped target Local File Systems.
         Stopping udev Kernel Device Manager...
[[32m  OK  [0m] Started Plymouth switch root service.
[[32m  OK  [0m] Stopped udev Kernel Device Manager.
         Stopping dracut pre-udev hook...
[[32m  OK  [0m] Stopped dracut pre-udev hook.
         Stopping dracut cmdline hook...
[[32m  OK  [0m] Stopped dracut cmdline hook.
         Stopping Create Static Device Nodes in /dev...
[[32m  OK  [0m] Stopped Create Static Device Nodes in /dev.
         Stopping Create list of required static device nodes for the current kernel...
[[32m  OK  [0m] Stopped Create list of required static device nodes for the current kernel.
[[32m  OK  [0m] Closed udev Kernel Socket.
[[32m  OK  [0m] Closed udev Control Socket.
         Starting Cleanup udevd DB...
[[32m  OK  [0m] Started Cleanup udevd DB.
[[32m  OK  [0m] Reached target Switch Root.
         Starting Switch Root...
Welcome to [0;34mFedora 21 (Twenty One)[0m!
[[32m  OK  [0m] Stopped Switch Root.
[[32m  OK  [0m] Stopped target Switch Root.
[[32m  OK  [0m] Stopped target Initrd File Systems.
         Stopping File System Check on /dev/disk/by-uuid/d62974df-0b60-418b-ae7d-05b810939356...
[[32m  OK  [0m] Stopped File System Check on /dev/disk/by-uuid/d62974df-0b60-418b-ae7d-05b810939356.
[[32m  OK  [0m] Stopped target Initrd Root File System.
[[32m  OK  [0m] Reached target User and Group Name Lookups.
         Starting Collect Read-Ahead Data...
         Starting Replay Read-Ahead Data...
[[32m  OK  [0m] Created slice system-getty.slice.
[[32m  OK  [0m] Reached target Login Prompts.
[[32m  OK  [0m] Created slice User and Session Slice.
         Mounting RPC Pipe File System...
[[32m  OK  [0m] Reached target Slices.
[[32m  OK  [0m] Listening on Delayed Shutdown Socket.
[[32m  OK  [0m] Listening on /dev/initctl Compatibility Named Pipe.
[[32m  OK  [0m] Set up automount Arbitrary Executable File Formats File System Automount Point.
[[32m  OK  [0m] Stopped Flush Journal to Persistent Storage.
         Stopping Journal Service...
[[32m  OK  [0m] Stopped Journal Service.
         Starting Journal Service...
         Starting Create list of required static device nodes for the current kernel...
         Mounting POSIX Message Queue File System...
         Mounting Huge Pages File System...
         Mounting Debug File System...
[[32m  OK  [0m] Listening on udev Kernel Socket.
[[32m  OK  [0m] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
[[32m  OK  [0m] Listening on Device-mapper event daemon FIFOs.
[[32m  OK  [0m] Listening on LVM2 metadata daemon socket.
         Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[[32m  OK  [0m] Reached target Swap.
         Mounting Temporary Directory...
         Expecting device dev-disk-by\x2duuid-e8491a72\x2d95c9\x2d4485\x2d800b\x2d063bba2eb5c2.device...
[[32m  OK  [0m] Started Collect Read-Ahead Data.
[[32m  OK  [0m] Started Replay Read-Ahead Data.
         Starting File System Check on Root Device...
         Starting Apply Kernel Variables...
         Starting Set Up Additional Binary Formats...
[[32m  OK  [0m] Mounted POSIX Message Queue File System.
[[32m  OK  [0m] Mounted Huge Pages File System.
[[32m  OK  [0m] Mounted Debug File System.
[[32m  OK  [0m] Mounted Temporary Directory.
[[32m  OK  [0m] Started Apply Kernel Variables.
[[32m  OK  [0m] Started Create list of required static device nodes for the current kernel.
         Mounting Arbitrary Executable File Formats File System...
[[32m  OK  [0m] Started udev Coldplug all Devices.
         Starting udev Wait for Complete Device Initialization...
         Starting LVM2 metadata daemon...
[[32m  OK  [0m] Started LVM2 metadata daemon.
[[32m  OK  [0m] Mounted Arbitrary Executable File Formats File System.
[[32m  OK  [0m] Started Set Up Additional Binary Formats.
[[32m  OK  [0m] Mounted RPC Pipe File System.
[[32m  OK  [0m] Started File System Check on Root Device.
         Starting Remount Root and Kernel File Systems...
[[32m  OK  [0m] Started Journal Service.
[   13.120508] systemd-fsck[475]: ogolne: Superblok last write time is in the future.
[   13.121044] systemd-fsck[475]: (by less than a day, probably due to the hardware clock being incorrectly set)
[   13.121269] systemd-fsck[475]: ogolne: czysty, 750414/4456448 plików, 6510634/17798144 bloków
[[32m  OK  [0m] Started Remount Root and Kernel File Systems.
         Starting Configure read-only root support...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
         Starting Import network configuration from initramfs...
[[32m  OK  [0m] Started Configure read-only root support.
[[32m  OK  [0m] Started Load/Save Random Seed.
[[32m  OK  [0m] Started Import network configuration from initramfs.
[[32m  OK  [0m] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[[32m  OK  [0m] Reached target Local File Systems (Pre).
         Mounting NFSD configuration filesystem...
[[32m  OK  [0m] Mounted NFSD configuration filesystem.
[[32m  OK  [0m] Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[[32m  OK  [0m] Started udev Kernel Device Manager.
%G%G[[32m  OK  [0m] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight Brightness of backlight:acpi_video1...
         Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
[[32m  OK  [0m] Started Load/Save Screen Backlight Brightness of backlight:acpi_video1.
[[32m  OK  [0m] Started Load/Save Screen Backlight Brightness of backlight:intel_backlight.
         Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
[[32m  OK  [0m] Started Load/Save Screen Backlight Brightness of backlight:acpi_video0.
[[32m  OK  [0m] Created slice system-systemd\x2drfkill.slice.
         Starting Load/Save RF Kill Switch Status of rfkill2...
         Starting Load/Save RF Kill Switch Status of rfkill1...
         Starting Load/Save RF Kill Switch Status of rfkill0...
[[1;31mFAILED[0m] Failed to start Load/Save RF Kill Switch Status of rfkill2.
See "systemctl status [email protected]" for details.
[[1;31mFAILED[0m] Failed to start Load/Save RF Kill Switch Status of rfkill1.
[[32m  OK  [0m] Started Load/Save RF Kill Switch Status of rfkill0.
         Starting File System Check on /dev/disk/by-uuid/e8491a72-95c9-4485-800b-063bba2eb5c2...
[[32m  OK  [0m] Reached target Sound Card.
         Starting Load/Save RF Kill Switch Status of rfkill3...
[[32m  OK  [0m] Started udev Wait for Complete Device Initialization.
         Starting Activation of DM RAID sets...
[[32m  OK  [0m] Started Flush Journal to Persistent Storage.
[[32m  OK  [0m] Started Activation of DM RAID sets.
[[32m  OK  [0m] Reached target Encrypted Volumes.
[[32m  OK  [0m] Started File System Check on /dev/disk/by-uuid/e8491a72-95c9-4485-800b-063bba2eb5c2.
         Mounting /boot...
[[32m  OK  [0m] Mounted /boot.
[[32m  OK  [0m] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Tell Plymouth To Write Out Runtime Data...
[[32m  OK  [0m] Started Tell Plymouth To Write Out Runtime Data.
[[1;31mFAILED[0m] Failed to start Load/Save RF Kill Switch Status of rfkill3.
[[32m  OK  [0m] Started Create Volatile Files and Directories.
         Starting Security Auditing Service...
[[32m  OK  [0m] Started Security Auditing Service.
         Starting Update UTMP about System Boot/Shutdown...
[[32m  OK  [0m] Started Update UTMP about System Boot/Shutdown.
[[32m  OK  [0m] Reached target System Initialization.
[   27.908449] systemd-fsck[630]: boot: czysty, 415/121920 plików, 170462/487424 bloków
[[32m  OK  [0m] Listening on CUPS Printing Service Sockets.
[[32m  OK  [0m] Listening on Open-iSCSI iscsid Socket.
[[32m  OK  [0m] Listening on Open-iSCSI iscsiuio Socket.
[[32m  OK  [0m] Listening on RPCbind Server Activation Socket.
[[32m  OK  [0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[[32m  OK  [0m] Listening on D-Bus System Message Bus Socket.
[[32m  OK  [0m] Reached target Sockets.
[[32m  OK  [0m] Reached target Timers.
         Starting Manage Sound Card State (restore and store)...
[[32m  OK  [0m] Started Manage Sound Card State (restore and store).
         Starting Bluetooth service...
         Starting Accounts Service...
         Starting RealtimeKit Scheduling Policy Service...
         Starting NTP client/server...
         Starting irqbalance daemon...
[[32m  OK  [0m] Started irqbalance daemon.
         Starting Modem Manager...
         Starting Machine Check Exception Logging Daemon...
         Starting Console Mouse manager...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting System Logging Service...
         Starting Self Monitoring and Reporting Technology (SMART) Daemon...
[[32m  OK  [0m] Started Self Monitoring and Reporting Technology (SMART) Daemon.
         Starting Hardware RNG Entropy Gatherer Daemon...
[[32m  OK  [0m] Started Hardware RNG Entropy Gatherer Daemon.
         Starting D-Bus System Message Bus...
[[32m  OK  [0m] Started D-Bus System Message Bus.
[[32m  OK  [0m] Started Avahi mDNS/DNS-SD Stack.
[[32m  OK  [0m] Started RealtimeKit Scheduling Policy Service.
[[32m  OK  [0m] Started Bluetooth service.
[[32m  OK  [0m] Reached target Bluetooth.
         Starting Login Service...
         Starting LSB: Init script for live image....
         Starting Preprocess NFS configuration...
         Starting GSSAPI Proxy Daemon...
         Starting firewalld - dynamic firewall daemon...
[[32m  OK  [0m] Started Machine Check Exception Logging Daemon.
[[32m  OK  [0m] Started Console Mouse manager.
[[32m  OK  [0m] Started LSB: Init script for live image..
[[32m  OK  [0m] Started System Logging Service.
[[32m  OK  [0m] Started Modem Manager.
         Starting ABRT Automated Bug Reporting Tool...
[[32m  OK  [0m] Started ABRT Automated Bug Reporting Tool.
         Starting Install ABRT coredump hook...
         Starting ABRT Xorg log watcher...
[[32m  OK  [0m] Started ABRT Xorg log watcher.
         Starting ABRT kernel log watcher...
[[32m  OK  [0m] Started ABRT kernel log watcher.
[[32m  OK  [0m] Started Preprocess NFS configuration.
[[32m  OK  [0m] Started Install ABRT coredump hook.
[[32m  OK  [0m] Started Login Service.
[[32m  OK  [0m] Started GSSAPI Proxy Daemon.
         Starting Authorization Manager...
         Starting Hostname Service...
[[32m  OK  [0m] Started NTP client/server.
[[32m  OK  [0m] Started Authorization Manager.
[[32m  OK  [0m] Started Accounts Service.
[[32m  OK  [0m] Started Hostname Service.
[[32m  OK  [0m] Started firewalld - dynamic firewall daemon.
         Starting Network Manager...
[[32m  OK  [0m] Started Network Manager.
         Starting Network Manager Wait Online...
         Starting Network Manager Script Dispatcher Service...
[[32m  OK  [0m] Started Network Manager Script Dispatcher Service.
[[0m[31m*     [0m] A start job is running for Network Manager Wait Online (53s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (54s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (54s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (55s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (55s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (56s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (56s / no limit) [K[     [31m*[0m] A start job is running for Network Manager Wait Online (57s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (57s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (58s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (58s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (58s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (59s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (59s / no limit) [K[[0m[31m*     [0m] A start job is running for Network Manager Wait Online (1min / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (1min / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (1min 1s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (1min 1s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (1min 2s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 2s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 3s / no limit) [K[     [31m*[0m] A start job is running for Network Manager Wait Online (1min 3s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 4s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 4s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (1min 5s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (1min 5s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (1min 6s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (1min 6s / no limit) [K[[0m[31m*     [0m] A start job is running for Network Manager Wait Online (1min 7s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (1min 7s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (1min 8s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (1min 8s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (1min 9s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 9s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 10s / no limit) [K[     [31m*[0m] A start job is running for Network Manager Wait Online (1min 10s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 11s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 11s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (1min 12s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (1min 12s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (1min 13s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (1min 13s / no limit) [K[[0m[31m*     [0m] A start job is running for Network Manager Wait Online (1min 14s / no limit) [K[[1;31m*[0m[31m*    [0m] A start job is running for Network Manager Wait Online (1min 14s / no limit) [K[[31m*[1;31m*[0m[31m*   [0m] A start job is running for Network Manager Wait Online (1min 15s / no limit) [K[ [31m*[1;31m*[0m[31m*  [0m] A start job is running for Network Manager Wait Online (1min 15s / no limit) [K[  [31m*[1;31m*[0m[31m* [0m] A start job is running for Network Manager Wait Online (1min 16s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 16s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 17s / no limit) [K[     [31m*[0m] A start job is running for Network Manager Wait Online (1min 17s / no limit) [K[    [31m*[1;31m*[0m] A start job is running for Network Manager Wait Online (1min 18s / no limit) [K[   [31m*[1;31m*[0m[31m*[0m] A start job is running for Network Manager Wait Online (1min 18s / no limit) [K[[1;31mFAILED[0m] Failed to start Network Manager Wait Online.
See "systemctl status NetworkManager-wait-online.service" for details.
[[32m  OK  [0m] Reached target Network.
[[32m  OK  [0m] Reached target Network is Online.
         Starting Notify NFS peers of a restart...
[[32m  OK  [0m] Started Notify NFS peers of a restart.
[[32m  OK  [0m] Reached target NFS client services.
         Starting Permit User Sessions...
         Starting LSB: start and stop the SIP express Router...
[[32m  OK  [0m] Started Permit User Sessions.
         Starting Command Scheduler...
[[32m  OK  [0m] Started Command Scheduler.
         Starting Job spooling tools...
[[32m  OK  [0m] Started Job spooling tools.
         Starting Terminate Plymouth Boot Screen...
         Starting Wait for Plymouth Boot Screen to Quit...
plik Xorg.0.log
[   391.025]
X.Org X Server 1.16.3
Release Date: 2014-12-20
[   391.025] X Protocol Version 11, Revision 0
[   391.025] Build Operating System:  3.17.8-300.bz1178975.fc21.x86_64
[   391.025] Current Operating System: Linux 87-239-177-73.rev.inds.pl 3.19.7-200.fc21.i686 #1 SMP Thu May 7 22:36:18 UTC 2015 i686
[   391.025] Kernel command line: BOOT_IMAGE=/vmlinuz-3.19.7-200.fc21.i686 root=UUID=d62974df-0b60-418b-ae7d-05b810939356 ro rhgb quiet LANG=pl_PL.UTF-8
[   391.026] Build Date: 31 January 2015  11:23:31PM
[   391.026] Build ID: xorg-x11-server 1.16.3-2.fc21
[   391.026] Current version of pixman: 0.32.6
[   391.026]     Before reporting problems, check http://wiki.x.org
[   391.026] Markers: (--) probed, (**) from config file, (==) default setting,
[   391.026] (==) Log file: "/var/log/Xorg.0.log", Time: Wed May 27 15:46:14 2015
[   391.080] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   391.080] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   391.150] (==) No Layout section.  Using the first Screen section.
[   391.150] (==) No screen section available. Using defaults.
[   391.150] (**) |-->Screen "Default Screen Section" (0)
[   391.150] (**) |   |-->Monitor "<default monitor>"
[   391.153] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[   391.153] (==) Automatically adding devices
[   391.153] (==) Automatically enabling devices
[   391.153] (==) Automatically adding GPU devices
[   391.153] (==) FontPath set to:
    catalogue:/etc/X11/fontpath.d,
    built-ins
[   391.153] (==) ModulePath set to "/usr/lib/xorg/modules"
[   391.153] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[   391.153] (II) Loader magic: 0x8282740
[   391.153] (II) Module ABI versions:
[   391.153]     X.Org ANSI C Emulation: 0.4
[   391.153]     X.Org Video Driver: 18.0
[   391.153]     X.Org XInput driver : 21.0
[   391.153]     X.Org Server Extension : 8.0
[   391.163] (EE) systemd-logind: failed to get session: PID 1250 does not belong to any known session
[   391.164] (II) xfree86: Adding drm device (/dev/dri/card1)
[   391.769] (II) xfree86: Adding drm device (/dev/dri/card0)
[   391.771] (--) PCI:*(0:0:2:0) 8086:0116:1043:15e2 rev 9, Mem @ 0xdd400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64, BIOS @ 0x????????/131072
[   391.771] (--) PCI: (0:1:0:0) 10de:0df4:1043:15e2 rev 161, Mem @ 0xdc000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[   391.772] (II) LoadModule: "glx"
[   391.813] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   392.017] (II) Module glx: vendor="X.Org Foundation"
[   392.017]     compiled for 1.16.3, module version = 1.0.0
[   392.017]     ABI class: X.Org Server Extension, version 8.0
[   392.017] (==) AIGLX enabled
[   392.017] (==) Matched intel as autoconfigured driver 0
[   392.017] (==) Matched nouveau as autoconfigured driver 1
[   392.017] (==) Matched nv as autoconfigured driver 2
[   392.017] (==) Matched intel as autoconfigured driver 3
[   392.017] (==) Matched modesetting as autoconfigured driver 4
[   392.017] (==) Matched fbdev as autoconfigured driver 5
[   392.017] (==) Matched vesa as autoconfigured driver 6
[   392.017] (==) Assigned the driver to the xf86ConfigLayout
[   392.017] (II) LoadModule: "intel"
[   392.017] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[   392.094] (II) Module intel: vendor="X.Org Foundation"
[   392.094]     compiled for 1.16.2.901, module version = 2.99.917
[   392.094]     Module class: X.Org Video Driver
[   392.094]     ABI class: X.Org Video Driver, version 18.0
[   392.094] (II) LoadModule: "nouveau"
[   392.094] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   392.130] (II) Module nouveau: vendor="X.Org Foundation"
[   392.131]     compiled for 1.16.1, module version = 1.0.11
[   392.131]     Module class: X.Org Video Driver
[   392.131]     ABI class: X.Org Video Driver, version 18.0
[   392.131] (II) LoadModule: "nv"
[   392.131] (WW) Warning, couldn't open module nv
[   392.132] (II) UnloadModule: "nv"
[   392.132] (II) Unloading nv
[   392.132] (EE) Failed to load module "nv" (module does not exist, 0)
[   392.132] (II) LoadModule: "modesetting"
[   392.132] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   392.145] (II) Module modesetting: vendor="X.Org Foundation"
[   392.145]     compiled for 1.16.0, module version = 0.9.0
[   392.145]     Module class: X.Org Video Driver
[   392.145]     ABI class: X.Org Video Driver, version 18.0
[   392.145] (II) LoadModule: "fbdev"
[   392.145] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   392.147] (II) Module fbdev: vendor="X.Org Foundation"
[   392.147]     compiled for 1.16.0, module version = 0.4.3
[   392.147]     Module class: X.Org Video Driver
[   392.147]     ABI class: X.Org Video Driver, version 18.0
[   392.147] (II) LoadModule: "vesa"
[   392.147] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[   392.149] (II) Module vesa: vendor="X.Org Foundation"
[   392.149]     compiled for 1.16.0, module version = 2.3.2
[   392.149]     Module class: X.Org Video Driver
[   392.149]     ABI class: X.Org Video Driver, version 18.0
[   392.149] (II) intel: Driver for Intel® Integrated Graphics Chipsets:
    i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
    915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
    Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
    GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[   392.150] (II) intel: Driver for Intel® HD Graphics: 2000-6000
[   392.150] (II) intel: Driver for Intel® Iris Graphics: 5100, 6100
[   392.150] (II) intel: Driver for Intel® Iris Pro Graphics: 5200, 6200, P6300
[   392.150] (II) NOUVEAU driver
[   392.150] (II) NOUVEAU driver for NVIDIA chipset families :
[   392.150]     RIVA TNT        (NV04)
[   392.150]     RIVA TNT2       (NV05)
[   392.150]     GeForce 256     (NV10)
[   392.150]     GeForce 2       (NV11, NV15)
[   392.151]     GeForce 4MX     (NV17, NV18)
[   392.151]     GeForce 3       (NV20)
[   392.151]     GeForce 4Ti     (NV25, NV28)
[   392.151]     GeForce FX      (NV3x)
[   392.151]     GeForce 6       (NV4x)
[   392.151]     GeForce 7       (G7x)
[   392.151]     GeForce 8       (G8x)
[   392.151]     GeForce GTX 200 (NVA0)
[   392.151]     GeForce GTX 400 (NVC0)
[   392.151] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   392.151] (II) FBDEV: driver for framebuffer: fbdev
[   392.151] (II) VESA: driver for VESA chipsets: vesa
[   392.151] (++) using VT number 1
[   392.171] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20141121
[   392.177] (II) [drm] nouveau interface version: 1.2.1
[   392.177] (WW) Falling back to old probe method for modesetting
[   392.177] (WW) Falling back to old probe method for fbdev
[   392.177] (II) Loading sub module "fbdevhw"
[   392.177] (II) LoadModule: "fbdevhw"
[   392.178] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   392.180] (II) Module fbdevhw: vendor="X.Org Foundation"
[   392.180]     compiled for 1.16.3, module version = 0.0.2
[   392.180]     ABI class: X.Org Video Driver, version 18.0
[   392.180] (WW) Falling back to old probe method for vesa
[   392.183] (--) intel(0): Integrated Graphics Chipset: Intel® HD Graphics 3000
[   392.183] (--) intel(0): CPU: x86, sse2, sse3, ssse3, sse4.1, sse4.2, avx
[   392.184] (II) intel(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[   392.184] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   392.184] (==) intel(0): RGB weight 888
[   392.184] (==) intel(0): Default visual is TrueColor
[   392.184] (II) intel(0): Output LVDS1 has no monitor section
[   392.185] (--) intel(0): Found backlight control interface acpi_video1 (type 'firmware') for output LVDS1
[   392.185] (II) intel(0): Enabled output LVDS1
[   392.185] (II) intel(0): Output VGA1 has no monitor section
[   392.185] (II) intel(0): Enabled output VGA1
[   392.185] (II) intel(0): Output HDMI1 has no monitor section
[   392.185] (II) intel(0): Enabled output HDMI1
[   392.185] (II) intel(0): Output DP1 has no monitor section
[   392.185] (II) intel(0): Enabled output DP1
[   392.185] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   392.186] (II) intel(0): Output VIRTUAL1 has no monitor section
[   392.186] (II) intel(0): Enabled output VIRTUAL1
[   392.186] (--) intel(0): Output LVDS1 using initial mode 1600x900 on pipe 0
[   392.186] (==) intel(0): TearFree disabled
[   392.186] (==) intel(0): DPI set to (96, 96)
[   392.186] (II) Loading sub module "dri3"
[   392.186] (II) LoadModule: "dri3"
[   392.186] (II) Module "dri3" already built-in
[   392.186] (II) Loading sub module "dri2"
[   392.186] (II) LoadModule: "dri2"
[   392.186] (II) Module "dri2" already built-in
[   392.186] (II) Loading sub module "present"
[   392.186] (II) LoadModule: "present"
[   392.186] (II) Module "present" already built-in
[   392.187] (--) NOUVEAU(G0): Chipset: "NVIDIA NVC1"
[   392.187] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
[   392.187] (==) NOUVEAU(G0): RGB weight 888
[   392.187] (==) NOUVEAU(G0): Default visual is TrueColor
[   392.187] (==) NOUVEAU(G0): Using HW cursor
[   392.187] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[   392.187] (==) NOUVEAU(G0): Page flipping enabled
[   392.187] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[   392.187] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[   392.187] (II) NOUVEAU(G0): Initializing outputs ...
[   392.198] (II) NOUVEAU(G0): Output VGA-1-2 has no monitor section
[   392.198] (II) NOUVEAU(G0): 1 crtcs needed for screen.
[   392.206] (II) NOUVEAU(G0): Allocated crtc nr. 0 to this screen.
[   392.206] (II) NOUVEAU(G0): Allocated crtc nr. 1 to this screen.
[   392.217] (II) NOUVEAU(G0): EDID for output VGA-1-2
[   392.217] (II) NOUVEAU(G0): Printing probed modes for output VGA-1-2
[   392.217] (II) NOUVEAU(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   392.217] (II) NOUVEAU(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   392.217] (II) NOUVEAU(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   392.217] (II) NOUVEAU(G0): Modeline "848x480"x60.0   33.75  848 864 976 1088  480 486 494 517 +hsync +vsync (31.0 kHz e)
[   392.217] (II) NOUVEAU(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 489 492 525 -hsync -vsync (31.5 kHz e)
[   392.217] (II) NOUVEAU(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[   392.217] (--) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[   392.217] (**) NOUVEAU(G0):  Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[   392.217] (**) NOUVEAU(G0):  Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[   392.217] (**) NOUVEAU(G0):  Driver mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
[   392.217] (**) NOUVEAU(G0):  Driver mode "848x480": 33.8 MHz (scaled from 0.0 MHz), 31.0 kHz, 60.0 Hz
[   392.217] (**) NOUVEAU(G0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[   392.217] (==) NOUVEAU(G0): DPI set to (96, 96)
[   392.217] (II) Loading sub module "fb"
[   392.217] (II) LoadModule: "fb"
[   392.218] (II) Loading /usr/lib/xorg/modules/libfb.so
[   392.224] (II) Module fb: vendor="X.Org Foundation"
[   392.224]     compiled for 1.16.3, module version = 1.0.0
[   392.224]     ABI class: X.Org ANSI C Emulation, version 0.4
[   392.224] (II) Loading sub module "shadowfb"
[   392.224] (II) LoadModule: "shadowfb"
[   392.224] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[   392.236] (II) Module shadowfb: vendor="X.Org Foundation"
[   392.236]     compiled for 1.16.3, module version = 1.0.0
[   392.236]     ABI class: X.Org ANSI C Emulation, version 0.4
[   392.236] (II) UnloadModule: "modesetting"
[   392.236] (II) Unloading modesetting
[   392.236] (II) UnloadModule: "fbdev"
[   392.236] (II) Unloading fbdev
[   392.236] (II) UnloadSubModule: "fbdevhw"
[   392.236] (II) Unloading fbdevhw
[   392.237] (II) UnloadModule: "vesa"
[   392.237] (II) Unloading vesa
[   392.237] (==) Depth 24 pixmap format is 32 bpp
[   392.248] (II) NOUVEAU(G0): Channel setup complete.
[   392.252] (II) NOUVEAU(G0): [COPY] async initialised.
[   392.268] (II) NOUVEAU(G0): [DRI2] Setup complete
[   392.268] (II) NOUVEAU(G0): [DRI2]   DRI driver: nouveau
[   392.268] (II) NOUVEAU(G0): [DRI2]   VDPAU driver: nouveau
[   392.288] (II) Loading sub module "exa"
[   392.288] (II) LoadModule: "exa"
[   392.288] (II) Loading /usr/lib/xorg/modules/libexa.so
[   392.303] (II) Module exa: vendor="X.Org Foundation"
[   392.303]     compiled for 1.16.3, module version = 2.6.0
[   392.303]     ABI class: X.Org Video Driver, version 18.0
[   392.303] (II) EXA(256): Driver allocated offscreen pixmaps
[   392.303] (II) EXA(256): Driver registered support for the following operations:
[   392.303] (II)         Solid
[   392.303] (II)         Copy
[   392.303] (II)         Composite (RENDER acceleration)
[   392.303] (II)         UploadToScreen
[   392.304] (II)         DownloadFromScreen
[   392.304] (==) NOUVEAU(G0): Backing store enabled
[   392.304] (==) NOUVEAU(G0): Silken mouse enabled
[   392.307] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[   392.307] (II) NOUVEAU(G0): [XvMC] Extension initialized.
[   392.307] (==) NOUVEAU(G0): DPMS enabled
[   392.307] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   392.320] (II) intel(0): SNA initialized with Sandybridge (gen6, gt2) backend
[   392.320] (==) intel(0): Backing store enabled
[   392.320] (==) intel(0): Silken mouse enabled
[   392.320] (II) intel(0): HW Cursor enabled
[   392.320] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   392.321] (==) intel(0): DPMS enabled
[   392.321] (==) intel(0): display hotplug detection enabled
[   392.321] (II) intel(0): [DRI2] Setup complete
[   392.321] (II) intel(0): [DRI2]   DRI driver: i965
[   392.321] (II) intel(0): [DRI2]   VDPAU driver: i965
[   392.321] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   392.321] (II) intel(0): hardware support for Present enabled
[   392.321] (--) RandR disabled
[   392.353] (II) SELinux: Disabled by boolean
[   392.540] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[   392.540] (II) AIGLX: enabled GLX_ARB_create_context
[   392.540] (II) AIGLX: enabled GLX_ARB_create_context_profile
[   392.540] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[   392.540] (II) AIGLX: enabled GLX_INTEL_swap_event
[   392.540] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[   392.540] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[   392.540] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[   392.540] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[   392.540] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[   392.541] (II) AIGLX: Loaded and initialized i965
[   392.541] (II) GLX: Initialized DRI2 GL provider for screen 0
[   392.543] (II) NOUVEAU(G0): NVEnterVT is called.
[   392.565] (II) intel(0): switch to mode [email protected] on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[   392.568] (II) intel(0): Setting screen physical size to 423 x 238
[   393.192] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   393.193] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   393.193] (**) Power Button: Applying InputClass "system-keyboard"
[   393.193] (II) LoadModule: "evdev"
[   393.193] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[   393.230] (II) Module evdev: vendor="X.Org Foundation"
[   393.230]     compiled for 1.16.3, module version = 2.9.1
[   393.230]     Module class: X.Org XInput Driver
[   393.230]     ABI class: X.Org XInput driver, version 21.0
[   393.230] (II) Using input driver 'evdev' for 'Power Button'
[   393.230] (**) Power Button: always reports core events
[   393.230] (**) evdev: Power Button: Device: "/dev/input/event2"
[   393.230] (--) evdev: Power Button: Vendor 0 Product 0x1
[   393.230] (--) evdev: Power Button: Found keys
[   393.230] (II) evdev: Power Button: Configuring as keyboard
[   393.230] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   393.230] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   393.230] (**) Option "xkb_rules" "evdev"
[   393.230] (**) Option "xkb_layout" "pl"
[   393.293] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[   393.293] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   393.293] (**) Video Bus: Applying InputClass "system-keyboard"
[   393.294] (II) Using input driver 'evdev' for 'Video Bus'
[   393.294] (**) Video Bus: always reports core events
[   393.294] (**) evdev: Video Bus: Device: "/dev/input/event5"
[   393.294] (--) evdev: Video Bus: Vendor 0 Product 0x6
[   393.294] (--) evdev: Video Bus: Found keys
[   393.294] (II) evdev: Video Bus: Configuring as keyboard
[   393.294] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input13/event5"
[   393.294] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   393.294] (**) Option "xkb_rules" "evdev"
[   393.294] (**) Option "xkb_layout" "pl"
[   393.295] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[   393.295] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   393.295] (**) Video Bus: Applying InputClass "system-keyboard"
[   393.295] (II) Using input driver 'evdev' for 'Video Bus'
[   393.295] (**) Video Bus: always reports core events
[   393.295] (**) evdev: Video Bus: Device: "/dev/input/event4"
[   393.295] (--) evdev: Video Bus: Vendor 0 Product 0x6
[   393.295] (--) evdev: Video Bus: Found keys
[   393.295] (II) evdev: Video Bus: Configuring as keyboard
[   393.295] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4a/LNXVIDEO:00/input/input12/event4"
[   393.295] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   393.295] (**) Option "xkb_rules" "evdev"
[   393.295] (**) Option "xkb_layout" "pl"
[   393.296] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   393.296] (II) No input driver specified, ignoring this device.
[   393.296] (II) This device may have been added with another device file.
[   393.297] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   393.297] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   393.297] (**) Sleep Button: Applying InputClass "system-keyboard"
[   393.297] (II) Using input driver 'evdev' for 'Sleep Button'
[   393.297] (**) Sleep Button: always reports core events
[   393.297] (**) evdev: Sleep Button: Device: "/dev/input/event1"
[   393.297] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[   393.297] (--) evdev: Sleep Button: Found keys
[   393.297] (II) evdev: Sleep Button: Configuring as keyboard
[   393.297] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   393.297] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[   393.297] (**) Option "xkb_rules" "evdev"
[   393.297] (**) Option "xkb_layout" "pl"
[   393.300] (II) config/udev: Adding input device USB2.0 UVC 2M WebCam (/dev/input/event11)
[   393.300] (**) USB2.0 UVC 2M WebCam: Applying InputClass "evdev keyboard catchall"
[   393.300] (**) USB2.0 UVC 2M WebCam: Applying InputClass "system-keyboard"
[   393.300] (II) Using input driver 'evdev' for 'USB2.0 UVC 2M WebCam'
[   393.300] (**) USB2.0 UVC 2M WebCam: always reports core events
[   393.300] (**) evdev: USB2.0 UVC 2M WebCam: Device: "/dev/input/event11"
[   393.300] (--) evdev: USB2.0 UVC 2M WebCam: Vendor 0x13d3 Product 0x5122
[   393.300] (--) evdev: USB2.0 UVC 2M WebCam: Found keys
[   393.300] (II) evdev: USB2.0 UVC 2M WebCam: Configuring as keyboard
[   393.300] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input18/event11"
[   393.300] (II) XINPUT: Adding extended input device "USB2.0 UVC 2M WebCam" (type: KEYBOARD, id 10)
[   393.300] (**) Option "xkb_rules" "evdev"
[   393.300] (**) Option "xkb_layout" "pl"
[   393.301] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[   393.301] (II) No input driver specified, ignoring this device.
[   393.301] (II) This device may have been added with another device file.
[   393.302] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[   393.302] (II) No input driver specified, ignoring this device.
[   393.302] (II) This device may have been added with another device file.
[   393.302] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[   393.303] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event6)
[   393.303] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[   393.303] (**) USB USB Keykoard: Applying InputClass "system-keyboard"
[   393.303] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[   393.303] (**) USB USB Keykoard: always reports core events
[   393.303] (**) evdev: USB USB Keykoard: Device: "/dev/input/event6"
[   393.303] (--) evdev: USB USB Keykoard: Vendor 0x1a2c Product 0x23
[   393.303] (--) evdev: USB USB Keykoard: Found keys
[   393.303] (II) evdev: USB USB Keykoard: Configuring as keyboard
[   393.303] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:1A2C:0023.0001/input/input14/event6"
[   393.303] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 11)
[   393.303] (**) Option "xkb_rules" "evdev"
[   393.304] (**) Option "xkb_layout" "pl"
[   393.305] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event7)
[   393.305] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[   393.305] (**) USB USB Keykoard: Applying InputClass "system-keyboard"
[   393.305] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[   393.305] (**) USB USB Keykoard: always reports core events
[   393.305] (**) evdev: USB USB Keykoard: Device: "/dev/input/event7"
[   393.305] (--) evdev: USB USB Keykoard: Vendor 0x1a2c Product 0x23
[   393.305] (--) evdev: USB USB Keykoard: Found 1 mouse buttons
[   393.305] (--) evdev: USB USB Keykoard: Found scroll wheel(s)
[   393.305] (--) evdev: USB USB Keykoard: Found relative axes
[   393.305] (II) evdev: USB USB Keykoard: Forcing relative x/y axes to exist.
[   393.305] (--) evdev: USB USB Keykoard: Found absolute axes
[   393.305] (II) evdev: USB USB Keykoard: Forcing absolute x/y axes to exist.
[   393.305] (--) evdev: USB USB Keykoard: Found keys
[   393.305] (II) evdev: USB USB Keykoard: Configuring as mouse
[   393.305] (II) evdev: USB USB Keykoard: Configuring as keyboard
[   393.305] (II) evdev: USB USB Keykoard: Adding scrollwheel support
[   393.305] (**) evdev: USB USB Keykoard: YAxisMapping: buttons 4 and 5
[   393.305] (**) evdev: USB USB Keykoard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[   393.305] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:1A2C:0023.0002/input/input15/event7"
[   393.305] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 12)
[   393.305] (**) Option "xkb_rules" "evdev"
[   393.305] (**) Option "xkb_layout" "pl"
[   393.306] (II) evdev: USB USB Keykoard: initialized for relative axes.
[   393.306] (WW) evdev: USB USB Keykoard: ignoring absolute axes.
[   393.306] (**) USB USB Keykoard: (accel) keeping acceleration scheme 1
[   393.306] (**) USB USB Keykoard: (accel) acceleration profile 0
[   393.306] (**) USB USB Keykoard: (accel) acceleration factor: 2.000
[   393.306] (**) USB USB Keykoard: (accel) acceleration threshold: 4
[   393.307] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/event8)
[   393.307] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[   393.307] (II) Using input driver 'evdev' for 'USB OPTICAL MOUSE '
[   393.307] (**) USB OPTICAL MOUSE : always reports core events
[   393.307] (**) evdev: USB OPTICAL MOUSE : Device: "/dev/input/event8"
[   393.307] (--) evdev: USB OPTICAL MOUSE : Vendor 0x101 Product 0x7
[   393.307] (--) evdev: USB OPTICAL MOUSE : Found 9 mouse buttons
[   393.307] (--) evdev: USB OPTICAL MOUSE : Found scroll wheel(s)
[   393.307] (--) evdev: USB OPTICAL MOUSE : Found relative axes
[   393.307] (--) evdev: USB OPTICAL MOUSE : Found x and y relative axes
[   393.307] (II) evdev: USB OPTICAL MOUSE : Configuring as mouse
[   393.307] (II) evdev: USB OPTICAL MOUSE : Adding scrollwheel support
[   393.307] (**) evdev: USB OPTICAL MOUSE : YAxisMapping: buttons 4 and 5
[   393.307] (**) evdev: USB OPTICAL MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[   393.307] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0101:0007.0003/input/input16/event8"
[   393.307] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 13)
[   393.307] (II) evdev: USB OPTICAL MOUSE : initialized for relative axes.
[   393.308] (**) USB OPTICAL MOUSE : (accel) keeping acceleration scheme 1
[   393.308] (**) USB OPTICAL MOUSE : (accel) acceleration profile 0
[   393.308] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[   393.308] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[   393.308] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/mouse0)
[   393.308] (II) No input driver specified, ignoring this device.
[   393.308] (II) This device may have been added with another device file.
[   393.309] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event10)
[   393.309] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   393.309] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[   393.309] (II) Using input driver 'evdev' for 'Asus WMI hotkeys'
[   393.309] (**) Asus WMI hotkeys: always reports core events
[   393.309] (**) evdev: Asus WMI hotkeys: Device: "/dev/input/event10"
[   393.309] (--) evdev: Asus WMI hotkeys: Vendor 0 Product 0
[   393.309] (--) evdev: Asus WMI hotkeys: Found keys
[   393.309] (II) evdev: Asus WMI hotkeys: Configuring as keyboard
[   393.309] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input17/event10"
[   393.309] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 14)
[   393.309] (**) Option "xkb_rules" "evdev"
[   393.309] (**) Option "xkb_layout" "pl"
[   393.310] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[   393.310] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   393.310] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   393.310] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[   393.311] (**) AT Translated Set 2 keyboard: always reports core events
[   393.311] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[   393.311] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[   393.311] (--) evdev: AT Translated Set 2 keyboard: Found keys
[   393.311] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[   393.311] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[   393.311] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[   393.311] (**) Option "xkb_rules" "evdev"
[   393.311] (**) Option "xkb_layout" "pl"
[   393.312] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event9)
[   393.312] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[   393.312] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad catchall"
[   393.312] (**) ETPS/2 Elantech Touchpad: Applying InputClass "Default clickpad buttons"
[   393.312] (II) LoadModule: "synaptics"
[   393.312] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[   393.322] (II) Module synaptics: vendor="X.Org Foundation"
[   393.322]     compiled for 1.16.3, module version = 1.8.1
[   393.322]     Module class: X.Org XInput Driver
[   393.323]     ABI class: X.Org XInput driver, version 21.0
[   393.323] (II) Using input driver 'synaptics' for 'ETPS/2 Elantech Touchpad'
[   393.323] (**) ETPS/2 Elantech Touchpad: always reports core events
[   393.323] (**) Option "Device" "/dev/input/event9"
[   393.335] (II) synaptics: ETPS/2 Elantech Touchpad: ignoring touch events for semi-multitouch device
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: x-axis range 0 - 1152 (res 0)
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: y-axis range 0 - 576 (res 0)
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: pressure range 0 - 255
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: finger width range 0 - 15
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: buttons: left right double triple
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: Vendor 0x2 Product 0xe
[   393.335] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[   393.335] (**) ETPS/2 Elantech Touchpad: always reports core events
[   393.344] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input11/event9"
[   393.344] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 16)
[   393.344] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[   393.344] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MaxSpeed is now 1.75
[   393.344] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) AccelFactor is now 0.155
[   393.344] (**) ETPS/2 Elantech Touchpad: (accel) keeping acceleration scheme 1
[   393.344] (**) ETPS/2 Elantech Touchpad: (accel) acceleration profile 1
[   393.344] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[   393.344] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[   393.345] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[   393.345] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse1)
[   393.345] (II) No input driver specified, ignoring this device.
[   393.345] (II) This device may have been added with another device file.
[   395.632] reporting 5 6 6 44
[   415.546] reporting 5 6 6 44
[   416.307] reporting 5 6 6 44
[   416.607] (II) intel(0): EDID vendor "AUO", prod id 5022
[   416.607] (II) intel(0): Printing DDC gathered Modelines:
[   416.607] (II) intel(0): Modeline "1600x900"x0.0  110.00  1600 1648 1680 2000  900 903 909 912 -hsync -vsync (55.0 kHz eP)
[   416.620] reporting 5 6 10 73
[   416.621] reporting 5 6 10 73
[   416.624] reporting 5 6 10 73
[   416.637] reporting 5 6 10 73
[   416.661] reporting 5 6 10 73
[   417.668] reporting 5 6 10 73
[   417.704] reporting 5 6 10 73
[   419.232] reporting 5 6 10 73
[   419.714] reporting 5 6 10 73
[   420.009] reporting 5 6 10 73
[   420.178] reporting 5 6 10 73
[   420.184] reporting 5 6 10 73
[   420.185] reporting 5 6 10 73
[   420.189] reporting 5 6 10 73
[   420.194] reporting 5 6 10 73
[   420.195] reporting 5 6 10 73
[   420.389] reporting 5 6 10 73
[   420.460] reporting 5 6 10 73
[   420.566] reporting 5 6 10 73
[   420.727] reporting 5 6 10 73
[   421.979] reporting 5 6 10 73
[   422.374] reporting 5 6 10 73
[   422.401] reporting 5 6 10 73
[   422.415] reporting 5 6 10 73
[   422.779] reporting 5 6 10 73
[   449.756] reporting 5 6 10 73
[   509.172] reporting 5 6 10 73
[   577.101] reporting 5 6 10 73
[   605.297] reporting 5 6 10 73
[   655.376] reporting 5 6 10 73
[   709.316] reporting 5 6 10 73
[   978.206] reporting 5 6 10 73
Dziękuje za pomoc
Sam zabacz dlaczego wolno startuje, użyj polecenia
systemd-analyze critical-path
poprawka
systemd-analyze critical-chain
Ja obstawiam NetworkManager-wait-online.service proponuje go zablokować
systemctl disable NetworkManager-wait-online.service
Edytowane przez sunrise
