Darknek Napisano Kwiecień 16, 2007 Zgłoszenie Share Napisano Kwiecień 16, 2007 mam maly problem jak chce skasowac cd-rw to wyskakuje mi blad i takie cos: System ----------------------- K3b Version: 0.12.15 KDE Version: 3.5.5-0.2.fc5 Fedora-Core QT Version: 3.3.7 Kernel: 2.6.20-1.2312.fc5 Devices ----------------------- LITE-ON DVDRW LH-20A1H LL06 (/dev/hdc, ) at [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-RAM; DVD-R; DVD-RW; DVD-R dwuwarstwowa; DVD+R; DVD+RW; DVD+R dwuwarstwowa] [DVD-ROM; DVD-R sekwencyjna; DVD-R dwuwarstwowa sekwencyjna; DVD+R dwuwarstwowa; DVD-RAM; DVD-RW w trybie ograniczonego zastępowania; DVD-RW sekwencyjny; DVD+RW; DVD+R; DVD+R dwuwarstwowa; CD-ROM; CD-R; CD-RW] [sesja naraz (SAO); TAO; RAW; SAO/R96P; SAO/R96R; Surowe/R16; Surowe/R96P; Surowe/R96R; Ograniczone zastępowanie; Przeskok warstwy] Used versions ----------------------- cdrecord: 2.1.1a03 cdrecord command: ----------------------- /usr/bin/cdrecord -v gracetime=2 dev=/dev/hdc speed=16 -tao driveropts=burnfree -eject blank=fast -force cdrecord ----------------------- /usr/bin/cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2). /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns. /usr/bin/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler /usr/bin/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority(). /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns. scsidev: '/dev/hdc' devname: '/dev/hdc' scsibus: -2 target: -2 lun: -2 Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Error trying to open /dev/hdc exclusively ... retrying in 1 second. Cdrecord-Clone 2.01.01a03-dvd (i686-pc-linux-gnu) Copyright © 1995-2005 Jörg Schilling NOTE: This version contains the OSS DVD extensions for cdrtools and thus may have bugs related to DVD issues that are not present in the original cdrtools. Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla The original cdrtools author should not be bothered with problems in this version. TOC Type: 1 = CD-ROM /usr/bin/cdrecord: Device or resource busy. Cannot open '/dev/hdc'. Cannot open SCSI driver. /usr/bin/cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root. /usr/bin/cdrecord: For possible transport specifiers try 'cdrecord dev=help'. Co to sie kaszani :?: ------------------------ (Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" - WalDo) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Kwiecień 16, 2007 Zgłoszenie Share Napisano Kwiecień 16, 2007 Co to sie kaszani :?:Update systemu pełny? CD niezamontowany? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Darknek Napisano Kwiecień 16, 2007 Autor Zgłoszenie Share Napisano Kwiecień 16, 2007 update jasne jakisz czas temu dzialalo co znaczy cd niezamontowany? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Kwiecień 16, 2007 Zgłoszenie Share Napisano Kwiecień 16, 2007 co znaczy cd niezamontowany?Ja to robię tak: sprawdzam czy cd jest zamontowane poleceniem mount -l, jeżeli jest to odmontowuje umount /dev/<nazwa urządzenia> Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Darknek Napisano Kwiecień 16, 2007 Autor Zgłoszenie Share Napisano Kwiecień 16, 2007 Ja to robię tak: sprawdzam czy cd jest zamontowane poleceniem mount -l, jeżeli jest to odmontowuje umount /dev/<nazwa urządzenia> i co to daje ze odmontuje :?: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Kwiecień 16, 2007 Zgłoszenie Share Napisano Kwiecień 16, 2007 i co to daje ze odmontuje :?:U mnie odmontowany łatwiej się kasuje Nie prościej sprawdzić niż się pytać? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
