adam_993 Napisano Sierpień 13, 2009 Zgłoszenie Share Napisano Sierpień 13, 2009 (edytowane) Zaktualizowałem system, wziąłem się za sterowniki własnościwe do karty GeForce MX400. Tak więc pobrałem z repozytoriów serię 96. Zainstalowałem. Restart. Nie mam 3d, w xorg.conf widnieje sterownik nv. Poprawiam na nvidia ale po restacje (oczywicie zapisuję) nadal jest nv. Dodałem nopat, ale to nic nie dało. # Xorg configuration created by livna-config-display Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules" FontPath "catalogue:/etc/X11/fontpath.d" FontPath "built-ins" EndSection Section "Module" Load "record" Load "dri2" Load "glx" Load "dbe" Load "extmod" EndSection Section "ServerFlags" Option "AIGLX" "on" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5 6 7" EndSection Section "Monitor" #DisplaySize 340 270 # mm Identifier "Monitor0" VendorName "DEL" ModelName "DELL E177FP" HorizSync 31.0 - 80.0 VertRefresh 56.0 - 75.0 Option "DPMS" EndSection Section "Device" ### Available Driver options are:- ### Values: <i>: integer, <f>: float, <bool>: "True"/"False", ### <string>: "String", <freq>: "<f> Hz/kHz/MHz" ### [arg]: arg optional #Option "SWcursor" # [<bool>] #Option "HWcursor" # [<bool>] #Option "NoAccel" # [<bool>] #Option "ShadowFB" # [<bool>] #Option "VideoKey" # <i> #Option "FlatPanel" # [<bool>] #Option "FPDither" # [<bool>] #Option "FPScale" # [<bool>] #Option "FPTweak" # <i> #Option "CBLocation" # <str> #Option "CBSize" # <i> #Option "Randr12" # [<bool>] #Option "ScalingMode" # <str> #Option "EXAPixmaps" # [<bool>] Identifier "Card0" Driver "nv" VendorName "nVidia Corporation" BoardName "NV11 [GeForce2 MX/MX 400]" BusID "PCI:1:0:0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 1 EndSubSection SubSection "Display" Viewport 0 0 Depth 4 EndSubSection SubSection "Display" Viewport 0 0 Depth 8 EndSubSection SubSection "Display" Viewport 0 0 Depth 15 EndSubSection SubSection "Display" Viewport 0 0 Depth 16 EndSubSection SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Section "Extensions" Option "Composite" "Enable" EndSection oraz 00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge (rev 80) 00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge 00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80) 00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) 00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81) 00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81) 00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81) 00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81) 00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86) 00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South] 00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60) 00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78) 01:00.0 VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX/MX 400] (rev b2) Co tu począć? W Ubuntu 9.04 działało. Jeszcze: glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose) server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe, GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer client glx vendor string: NVIDIA Corporation client glx version string: 1.4 client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync, GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float, GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap GLX version: 1.2 GLX extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_SGIX_fbconfig, GLX_ARB_get_proc_address OpenGL vendor string: Mesa Project OpenGL renderer string: Software Rasterizer OpenGL version string: 1.4 (2.1 Mesa 7.6-devel) OpenGL extensions: GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_program, GL_ARB_window_pos, GL_ATI_texture_mirror_once, GL_EXT_texture_env_add, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_vertex_array, GL_IBM_texture_mirrored_repeat, GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_texgen_reflection, GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod 64 GLX Visuals visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0xde 24 tc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xdf 24 tc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0xe0 24 tc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xe1 24 tc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0xe2 24 tc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0xe3 24 tc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0xe4 24 tc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0xe5 24 tc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0xe6 24 tc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0xe7 24 tc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0xe8 24 tc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0xe9 24 tc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0xea 24 tc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0xeb 24 tc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0xec 24 tc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0xed 24 tc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0xee 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0xef 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0xf0 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0xf1 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0xf2 24 tc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0xf3 24 tc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0xf4 24 tc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0xf5 24 tc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0xf6 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0xf7 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0xf8 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0xf9 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0xfa 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0xfb 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0xfc 24 dc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xfd 24 dc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0xfe 24 dc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xff 24 dc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0x100 24 dc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0x101 24 dc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0x102 24 dc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0x103 24 dc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0x104 24 dc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0x105 24 dc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0x106 24 dc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0x107 24 dc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0x108 24 dc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0x109 24 dc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0x10a 24 dc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0x10b 24 dc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0x10c 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0x10d 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0x10e 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0x10f 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0x110 24 dc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0x111 24 dc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0x112 24 dc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0x113 24 dc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0x114 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x115 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0x116 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x117 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0x118 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x119 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0x11a 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0x5d 32 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 128 GLXFBConfigs: visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x5e 0 tc 0 8 0 r . . 3 3 2 0 0 0 0 0 0 0 0 0 0 None 0x5f 0 tc 0 8 0 r . . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow 0x60 0 tc 0 8 0 r y . 3 3 2 0 0 0 0 0 0 0 0 0 0 None 0x61 0 tc 0 8 0 r y . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow 0x62 0 tc 0 8 0 r . . 3 3 2 0 0 0 8 0 0 0 0 0 0 None 0x63 0 tc 0 8 0 r . . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow 0x64 0 tc 0 8 0 r y . 3 3 2 0 0 0 8 0 0 0 0 0 0 None 0x65 0 tc 0 8 0 r y . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow 0x66 0 tc 0 8 0 r . . 3 3 2 0 0 8 0 0 0 0 0 0 0 None 0x67 0 tc 0 8 0 r . . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow 0x68 0 tc 0 8 0 r y . 3 3 2 0 0 8 0 0 0 0 0 0 0 None 0x69 0 tc 0 8 0 r y . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow 0x6a 0 tc 0 8 0 r . . 3 3 2 0 0 8 8 0 0 0 0 0 0 None 0x6b 0 tc 0 8 0 r . . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow 0x6c 0 tc 0 8 0 r y . 3 3 2 0 0 8 8 0 0 0 0 0 0 None 0x6d 0 tc 0 8 0 r y . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow 0x6e 0 tc 0 16 0 r . . 5 6 5 0 0 0 0 0 0 0 0 0 0 None 0x6f 0 tc 0 16 0 r . . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow 0x70 0 tc 0 16 0 r y . 5 6 5 0 0 0 0 0 0 0 0 0 0 None 0x71 0 tc 0 16 0 r y . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow 0x72 0 tc 0 16 0 r . . 5 6 5 0 0 0 8 0 0 0 0 0 0 None 0x73 0 tc 0 16 0 r . . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow 0x74 0 tc 0 16 0 r y . 5 6 5 0 0 0 8 0 0 0 0 0 0 None 0x75 0 tc 0 16 0 r y . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow 0x76 0 tc 0 16 0 r . . 5 6 5 0 0 16 0 0 0 0 0 0 0 None 0x77 0 tc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow 0x78 0 tc 0 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None 0x79 0 tc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow 0x7a 0 tc 0 16 0 r . . 5 6 5 0 0 16 8 0 0 0 0 0 0 None 0x7b 0 tc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow 0x7c 0 tc 0 16 0 r y . 5 6 5 0 0 16 8 0 0 0 0 0 0 None 0x7d 0 tc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow 0x7e 0 tc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0x7f 0 tc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0x80 0 tc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0x81 0 tc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0x82 0 tc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0x83 0 tc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0x84 0 tc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0x85 0 tc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0x86 0 tc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0x87 0 tc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0x88 0 tc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0x89 0 tc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0x8a 0 tc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0x8b 0 tc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0x8c 0 tc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0x8d 0 tc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0x8e 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0x8f 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0x90 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0x91 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0x92 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0x93 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0x94 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0x95 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0x96 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x97 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0x98 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x99 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0x9a 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x9b 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0x9c 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x9d 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0x9e 0 dc 0 8 0 r . . 3 3 2 0 0 0 0 0 0 0 0 0 0 None 0x9f 0 dc 0 8 0 r . . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow 0xa0 0 dc 0 8 0 r y . 3 3 2 0 0 0 0 0 0 0 0 0 0 None 0xa1 0 dc 0 8 0 r y . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow 0xa2 0 dc 0 8 0 r . . 3 3 2 0 0 0 8 0 0 0 0 0 0 None 0xa3 0 dc 0 8 0 r . . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow 0xa4 0 dc 0 8 0 r y . 3 3 2 0 0 0 8 0 0 0 0 0 0 None 0xa5 0 dc 0 8 0 r y . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow 0xa6 0 dc 0 8 0 r . . 3 3 2 0 0 8 0 0 0 0 0 0 0 None 0xa7 0 dc 0 8 0 r . . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow 0xa8 0 dc 0 8 0 r y . 3 3 2 0 0 8 0 0 0 0 0 0 0 None 0xa9 0 dc 0 8 0 r y . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow 0xaa 0 dc 0 8 0 r . . 3 3 2 0 0 8 8 0 0 0 0 0 0 None 0xab 0 dc 0 8 0 r . . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow 0xac 0 dc 0 8 0 r y . 3 3 2 0 0 8 8 0 0 0 0 0 0 None 0xad 0 dc 0 8 0 r y . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow 0xae 0 dc 0 16 0 r . . 5 6 5 0 0 0 0 0 0 0 0 0 0 None 0xaf 0 dc 0 16 0 r . . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow 0xb0 0 dc 0 16 0 r y . 5 6 5 0 0 0 0 0 0 0 0 0 0 None 0xb1 0 dc 0 16 0 r y . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow 0xb2 0 dc 0 16 0 r . . 5 6 5 0 0 0 8 0 0 0 0 0 0 None 0xb3 0 dc 0 16 0 r . . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow 0xb4 0 dc 0 16 0 r y . 5 6 5 0 0 0 8 0 0 0 0 0 0 None 0xb5 0 dc 0 16 0 r y . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow 0xb6 0 dc 0 16 0 r . . 5 6 5 0 0 16 0 0 0 0 0 0 0 None 0xb7 0 dc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow 0xb8 0 dc 0 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None 0xb9 0 dc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow 0xba 0 dc 0 16 0 r . . 5 6 5 0 0 16 8 0 0 0 0 0 0 None 0xbb 0 dc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow 0xbc 0 dc 0 16 0 r y . 5 6 5 0 0 16 8 0 0 0 0 0 0 None 0xbd 0 dc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow 0xbe 0 dc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xbf 0 dc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0xc0 0 dc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None 0xc1 0 dc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow 0xc2 0 dc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0xc3 0 dc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0xc4 0 dc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None 0xc5 0 dc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow 0xc6 0 dc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0xc7 0 dc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0xc8 0 dc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None 0xc9 0 dc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow 0xca 0 dc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0xcb 0 dc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0xcc 0 dc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None 0xcd 0 dc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow 0xce 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0xcf 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0xd0 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None 0xd1 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow 0xd2 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0xd3 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0xd4 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None 0xd5 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow 0xd6 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0xd7 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0xd8 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0xd9 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow 0xda 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0xdb 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow 0xdc 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0xdd 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow Zakazałem livna-config edytowanie plików. Wyedytowałem xorg.conf, po restacie iksy nie wstają. Szybka edycja w nano. Wygląda na to, że nie może wczytać modułu sterownika. -------------------------- Korzystaj ze znaczników [codebox][/codebox] zamiast [code][/code], gdy wklejasz listingi dłuższe niż 15 linii Edytowane Sierpień 13, 2009 przez WalDo Zmiana znaczników [code] → [codebox] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Sierpień 13, 2009 Zgłoszenie Share Napisano Sierpień 13, 2009 Spróbowałbym tak: 1. Dać init 3 zmienić driver na nvidia i dać startx. Możesz jeszcze dodać do sekcji Files ModulePath "/usr/lib/xorg/modules/drivers" Jak X nie wystartuje to może jakieś info będzie w /var/log/Xorg.0.log 2. Być może trzeba będzie dodać do blacklisty nouveau - jak to zrobić opisane jest tu. 3. Możesz też wywalić kmoda i zainstalować sterowniki binarne ze strony nvidii (nie zalecane na forum). Najnowsza wersja pe-release to 96.43.13 do pobrania tu. Sam mam zastosowaną opcję 3, ale trzeba trochę czasu poświęcać przy aktualizacji jądra. Z nouveau nic nie robiłem, ale problem jest chyba losowy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 14, 2009 Autor Zgłoszenie Share Napisano Sierpień 14, 2009 Męczyłem się i wyszło na to, że brakuje pakietów do jądra. Nie pamiętam jakich, ale sources i chyba nagłówkowych. Spróbuję zainstalować. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Sierpień 14, 2009 Zgłoszenie Share Napisano Sierpień 14, 2009 W logu xorga nie ma nic ciekawego? Jeśli chcesz instalować binarne sterowniki nvidii to potrzebujesz kernel-headers kernel-devel /Edycja. Nie wiem czy Ci się do czegoś przyda, ale mój xorg.conf wygląda tak: # nvidia-xconfig: version 1.0 (buildmeister@builder63) Thu Jun 25 18:57:07 PDT 2009 #Section "ServerFlags" # Option "AIGLX" "off" #EndSection Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules" ModulePath "/usr/lib/xorg/modules/extensions" EndSection Section "Module" Load "glx" Load "v4l" Load "extmod" Load "freetype" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "Emulate3Buttons" "no" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "Monitor" Identifier "Monitor0" ModelName "HP 7540" HorizSync 30.0 - 70.0 VertRefresh 50.0 - 120.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" VendorName "Videocard vendor" BoardName "Gforce 2 MX" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 Option "AddARGBGLXVisuals" "True" Option "DisableGLXRootClipping" "True" SubSection "Display" Viewport 0 0 Depth 24 Modes "1024x768" "800x600" "640x480" EndSubSection EndSection Section "Extensions" Option "Composite" "Disable" EndSection Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 14, 2009 Autor Zgłoszenie Share Napisano Sierpień 14, 2009 Zainstalowałem kernel-devel. Wchodzę w tryb init 3 i o dziwo raczę się widokiem automatycznej kompilacji sterowników Nvidii. Po restacie działają efekty graficzne a livna poprawiła wpis na właściwy sterownik. Czy jak zainstaluję nowe jądro, moduły zostaną dodane do jądra automatyczne? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fafig Napisano Sierpień 14, 2009 Zgłoszenie Share Napisano Sierpień 14, 2009 wywal ten pakiet konfiguracyjny z livny to Ci to nie bedzie nadpisywalo configow wygenerowanych na koncu przez nvidia-xconfig. livna-config-display czy jakos tak Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
multics Napisano Sierpień 14, 2009 Zgłoszenie Share Napisano Sierpień 14, 2009 Zawsze można zrobić żeby pliku nie dało się modyfikować su - chattr +i <plik> Chyba w przypadku xorg.conf'a można sobie na to pozwolić? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 14, 2009 Autor Zgłoszenie Share Napisano Sierpień 14, 2009 A czy nie livna-config-display edytuje xorg.conf? Bo taki wpis jest widoczny w pliku. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 14, 2009 Zgłoszenie Share Napisano Sierpień 14, 2009 A czy nie livna-config-display edytuje xorg.conf?Masz rację. Przynajmniej dopóki jest "zahaczona" opcja "Pozwól livna-config-display na modyfikowanie...". Dlatego jeśli chcesz, żeby np. zmiany wprowadzane przez Ciebie nie "znikały" z xorg.conf, to trzeba tę opcję odznaczyć. [EDIT] Albo bardziej linuksowo Z konsoli korzystając z edytora teksowego (najlepiej vi lub emacs, bo tylko cieniasy korzystają z nano lub mcedit) zmienić w pliku /etc/sysconfig/livna-config-display w sekcji [Configuration] parametr "active" z True na False Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Sierpień 15, 2009 Zgłoszenie Share Napisano Sierpień 15, 2009 Czy jak zainstaluję nowe jądro, moduły zostaną dodane do jądra automatyczne? Niestety tak dobrze nie jest. Jak zainstalujesz nowe jądro instalację trzeba powtórzyć, wcześniej odinstaluj to co teraz zainstalowałeś (./Nvidia.. --uninstall). Takie są mankamenty tych sterowników. Dalej nie wiadomo, czemu te z rpmfusion Ci nie działały. Jak wyjdzie nowe jądro zawsze możesz znowu spróbować kmoda, wyłączyłbym tylko livna-config-display w sposób jaki przedstawił Waldo. Automatyczne budowa sterowników dostarczana jest przez akmod-nvidia-96xx - nigdy nie używałem to nie wiem jak to wygląda w praktyce. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 15, 2009 Autor Zgłoszenie Share Napisano Sierpień 15, 2009 Nie instalowałem z instalatora ze strony Nvidii, tylko z RPMFusion. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fafig Napisano Sierpień 15, 2009 Zgłoszenie Share Napisano Sierpień 15, 2009 akmod sie wlacza przy starcie systemu, jesli w katalogu z modulami dla uruchamianego kernela jest modul to nic nie robi, jesli go znajdzie to kompiluje. to chyba dziala analogicznie jak dkms Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 15, 2009 Autor Zgłoszenie Share Napisano Sierpień 15, 2009 Własnie to zauważyłem. A z rpmfusion nie działały bo nie miałem kernel-devel. Proponuję uwzględnić to w poradniku. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fafig Napisano Sierpień 15, 2009 Zgłoszenie Share Napisano Sierpień 15, 2009 przeciez pakiet z rpmfusion to skompilowany modul i nie ma w zaleznosciach kernel-devel ... akmod czy dkms lub zwykle binarki nvidii tak, ale sam sterownik nie. mozna sprawdzic yum deplist Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adam_993 Napisano Sierpień 15, 2009 Autor Zgłoszenie Share Napisano Sierpień 15, 2009 Nie ma co zagłębiać się. Grunt że działa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
