Ati Radeon X1300 Instalacja Sterowników - Konflikt Z X11
zbyszekduzy
Witam ; FC6
próbowałem zainstalować sterowniki ze strony ATI . ściągnął plik ati-driver-installer-8-01-x86.x86_64.run ale [root@localhost Desktop]# chmod a+x ati-driver-installer-8-01-x86.x86_64.run
nic nie daje podobnie jaksu -
(hasło roota)
yum -y install kmod-fglrx
* w trybie graficznym uruchamiamy ściągnięty plik poleceniem:
$sh ati-driver-installer-[numer_wersji].run
próba podjęta po deinstalacji sterownika wygląda tak:
su -
(hasło roota)
i kończy się konfliktem:
--> Running transaction check
--> Processing Conflict: ATI-fglrx conflicts xorg-x11-drv-fglrx
--> Processing Conflict: ATI-fglrx conflicts kmod-fglrx
--> Processing Conflict: xorg-x11-drv-fglrx conflicts ATI-fglrx
--> Finished Dependency Resolution
Error: ATI-fglrx conflicts with xorg-x11-drv-fglrx
Error: ATI-fglrx conflicts with kmod-fglrx
Error: xorg-x11-drv-fglrx conflicts with ATI-fglrx
zbyszek duzy
yum install --disablerepo=freshrpms kmod-fglrx
[root@localhost Desktop]# yum install --disablerepo=freshrpms kmod-fglrx
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
core                      100% |=========================| 1.1 kB    00:00
livna                     100% |=========================| 2.1 kB    00:00
flash                     100% |=========================| 1.9 kB    00:00
adobe-linux-i386          100% |=========================|  951 B    00:00
jpackage-fedora           100% |=========================|  951 B    00:00
updates                   100% |=========================| 1.2 kB    00:00
jpackage-generic          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package kmod-fglrx.i686 0:8.39.4-2.2.6.22.14_72.fc6 set to be installed
--> Processing Dependency: kernel-i686 = 2.6.22.14-72.fc6 for package: kmod-fglrx
--> Processing Dependency: fglrx-kmod-common >= 8.39.4 for package: kmod-fglrx
--> Restarting Dependency Resolution with new changes.
---> Package xorg-x11-drv-fglrx.i386 0:8.39.4-2.lvn6 set to be updated
---> Package kernel.i686 0:2.6.22.14-72.fc6 set to be installed
--> Processing Dependency: livna-config-display for package: xorg-x11-drv-fglrx
---> Package livna-config-display.noarch 0:0.0.17-1.lvn6 set to be updated
--> Processing Dependency: system-config-display for package: livna-config-display
---> Package system-config-display.noarch 0:1.0.45-1 set to be updated
--> Processing Dependency: rhpxl >= 0.34-1 for package: system-config-display
--> Processing Dependency: /usr/bin/Xorg for package: system-config-display
---> Package rhpxl.i386 0:0.39-2 set to be updated
---> Package xorg-x11-server-Xorg.i386 0:1.1.1-47.10.fc6 set to be updated
--> Processing Dependency: xorg-x11-drv-void for package: xorg-x11-server-Xorg
--> Processing Dependency: xorg-x11-drv-mouse for package: xorg-x11-server-Xorg
--> Processing Dependency: xorg-x11-drv-keyboard for package: xorg-x11-server-Xorg
--> Processing Dependency: xorg-x11-drv-vesa for package: xorg-x11-server-Xorg
--> Processing Dependency: xorg-x11-drv-evdev for package: xorg-x11-server-Xorg
---> Package xorg-x11-drv-void.i386 0:1.1.0-3.1 set to be updated
---> Package xorg-x11-drv-evdev.i386 0:1.1.2-2.1 set to be updated
---> Package xorg-x11-drv-mouse.i386 0:1.2.1-1.fc6 set to be updated
---> Package xorg-x11-drv-keyboard.i386 0:1.1.0-2.1 set to be updated
---> Package xorg-x11-drv-vesa.i386 0:1.2.1-4 set to be updated
---> Package kernel.i686 0:2.6.20-1.2944.fc6 set to be erased
próbowałem jeszcze inaczej: tworzenie rpm z ati:
[root@localhost Desktop]# sh ati-driver-installer-8-01-x86.x86_64.run --buildpkg Fedora/FC6
Created directory fglrx-install.b11488
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.452.1.........................................................................
ATI Technologies Linux Driver Installer/Packager
Generating package: Fedora/FC6
Package build failed!
Package build utility output:
Building target platforms: i386
Building for target i386
Executing(%prep): /bin/sh -e /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/rpm-tmp.47821
+ umask 022
+ cd /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD
+ LANG=C
+ export LANG
+ unset DISPLAY
+ cd ATI-fglrx-8.452.1
++ /usr/bin/id -u
+ '[' 0 = 0 ']'
+ /bin/chown -Rhf root .
++ /usr/bin/id -u
+ '[' 0 = 0 ']'
+ /bin/chgrp -Rhf root .
+ /bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
Executing(%build): /bin/sh -e /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/rpm-tmp.47821
+ umask 022
+ LANG=C
+ export LANG
+ unset DISPLAY
+ exit 0
Executing(%install): /bin/sh -e /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/rpm-tmp.47821
+ umask 022
+ LANG=C
+ export LANG
+ unset DISPLAY
+ rm -rf /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root
+ '[' -d /etc/ld.so.conf.d ']'
+ mkdir -p /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/etc/ld.so.conf.d
+ pushd /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/etc/ld.so.conf.d
/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/etc/ld.so.conf.d /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1
+ cat
+ popd
+ mkdir -p /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/usr/share/applications
+ pushd /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/usr/share/applications
/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/usr/share/applications /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1
+ cat
+ popd
+ cp -pR /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1/etc /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1/lib /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1/usr /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root
+ find /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/usr/share/doc -type f -perm 0555 -exec chmod 0644 '{}' ';'
+ find /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root -type f -perm 0555 -exec chmod 0755 '{}' ';'
+ export AS_USER=y
+ AS_USER=y
+ pushd /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod
/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod /tmp/ATI-fglrx-8.452.1-1-11566-root/BUILD/ATI-fglrx-8.452.1
+ bash make.sh verbose
ATI module generator V 2.0
initializing...
OsRelease=2.6.22.9-61.fc6
major=2
minor=6
patch=22
extra=.9-61.fc6
SMP=1
smp=-SMP
iii=
AGP=1
CC=gcc
cc_version=
cleaning...
patching 'highmem.h'...
assuming new VMA API since we do have kernel 2.6.x...
Assuming default VMAP API
Assuming default munmap API
doing Makefile based build for kernel 2.6.x and higher
make -C /lib/modules/2.6.22.9-61.fc6/build SUBDIRS=/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/kernels/2.6.22.9-61.fc6-i686'
 CC [M]  /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function '__ke_request_irq':
/tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2945: warning: 'deprecated_irq_flag' is deprecated (declared at include/linux/interrupt.h:66)
 LD [M]  /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/fglrx.o
 Building modules, stage 2.
 MODPOST 1 modules
 CC      /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/fglrx.mod.o
 LD [M]  /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx/build_mod/2.6.x/fglrx.ko
make[1]: Leaving directory `/usr/src/kernels/2.6.22.9-61.fc6-i686'
build succeeded with return value 0
duplicating results into driver repository...
done.
You must change your working directory to /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx
and then call ./make_install.sh in order to install the built module.
+ mkdir -p /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/2.6.22.9-61.fc6/extra
+ install -D -m 0644 fglrx.ko /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/2.6.22.9-61.fc6/extra/fglrx/fglrx.ko
+ rm -rf /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root/lib/modules/fglrx
+ popd
+ /usr/lib/rpm/redhat/brp-compress
+ /usr/lib/rpm/redhat/brp-strip /usr/bin/strip
+ /usr/lib/rpm/redhat/brp-strip-static-archive /usr/bin/strip
+ /usr/lib/rpm/redhat/brp-strip-comment-note /usr/bin/strip /usr/bin/objdump
+ /usr/lib/rpm/brp-python-bytecompile
+ /usr/lib/rpm/redhat/brp-java-repack-jars
Processing files: ATI-fglrx-8.452.1-1.fc6
Provides: config(ATI-fglrx) = 8.452.1-1.fc6 fglrx_dri.so fglrx_drv.so glesx.so libGL.so.1 libfglrx_dm.so.1.0 libfglrx_gamma.so.1 libfglrx_pp.so.1.0 libfglrx_tvout.so.1 libfglrxdrm.so
Requires(interp): /bin/sh /bin/sh /bin/sh
Requires(rpmlib): rpmlib(CompressedFileNames) <= 3.0.4-1 rpmlib(PayloadFilesHavePrefix) <= 4.0-1
Requires(post): /bin/sh /sbin/chkconfig /sbin/ldconfig
Requires(preun): /bin/sh /sbin/chkconfig /sbin/service
Requires(postun): /bin/sh /sbin/ldconfig /sbin/service
Requires: /bin/bash /bin/sh config(ATI-fglrx) = 8.452.1-1.fc6 kernel-module-ATI-fglrx-2.6.22.9-61.fc6 = 8.452.1-1.fc6 libGL.so.1 libX11.so.6 libXext.so.6 libXrandr.so.2 libXrender.so.1 libc.so.6 libc.so.6(GLIBC_2.0) libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3) libc.so.6(GLIBC_2.2) libc.so.6(GLIBC_2.2.3) libdl.so.2 libdl.so.2(GLIBC_2.0) libdl.so.2(GLIBC_2.1) libfglrx_dm.so.1.0 libfglrx_gamma.so.1 libfglrx_pp.so.1.0 libfglrx_tvout.so.1 libgcc_s.so.1 libgcc_s.so.1(GCC_3.0) libm.so.6 libm.so.6(GLIBC_2.0) libpthread.so.0 libpthread.so.0(GLIBC_2.0) libpthread.so.0(GLIBC_2.1) libpthread.so.0(GLIBC_2.2) librt.so.1 librt.so.1(GLIBC_2.2) system-config-display
Conflicts: fglrx fglrx-glc22 fglrx_4_3_0 fglrx_6_8_0 kernel-module-fglrx ati-fglrx ati-fglrx-devel kmod-fglrx xorg-x11-drv-fglrx xorg-x11-drv-fglrx-devel nvidia-glx nvidia-glx-legacy xorg-x11-drv-nvidia xorg-x11-drv-nvidia-legacy
Processing files: ATI-fglrx-control-center-8.452.1-1.fc6
Requires: ATI-fglrx = 8.452.1-1.fc6 libGL.so.1 libICE.so.6 libSM.so.6 libX11.so.6 libXcursor.so.1 libXext.so.6 libXi.so.6 libXrandr.so.2 libXrender.so.1 libc.so.6 libc.so.6(GLIBC_2.0) libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3) libc.so.6(GLIBC_2.2) libc.so.6(GLIBC_2.2.4) libdl.so.2 libdl.so.2(GLIBC_2.0) libdl.so.2(GLIBC_2.1) libfontconfig.so.1 libfreetype.so.6 libm.so.6 libm.so.6(GLIBC_2.0) libm.so.6(GLIBC_2.1) libm.so.6(GLIBC_2.2) libpthread.so.0 libpthread.so.0(GLIBC_2.0) libpthread.so.0(GLIBC_2.1) libpthread.so.0(GLIBC_2.2)
Processing files: ATI-fglrx-devel-8.452.1-1.fc6
Requires: /usr/include/GL ATI-fglrx = 8.452.1-1.fc6 libGL.so.1
Processing files: kernel-module-ATI-fglrx-2.6.22.9-61.fc6-8.452.1-1.fc6
Checking for unpackaged file(s): /usr/lib/rpm/check-files /tmp/ATI-fglrx-8.452.1-1-11566-root/tmp/ATI-fglrx-8.452.1-1.fc6-root-root
error: Installed (but unpackaged) file(s) found:
  /usr/sbin/amdnotifyui
RPM build errors:
Removing temporary directory: fglrx-install.b11488
To i tutaj dorzucę info od ecik__a o wtyczce yum-priorities oraz przy oakzji o moim odkryciu wtyczki yum-fedorakmod :) Warto spróbować.
dociągnąłem obie propozycje dałem ponownie yum -y install kmod-fglrx
i znów
Zaraz zaraz, to mi wygląda na to, że masz już w systemie stery ATI i to te najgorsze, dostarczane z oficjalnej strony. Sprawdź, czy faktycznie tak jest (jeśli nie masz świadomości tego, że je zainstalowałeś).
Niestety nie mam już X ;(.
GDM: X server not found: /usr/bin/X0rg: o -br -audit0 -auth /var/gdm/ :0.
Error: command could not executeed !
Please install the X server or correct GDM configuration znd restart GDM
Nie umiem :lammer:
Może zainstaluj sobie FC8 i poćwicz od zera ;)
Narazie zostanę na FC6. W trybie rescue doinstalowałem yumem xorg-x11-server* i mam okienka :D
filmy w mplayerze mi chodzą,
sprawdzilem jakie stery mam w systemie
[root@localhost ~]# glxinfo
name of display: :0.0
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
   GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
   GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
   GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
   GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
   GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
   GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
   GLX_ARB_multisample
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.5.1)
OpenGL extensions:
   GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
   GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
   GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
   GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
   GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
   GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
   GL_EXT_texture_lod_bias
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x22 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x23 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x24 24 tc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x3d 32 tc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
kombinowałem z usunięciem sterów ATI
[root@localhost ~]# yum remove ATI-fglrx
Loading "fedorakmod" plugin
Loading "priorities" plugin
Setting up Remove Process
---> Package ATI-fglrx.i386 0:8.36.5-1.fc6 set to be erased
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Removing:
ATI-fglrx               i386       8.36.5-1.fc6     installed          16 M
Transaction Summary
Install      0 Package(s)
Update       0 Package(s)
Remove       1 Package(s)
Is this ok [y/N]: y
Downloading Packages:
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
error: %preun(ATI-fglrx-8.36.5-1.fc6.i386) scriptlet failed, exit status 127
Removed: ATI-fglrx.i386 0:8.36.5-1.fc6
Complete!
proszę o sugestie zmian
Po usunięciu tych firmowych sterów ATI (o ile faktycznie nie ma ich już w systemie), odpaleniu updatedb oraz yum clean all, powinieneś nowe zainstalować bez problemu poleceniem:
niestety stery ATI nadal są
Update       0 Package(s)
Remove       1 Package(s)
Is this ok [y/N]: y
Running Transaction
Complete!
bowiem kolejne kroki wskazane do wykonania zakończyły się niepowodzeniem.
[root@localhost ~]# updatedb
[root@localhost ~]# yum clean all
Cleaning up Everything
[root@localhost ~]# yum install --disablerepo=freshrpms kmod-fglrx
primary.xml.gz            100% |=========================| 824 kB    00:14
core      : ################################################## 2242/2242
primary.xml.gz            100% |=========================|  66 kB    00:02
livna     : ################################################## 222/222
primary.xml.gz            100% |=========================| 1.4 kB    00:00
flash     : ################################################## 4/4
primary.xml.gz            100% |=========================| 1.3 kB    00:00
adobe-linu: ################################################## 2/2
primary.xml.gz            100% |=========================| 2.9 kB    00:00
jpackage-f: ################################################## 12/12
primary.xml.gz            100% |=========================| 475 kB    00:08
updates   : ################################################## 1285/1285
primary.xml.gz            100% |=========================| 520 kB    00:08
jpackage-g: ################################################## 2277/2277
primary.xml.gz            100% |=========================| 1.7 MB    00:35
extras    : ################################################## 5211/5211
0 packages excluded due to repository priority protections
---> Downloading header for kmod-fglrx to pack into transaction set.
kmod-fglrx-8.39.4-2.2.6.2 100% |=========================|  15 kB    00:01
---> Downloading header for xorg-x11-drv-fglrx to pack into transaction set.
xorg-x11-drv-fglrx-8.39.4 100% |=========================|  36 kB    00:02
---> Downloading header for kernel to pack into transaction set.
kernel-2.6.22.14-72.fc6.i 100% |=========================| 211 kB    00:04
---> Downloading header for livna-config-display to pack into transaction set.
livna-config-display-0.0. 100% |=========================|  14 kB    00:00
---> Downloading header for system-config-display to pack into transaction set.
system-config-display-1.0 100% |=========================|  28 kB    00:01
---> Downloading header for rhpxl to pack into transaction set.
rhpxl-0.39-2.i386.rpm     100% |=========================|  19 kB    00:01
a gdyby tak wyrzucić sterowniki ATI poleceniem
rpm -Va
bo jak podaje http://www.redhat.com/archives/fedora-deve...y/msg01178.html
You must
remove Nvidia's driver completely from your hard disk, and completely
reinstall all of the xorg-x11 and mesa packages, and ensure they are
all intact by using: rpm -Va
a potem kolejne ruchy z czyszczeniem yuma itd. ?
dzięki za pomoc , może komuś wpadnie jakiś pomysł ....
rpm -Va
Spróbuj i zastosuj się do wskazówek z tego linka. Na wszelki wypadek sprawdź wcześniej, czy w paczce z firmowymi sterami nie ma pliku deinstalacyjnego (lub czy nie ma o tym mowy w dołączonej dokumentacji). Samo usunięcie plików (i tak nie znalazłbyś ich wszystkich) nic nie pomoże.
Zainstalowałem FC8 ( stare sterowniki nie udało sie wywalić z FC6 i nie udało się odzyskać x-ów przez te konflikty).
Niestety mimo że nic nie instalowałem -czysta instalacja - nadal jest problem.
Zgodnie z sugestią z Fedora 8 faq próbowałem zainstalować stery .
[root@localhost ~]# yum install kmod-fglrx
125 packages excluded due to repository priority protections
---> Package kmod-fglrx.i686 0:8.452.1-2.8.01.lvn8 set to be updated
--> Processing Dependency: kmod-fglrx-2.6.23.14-115.fc8 = 8.452.1-2.8.01.lvn8 for package: kmod-fglrx
---> Package kmod-fglrx-2.6.23.14-115.fc8.i686 0:8.452.1-2.8.01.lvn8 set to be updated
--> Processing Dependency: kernel-i686 = 2.6.23.14-115.fc8 for package: kmod-fglrx-2.6.23.14-115.fc8
--> Processing Dependency: fglrx-kmod-common >= 8.452.1 for package: kmod-fglrx-2.6.23.14-115.fc8
---> Package kernel.i686 0:2.6.23.14-115.fc8 set to be updated
---> Package xorg-x11-drv-fglrx.i386 0:8.452.1-3.8.01.lvn8 set to be updated
--> Processing Dependency: libfglrx_gamma.so.1 for package: xorg-x11-drv-fglrx
--> Processing Dependency: livna-config-display >= 0.0.18 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5(GLIBCPP_3.2) for package: xorg-x11-drv-fglrx
--> Processing Dependency: /usr/lib/fglrx/libGL.so.1.2 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5 for package: xorg-x11-drv-fglrx
--> Processing Dependency: libstdc++.so.5(CXXABI_1.2) for package: xorg-x11-drv-fglrx
--> Processing Dependency: xorg-x11-drv-fglrx-libs = 8.452.1-3.8.01.lvn8 for package: xorg-x11-drv-fglrx
---> Package livna-config-display.noarch 0:0.0.20-1.lvn8 set to be updated
---> Package compat-libstdc++-33.i386 0:3.2.3-62 set to be updated
---> Package ati-x11-drv.i386 0:8.40.4-2.fc7 set to be updated
--> Processing Dependency: dkms for package: ati-x11-drv
--> Processing Dependency: gcc for package: ati-x11-drv
---> Package xorg-x11-drv-fglrx-libs.i386 0:8.452.1-3.8.01.lvn8 set to be updated
---> Package gcc.i386 0:4.1.2-33 set to be updated
--> Processing Dependency: glibc-devel >= 2.2.90-12 for package: gcc
---> Package dkms.noarch 0:2.0.17.5-1.fc8 set to be updated
--> Processing Dependency: kernel-devel for package: dkms
---> Package kernel-devel.i686 0:2.6.23.14-115.fc8 set to be updated
---> Package glibc-devel.i386 0:2.7-2 set to be updated
--> Processing Dependency: glibc-headers for package: glibc-devel
--> Processing Dependency: glibc-headers = 2.7-2 for package: glibc-devel
---> Package glibc-headers.i386 0:2.7-2 set to be updated
--> Processing Dependency: kernel-headers for package: glibc-headers
--> Processing Dependency: kernel-headers >= 2.2.1 for package: glibc-headers
---> Package kernel-headers.i386 0:2.6.23.14-115.fc8 set to be updated
--> Processing Conflict: ati-x11-drv conflicts xorg-x11-drv-fglrx
Error: ati-x11-drv conflicts with xorg-x11-drv-fglrx
Muszę się przyznać że w komputerze jest jeszcze XP w którym ta karta działa na sterach ATI, ale to chyba nie jest powodem problemu.
Z góry dzięki za sugestie.
ok sterownik zainstalowany
niestety odpalanie poleceniem wydawanym w trybie init:3
aticonfig -initial
podanym w przyklejonym wątku nie działa :angry:
error :unable to open display 0
po reboocie na zaktualizowanym do 2.6.23-14-115 jądrze na którym robiłem te operacje zobaczyłem tylko jasny ekran...
fc odpaliła na wcześniejszym kernelu - z instalacji FC8
