Yum Update, Brakujące Paczki Z Zależności
matlas
cos od wczoraj nie moge robic update yumem, a wyglada to tak:
[root@localhost ~]# yum update
Loading "installonlyn" plugin
Setting up Update Process
Setting up repositories
core					  100% |=========================| 1.1 kB	00:00
livna					 100% |=========================| 1.1 kB	00:00
flash					 100% |=========================|  951 B	00:00
jpackage-fedora		   100% |=========================|  951 B	00:00
updates				   100% |=========================| 1.2 kB	00:00
jpackage-generic		  100% |=========================|  951 B	00:00
extras					100% |=========================| 1.1 kB	00:00
primary.xml.gz			100% |=========================| 404 kB	00:03
jpackage-g: ################################################## 1596/1596
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package lucene.noarch 0:1.4.3-2jpp set to be updated
---> Package geronimo-specs.noarch 0:1.0-0.M2.3jpp set to be updated
---> Package subversion.i386 0:1.4.3-2.fc6 set to be updated
---> Package axis.noarch 0:1.4-2jpp set to be updated
---> Package jakarta-oro.i386 0:2.0.8-3jpp.1 set to be updated
---> Package lftp.i386 0:3.5.9-0.fc6 set to be updated
---> Package iputils.i386 0:20070202-3.fc6 set to be updated
---> Package tar.i386 2:1.15.1-25.fc6 set to be updated
--> Running transaction check
--> Processing Dependency: geronimo-specs = 1.0-0.M2.2jpp.12 for package: geronimo-specs-compat
--> Processing Dependency: lucene = 0:1.4.3-1jpp.14 for package: lucene-devel
--> Processing Dependency: xmlbeans for package: geronimo-specs
--> Restarting Dependency Resolution with new changes.
---> Package xmlbeans.noarch 0:1.0.4-2jpp set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: geronimo-specs = 1.0-0.M2.2jpp.12 is needed by package geronimo-specs-compat
Error: Missing Dependency: lucene = 0:1.4.3-1jpp.14 is needed by package lucene-devel
co z tym fantem zrobic?
(Listingi do 12-15 linijek umieszczaj miedzy znacznikami [code] i [/code], dluzsze niz 15 linii pomiedzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" - WalDo)
przy wylaczonych update zrobiony!
Ale mam uwage: jesli je wylacze nie ma wtdy mozliwosci aktualizacji paczek javowych, wiec to nie jest rozwiazanie? czy sie myle?
opiekunowie paczek na repozytorium z Jpaczkami javovymi najwyraźniej nie nadążyli z przebudowaniem / aktualizacją swoich pakietów i są w tyle za "głównymi" repo updates / extras; zapewne już to zauważyli i niedługo wszystko poprawią; za dzień-dwa włącz w yumie te repozytoria i zaktualizuj system
  • 2 weeks later...
wpisz yum clean all
yum sam nie kasuje ściągniętych pakietów, jeśli ich nie zainstaluje
nic nie pomoglo, nadal mi nie dziala
Nie wiem czy próbowałeś tego ale możesz ręcznie pobrać te paczki a potem rpm --force. Po instalacji możesz sprobować odpalić yum update. Ja miałem podobny problem z nas i jak to załatwiłem w ten sposób wszystko poszło dalej. Co prawda jest to ryzykowne bo można zamieszać w systemie ale warto sprobowac :) do odważnych świat należy ;)
Spróbuj chwilowo wyłączyć te repozytoria jpackage-* i zrób normalnie update systemu - będziemy chociaż wiedzieli czy problem jest z yumem czy coś w repo jest nie tak.
yum clean all
yum update --disablerepo=jpackage\*
