Pirouette Napisano Grudzień 4, 2009 Zgłoszenie Share Napisano Grudzień 4, 2009 (edytowane) System MOBLIN 2.1 Application failure message 1: Program: /usr/bin/mutter Type: Aborted. [New process 586] #0 0x008fabf6 in raise () from /lib/libc.so.6 #0 0x008fabf6 in raise () from /lib/libc.so.6 #1 0x008fc908 in abort () from /lib/libc.so.6 #2 0x08087885 in meta_bug () #3 0x080757eb in ?? () #4 0x00c58e46 in _XError () from /usr/lib/libX11.so.6 #5 0x00c5df2b in ?? () from /usr/lib/libX11.so.6 #6 0x00c5e4ef in _XReply () from /usr/lib/libX11.so.6 #7 0x00c54ab8 in XSync () from /usr/lib/libX11.so.6 #8 0x0053c13a in gdk_flush () from /usr/lib/libgdk-x11-2.0.so.0 #9 0xb6d143fe in mnb_panel_focus () from /usr/lib/mutter/plugins/moblin-netbook.so #10 0xb6d14aa4 in ?? () from /usr/lib/mutter/plugins/moblin-netbook.so #11 0x00bddc08 in g_cclosure_marshal_VOID__VOID () from /lib/libgobject-2.0.so.0 #12 0x00bd2e58 in ?? () from /lib/libgobject-2.0.so.0 #13 0x00bd370d in g_closure_invoke () from /lib/libgobject-2.0.so.0 #14 0x00be073e in ?? () from /lib/libgobject-2.0.so.0 #15 0x00be105e in g_signal_emit_valist () from /lib/libgobject-2.0.so.0 #16 0x00be13c3 in g_signal_emit () from /lib/libgobject-2.0.so.0 #17 0xb6d0eda4 in ?? () from /usr/lib/mutter/plugins/moblin-netbook.so #18 0x00bddc08 in g_cclosure_marshal_VOID__VOID () from /lib/libgobject-2.0.so.0 #19 0x00bd370d in g_closure_invoke () from /lib/libgobject-2.0.so.0 #20 0x00be0898 in ?? () from /lib/libgobject-2.0.so.0 #21 0x00be105e in g_signal_emit_valist () from /lib/libgobject-2.0.so.0 #22 0x00be13c3 in g_signal_emit () from /lib/libgobject-2.0.so.0 #23 0x07ccb6e6 in ?? () from /usr/lib/libclutter-glx-1.0.so.0 #24 0x00bddc08 in g_cclosure_marshal_VOID__VOID () from /lib/libgobject-2.0.so.0 #25 0x00bd370d in g_closure_invoke () from /lib/libgobject-2.0.so.0 #26 0x00be05c8 in ?? () from /lib/libgobject-2.0.so.0 #27 0x00be105e in g_signal_emit_valist () from /lib/libgobject-2.0.so.0 #28 0x00be13c3 in g_signal_emit () from /lib/libgobject-2.0.so.0 #29 0x07cf7c78 in clutter_timeline_do_tick () from /usr/lib/libclutter-glx-1.0.so.0 #30 0x07cdf287 in ?? () from /usr/lib/libclutter-glx-1.0.so.0 #31 0x07cdf466 in ?? () from /usr/lib/libclutter-glx-1.0.so.0 #32 0x00aac68f in g_main_context_dispatch () from /lib/libglib-2.0.so.0 #33 0x00aae63c in ?? () from /lib/libglib-2.0.so.0 #34 0x00aaf4c8 in g_main_loop_run () from /lib/libglib-2.0.so.0 #35 0x0807c22d in main () Można jakoś to naprawić? Edytowane Grudzień 4, 2009 przez WalDo dodanie znacznika CODEBOX Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
multics Napisano Grudzień 4, 2009 Zgłoszenie Share Napisano Grudzień 4, 2009 Postaraj się uruchomić kompa w trybie tekstowym 3. Aby uruchomić kompa w trybie tekstowym robimy: -gdy pojawia się grub naciskamy dowolny klawisz (byle nie enter) -mając zaznaczony jakiś kernel naciskamy e -przechodzimy na koniec linii i wstawiamy tam 3 -zatwierdzamy zmianę i naciskamy b Gdy komp uruchomi się w trybie tekstowym logujemy się na roota i próbujemy przeinstalować pakiet mutter: yum reinstall mutter Restart. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Pirouette Napisano Grudzień 4, 2009 Autor Zgłoszenie Share Napisano Grudzień 4, 2009 Postaraj się uruchomić kompa w trybie tekstowym 3. Aby uruchomić kompa w trybie tekstowym robimy: -gdy pojawia się grub naciskamy dowolny klawisz (byle nie enter) -mając zaznaczony jakiś kernel naciskamy e -przechodzimy na koniec linii i wstawiamy tam 3 -zatwierdzamy zmianę i naciskamy b Gdy komp uruchomi się w trybie tekstowym logujemy się na roota i próbujemy przeinstalować pakiet mutter: yum reinstall mutter Restart. Dziękuję za pomoc, ale przy moich umiejętnościach nie jestem w stanie sobie poradzić wg scenariusza podanego przez Kolegę. Nie można tego zrobić w jakis prostrzy sposób? Np. z konsoli w "normalnym"trybie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 4, 2009 Zgłoszenie Share Napisano Grudzień 4, 2009 Nie można tego zrobić w jakis prostrzy sposób?Jeszcze prostszy? Pewnie nie widzisz menu GRUBa przy starcie i stąd problem? Trzymaj wciśnięty lewy shift po fizycznym włączeniu komputera. Np. z konsoli w "normalnym"trybie?Można: "init 3", powrót do trybu graficznego "init 5". Dlaczego Moblin? Przecież to jest na urządzenia mobilne a nie na desktop? Bez sensu chyba P.S. Tylko, że takie pytania to w przyszłości na "Oślej łączce" zadawaj. A wcześniej pofatyguj się z łaski swojej i poczytaj artykuły na wiki.fedora.pl. P.S.2 Nie cytuj w całości postu widocznego powyżej. Wycinaj istotny fragment, do którego chcesz się odnieść lub korzystaj z przycisku [ODPOWIEDZ] pod wątkiem zamiast przycisku [ODPISZ] pod postem (chociaż niektórzy jak np. @qmic twierdzą, że tego przycisku nie ma, a skrypt forum powinien znać ich myśli) Druga sprawa to wstawianie listingów, fragmentów kodu itp. Korzystaj ze znaczników [code][/code] (wklejka do 15 linii) lub [codebox][/codebox] (dłuższe teksty) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Pirouette Napisano Grudzień 4, 2009 Autor Zgłoszenie Share Napisano Grudzień 4, 2009 Ale ja mam tego Moblina na Lenovo S 10 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Grudzień 4, 2009 Zgłoszenie Share Napisano Grudzień 4, 2009 Np. z konsoli w "normalnym"trybie?Możesz przeinstalować ten pakiet w dowolnym trybie. Mutter to chyba menedżer okien. Poza tym komunikatem masz jakieś problemy z okienkami? Jeśli nie to go zignoruj i po sprawie. Btw. te tematy powinny trafiać do subforum "Pozostałe dytrybucje", bo moblin chociaż jest oparty na fedorze to jak widać jest zupełnie inną dystrybucją. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 4, 2009 Zgłoszenie Share Napisano Grudzień 4, 2009 Btw. te tematy powinny trafiać do subforum "Pozostałe dytrybucje", bo moblin chociaż jest oparty na fedorze to jak widać jest zupełnie inną dystrybucją.I tak i nie. Niby samodzielny system ale też[root@vbox ~]# yum grouplist [...] Środowiska graficzne Moblin [...] Jak się uprzesz to zainstalujesz sobie jako desktop pod Fedorą, stąd moje wcześniejsze pytanie, bo nie wiedziałem, że @Pirouette ma go na netbooku. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
