Piotrek23 Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 Przy próbie instalacji czy to YUM-em w obu przypadkach system zwraca błąd. Podczas gdy chce zainstalować pakiet dwuklikiem, dostaje taki komunikat: Error Type: <type 'exceptions.TypeError'> Error Value: rpmdb open failed File : /usr/share/PackageKit/helpers/yum/install-files.py , line 19, in <module> backend = PackageKitYumBackend(sys.argv[1:]) File : /usr/share/PackageKit/helpers/yum/yumBackend.py , line 242, in __init__ self._setup_yum() File : /usr/share/PackageKit/helpers/yum/yumBackend.py , line 1556, in _setup_yum self.yumbase.doConfigSetup(errorlevel=0,debuglevel=0) # Setup Yum Config File : /usr/lib/python2.5/site-packages/yum/__init__.py , line 134, in doConfigSetup errorlevel=errorlevel) File : /usr/lib/python2.5/site-packages/yum/__init__.py , line 182, in _getConfig self._conf = config.readMainConfig(startupconf) File : /usr/lib/python2.5/site-packages/yum/config.py , line 732, in readMainConfig yumvars['releasever'] = _getsysver(startupconf.installroot, startupconf.distroverpkg) File : /usr/lib/python2.5/site-packages/yum/config.py , line 802, in _getsysver idx = ts.dbMatch('provides', distroverpkg) A gdy chcę zainstalować YUM-em: rpmdb: PANIC: fatal region error detected; run recovery błąd: błąd db4(-30977) z dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery błąd: nie można otworzyć indeksu Packages używając bazy danych3 - (-30977) błąd: nie można otworzyć bazy Packages w /var/lib/rpm Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 243, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 98, in main base.getOptionsConfig(args) File "/usr/share/yum-cli/cli.py", line 183, in getOptionsConfig disabled_plugins=self.optparser._splitArg(opts.disableplugins)) File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 182, in _getConfig self._conf = config.readMainConfig(startupconf) File "/usr/lib/python2.5/site-packages/yum/config.py", line 732, in readMainConfig yumvars['releasever'] = _getsysver(startupconf.installroot, startupconf.distroverpkg) File "/usr/lib/python2.5/site-packages/yum/config.py", line 802, in _getsysver idx = ts.dbMatch('provides', distroverpkg) TypeError: rpmdb open failed Nie mam żadnego pojęcia czym mogło by być to spowodowane, dlatego proszę was o rady i pomoc w rozwiązaniu problemu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 pokaż plik /var/log/yum.log Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 Plik jest tutaj: http://wklej.org/id/9ad470a1c4 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 rpmdb: PANIC: fatal region error detected; run recovery błąd: błąd db4(-30977) z dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery Tu jest rozwiązanie. Warto czytać logi. Uszkodzona baza indeksów RPM. Wykonaj jako root kolejno:cd /var/lib/rpm rm __db.* mv Packages Packages_old # to jako backup na wszelki wypadek rpm --rebuilddb # może trwać nawet kilkanaście minut, nie wyłączaj komputera, nie przerywaj działania yum clean all Oczywiście należy wyłączyć wszelkie programy i serwisy działające na tej bazie np.yum-updatesd. Awaria spowodowana była prawdopodobnie gwałtownym przerwaniem instalacji (np.reset komputera w czasie aktualizacji/instalacji). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 Tu jest rozwiązanie. Warto czytać logi. Uszkodzona baza indeksów RPM. Wykonaj jako root kolejno:cd /var/lib/rpm rm __db.* mv Packages Packages_old # to jako backup na wszelki wypadek rpm --rebuilddb # może trwać nawet kilkanaście minut, nie wyłączaj komputera, nie przerywaj działania yum clean all Oczywiście należy wyłączyć wszelkie programy i serwisy działające na tej bazie np.yum-updatesd. Awaria spowodowana była prawdopodobnie gwałtownym przerwaniem instalacji (np.reset komputera w czasie aktualizacji/instalacji). Niestety już przy 3 poleceniu na potkałem błędy: rpmdb: PANIC: fatal region error detected; run recovery błąd: błąd db4(-30977) z dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery błąd: nie można otworzyć indeksu Packages używając bazy danych3 - (-30977) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 Sprawdziłeś czy w katalogu /var/lib/rpm na pewno nie ma już plików __db.* ? Przed "db" są dwa znaki podkreślenia! I chyba zrobiłem błąd. Nie mv tylko cp. Plik "Packages" musi istnieć w /var/lib/rpm. Czyli trzeba przywrócić: cp Packages_old Packages rpm --rebuilddb Sorki, mój błąd. Przy okazji sprawdź czy nie masz "gryzących" się ze sobą repozytoriów. Poza standardowymi Fedory dostarczonymi z instalacją i Livną. Nie powinno być innych. Jak będzie dobrze, to dodasz sobie jeszcze Adobe, żeby mieć wtyczki flash-plugin do przeglądarek. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 Niestety przywróciłem kopię i wydałem polecenie, lecz nie trwało to nawet sekundy od razu przeszło do nowej lini, a po wykonaniu kolejnego polecenia zwróciło mi to: Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 243, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 98, in main base.getOptionsConfig(args) File "/usr/share/yum-cli/cli.py", line 183, in getOptionsConfig disabled_plugins=self.optparser._splitArg(opts.disableplugins)) File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 182, in _getConfig self._conf = config.readMainConfig(startupconf) File "/usr/lib/python2.5/site-packages/yum/config.py", line 732, in readMainConfig yumvars['releasever'] = _getsysver(startupconf.installroot, startupconf.distroverpkg) File "/usr/lib/python2.5/site-packages/yum/config.py", line 808, in _getsysver hdr = idx.next() StopIteration Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 A "yum clean all" zrobiłeś? Bo teraz wygląda na to, że błąd bazy RPM już się nie pojawił. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 Właśnie przy yum clean all wywaliło mi taki błąd. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 Sprawdź może czy baza RPM jest już OK. Np poleceniem "rpm -qa" - powinno wyświetlić wszystkie paczki w systemie. Jeśli zadziała bez błędów, to sprawdź jaką masz wersję yuma ("rpm -qa yum"). Ściągnij paczkę (wersja z poprzedniego polecenia) gdzieś z sieci np.http://download.fedora.redhat.com/pub/fedora/linux/updates/9/ i potem wybierz architekturę odpowiednią dla Twojego procesora (32-bit - i386, x86_64 dla 64-bit). Przeinstaluj "rpm -Uvh --replacepgks yum....<coś tam, coś tam, wersja>.rpm". Głowy nie dam, ale może coś się polepszy. Gorzej na pewno nie będzie. Wklejając błędy na forum pisz dokładnie z jakiego polecenia, z jakimi parametrami i z jakiego użytkownika wykonywałeś - będzie szybciej, bo bez nieporozumień. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 rpm -qa mówi samo za siebie, wynik polecenia: [root@localhost rpm]# rpm -qa [root@localhost rpm]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 Hmmm... Cóż, i tak bywa. Domyślam się że plik /var/lib/rpm/Packages ma wielkość 0 bajtów. Ciekawe czy Packages_old był większy? Tak czy siak nie wiem czy uda się wyjść z tego inaczej niż reinstalacja systemu, w każdym razie ja nie mam już pomysłów. Poza być może próbą kolejną próbą przywrócenia bazy o ile Packages_old jest > 0. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek23 Napisano Sierpień 20, 2008 Autor Zgłoszenie Share Napisano Sierpień 20, 2008 Nie ma (_wogóle_ ? w ogóle) ORT katalogu /var/lib/rpm/Packages jest tylko /var/lib/rpm/PackagesKit z plikiem transactions.db ale to jak się domyślam jest plik do wykonywania transakcji. Tak więc reinstalacja? Ehh, jak ja tego nie lubie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2008 Zgłoszenie Share Napisano Sierpień 20, 2008 Nie ma (_wogóle_ ? w ogóle) ORT katalogu /var/lib/rpm/Packages jest tylko /var/lib/rpm/PackagesKit :lammer: To być może coś się w F9 zmieniło, bo w F8 nadal jest tak jak pisałem. Co w takim razie kopiowałeś? Przecież miałeś skopiować plik Packages? Nie mogłeś od razu napisać, że tego pliku nie ma? W takim razie nie reinstaluj. Może ktoś kto ma F9 coś lepszego wymyśli. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Sierpień 21, 2008 Zgłoszenie Share Napisano Sierpień 21, 2008 Na F9 dane bazy rpm są cały czas w tym samym miejscu co w innych wersjach. Pokaż co masz dokładnie w ls -lR /var/lib/rpm* Nie zainstalowałeś czasem pakietu rpm z rawhide'a (f10) ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
