zmarekz Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 Witam Postępuje zgodnie zinstrukcją opisaną tutaj Niestety ale po wyborze pakietów wyświetla mi cos takiego: Loading "installonlyn" plugin Setting up Yum Shell > Setting up Remove Process No Match for argument: totem > Setting up Install Process Parsing package install arguments > --> Running transaction check ---> Package libdvdcss.i386 0:1.2.9-4.lvn6 set to be updated ---> Package totem-xine.i386 0:2.18.0-1.lvn7 set to be updated ---> Package totem-plparser.i386 0:2.18.1-3.fc7 set to be erased ---> Package totem-xine-plparser.i386 0:2.18.0-1.lvn7 set to be updated ---> Package mplayer-gui.i386 0:1.0-0.75.20070513svn.lvn7 set to be updated ---> Package xine-lib-extras-nonfree.i386 0:1.1.6-1.lvn7 set to be updated --> Processing Dependency: libvcdinfo.so.0 for package: xine-lib-extras-nonfree --> Processing Dependency: libdts.so.0 for package: xine-lib-extras-nonfree --> Processing Dependency: libvcdinfo.so.0(VCDINFO_0) for package: xine-lib-extras-nonfree --> Processing Dependency: libavutil.so.49 for package: xine-lib-extras-nonfree --> Processing Dependency: libdts.so.0 for package: mplayer-gui --> Processing Dependency: libavcodec.so.51 for package: xine-lib-extras-nonfree --> Processing Dependency: vcdimager >= 0.7.23 for package: xine-lib-extras-nonfree --> Processing Dependency: libpostproc.so.51 for package: xine-lib-extras-nonfree --> Processing Dependency: mplayer = 1.0-0.75.20070513svn.lvn7 for package: mplayer-gui --> Restarting Dependency Resolution with new changes. --> Running transaction check ---> Package mplayer.i386 0:1.0-0.75.20070513svn.lvn7 set to be updated ---> Package ffmpeg.i386 0:0.4.9-0.8.20070530.fc7 set to be updated ---> Package ffmpeg-libs.i386 0:0.4.9-0.37.20070503.lvn7 set to be updated ---> Package vcdimager.i386 0:0.7.23-5.fc7 set to be updated --> Processing Dependency: libfaad.so.0 for package: ffmpeg --> Processing Dependency: faad2 < 2.5 for package: ffmpeg-libs --> Processing Dependency: libdts.so.0 for package: mplayer --> Processing Dependency: libx264.so.54 for package: ffmpeg-libs --> Processing Dependency: libdts.so.0 for package: ffmpeg-libs --> Processing Dependency: libfaad.so.0 for package: ffmpeg-libs --> Restarting Dependency Resolution with new changes. --> Running transaction check ---> Package faad2.i386 0:2.5-2.fc7 set to be updated ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: libdvdcss i386 1.2.9-4.lvn6 livna 31 k mplayer-gui i386 1.0-0.75.20070513svn.lvn7 livna 3.6 M totem-xine i386 2.18.0-1.lvn7 livna 2.1 M totem-xine-plparser i386 2.18.0-1.lvn7 livna 36 k xine-lib-extras-nonfree i386 1.1.6-1.lvn7 livna 531 k Removing: totem-plparser i386 2.18.1-3.fc7 installed 60 k Installing for dependencies: faad2 i386 2.5-2.fc7 freshrpms 194 k ffmpeg i386 0.4.9-0.8.20070530.fc7 freshrpms 2.0 M ffmpeg-libs i386 0.4.9-0.37.20070503.lvn7 livna 1.6 M mplayer i386 1.0-0.75.20070513svn.lvn7 livna 4.2 M vcdimager i386 0.7.23-5.fc7 freshrpms 642 k Transaction Summary ============================================================================= Install 10 Package(s) Update 0 Package(s) Remove 1 Package(s) Total download size: 15 M Downloading Packages: Running Transaction Test Finished Transaction Test Error: Transaction Check Error: file /usr/lib/libavcodec.so.51.40.4 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/libavformat.so.51.12.1 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/libavutil.so.49.4.0 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/drawtext.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/fish.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/imlib2.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/null.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/ppm.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 file /usr/lib/vhook/watermark.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.37.20070503.lvn7 and ffmpeg-0.4.9-0.8.20070530.fc7 Error Summary ------------- > Leaving Shell W czym jest problem. Próbowałem juz wielokrotnie zainstalować Mplaera pod Fedorą 7. Ale jakoś bezskutecznie. Pod 6 poszło mi to o wiele sprawniej, Pozdrawiam i dziękuje za okazaną pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adios Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 Nie instalowałeś paczek z jakiś atrpms czy freshrpms ? Te repo tak mieszają w systemie, że czasem ciężko system uratować. Daj w konsoli: su -c "rpm -qa| grep ffmpeg" i wrzuć na forum wynik polecenia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
da_niel Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 A jakich repozytoriow uzywasz? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 Przecież w listingu widać że używa livny i freshrpms. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 Nie instalowales paczek z jakis atrpms czy freshrpms ? Te repo tak mieszaja w systemie, ze czasem ciezko system uratowac. Z "loga" wynika, ze ma wlaczone repo freshrpms i czesc yum chce stamtad doinstalowac (zamiast zaktualizowac/doinstalowac z livny). EDIT: Ponury mnie wyprzedzil Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zmarekz Napisano Czerwiec 10, 2007 Autor Zgłoszenie Share Napisano Czerwiec 10, 2007 Witam cóż polecenie su -c "rpm -qa| grep ffmpeg" nie wyświetla nic. Tj, prosi o podanie hasła kiedy je podam nic sie nie dzieje. A używam 1. updates 2. freshrpms - własnie wyłączam 3. livna 4. macromedia. Spróbuje jeszcze raz po wyłączeniu 2 zainstalować jesli sie nie uda to sie odezwę. Repozytorium próbuje wyłączyć w yumex-ie - czy są jakies ine sposoby na to ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 Witam cóż polecenie su -c "rpm -qa| grep ffmpeg" nie wyświetla nic. Tj, prosi o podanie hasła kiedy je podam nic sie nie dzieje. Musisz trochę odczekać (w zależności od ilości zainstalowanych pakietów trochę to może potrwać). Co do repozytoriów to jeżeli musisz czasem korzystać z freshrpms to najlepiej wyedytować plik w /etc/yum.reps.d/ i zmienić w freshrpms enabled=1 na enabled=0 i w razie konieczności używać yuma z argumentem --enablerepo=freshrpms Jeżeli nie musisz korzystać z tego repo to najprościej usunąć odpowiedni plik z /etc/yum.repos.d/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adios Napisano Czerwiec 10, 2007 Zgłoszenie Share Napisano Czerwiec 10, 2007 katalogu /etc/yum.repos.d masz pliki repozytoriów. Wystarczy wyedytować plik repo i z Enabled = 1 zrobić 0 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zmarekz Napisano Czerwiec 10, 2007 Autor Zgłoszenie Share Napisano Czerwiec 10, 2007 Ale mi naprawde nic nie pokazuje. Prosi o hasło które podaje a potem wraca z powrotem do "znaku zachęty". Ok wywaliłem to repozytorium i już instalacja poszła. Dzieki Hm W nocy byłem szcześliwy bo sie zainstalowało. Ale się nie uruchamia. Przy próbie uruchomienia wyświetla: mplayer: error while loading shared libraries: libdts.so.0: cannot open shared object file: No such file or directory natomiast polecenie: su -c "rpm -qa| grep ffmpeg" zwraca: ffmpeg-libs-0.4.9-0.37.20070503.lvn7 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Czerwiec 11, 2007 Zgłoszenie Share Napisano Czerwiec 11, 2007 Daj w konsoli: su -c "rpm -qa| grep ffmpeg" i wrzuć na forum wynik polecenia. A po co query robić na roocie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adios Napisano Czerwiec 11, 2007 Zgłoszenie Share Napisano Czerwiec 11, 2007 Cholera przyzwyczajenia Systemu raczej nie upsuje się samym zapytaniem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zmarekz Napisano Czerwiec 12, 2007 Autor Zgłoszenie Share Napisano Czerwiec 12, 2007 A macie może jakiś pomysł co zrobić aby Mplayer działał ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adios Napisano Czerwiec 12, 2007 Zgłoszenie Share Napisano Czerwiec 12, 2007 Wywal wszystko co instalowałeś z fresh/at rpms . To one psują zależności systemowe, Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 12, 2007 Zgłoszenie Share Napisano Czerwiec 12, 2007 A macie może jakiś pomysł co zrobić aby Mplayer działał ?Wg mnie wystarczy, żebyś teraz wyłączył repo freshrpms zostawiając tylko standardowe repo Fedory + Livna. ffmpeg raczej nie masz zainstalowanego, więc nic dziwnego, że rpm -qa ... nic Ci nie pokazuje. Należy się tylko z tego cieszyć, bo była próba instalki z freshrpms. Żeby mieć całkowitą pewność zrób jeszcze jako rootrpm -e ffmpeg faad2 vcdimager bo te pakiety chciały wejść z freshrpms. Prawdopodobnie dostaniesz komunikat, że nie są zainstalowane, a jeśli są to powinny sie odinstalować (mam nadzieję, że nie mają jakichś rozbudowanych zależności ) No i teraz od nowa, na czysto, tylko z repozytoriami Fedory i Livna, nadal jako root yum install mplayer czy jak to tam poprzednio instalowałeś. Konflikty, które się wcześniej pojawiały wynikały prawdopodobnie z tego, że ffmpeg miał być instalowany z freshrpms a ffmpeg-libs z livny, a te dwie biblioteki nie są wzajemnie kompatybilne. Jeśli tylko jedna z nich jest aktywna, to takich problemów nie ma (no, powiedzmy, że nie powinno być ) [EDIT]"dwie biblioteki nie są wzajemnie kompatybilne" - miało być oczywiście "dwa repozytoria". Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zmarekz Napisano Czerwiec 12, 2007 Autor Zgłoszenie Share Napisano Czerwiec 12, 2007 Ok już niewiele z tego rozumie rpm -qa| grep ffmpeg zwraca ffmpeg-libs-0.4.9-0.37.20070503.lvn7 ale juz rpm -e ffmpeg faad2 vcdimager zwraca błąd: pakiet ffmpeg nie jest zainstalowany freshrpms - wyłączyłem Jak daje yum install mplayer otrzymuje: Loading "installonlyn" plugin Setting up Install Process Parsing package install arguments Nothing to do A przy próbie uruchomienia Mplayera wywala błąd opisany powyżej. mplayer: error while loading shared libraries: libdts.so.0: cannot open shared object file: No such file or directory Próbuje go uruchomić bo w Aplikacje - Dzwięk i obraz widnieje jego ikonka. Pozdrawiam i prosze o poradę co jeszcze może byc nie tak. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
