Jarek.S Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Witam! Postępowałem zgodnie z poniższym opisem który znalazłem w internecie.Poniżejsz przedstawiam opis tego: This HowTo explains compiling aMule and wxGTK from source under Fedora Core 3 and 4 First of all, you need a sane toolchain for GCC - This means you need to have the GCC package and its dependencies installed. Then, you need several development packages. The one I found most surprising was gettext-devel, because in FC2 and FC1 there was one single package for gettext. So be sure to have gettext-devel installed, as well as gtk+-devel, curl-devel and gd-devel. The easiest way to achieve this is usually using yum, the Fedora package manager. yum install gettext-devel gtk+-devel curl-devel gd-devel This should install all necessary devel packages, as well as the libraries/packages itself if they are not installed. Now, we're ready to go for the compilation of wxGTK wxGTK-2.4.2 & wxBase-2.4.2: You need to compile two libraries to compile all programs that are included within the aMule source package, but 2.4.2 is the stable release of the wxWidgets library at the moment. wxGTK-2.5.4 : This package includes wxGTK and wxBase and it is generally much less cpu hungry, but it is marked unstable and you might probably get troubles due to that. (I didn't encounter any trouble, btw) So, decide for one of the two options and let's go! First of all, download all necessary packages: If you decided for wxGTK-2.4.2: wxGTK-2.4.2.tar.bz2 wxBase-2.4.2.tar.bz2 If you decided for wxGTK-2.5.4: wxGTK-2.5.4.tar.bz2 And finally aMule-2.0.0rc8.tar.bz2 For wxGTK-2.4.2 & wxBase-2.4.2 Untar the wxGTK tar xfj wxGTK-2.4.2.tar.bz2 cd into the new directory cd wxGTK-2.4.2/ and run the configure script ./configure --prefix=/usr --disable-gtk2 Once that is finished without errors, you can go and build the package! Simply type make After that has finished, become super-user (generally root) with su (Type in super-user's password) run make install and exit super-user mode exit Next, let's install the wxBase package tar xfj wxBase-2.4.2.tar.bz2 cd into it cd wxBase-2.4.2/ run configure ./configure --prefix=/usr run make make and install as super-user again: su (Type in super-user's password) make install ln -sf /usr/bin/wxgtk-2.4-config /usr/bin/wx-config ln -sf /usr/bin/wxbase-2.4-config /usr/bin/wxbase-config Now exit super-user mode: exit For wxGTK-2.5.4 NOTE: There is support in aMule for a wxWidgets that is linked against GTK2 - But be warned, wxWidgets will leak HELL of a lot memory (about 100MB of RAM per day!) and so I really do not recommend this! Untar wxGTK-2.5.4 tar xfj wxGTK-2.5.4.tar.bz2 cd into the new directory cd wxGTK-2.5.4/ configure wxWidgets ./configure --prefix=/usr --disable-gtk2 run make make and install as super-user su (Type in super-user's password) make install Now exit super-user mode exit Good, you have wxWidgets now. Compilation of aMule Untar aMule's source tar xfj aMule-2.0.0rc7.tar.bz2 cd into the new directory cd aMule-2.0.0rc8/ Configure aMule (please take a look at this article) ./configure --prefix=/usr --enable-optimize --disable-debug --enable-wxcas --enable-cas --enable-alc --enable-alcc --enable-amule-daemon --enable-amulecmd --enable-webserver (This command tells the configure system to build every single program included in the aMule source package) make it: make and as super-user, install: su (Type in super-user's password) make install That's it! You're done! Comments and problems Comments / corrections are welcome, you can find me usually on IRC in #amule at irc://irc.freenode.net or reach me by mail: citroklar at amule dot org Citroklar 2005-03-11: Updated by Citroklar to version numbers wxGTK-2.5.4 and aMule-2.0.0rc8 after I got a tip to do so from bannerman in #amule. Thanks! 2005-10-07: it works also with wxWidgets CVS (2.7.0); I tried to build aMule on FC4 against wx compiled in ANSI+release mode. Postępując według powyższego opisu instalacja przebiegała dobrze bez błędów. Jednak efekt końcowy nie był zadowalający. Pisząc w konsoli amule lub klikając na skrót nie uruchamiał się. Proszę o odpowiedz w tej sprawie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
!Ci Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 OMG wedlug mnie to strasznie duzo zachodu dla zainstalowania. Rozumiem ze niektorzy wola wszystko ze zrodel... no ale przeciez jest takie cos jak Gentoo. Proponuje Ci zebys zainstalowal sobie poprzez yuma dodaj sobie tylko repozytorium livna. Jeszcze jedna rzecz to taka jesli zalezy Ci aby miec dostep do sieci Kad z amule bedzie potrzebna wersja 2.1 .Ja mozesz sobie sciagnac z oficjalnej strony amule. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Mi albo z livny albo z reszty podstawowych repozytoriów zainstalowała się wersja 2.1 z kademilą Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mysio Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Do aMula będziesz potrzebował wxGTK-2.6.2 stąd mrzesz ją ściągnąć http://rpm.pbone.net/index.php3/stat/4/idp...4.i386.rpm.html A tu masz aMula http://rpm.pbone.net/index.php3/stat/4/idp...4.i386.rpm.html Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Kamills Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 człowiku robisz problemy jak nie wiem co to Fedora nie Gento wiec starczy dać repo livina i wpisać yum install Amule bo ze źródeł to pobaw sie Gentoo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Postępując według powyższego opisu instalacja przebiegała dobrze bez błędów. Jednak efekt końcowy nie był zadowalający. Pisząc w konsoli amule lub klikając na skrót nie uruchamiał się. Proszę o odpowiedz w tej sprawie a uruchamiał się w inny sposób? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Sanczo Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Jarek.S make install O zgrozo Używaj checkinstall, masz na forum o tym. Postępując według powyższego opisu instalacja przebiegała dobrze bez błędów. Jednak efekt końcowy nie był zadowalający. Pisząc w konsoli amule lub klikając na skrót nie uruchamiał się. Proszę o odpowiedz w tej sprawie Z tego co widze zainstalowałeś go w /usr. Poszukaj jakiś jego katalogów w /usr i jego podkatalogach. Może pomoże: whereis amule Gdy chcesz odpalić amule to coś wypisuje Ci na ekran ,czy po prostu nie może znaleźć pliku binarnego? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Daniello Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Dla mnie aMule jest lewy. Nieciekawy interfejs, a poza tym prawie zawsze nie może znaleźć źródeł. Ale już chyba znalazłem na to sposób. Bede udostepniał pliki z partycji windowsowych. To i może jakieś kredyty dostanę. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tomis Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 a masz może javę zainstalowaną bo może nie masz javy jak masz zainstalowany Amule i nierusza albo jakiejś biblioteki najlepiej w konsoli wklepać amule i zobaczyć co ci pokaże i wtedy wiesz o co chodzi Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 A co ma wspólnego aMule z javą? To nie azureus :] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rafalzaq Napisano Styczeń 19, 2006 Zgłoszenie Share Napisano Styczeń 19, 2006 Nowy aMule (z Kad) jest dostępny w repo razem z zależnościami. Wystarczy mieć skonfigurowanego yuma tak jak w FAQ. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zajec00 Napisano Listopad 13, 2007 Zgłoszenie Share Napisano Listopad 13, 2007 amule z repo livna instaluje sie bez najmniejszych problemow, ale za to ma pewien bug... otoz po jakims czasie dzialania sam sie wylacza... natomiast po skompilowaniu ze zrodel nie ma tego problemu... amule moze chodzic caly tydzien i sie nie wylaczy... niestety, ostatnio bylem zmuszony zainstalowac wersje z repo, gdyz podczac kompilacji zrodel wyskakiwala masa zaleznosci, a gdy doszlo do wxWidgets to po ich "dograniu" (ich kompilacja zajela mi ponad 20min ) kompilator amula wywalil mi info ze wxWidgets jest zainstalowane ale jeden z jego parametrow (o ktorym wczesniej w zaden sposob mnie nie poinformowal) jest nieodpowiedni wzgledem amule'a i ze powinienem je przeinstalowac Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
