Rysio Napisano Marzec 18, 2010 Zgłoszenie Share Napisano Marzec 18, 2010 Zainstalowałem zgodnie z zaleceniem sterownik do karty ale niestety same problemy. Od początku lspci |grep nVidia 01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 440] (rev a3) więc zainstalowałem yum install kmod-nvidia-96xx-2.6.32.9-70.fc12.i686.i686 uruchamiam komputer i widzę czarny ekran, loguję się jako root i : startx xauth: creating new authority file /root/.serverauth.2283 X.Org X Server 1.7.5.901 (1.7.6 RC 1) Release Date: 2010-03-05 X Protocol Version 11, Revision 0 Build Operating System: x86-03 2.6.18-164.6.1.el5 Current Operating System: Linux telekom1 2.6.32.9-70.fc12.i686 #1 SMP Wed Mar 3 05:14:32 UTC 2010 i686 Kernel command line: ro root=UUID=d5cf5ef4-e531-4864-9724-ee07b299d769 LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet Build Date: 09 March 2010 02:35:04AM Build ID: xorg-x11-server 1.7.5.901-4.fc12 Current version of pixman: 0.16.6 Before reporting problems, check http://bodhi.fedoraproject.org/ to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Thu Mar 18 08:15:26 2010 (==) Using config file: "/etc/X11/xorg.conf" WARNING: Deprecated config file /etc/modprobe.conf, all config files belong into /etc/modprobe.d/. FATAL: Error inserting nvidia (/lib/modules/2.6.32.9-70.fc12.i686/extra/nvidia-96xx/nvidia.ko): No such device (EE) NVIDIA(0): Failed to load the NVIDIA kernel module! (EE) NVIDIA(0): *** Aborting *** (EE) Screen(s) found, but none have a usable configuration. Fatal server error: no screens found Please consult the Fedora Project support at http://bodhi.fedoraproject.org/ for help. Please also check the log file at "/var/log/Xorg.0.log" for additional information. giving up. xinit: No such file or directory (errno 2): unable to connect to X server xinit: No such process (errno 3): Server error. No i tak to jest, próbowałem również z kernelem PAE i sterownikami 173xx i oczywiście z pakietem akmod również, niestety podobny skutek. Nawet nie miałem dostępu do powłoki - na szczęście miałem otwartą furtkę poprzez ssh - dlatego mogłem wkleić tę diagnostykę. Gdyby ktoś podejrzewał że może nie ma wsparcia dla tej karty to dodam że pod FC8 3D dizałało bez zarzutu. Wklejam jeszcze ostatni fragment Xorg.0.log który potwierdza że system nie może załadować modułów do jądra; SELINUX jest wyłączony. "Default Screen Section" for depth/fbbpp 24/32 (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32 (==) NVIDIA(0): RGB weight 888 (==) NVIDIA(0): Default visual is TrueColor (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0) (**) NVIDIA(0): Option "AddARGBGLXVisuals" "True" (**) NVIDIA(0): Enabling RENDER acceleration (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is (II) NVIDIA(0): enabled. (EE) NVIDIA(0): Failed to load the NVIDIA kernel module! (EE) NVIDIA(0): *** Aborting *** (II) UnloadModule: "nvidia" (II) UnloadModule: "fb" (EE) Screen(s) found, but none have a usable configuration. Fatal server error: no screens found Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Marzec 18, 2010 Zgłoszenie Share Napisano Marzec 18, 2010 Zazwyczaj nie polecam tego rozwiązania, ale spróbuj zainstalować binarkę ze strony nvidii (wcześniej usuń wszystko co instalowałeś z repo). Btw. ten plik /lib/modules/2.6.32.9-70.fc12.i686/extra/nvidia-96xx/nvidia.ko w ogóle istnieje? A jak zainstalowałeś akmod to próbowałeś ręcznie generować moduł (chyba polecenie akmods)? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Amos Napisano Marzec 18, 2010 Zgłoszenie Share Napisano Marzec 18, 2010 Otwórz plik /boot/grub.conf i w linijce zaczynającej się od kernel dopisz na końcu: rdblacklist=nouveau Potem zrestartuj kompa i już... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gregor_szczecin Napisano Marzec 18, 2010 Zgłoszenie Share Napisano Marzec 18, 2010 Witam (chyba polecenie akmods)? Dokładnie. W razie coś, pokaże co boli Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rysio Napisano Marzec 30, 2010 Autor Zgłoszenie Share Napisano Marzec 30, 2010 No tak, AMOS jesteś wielki - faktycznie pomogło dopisanie tych dwóch magicznych słów ;-). [sOLVED] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
