Fc9 Nvidia-96xx Problem Z Uruchomieniem X
Thumper
Posiadam kartę GeForce4 Titanium 4200 AGP8x i zainstalowany sysytem Fedora Core 9. Zainstalowalem testowe sterowniki 96xx pochodzące z repozytorium livna. Po z restartowaniu systemu Xy nie chca się uruchomic. Oto zawartosc loga
X.Org X Server 1.4.99.902 (1.5.0 RC 2)
Release Date: 5 September 2007
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.18-53.1.19.el5 i686
Current Operating System: Linux localhost.localdomain 2.6.25.6-55.fc9.i686 #1 SMP Tue Jun 10 16:27:49 EDT 2008 i686
Build Date: 12 June 2008  01:05:58AM
Build ID: xorg-x11-server 1.4.99.902-3.20080612.fc9
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Jun 19 18:30:41 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "<default monitor>"
(**) |   |-->Device "Videocard0"
(==) No monitor specified for screen "Screen0".
Using a default monitor configuration.
(**) |-->Input Device "Keyboard0"
(**) Option "AIGLX" "off"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
(**) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is disabled
(==) |-->Input Device "<default pointer>"
(==) The core pointer device wasn't specified explicitly in the layout.
Using the default mouse configuration.
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81f8400
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 4.0
X.Org XInput driver : 2.0
X.Org Server Extension : 1.0
X.Org Font Renderer : 0.5
(II) Loader running on linux
(--) using VT number 7
(--) PCI:*(0@1:0:0) nVidia Corporation NV28 [GeForce4 Ti 4200 AGP 8x] rev 161, Mem @ 0xe0000000/0, 0xd8000000/0, BIOS @ 0x????????/131072
(II) System resource ranges:
[0] -1	0	0xffffffff - 0xffffffff (0x1) MX[b]
[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[b]
[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[b]
[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[b]
[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
[5] -1	0	0x00000000 - 0x00000000 (0x1) IX[b]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.4.99.902, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 1.0
(II) Loading extension SELinux
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(**) AIGLX disabled
(**) Exporting typical set of GLX visuals
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.4.99.902, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
dlopen: /usr/lib/xorg/modules/drivers//nvidia_drv.so: undefined symbol: AllocateScreenPrivateIndex
(EE) Failed to load /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) UnloadModule: "nvidia"
(EE) Failed to load module "nvidia" (loader failed, 7)
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.4.99.901, module version = 1.3.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
(EE) No drivers available.
Fatal server error:
no screens found
Czym może byc spowodowane pojawianie się takiego błedu? Jak to naprawić?
  • 2 months later...
Obecne sterowniki nie wspierają nowych rozwiązań X.orga (szczególnie nowego ABI), tak więc akceleracja pojawi się nie prędko - nvidia musi po porostu wypuścić zaktualizowane sterowniki (na forum nvidii developerzy piszą, że prace trwają, ale nie wiadomo kiedy zaktualizowane sterowniki się pojawią). Ja osobiście zrobiłem downgroad X-serwera do wersji z F8 - akceleracja chodzi bezproblemowo, efekty pulpitu w KDE 4.1 też normalnie działają, compiza nie instalowałem to nie wiem, ale skoro efekty kde działają to on też powinien. Przy takim rozwiązaniu trzeba instalować sterowniki pobrane ze strony nvidii (w przeciwieństwie do forumowiczów mam o nich dobre zdanie - generalnie mam z nimi mniej problemów niż z tymi z livny, a reinstalację przy aktualizacji kernela spokojnie przeżywam).
Nie wiem co ty za bzdury piszesz jak sterowniki nvidii do nowego xorga są już od dobrych kilku miesięcy...
Od paru miesięcy są sterowniki dla najnowszych kart, bodajże 173xx, mówimy tutaj o sterownikach legacy 96xx a te nie działają. Mowa o tym między innymi w Tym temacie (4 post). Co prawda temat jest z przed paru miesięcy, ale sytuacja się nie zmieniła. Wiadomo karty wspierane przez ten sterownik są już leciwe, więc nvidia się specjalnie nie śpieszy, ale sporo osób je jeszcze posiada.
