Błąd W Azureus!
ComboKiller
Witam! Kiedy próbuje zainstalowac azureus wyskakuje taki komunikat:
Starting Azureus...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.4.2]
Configuring environment...
Loading Azureus:
java -Xms16m -Xmx128m -cp "/home/Killer/Archiwa/azureus/Azureus2.jar:/home/Killer/Archiwa/azureus/swt.jar" -Djava.library.path="/home/Killer/Archiwa/azureus" -Dazureus.install.path="/home/Killer/Archiwa/azureus" org.gudy.azureus2.ui.swt.Main ''
java.lang.NoClassDefFoundError: org.gudy.azureus2.core3.peer.TyrantStats
  at java.lang.Class.initializeClass(libgcj.so.7rh)
  at org.gudy.azureus2.core3.util.Constants.<clinit>(Constants.java:68)
  at org.gudy.azureus2.core3.config.COConfigurationManager.preInitialise(COConfigurationManager.java:88)
  at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:50)
  at org.gudy.azureus2.ui.swt.Main.main(Main.java:162)
Caused by: java.lang.VerifyError: verification failed at PC 16 in org.gudy.azureus2.core3.peer.TyrantStats:fileLog((J)V): incompatible type on stack
  ...5 more
java.lang.NoClassDefFoundError: org.gudy.azureus2.core3.util.Constants
  at org.gudy.azureus2.core3.util.SystemProperties.getUserPath(SystemProperties.java:166)
  at org.gudy.azureus2.core3.util.FileUtil.readResilientConfigFile(FileUtil.java:440)
  at org.gudy.azureus2.core3.config.impl.ConfigurationManager.load(ConfigurationManager.java:145)
  at org.gudy.azureus2.core3.config.impl.ConfigurationManager.load(ConfigurationManager.java:193)
  at org.gudy.azureus2.core3.config.impl.ConfigurationManager.getInstance(ConfigurationManager.java:69)
  at org.gudy.azureus2.core3.logging.impl.LoggerImpl.init(LoggerImpl.java:90)
  at org.gudy.azureus2.core3.logging.Logger.<clinit>(Logger.java:48)
  at org.gudy.azureus2.ui.swt.StartServer.<init>(StartServer.java:70)
  at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:56)
DEBUG::Sat Mar 03 20:08:16 GMT+01:00 2007::java.lang.Class::initializeClass::-1:
 Error initializing Logger
StartServer::<init>::70,Main::<init>::56,Main::main::162
Exception in thread "main" java.lang.NoClassDefFoundError: org.gudy.azureus2.core3.util.Constants
  at org.gudy.azureus2.core3.config.impl.ConfigurationManager.getInstance(ConfigurationManager.java:79)
  at org.gudy.azureus2.core3.config.COConfigurationManager.initialise(COConfigurationManager.java:105)
  at com.aelitis.azureus.core.impl.AzureusCoreImpl.<init>(AzureusCoreImpl.java:143)
  at com.aelitis.azureus.core.impl.AzureusCoreImpl.create(AzureusCoreImpl.java:92)
  at com.aelitis.azureus.core.AzureusCoreFactory.create(AzureusCoreFactory.java:46)
  at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:143)
Azureus TERMINATED.
[root@localhost ~]# mcStarting Azureus...
Loading Azureus:
  ...5 more
Azureus TERMINATED.
-bash: mc: command not found
[root@localhost ~]# sh /home/Killer/Archiwa/azureus/azureus
Starting Azureus...
Loading Azureus:
  ...5 more
DEBUG::Sat Mar 03 20:44:08 GMT+01:00 2007::java.lang.Class::initializeClass::-1:
Azureus TERMINATED.
Starting Azureus...
Loading Azureus:
  ...5 more
Azureus TERMINATED.
Witam! Kiedy próbuję zainstalować azureus wyskakuje taki komunikat:
Off Topic Na przyszłość, przy długich listingach korzystaj ze znacznika 'codebox' zamiast 'code'
A co do Azora: nie myślałeś o zmianie na jakiegoś innego klienta? Mnie wkurzyły ciągłe boje z tym programem. Zainstalowałem Ktorrent i jestem zadowolony - wreszcie spokój, wszystko idzie równo, jakby szybciej niż w Azureusie również. Oczywiście Azureus jest chyba najbardziej wypasionym klientem bittorrenta pod linuksa. Nie wiem czego po nim oczekujesz, ale jeśli tylko ściągasz pliki, to wspomniany Ktorrent jest godny polecenia.
Używałem Azureusa ponad rok, ale odkąd w Ktorrent jest wtyczka UPnP przesiadłem się na tego klienta. Jego plusy jak dla mnie w porównaniu z Azureusem to mniejsze zużycie pamięci - ok 40 Mb (wiadomo jak po kilkunastu godzinach java potrafi się rozbujać), możliwość otworzenia dodatkowego portu dla DHT, oraz PeerGuardian - filtrujący "niepożądane" IP. Generalnie wydaje mi się że ściąga się trochę szybciej. Minusy natomiast to brak możliwości ustawienia limitu wysyłania dla pojedynczego torrenta, oraz Ktorrent potrafi trochę przymulić jak ściąga się coś, gdzie jest koło tysiąca peerów (wiadomo nie jest to często).
Odnośnie Azureusa natomiast - zakładam że ściągnąłeś go ze strony, a nie instalowałeś yumem. Jak tak to z tąd możesz ściągnąć Sun jave. Jest to plik bin więc dajesz najpierw jako root
chmod a+x jre-1_5_0_11-linux-i586-rpm.bin
a potem też jako root
./jre-1_5_0_11-linux-i586-rpm.bin
Sun Jave masz zainstalowaną w katalogu /usr/java/jre1.5.0_11/bin.
Teraz przechodzisz do katalogu gdzie rozpakowałeś Azureusa i edytujesz skrypt azureus.Tam na samej górze masz opcje gdzie program ma szukać javy.Wpisujesz
JAVA_PROGRAM_DIR="/usr/java/jre1.5.0_11/bin/"
PROGRAM_DIR="TWOJA ścieżka do programu"
Powinno teraz być wszystko OK. Jak dla mnie problemem jest to że java dostarczana przez Fedorę to 1.4 a od ładnego czasu jest już 1.5.
Myślę, że każdy program sieci Torrent jest szybki. I zawsze można przyszpieszyć transfer przez ratio :) Ja np. nie widzę już różnicy pomiędzy ściąganiem z *Mule i Torrentem, ponieważ mam bardzo duże już ratio na Mułkach :) Jeśli chodzi o twój problem w Azureusie musisz zapewne zainstalować poprawnie i w pełni javę. Musi być jre* i jdk. -devele też by się przydały, kombinuj. Jeśli chcesz KTorrent możesz używać, ale nie zapewniam dobrych transferów. Kiedyś próbowałem i nie chciał ruszyć nawet z plikiem, który miał dosyć dużo seedów. Pod Linuksa najlepszy jest Azureus i bez wątpienia BitTorrent :)
A czy Ktorrent w najnowszej wersji ma już wtyczkę UpNp czy trzeba doinstalować? I skąd można ją pobrać?
Ktorrent ma tą wtyczkę wbudowaną, ewentualnie nie jest ona wczytana przez program. Wchodzisz w Ustawienia-->Konfiguracja Ktorrent i opcje wtyczki, zaznaczasz upnpplugin i dajesz wczytaj. Porty ustawiasz w zakładce Pobierane
@ComboKiller - czytaj ze zrozumieniem ;)
[...]ale odkąd w Ktorrent jest wtyczka UPnP[...]
Wypróbuję Ktorrent ale powiedz, czy transfer jest szybszy?
[...] jakby szybciej niż w Azureusie również.[...]
  • 2 weeks later...
Mały OT: Dla Gnomowców polecam Deluge, nie żre tyle zasobów co Azureus i jest przyjemniejszy dla oka od BitTorrenta, do tego ładuje się do "obszaru powiadamiani". Oczywiście dostępny w repo.
Ładny, szybki, ale zrezygnowałem na korzyść Ktorrenta. Deluge nie ma niestety wtyczki typu SavePeer czy innej ochrony przed śmieciami z netu. Chyba, że się mylę, ale jakoś nie znalazłem takiej opcji.
Trochę stara ta java. Zainstaluj sobie jre-6-linux-i586-rpm.bin, potem Azureus_2.5.0.4_linux.tar.bz2 i nie powinno być problemów. U mnie tak chodzi juz kilka miesięcy i ani razu się nie wyłączył. Wcześniej miałem podobne problemy z azureusem instalowanym przez yuma.
