@Kamills Napisano Grudzień 14, 2005 Zgłoszenie Share Napisano Grudzień 14, 2005 Zainstalowałem wysztsko jak FAQ przykazało i po poleceniu glxinfo pokazuje mi [root@ip-184-122 ~]# glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: No server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: SGI client glx version string: 1.4 client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory, GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group GLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIS_multisample OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.2.1) OpenGL extensions: GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3, GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square, GL_NV_point_sprite, GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x30 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None [root@ip-184-122 ~]# to czy mam akceleracje 3d mam karte ati radeon 9550 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Grudzień 14, 2005 Zgłoszenie Share Napisano Grudzień 14, 2005 [root@ip-184-122 ~]# glxinfo direct rendering: No (...) to czy mam akceleracje 3d Nie masz akceleracji. To dziwne, bo ta chipset Twojej karty jest wpierany przez sterowniki ati. Mógłbyś podać wersję sterowników, które pobrałeś? rpm -q ati-fglrx rpm -q kernel-module-fglrx Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Kamills Napisano Grudzień 14, 2005 Autor Zgłoszenie Share Napisano Grudzień 14, 2005 a skąd wiesz jaki ja mam chipset o lol dzisiaj rano instalowałem [root@ip-184-122 ~]# rpm -q kernel-module-fglrx pakiet kernel-module-fglrx nie jest zainstalowany [root@ip-184-122 ~]# a pierwsza komenda pokazuje [root@ip-184-122 ~]# rpm -q ati-fglrx ati-fglrx-8.20.8.1-0.lvn.2.4 [root@ip-184-122 ~]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
arturek Napisano Grudzień 14, 2005 Zgłoszenie Share Napisano Grudzień 14, 2005 (edytowane) A czy to robiłeś z lub dla nowego kernela 2.6.14-1.1653_FC4 jak tak to zawsze troche trzeba poczekać na nowe stery jeszcze nie ma już są Edytowane Grudzień 15, 2005 przez arturek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Kamills Napisano Grudzień 15, 2005 Autor Zgłoszenie Share Napisano Grudzień 15, 2005 Rozumiem że teraz mam direct rendering: Yes zorzumiałem że sterowniki z FAQ są dupne (_ściągnołem_ → ściągnąłem) ORT z officjale site i działiło Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Grudzień 15, 2005 Zgłoszenie Share Napisano Grudzień 15, 2005 zorzumiałem że sterowniki z FAQ są dupne Ej, wypraszam sobie. Jeszcze zniechęcisz do używania FAQ i znowu będziemy mieć powódź powtarzających się pytań. Sterowniki z FAQ są OK, jakoś tylko Tobie nie działają (pewnie coś źle skonfigurowałeś). Nawet u mnie działają, na "dziwnie" wpieranej mobility X700. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Grudzień 16, 2005 Zgłoszenie Share Napisano Grudzień 16, 2005 o lol dzisiaj rano instalowałem [root@ip-184-122 ~]# rpm -q kernel-module-fglrx pakiet kernel-module-fglrx nie jest zainstalowany [root@ip-184-122 ~]# sam coś musiałeś namieszać przy instalacji kernel-module, dlatego ci nie trybiło. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Enro Napisano Luty 24, 2006 Zgłoszenie Share Napisano Luty 24, 2006 Witam, podpinam sie pod ten wątek, bo jest bardzo podobny do mojej sytuacji Mam jądro 2.6.11 zrobiłem wszystko jak przykazał FAQ za pomocą (_yum'a_ → yuma) ORT i akceleracja dla ATI 9550 nie działa. Przeczytałem, że z tym jądrem są problemy i teraz nie wiem, czy mam odinstalować te sterowniki ( w sumie też nie wiem jak) czy może da się to jakoś wyprostować. Bedę wdzięczny bo przy tej jakości obrazu naprawdę bolą mnie oczy:) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Luty 24, 2006 Zgłoszenie Share Napisano Luty 24, 2006 yum update jak zaczniesz o 22 i masz cos o predkosci wyzszej od neo 512 to na 7 rano masz zrobione poza tym potem odpalaj FC z jajka 2.6.15 i doinstaluj stery do tego kernela Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Enro Napisano Luty 25, 2006 Zgłoszenie Share Napisano Luty 25, 2006 Niestety mam 256 i jeszcze jednego użytkownika wiec poczekam do poniedziałku z yum update , tak na margineis 522M. Postanowiłem jednak zainstalować sterowniki z ati.com pakiet ATI Driver installer, wcześniej odinstalowałem atifglrx. Po instalacji nowych sterowników mam problem ze skonfigurowaniem: [root@localhost X11]# fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9550 Generic OpenGL version string: 2.0.5642 (8.22.5) [root@localhost X11]# fglrxconfig -bash: fglrxconfig: command not found [root@localhost X11]# glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: Yes i co ja mam z tym zrobić? Nie mogę uruchomić fglrxconfig. Będę wdzięczny za podpowiedz. Zastanawiam się też jak ewentualnie odinstalować te sterowniki? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Luty 25, 2006 Zgłoszenie Share Napisano Luty 25, 2006 Niestety mam 256 i jeszcze jednego użytkownika wiec poczekam do poniedziałku z yum update Nie pamietam czy w KDE 3.4 jest mozliwosc przelaczania userow... jak jest to uzyj tego tak na margineis 522M. ja sciagalem 750 mb direct rendering: Yes masz akcelelacje Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Enro Napisano Luty 25, 2006 Zgłoszenie Share Napisano Luty 25, 2006 Dzięki, co do użytkownika to wisi on na routerze sprzętowym i sieć ma po WLAN o to mi chodziło, jestem człowiekiem i nie chcę ograniczać.. a teraz wracając do tematu... akceleracja swoją drogą, ale ja nie znalazłem sekdji ATI w xorg.conf, dla zmniejszenia objętośći wyciąłem linijki z # Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # the X server to render fonts. RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Option "XkbModel" "pc102" Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "720E" DisplaySize 320 240 HorizSync 30.0 - 72.0 VertRefresh 50.0 - 160.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" VendorName "Videocard vendor" BoardName "ATI Radeon 9600" Option "VideoOverlay" "on" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Jednak nadal [root@localhost X11]# fglrxconfig -bash: fglrxconfig: command not found Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Luty 25, 2006 Zgłoszenie Share Napisano Luty 25, 2006 jak chcesz wrzucac pliki to idz na http://pastebin.com i podaj nam tylko linka co wygenerowal. co do sekcji ATI to ja masz [ciach] Section "Device" Identifier "Videocard0" Driver "fglrx" VendorName "Videocard vendor" BoardName "ATI Radeon 9600" Option "VideoOverlay" "on" EndSection [ciach] Section "DRI" Group 0 Mode 0666 EndSection [ciach] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
