Problem Z Mplayerem
konrad85
Zainstalowalem zgodnie z instrukcja z tego forum i otrzymuje taki komunikat po wpisaniu gmplayer
[root@localhost Desktop]# gmplayer
bash: /usr/bin/gmplayer: Nie ma takiego pliku ani katalogu
[root@localhost Desktop]# mplayer
MPlayer 1.0pre2-RPM-3.2 © 2000-2003 MPlayer Team
CPU: Advanced Micro Devices Duron MG Morgan 1406 MHz (Family: 6, Stepping: 0)
Detected cache-line size is 64 bytes
MMX2 supported but disabled
SSE supported but disabled
3DNow supported but disabled
3DNowExt supported but disabled
CPUflags: MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
Compiled for x86 CPU with extensions: MMX
Reading config file /etc/mplayer/mplayer.conf
Reading config file /root/.mplayer/config
Reading /root/.mplayer/codecs.conf: Can't open '/root/.mplayer/codecs.conf': Nie ma takiego pliku ani katalogu
Reading /etc/mplayer/codecs.conf: 61 audio & 157 video codecs
Usage: mplayer [options] [url|path/]filename
Basic options: (complete list in the man page)
-vo <drv[:dev]> select video output driver & device ('-vo help' for a list)
-ao <drv[:dev]> select audio output driver & device ('-ao help' for a list)
vcd://<trackno> play VCD (Video CD) track from device instead of plain file
dvd://<titleno> play DVD title from device instead of plain file
-alang/-slang select DVD audio/subtitle language (by 2-char country code)
-ss <timepos> seek to given (seconds or hh:mm:ss) position
-nosound do not play sound
-fs fullscreen playback (or -vm, -zoom, details in the man page)
-x <x> -y <y> set display resolution (for use with -vm or -zoom)
-sub <file> specify subtitle file to use (also see -subfps, -subdelay)
-playlist <file> specify playlist file
-vid x -aid y select video (x) and audio (y) stream to play
-fps x -srate y change video (x fps) and audio (y Hz) rate
-pp <quality> enable postprocessing filter (details in the man page)
-framedrop enable frame dropping (for slow machines)
Basic keys: (complete list in the man page, also check input.conf)
<- or -> seek backward/forward 10 seconds
up or down seek backward/forward 1 minute
pgup or pgdown seek backward/forward 10 minutes
< or > step backward/forward in playlist
p or SPACE pause movie (press any key to continue)
q or ESC stop playing and quit program
+ or - adjust audio delay by +/- 0.1 second
o cycle OSD mode: none / seekbar / seekbar + timer
* or / increase or decrease PCM volume
z or x adjust subtitle delay by +/- 0.1 second
r or t adjust subtitle position up/down, also see -vop expand
* * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * *
co moge z tym zrobic?
Nie wiem, skąd miałeś tą instarukcję, ale to stara jest. Odinstaluj tą wersję mplayera i zainstaluj nową yumem (jeżeli nie wiesz jak to zobacz TU
I postaraj się nie uruchamiać takich programów z uprawnieniami roota.
moze to glupie ale ja odinstalowac wszystko co jest zwiazane z mplayerem? bo probowalem ale mi sie nie udalo. Dlaczego nie uruchamiac takich programow z roota?
A jak instalowałeś? Napisz jakie paczki to były. Konto roota służy do prac administracyjnych w systemie i łatwo możesz coś niepotrzebnie pozmieniać. To dobre zabezpieczenia. Używaj konta normalnego użytkownika.
Byly to takie paczki:
mplayer-1.0pre2-1.i686.rpm
mplayer-common-1.0pre2-1.i686.rpm
mplayer-gui-1.0pre2-1.i686.rpm
mplayer-skin-default-1.0-2.noarch.rpm
mplayer-tools-1.0pre2-1.i686.rpm
z tym ze ze 2 z nich to byly 386 a nie 686 bo nie znalazlem 686
sposob instalacji: sciagalem rpmy ze stronek i instalowalem z konsoli rpm -ivh ...
Tak tez uczynilem i oto co mi linux powiedzial:
[konrad@localhost ~]$ rpm -e mplayer-1.0pre2-1.i686.rpm
błąd: pakiet mplayer-1.0pre2-1.i686.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-1.0pre2-1.i386.rpm
błąd: pakiet mplayer-1.0pre2-1.i386.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-common-1.0pre2-1.i686.rpm
błąd: pakiet mplayer-common-1.0pre2-1.i686.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-common-1.0pre2-1.i386.rpm
błąd: pakiet mplayer-common-1.0pre2-1.i386.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-gui-1.0pre2-1.i686.rpm
błąd: pakiet mplayer-gui-1.0pre2-1.i686.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-gui-1.0pre2-1.i386.rpm
błąd: pakiet mplayer-gui-1.0pre2-1.i386.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-skin-default-1.0-2.noarch.rpm
błąd: pakiet mplayer-skin-default-1.0-2.noarch.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-tools-1.0pre2-1.i686.rpm
błąd: pakiet mplayer-tools-1.0pre2-1.i686.rpm nie jest zainstalowany
[konrad@localhost ~]$ rpm -e mplayer-tools-1.0pre2-1.i386.rpm
błąd: pakiet mplayer-tools-1.0pre2-1.i386.rpm nie jest zainstalowany
natomiast to polecenie pokazuje co innego:
[konrad@localhost ~]$ rpm -qa mplayer
mplayer-1.0pre2-1
Dzieki, 2 pakiety mi sie odinstalowaly ale co powiecie na to:
[root@localhost konrad]# rpm -e mplayer-common-1.0pre2-1.i686
mplayer-common = 1.0pre2 jest wymagany przez (zainstalowany) mplayer-1.0pre2-1.i686
[root@localhost konrad]# rpm -e mplayer-1.0pre2-1.i686
mplayer = 1.0pre2 jest wymagany przez (zainstalowany) mplayer-common-1.0pre2-1.i686
Dzieki. Wszystko sie odinstalowalo. Teraz zabieram sie za instalacje od nowa mplayera.
Czyli wniosek z tego taki ze jak chce odinstalowac pakiety ktore maja zaleznosci miedzy soba to musze jednoczesnie je odinstalowac?
Ktos z uzytkownikow forum podpowiedzial mi zeby zainstalowac yumem i tak tez uczynilem a w rezultacie dostalem to:
[konrad@localhost ~]$ mplayer
MPlayer 1.0pre7try2-4.0.1 © 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Duron MG Morgan (Family: 6, Stepping: 0)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount)
r or t adjust subtitle position up/down, also see -vf expand
Czyli mniejwiecej to samo co wczesniej. W czym problem?
No i dalej nic:
[konrad@localhost ~]$ gmplayer
bash: gmplayer: command not found
a przeciez jest zainstalowany:
mplayer-1.0-0.lvn.0.26.pre7try2.4
a w menu nie dodalo sie. :(
nic sie z tym nie da zrobic?
Jeszcze troche pokombinowalem i moze to pomoze jakiemus specowi w diagnozie:
[root@localhost Incoming]# mplayer -vo xv -ao sdl -fs Blaupunkt.\(osloskop.net\).mpg
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0 : No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing Blaupunkt.(osloskop.net).mpg.
Cache fill: 0.00% (0 bytes) MPEG-PS file format detected.
VIDEO: MPEG1 384x288 (aspect 1) 25.000 fps 1150.0 kbps (143.8 kbyte/s)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 128.0 kbit/9.07% (ratio: 16000->176400)
Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3)
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
vo: couldn't open the X11 display (:0.0)!
Error opening/initializing the selected video_out (-vo) device.
Exiting... (End of file)
nadal zle:
[root@localhost Incoming]# yum install mplayer-gui
Setting up Install Process
Setting up repositories
livna 100% |=========================| 951 B 00:00
updates-released 100% |=========================| 951 B 00:00
base 100% |=========================| 1.1 kB 00:00
extras 100% |=========================| 1.1 kB 00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for mplayer-gui to pack into transaction set.
mplayer-gui-1.0-0.lvn.0.2 100% |=========================| 22 kB 00:00
---> Package mplayer-gui.i386 0:1.0-0.lvn.0.26.pre7try2.4 set to be updated
--> Running transaction check
Dependencies Resolved
Package Arch Version Repository Size
Installing:
mplayer-gui i386 1.0-0.lvn.0.26.pre7try2.4 livna 239 k
Transaction Summary
Install 1 Package(s)
Update 0 Package(s)
Remove 0 Package(s)
Total download size: 239 k
Is this ok [y/N]: y
Downloading Packages:
(1/1): mplayer-gui-1.0-0. 100% |=========================| 239 kB 00:07
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing: mplayer-gui ######################### [1/1]
Installed: mplayer-gui.i386 0:1.0-0.lvn.0.26.pre7try2.4
Complete!
[root@localhost Incoming]# gmplayer
MPlayer GUI requires X11.
JUZ JEST OK
po odinstalowaniu wszystkiego i zainstalowaniu na nowo mplayer dziala ale nadal nie da go sie uruchomic z konsoli tylko trzeba z menu. I jeszcze jedno jak sie instaluje kodeki. w windzie zawsze instalowalem ffdshow i ac3 i wszystko smiagalo a tu jakie kodeki sie instaluje i jak?
Gość
