Amarok I Tekst Piosenek
sokar620
byc moze sa w tmp aamarok powbiera tekst z ustalonego wczesniej skryptu który pobieradane z tekstami np Lyrc lub Astraweb itp
lyrics_lyrc
About:
A lyrics script that interfaces with http://lyrc.com.ar.
Usage:
Just run the script, and then use the Lyrics tab in the Context sidebar.
Dependencies:
amaroK 1.4
Ruby 1.8
  • 1 year later...
Bo nie chcialem dostac odpowiedzi w stylu uzyj szukania
WIec sie podkleilem do juz istniejacego watku o amaroku i tesktach
Skrypt "Lyrc" zakończył działanie z kodem błędu: 1
/usr/lib/ruby/1.8/net/http.rb:560:in `initialize': Connection timed out - connect(2) (Errno::ETIMEDOUT)
    from /usr/lib/ruby/1.8/net/http.rb:560:in `open'
    from /usr/lib/ruby/1.8/net/http.rb:560:in `connect'
    from /usr/lib/ruby/1.8/timeout.rb:48:in `timeout'
    from /usr/lib/ruby/1.8/timeout.rb:76:in `timeout'
    from /usr/lib/ruby/1.8/net/http.rb:553:in `do_start'
    from /usr/lib/ruby/1.8/net/http.rb:542:in `start'
    from /usr/lib/ruby/1.8/net/http.rb:1035:in `request'
    from /usr/lib/ruby/1.8/net/http.rb:772:in `get'
    from /usr/share/apps/amarok/scripts/lyrics_lyrc/lyrics_lyrc.rb:127:in `fetchLyrics'
    from /usr/share/apps/amarok/scripts/lyrics_lyrc/lyrics_lyrc.rb:193
    from /usr/share/apps/amarok/scripts/lyrics_lyrc/lyrics_lyrc.rb:179:in `loop'
