slabypingwin Napisano Listopad 19, 2023 Zgłoszenie Share Napisano Listopad 19, 2023 Od kilku dni tam ten sam problem z odtwarzaczem KAffeine ; po jego uruchomieniu jest tylko dźwięk , nie ma nawet okna tego programu na pulpicie MATE . W konsoli wywala takie błędy ; d Cytuj arek@fedora:~$ kaffeine 19-11-23 13:10:08.777 [Warning ] QCommandLineParser: already having an option named "h" 19-11-23 13:10:08.777 [Warning ] QCommandLineParser: already having an option named "help-all" 19-11-23 13:10:08.777 [Warning ] QCommandLineParser: already having an option named "v" 19-11-23 13:10:08.939 [Info ] kaffeine.dvb: Using built-in dvb device manager 19-11-23 13:10:09.691 [Info ] kaffeine.dev: Found dvb device : Realtek RTL2832 (DVB-T) 19-11-23 13:10:10.453 [Info ] kaffeine.dev: Found dvb device : Sony CXD2837ER DVB-T/T2/C demodulator 19-11-23 13:10:10.505 [Warning ] kf.kio.core: Malformed JSON protocol file for protocol: "trash" , number of the ExtraNames fields should match the number of ExtraTypes fields [0000563f69528f20] main audio output error: too low audio sample frequency (0) [00007f55f80e5510] main decoder error: failed to create audio output [00007f55f8031b90] main decoder error: buffer deadlock prevented [0000563f69528f20] vlcpulse audio output error: digital pass-through stream connection failure: Błąd wejścia/wyjścia [0000563f69528f20] main audio output error: module not functional [00007f55f80e5510] main decoder error: failed to create audio output libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_20 libva info: va_openDriver() returns 0 [00007f55d8001e90] glconv_vaapi_x11 gl error: vaDeriveImage: operation failed [00007f55e4154420] main video output error: video output creation failed [00007f55f8031b90] main decoder error: failed to create video output Failed to open VDPAU backend libvdpau_radeonsi.so: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu Failed to open VDPAU backend libvdpau_radeonsi.so: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu Proszę o jakieś porady , co z tym zrobić , Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Listopad 19, 2023 Zgłoszenie Share Napisano Listopad 19, 2023 Może jest, może nie ma. Spróbuj znaleźć: locate libvdpau_radeonsi.so Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
slabypingwin Napisano Listopad 19, 2023 Autor Zgłoszenie Share Napisano Listopad 19, 2023 Niestety Seem - odpowiedź na twoje pytanie jest taka ; Cytuj darek@fedora:~$ locate libvdpau_radeonsi.so /var/lib/plocate/plocate.db: Nie ma takiego pliku ani katalogu darek@fedora:~$ Próbowałem przed chwilą uruchomić Kaffeine na pulpicie Gno,me , ale turaj też wywala błędy ; Cytuj darek@fedora:~$ kaffeine 19-11-23 18:36:13.202 [Warning ] QSocketNotifier: Can only be used with threads started with QThread 19-11-23 18:36:13.391 [Warning ] QCommandLineParser: already having an option named "h" 19-11-23 18:36:13.391 [Warning ] QCommandLineParser: already having an option named "help-all" 19-11-23 18:36:13.391 [Warning ] QCommandLineParser: already having an option named "v" 19-11-23 18:36:13.625 [Info ] kaffeine.dvb: Using built-in dvb device manager 19-11-23 18:36:14.551 [Info ] kaffeine.dev: Found dvb device : Realtek RTL2832 (DVB-T) 19-11-23 18:36:15.327 [Info ] kaffeine.dev: Found dvb device : Sony CXD2837ER DVB-T/T2/C demodulator 19-11-23 18:36:15.394 [Warning ] QObject::connect: No such signal QPlatformNativeInterface::systemTrayWindowChanged(QScreen*) 19-11-23 18:36:15.417 [Warning ] kf.kio.core: Malformed JSON protocol file for protocol: "trash" , number of the ExtraNames fields should match the number of ExtraTypes fields [0000556b2e151fb0] main audio output error: too low audio sample frequency (0) [00007fd0cc0e55f0] main decoder error: failed to create audio output [00007fd0cc031f30] main decoder error: buffer deadlock prevented [0000556b2e151fb0] vlcpulse audio output error: digital pass-through stream connection failure: Błąd wejścia/wyjścia [0000556b2e151fb0] main audio output error: module not functional [00007fd0cc0e55f0] main decoder error: failed to create audio output [00007fd0b01802d0] xcb_window window error: bad X11 window 0x00000007 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_20 libva info: va_openDriver() returns 0 [00007fd0a4001e90] glconv_vaapi_x11 gl error: vaDeriveImage: operation failed [00007fd0b014fde0] main video output error: video output creation failed [00007fd0cc031f30] main decoder error: failed to create video output [00007fd0b01802d0] xcb_window window error: bad X11 window 0x00000007 Failed to open VDPAU backend libvdpau_nvidia.so: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu Failed to open VDPAU backend libvdpau_nvidia.so: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu Naruszenie ochrony pamięci (zrzut pamięci) Będę musiał chyba zmienić dystrybucję na inną . Mi się wydaje , że ten problem pojawił się ze 3 dni temu po zainstalowaniu aktualizacji . Wcześniej kaffeine uruchasmiała się normalnie ... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Listopad 20, 2023 Zgłoszenie Share Napisano Listopad 20, 2023 To nie jest niestety. (-: Trzeba tylko doinstalować. Paczkujący Kaffine zapomniał dopisać zależności do SPEC-a, zdarza się. Zainstaluj jeden z dwóch pakietów: dnf install mesa-vdpau-drivers lub, jeżeli używasz repozytoriów rpmfusion: dnf install mesa-vdpau-drivers-freeworld A locate bardzo polecam, bo fajne i szybko szuka plików po systemie operacyjnym: dnf install plocate Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
slabypingwin Napisano Listopad 23, 2023 Autor Zgłoszenie Share Napisano Listopad 23, 2023 Sem - marna to pociecha , że na innym linuksie - MS - kaffeine sprawia ten sam problem i w konsoli wywala podobne błędy ; Cytuj $ kaffeine 23-11-23 17:39:03.295 [Warning ] QCommandLineParser: already having an option named "h" 23-11-23 17:39:03.295 [Warning ] QCommandLineParser: already having an option named "help-all" 23-11-23 17:39:03.295 [Warning ] QCommandLineParser: already having an option named "v" 23-11-23 17:39:03.489 [Info ] kaffeine.dvb: Using built-in dvb device manager 23-11-23 17:39:04.163 [Info ] kaffeine.dev: Found dvb device : Realtek RTL2832 (DVB-T) 23-11-23 17:39:04.948 [Info ] kaffeine.dev: Found dvb device : Sony CXD2837ER DVB-T/T2/C demodulator 23-11-23 17:39:04.991 [Warning ] kf.kio.core: Malformed JSON protocol file for protocol: "trash" , number of the ExtraNames fields should match the number of ExtraTypes fields 23-11-23 17:39:04.993 [Warning ] kf.kio.core: Malformed JSON protocol file for protocol: "trash" , number of the ExtraNames fields should match the number of ExtraTypes fields 23-11-23 17:39:04.995 [Warning ] kf.kio.core: Malformed JSON protocol file for protocol: "trash" , number of the ExtraNames fields should match the number of ExtraTypes fields 23-11-23 17:39:05.096 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found 23-11-23 17:39:05.097 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found 23-11-23 17:39:05.382 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found 23-11-23 17:39:05.382 [Warning ] kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
slabypingwin Napisano Listopad 28, 2023 Autor Zgłoszenie Share Napisano Listopad 28, 2023 W tej chwili mam zainstalowany taki klon Fedory -ULTRAMARINE linux. Na razie 2 dzień po instalacji - kaffeine działa , choć podczas skanowania kanałów tv też wywalała błąd . Mi się wydaje Że problemy z tym odtwarzaczem biorą się stąd że kaffeine nier jest już rozwijana . A nowe wersje linuksowych distr zawierają nowe wersje różnych bibliotek i programów .... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
