Google Earth - Problem Z Uruchomieniem. Fedora 14 X86_64
rafalz
Witam,
kilka watków nizej widnieje podobny post apropo GoogleEarth w Fedorze 12. Ktos sugeruje aby autor zainstalowal Fedore 14...
Mam na kompie Fedore 14 (x64 KDE)... Instaluje GoogleEarth zgodnie z Waszym opisem w poradniku na stronie... Konsola wywala taki blad:
[centurion@f14m64 google-earth]$ googleearth
Google Earth has caught signal 11.
We apologize for the inconvenience, but Google Earth has crashed.
This is a bug in the program, and should never happen under normal
circumstances. A bug report and debugging data have been written
to this text file:
   /home/centurion/.googleearth/crashlogs/crashlog-4ce57125.txt
Please include this file if you submit a bug report to Google.
Program jakby stara sie odpalac - wyskakuje okienko startowe programu, po chwili gasnie i dalej nic.
Tresc crashloga
Major Version 5
Minor Version 2
Build Number 0001
Build Date Sep  1 2010
Build Time 11:25:42
OS Type 3
OS Major Version 2
OS Minor Version 6
OS Build Version 35
OS Patch Version 6
Crash Signal 11
Crash Time 1290105125
Up Time 2,31296
Stacktrace from glibc:
./libgoogleearth_free.so(+0xd090b)[0x6f090b]
[0xd90400]
/usr/lib/libGL.so.1(glXMakeCurrent+0x17)[0xa33ecc]
./libIGGfx.so(_ZN3Gap3Gfx18igOglVisualContext19internalMakeCurrentEv+0x33)[0x2632d53]
./libIGGfx.so(_ZN3Gap3Gfx18igOglVisualContext21internalCreateContextEv+0x1a4)[0x2633424]
./libIGGfx.so(_ZN3Gap3Gfx18igOglVisualContext4openEv+0x9c)[0x26502ac]
/opt/google-earth/libevll.so(_ZN5earth4evll13VisualContext11OpenContextEN3Gap3Gfx25igRenderDestinationFormatERKNS0_8InitInfoE+0xff)[0x4764d3f]
/opt/google-earth/libevll.so(_ZN5earth4evll13VisualContext4initERKNS0_8InitInfoE+0x167)[0x4764ef7]
/opt/google-earth/libevll.so(_ZN5earth4evll17RenderContextImpl4initERKNS0_8InitInfoE+0x7e)[0x46bd2ce]
./librender.so(_ZN12RenderWidget6SetApiEPN5earth4evll3APIE+0x47)[0x9fc607]
./librender.so(_ZN5earth6render12RenderWindow12createWidgetEv+0x182)[0x9de532]
./libgoogleearth_free.so(_ZN5earth6client12ModuleWidget9showEventEP10QShowEvent+0x94)[0x6ce084]
./libQtGui.so.4(_ZN7QWidget5eventEP6QEvent+0xabb)[0xf1f7ef]
./libQtGui.so.4(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0xa0)[0xecfe20]
./libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x16f)[0xed98a3]
./libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x70)[0x249d50]
./libQtGui.so.4(_ZN14QWidgetPrivate11show_helperEv+0xcc)[0xf2255c]
./libQtGui.so.4(_ZN14QWidgetPrivate14show_recursiveEv+0x74)[0xf22264]
./libQtGui.so.4(_ZN14QWidgetPrivate12showChildrenEb+0x1f2)[0xf22482]
./libQtGui.so.4(_ZN14QWidgetPrivate11show_helperEv+0x45)[0xf224d5]
./libQtGui.so.4(_ZN7QWidget10setVisibleEb+0x33b)[0xf22a97]
./libQtGui.so.4(_ZN14QWidgetPrivate12showChildrenEb+0x1d9)[0xf22469]
./libQtGui.so.4(_ZN7QWidget10showNormalEv+0x4a)[0xf12e9e]
./libgoogleearth_free.so(_ZN10MainWindow18readScreensizeInfoEv+0xc35)[0x6bbb15]
./libgoogleearth_free.so(_ZN5earth6client11Application12SetupMainWinENS0_3Kvw7ProductEb+0x29e)[0x6f4c1e]
./libgoogleearth_free.so(_ZN5earth6client11Application3runEv+0x42f)[0x6fba7f]
./libgoogleearth_free.so(earthmain+0x27d)[0x6efd3d]
./googleearth-bin(_init+0x12e)[0x80486d2]
/lib/libc.so.6(__libc_start_main+0xe6)[0x46739e16]
./googleearth-bin(_init+0x9d)[0x8048641]
Jak widac instalacja F14 nie rozwiazuje problemu
Ktos sobie z tym poradzil czy to jakis wiekszy blad?
  • Odpowiedzi 31
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Niestety ja wlasnie instalowalem wedlug tego poradnika wiec najwyrazniej cos nie tak z tym KDE (po raz kolejny) tyle tylko ze dziwi mnie ze konsola nie wywala zadnych bledów czy braków. Instalacja przebiegla bez zajakniecia (w domyslnej lokacji /opt/google-earth -> moze w tym tkwi jakis problem? (zle wskazanie jakichs dowiazan gdzies?))
Zaryzykuj instalacje do lokalnego folderu uzytkownika tak jak opisalem w czerwonej ramce. Ja w /opt jako root w ogóle nie moglem zainstalowac. To oczywiscie tylko obejscie problemu a nie rozwiazanie, ale dla mnie wystarczajace.
[EDIT]
a wczesniej z roota bym spróbowal czy nie ma problemu z uprawnieniami, no i SElinux mozna na chwile wylaczyc.
[root@F14 x86]# mv setup.gtk
setup.gtk  setup.gtk2
Pomylka w druku :) Poprawilem, ale to w sumie i tak nie zwalnia od myslenia. Gdybys bohatersko brnal dalej to trafilbys - doslownie linijke nizej - na poprawny fragment
[root@F14 x86]# mv setup.gtk setup.gtk2
mv: zamazac `setup.gtk2'? y
Oczywiscie "mv: zamazac `setup.gtk2'? y" to nie jest polecenie a tylko komunikat, który sie wyswietla po wpisaniu polecenia "mv setup.gtk setup.gtk2"
Pomyłka w druku :) Poprawiłem, ale to w sumie i tak nie zwalnia od myślenia. Gdybyś bohatersko brnął dalej to trafiłbyś - dosłownie linijkę niżej - na poprawny fragment
mv: zamazać `setup.gtk2'? y
Oczywiście "mv: zamazać `setup.gtk2'? y" to nie jest polecenie a tylko komunikat, który się wyświetla po wpisaniu polecenia "mv setup.gtk setup.gtk2"
Wiem że to komunikat mi chodziło o to że to wygląda jak komenda:
mv setup.gtk setup.gtk setup.gtk2
która zupełnie nie ma sensu ... o to mi chodziło tylko i oczywiście przez to przebrnąłem bo wiem jak mv się używa ale inni nie koniecznie:)
Jeśli przebrnąłeś, widziałeś błąd i wiedziałeś jak powinno być poprawnie, to szkoda, że nie pomyślałeś o zrobieniu od razu poprawki w wiki <_< Wystarczy się zarejestrować - to trwa chwilę a innym może ułatwić życie z Fedorą.
Jesli przebrnales, widziales blad i wiedziales jak powinno byc poprawnie, to szkoda, ze nie pomyslales o zrobieniu od razu poprawki w wiki <_< Wystarczy sie zarejestrowac - to trwa chwile a innym moze ulatwic zycie z Fedora.
zajmuje sie podobnymi rzeczami w przypadku innych dystrybucji tak ze na brak zajec nie narzekam :) mam wrazenie ze i tak macie tutaj sporo rak do pracy
  • 1 month later...
Jako, że mam podobny problem, to się podczepię. Robię wszystko wg poradnika. Oczywiście wyskakuje wiadomy błąd. Kiedy robię "/home/user/Pobrane/GoogleEarthLinux.bin --target /tmp/ge" (w miejsce usera daję nazwę mojego konta) oczywiście jako root, dostaję komunikat: brak dostępu. Próbowałem zarówno z włączonym, jak i wyłączonym SELinuksem. O co chodzi?
Gość
