Problem Z Yumem
kicerk
witam,
Ostanio musiałem wyłączyć yuma w czasie jego działania. Teraz gdy próbuje go odpalić, nieważne z jakimi argumentami(yum update, yum clean all, yum, yum -v) to wywala mi błędy w postaci:
[root@localhost run]# yum
  File "/usr/bin/yum", line 29, in <module>
    yummain.user_main(sys.argv[1:], exit_code=True)
  File "/usr/share/yum-cli/yummain.py", line 311, in user_main
    errcode = main(args)
  File "/usr/share/yum-cli/yummain.py", line 159, in main
    base.getOptionsConfig(args)
  File "/usr/share/yum-cli/cli.py", line 190, in getOptionsConfig
    self.conf
  File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 705, in <lambda>
    conf = property(fget=lambda self: self._getConfig(),
  File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 242, in _getConfig
    startupconf = config.readStartupConfig(fn, root)
  File "/usr/lib/python2.6/site-packages/yum/config.py", line 788, in readStartupConfig
    startupconf.releasever = _getsysver(startupconf.installroot, startupconf.distroverpkg)
  File "/usr/lib/python2.6/site-packages/yum/config.py", line 890, in _getsysver
    hdr = idx.next()
StopIteration
dodam jeszcze:
[root@localhost run]# rpm --rebuilddb
[root@localhost run]# rpm -qa
[root@localhost run]# ls /etc/yum.repos.d/
[root@localhost run]# ls /var/cache/yum/
adobe-linux-i386  fedora  rpmfusion-free
[root@localhost run]# tail /var/log/yum.log
Oct 05 20:12:38 Installed: gnome-media-libs-2.27.90.fix-1.fc11.i586
Oct 05 20:12:44 Installed: gst-mixer-2.26.0-3.fc11.i586
Oct 05 20:28:29 Installed: t1lib-5.1.2-3.fc11.i586
Oct 05 20:28:30 Installed: php-gd-5.2.9-2.fc11.i586
Oct 05 20:51:24 Installed: streamripper-1.64.6-1.fc11.i586
Oct 05 21:08:36 Erased: plymouth-gdm-hooks
Oct 05 21:08:37 Erased: gdm-user-switch-applet
Oct 05 21:08:45 Erased: gdm
Oct 05 21:08:59 Erased: gdm-plugin-fingerprint
Oct 05 21:10:09 Installed: kdm-4.3.1-9.fc11.i586
[root@localhost run]# uname -a
Linux localhost.localdomain 2.6.30.8-64.fc11.i686.PAE #1 SMP Fri Sep 25 04:56:58 EDT 2009 i686 i686 i386 GNU/Linux
googlowałem trochę, znalazłem rozwiązanie, ale u mnie ono nie działa. Zastanawiam się jeszcze nad podmienieniem tych plików, o które się pluje yum, ale nie mam skąd. Jakieś pomysły?
[root@localhost krecik]# yum-complete-transaction
  File "/usr/sbin/yum-complete-transaction", line 211, in <module>
    util = YumCompleteTransaction()
  File "/usr/sbin/yum-complete-transaction", line 118, in __init__
    self.main()
  File "/usr/sbin/yum-complete-transaction", line 137, in main
    opts = self.doUtilConfigSetup()
  File "/usr/share/yum-cli/utils.py", line 84, in doUtilConfigSetup
    self.conf
    hdr = idx.next()
StopIteration
Wychodzi na to, że to samo, co przy odpalaniu yuma
Wykasowałem później, ale ten sam błąd wywala, wiec nie ma znaczenia moim zdaniem. Ale jak coś to mogę dodać.
wczoraj byly problemy z rpmfusion i stad te problemy. teraz powinno byc ok ...
Watpie, mi to wyglada na typowy wysyp po kompletnym padzie i uszkodzeniu yuma..
@kicerk
a) sciagnij z jakiegos oficjalnego repo Updates wszystkie pakiety yuma (czyli te z czlonem yum w nazwie ;))
b) zainstaluj wszystkie na raz w bardzo nieelegancki i niebezpieczny (czytaj: w normalnych warunkach niepolecany) sposob:
rpm -Uvh --force -- nofiles --nodeps --replacepkgs --replacefiles *yum*.rpm
... to polecenie wydane oczywiscie w konsoli w katalogu do ktorego sciagnales yumowe pakiety
c) wyczysc chache:
yum clean all
d) zapusc update:
yum update
Jak nie wysypie sie na kroku c) to wszystko bedzie dobrze, a jak sie wysypie to bedziemy grzebac dalej... u mnie po takich padach ten sposob rozwiazywal problemy w 99% przypadkow (raz tylko musialem dodatkowo wymusic instalacje wszystkiego z python w nazwie ;))
menth0l@
W tym problem, że yumexa nie mogę zainstalować, no chyba, że ręcznie z pakietów, ale nie wiem jakie są zależności.
exbros@
http://mirrors.fedoraproject.org/publiclist/
http://ftp.icm.edu.pl/pub/Linux/fedora/linux/updates/11/i386/
ściągnąłem sobie wszystko z yumem w nazwie, i ... to samo. Więc zacząłem wszystko ściągać co ma python w nazwie, i sporo tego wyszło. Więc selektywnie zacząłem, takie mniej więcej, związane z tym. I mam to samo. Spróbowałbym podmienić te pliki, tylko mam taką prośbę, żeby ktoś udostępnił:
/usr/lib/python2.6/site-packages/yum/plugins.py
/usr/lib/yum-plugins/tmprepo.py
-edit-
na razie przeglądam listę dyskusyjną yuma'a
http://www.google.pl/search?hl=pl&safe...=Szukaj&lr=
-edit2-
Znalazłem rozwiązanie na stronie
http://lists.baseurl.org/pipermail/yum-dev...May/005627.html
Czyli w skrócie skasowałem linię 179 pliku /usr/lib/yum-plugins/tmprepo.py
Teraz jeszcze raz trzeba dodać repozytoria :P
Wszystkie te pliki są w pakiecie yum. Ściągnij sobie najnowszą paczkę z http://rpm.pbone.net i wymuś instalację przez RPM (tak mniej więcej jak podał wyżej exbros).
[EDIT]
Na tym samym serwerze wchodząc na stronę paczki yumex możesz sobie obejrzeć zależności.. Kłamałem. Akurat do yumex nie widać zależności :rolleyes:
Edytowane przez WalDo
Mam taką prośbę o wrzucenie "podstawowej" zawartości katalogu /etc/yum.repos.d/ o raz treści plików, które się tam znajdują. Naszukałem się, z godzinę i nie mogłem znaleźć, albo jakieś stare posty dostawałem.
Połączenie wątków
No widzisz, a wystarczylo stare, dobre
yum update --noplugins
(od tak dawna nie widzialem tego bledu, ze nie zajarzylem ze to problem z wtyczkami/wtyczka)
Co do repozytoriow to wymuszona re-instalacja jednego pakietu yum-*.rpm zalatwi sprawe
rpm -Uvh --force -- nofiles --nodeps --replacepkgs --replacefiles yum*.rpm
(zadbaj tylko o to zeby pakiet byl w odpowiedniej wersji...)
