Gcc5 Zamiast Gcc6 W Fedorze24
tadek
Dzięki. Ja spróbowałem wg: http://www.tellurian.com.au/whitepapers/multiplegcc.php własnoręcznej kompilacji. Pomimo, że configure:
[tadeusz@toyo gobj]$ ~/gcc-5.3.0/configure --disable-multilib --prefix=/usr/local/gcc/53
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether ln works... yes
checking whether ln -s works... yes
checking for a sed that does not truncate output... /usr/bin/sed
checking for gawk... gawk
checking for libatomic support... yes
checking for libcilkrts support... yes
checking for libitm support... yes
checking for libsanitizer support... yes
checking for libvtv support... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether g++ accepts -static-libstdc++ -static-libgcc... no
checking for gnatbind... no
checking for gnatmake... no
checking whether compiler driver understands Ada... no
checking how to compare bootstrapped objects... cmp --ignore-initial=16 $$f1 $$f2
checking for objdir... .libs
checking for the correct version of gmp.h... yes
checking for the correct version of mpfr.h... yes
checking for the correct version of mpc.h... yes
checking for the correct version of the gmp/mpfr/mpc libraries... yes
checking for compatible ISL... no
The following languages will be built: c,c++,fortran,java,lto,objc
*** This configuration is not supported in the following subdirectories:
     target-libmpx gnattools gotools target-libada target-libgo target-libbacktrace target-liboffloadmic
    (Any other directories should still work fine.)
checking for default BUILD_CONFIG... bootstrap-debug
checking for --enable-vtable-verify... no
checking for bison... no
checking for byacc... no
checking for yacc... no
checking for gm4... no
checking for gnum4... no
checking for m4... m4
checking for flex... no
checking for lex... no
checking for makeinfo... no
/home/tadeusz/gcc-5.3.0/missing: line 81: makeinfo: command not found
checking for expect... no
checking for runtest... no
checking for ar... ar
checking for as... as
checking for dlltool... no
checking for ld... ld
checking for lipo... no
checking for nm... nm
checking for ranlib... ranlib
checking for strip... strip
checking for windres... no
checking for windmc... no
checking for objcopy... objcopy
checking for objdump... objdump
checking for readelf... readelf
checking for cc... cc
checking for c++... c++
checking for gcj... no
checking for gfortran... gfortran
checking for gccgo... no
checking for ar... no
checking for as... no
checking for ld... no
checking for nm... no
checking for objcopy... no
checking for objdump... no
checking for ranlib... no
checking for readelf... no
checking for strip... no
checking where to find the target ar... host tool
checking where to find the target as... host tool
checking where to find the target cc... just compiled
checking where to find the target c++... just compiled
checking where to find the target c++ for libstdc++... just compiled
checking where to find the target dlltool... host tool
checking where to find the target gcc... just compiled
checking where to find the target gcj... just compiled
checking where to find the target gfortran... just compiled
checking where to find the target gccgo... host tool
checking where to find the target ld... host tool
checking where to find the target lipo... host tool
checking where to find the target nm... host tool
checking where to find the target objcopy... host tool
checking where to find the target objdump... host tool
checking where to find the target ranlib... host tool
checking where to find the target readelf... host tool
checking where to find the target strip... host tool
checking where to find the target windres... host tool
checking where to find the target windmc... host tool
checking whether to enable maintainer-specific portions of Makefiles... no
configure: creating ./config.status
config.status: creating Makefile
przeszło to kompilacja wywraca się:
In file included from ./tm.h:48:0,
                 from /home/tadeusz/gcc-5.3.0/gcc/cp/except.c:27:
/home/tadeusz/gcc-5.3.0/gcc/defaults.h:126:24: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
       fprintf ((FILE), ","HOST_WIDE_INT_PRINT_UNSIGNED",%u\n",  \
In file included from /home/tadeusz/gcc-5.3.0/gcc/cp/except.c:1023:0:
cfns.gperf: In function ‘const char* libc_name_p(const char*, unsigned int)’:
cfns.gperf:101:1: error: ‘const char* libc_name_p(const char*, unsigned int)’ redeclared inline with ‘gnu_inline’ attribute
cfns.gperf:26:14: note: ‘const char* libc_name_p(const char*, unsigned int)’ previously declared here
cfns.gperf: At global scope:
cfns.gperf:26:14: warning: inline function ‘const char* libc_name_p(const char*, unsigned int)’ used but never defined
Makefile:1065: polecenia dla obiektu 'cp/except.o' nie powiodły się
make[3]: *** [cp/except.o] Błąd 1
make[3]: Opuszczenie katalogu '/home/tadeusz/gobj/gcc'
Makefile:4371: polecenia dla obiektu 'all-stage1-gcc' nie powiodły się
make[2]: *** [all-stage1-gcc] Błąd 2
make[2]: Opuszczenie katalogu '/home/tadeusz/gobj'
Makefile:22461: polecenia dla obiektu 'stage1-bubble' nie powiodły się
make[1]: *** [stage1-bubble] Błąd 2
make[1]: Opuszczenie katalogu '/home/tadeusz/gobj'
Makefile:22797: polecenia dla obiektu 'bootstrap' nie powiodły się
make: *** [bootstrap] Błąd 2
Może potrzebne są jakieś parametry?
