Kompilacja Furius Iso Mount
zyguli
Zainspirowany udaną, pierwszą w życiu kompilacją, postanowiłem skompilować Furius Iso Mount. Przy 'make' pojawiły się takie błędy:
[zyguli@zyguli-fedora furiusisomount-0.9.0.1]$ make
Making all in FuriusIsoMount
make[1]: Wejście do katalogu `/home/zyguli/Pulpit/gnome-color-chooser-0.2.4/furiusisomount-0.9.0.1/FuriusIsoMount'
mkdir -p 'bin/Debug'
cp 'furiusisomount' 'bin/Debug/furiusisomount'
chmod +x 'bin/Debug/furiusisomount'
mkdir -p bin/Debug/
gmcs -noconfig -codepage:utf8 -warn:4 -optimize+ -debug -define:DEBUG -out:bin/Debug/FuriusIsoMount.exe -target:exe './gtk-gui/generated.cs' './MainWindow.cs' './gtk-gui/MainWindow.cs' './Main.cs' './AssemblyInfo.cs' './FileHash.cs' './MessageBox.cs' '
./ImageAction.cs' './Log.cs' './AboutBox.cs' './Globals.cs' './LocalizableResources.cs'  '-resource:./gtk-gui/gui.stetic' '-resource:./gpl.txt' '-resource:./furiusisomount.png' '-resource:./FuriusIsoMount.resources' '-resource:./imageBurn.png' '-resource:./imageChecksum.png'    -r:/usr/lib/mono/gtk-sharp-2.0/pango-sharp.dll    -r:/usr/lib/mono/gtk-sharp-2.0/atk-sharp.dll    -r:/usr/lib/mono/gtk-sharp-2.0/gdk-sharp.dll    -r:/usr/lib/mono/gtk-sharp-2.0/gtk-sharp.dll    -r:/usr/lib/mono/gtk-sharp-2.0/glib-sharp.dll    -r:System    -r:System.Xml
./MainWindow.cs(142,44): error CS1061: Type `Gtk.TreeView' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.TreeView' could be found (are you missing a using directive or an assembly reference?)
./MainWindow.cs(143,35): error CS1061: Type `Gtk.Button' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.Button' could be found (are you missing a using directive or an assembly reference?)
./MainWindow.cs(144,34): error CS1061: Type `Gtk.Button' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.Button' could be found (are you missing a using directive or an assembly reference?)
./MainWindow.cs(145,36): error CS1061: Type `Gtk.Button' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.Button' could be found (are you missing a using directive or an assembly reference?)
./MainWindow.cs(146,37): error CS1061: Type `Gtk.Button' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.Button' could be found (are you missing a using directive or an assembly reference?)
./MainWindow.cs(147,33): error CS1061: Type `Gtk.Button' does not contain a definition for `TooltipText' and no extension method `TooltipText' of type `Gtk.Button' could be found (are you missing a using directive or an assembly reference?)
Compilation failed: 6 error(s), 0 warnings
make[1]: *** [bin/Debug/FuriusIsoMount.exe] Błąd 1
make[1]: Opuszczenie katalogu `/home/zyguli/Pulpit/gnome-color-chooser-0.2.4/furiusisomount-0.9.0.1/FuriusIsoMount'
make: *** [all-recursive] Błąd 1
Nigdzie nic nie znalazłem na ten temat. O co tu chodzi?
Edit: Strasznie się post rozwalił. Nie mam pomysłu jak to naprawić. :/
"bin/Debug/FuriusIsoMount.exe"? .exe? To przecież coś jakby Windowsem zalatywało? Co z tym na linuksie chciałeś robić? A jeśli kompilacja pod linuksem dla Windows, to pewnie trzeba jakieś opcje podać i zaopatrzyć się w odpowiednie biblioteki. Tak w ciemno strzelam, bo na programowaniu to znam się bardzo pobieżnie :lammer:
Poza tym wypadałoby podać ścieżkę do źródeł.
Nie wiem co to za program, ale strzelam że do montowania obrazów ISO, coś jak DaemonTools.
Spróbuj tego:
mount -o loop /ścieżka/do/pliku.iso /mnt/iso
EDIT$
WadDo: Możliwe też że ten program jest napisany w Mono. Pamiętam, że kiedyś widziałem w Linuksie jakiś program GTK właśnie dla GNOME, nie wiem czy to czasem Tomboy nie był. W jego katalogu były pliki .exe i .dll ;)
http://www.marcus-furius.com/?page_id=14
a to exe rzeczywiście dziwne, nie zauważyłem tego wcześniej.
Komendę montowania iso znam, ale to upierdliwe, w dodatku działa tylko z iso, a ten program jeszcze z innymi formatami. Wyhaczyłem go na gnomefiles.org, więc to nie jest jakiś kosmos.
Na pewno jest pisany w mono, i na pewno jest pod linuksa :)
Wygląda na to, że to jest jakiś błąd w źródłach gdyż jak podaje dokumentacja mono Gtk.Button rzeczywiście nie zawiera właściwości TooltipText. Znalazłem przy okazji poradnik o tym jak dodawać tooltipy do widgetów. Można by więc nałożyć patch na źródła.
Jakim cudem więc kod kompiluje się u autora? Być może po prostu posiada jakąś bibliotekę w starszej lub zupełnie nowej wersji, w której taka właściwość występuje. (to tylko moje domniemania, bo tak naprawdę moja wiedza o mono jest całkiem znikoma :])
