Problem Z Zainstalowaniem Systemu Na Virtualboxe
piotrino
Witam, po poprawnym zainstalowaniu virtualboxa za pomoca poradnika viki,wszystko sie ladnie zainstalowalo. Mam problem z uruchomieniem systemu na virtualboxie tzn zainstalowalem wczesniej "dkms" ale mimo to mam dalej blad:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
'/etc/init.d/vboxdrv setup'
as root. Users of Ubuntu, Fedora or Mandriva should install the DKMS package first. This package keeps track of Linux kernel changes and recompiles the vboxdrv kernel module if necessary.
No to postapilem wedlug wskazowek i dalej mam ten sam blad...
[root@Fedora log]# /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel modules                         [  OK  ]
Uninstalling old VirtualBox DKMS kernel modules            [  OK  ]
Trying to register the VirtualBox kernel modules using DKMS
Error! Your kernel source for kernel 2.6.35.6-45.fc14.x86_64 cannot be found at
/lib/modules/2.6.35.6-45.fc14.x86_64/build or /lib/modules/2.6.35.6-45.fc14.x86_64/source.
                                                          [FAILED]
 (Failed, trying without DKMS)
Recompiling VirtualBox kernel modules                      [FAILED]
 (Look at /var/log/vbox-install.log to find out what went wrong)
[root@Fedora log]# dir
anaconda.log	      cron     maillog		 secure		     wtmp
anaconda.program.log  cups     mcelog		 setroubleshoot      Xorg.0.log
anaconda.storage.log  dmesg    messages		 spooler	     Xorg.9.log
audit		      gdm      ntpstats		 sssd		     yum.log
boot.log	      httpd    pm-powersave.log  tallylog
btmp		      lastlog  ppp		 vbox-install.log
ConsoleKit	      mail     prelink		 wpa_supplicant.log
[root@Fedora log]# cat  vbox-install.log
Uninstalling modules from DKMS
 removing old DKMS module vboxhost version  3.2.10
Deleting module version: 3.2.10
completely from the DKMS tree.
Done.
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/3.2.10/source ->
                /usr/src/vboxhost-3.2.10
DKMS: add Completed.
You can use the --kernelsourcedir option to tell DKMS where it's located.
Failed to install using DKMS, attempting to install without
Makefile:159: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=<directory> and run Make again.  Stop.
[root@Fedora log]#
Link symboliczny utworzylem ale mimo to dalej mam blad przy instalacji systemu. Gdzie robie blad przy instalacji virtualboxa???
[root@Fedora log]# uname -a
Linux Fedora 2.6.35.6-45.fc14.x86_64 #1 SMP Mon Oct 18 23:57:44 UTC 2010 x86_64 x86_64 x86_64 GNU/Linux
POzdrawiam
  W dniu 19.11.2010 o 22:21, piotrino napisał:
Witam, po poprawnym zainstalowaniu virtualboxa za pomoca poradnika viki,wszystko sie ladnie zainstalowalo. Mam problem z uruchomieniem systemu na virtualboxie tzn zainstalowalem wczesniej "dkms" ale mimo to mam dalej blad...
Wszystko co potrzebne do instalacji VB jest opisane w poradniku do F11, jakimś cudem nie ma tego w poradnikach do późniejszych wersji :| Artykuł dotyczący samego VB też nie zawiera takich informacji :ph34r:
Przy ponownym zainstalowaniu virtualboxa i zainstalowaniu gcc,dkms,i kernel-devel mam taki komunikat:
[root@fedora sysconfig]# /etc/init.d/vboxdrv setup
                                                          [FAILED]
W jaki sposób moge ten problem rozwiazac....Aktualizacje systemu sa zrobione na biezaco
P.S Przy okazji jaka musze paczke zainstalowac na fedorze zebym mógl stworzyc virtualne interfejsy np. br0....?
Musisz sprawdzic czy kernel-devel masz zainstalowane dla kernela, na którym aktualnie siedzisz. Pakiet kernel-header tez moze byc potrzebny. Porównaj uname -r z rpm -qa | grep kernel . Co do wirtualnych interfejsów to zdaje sie, ze poza standardowym modulem vboxdrv musisz tez miec zaladowane vboxnetadp i vboxnetflt (u mnie w ten sposób dziala). Byc moze ten daemon na fedorze juz automatycznie je laduje.
Podaje:
[root@fedora Admin]# uname -r
[root@fedora Admin]# rpm -qa | grep kernel
abrt-addon-kerneloops-1.1.13-2.fc14.x86_64
kernel-2.6.35.6-48.fc14.x86_64
kernel-headers-2.6.35.6-48.fc14.x86_64
kernel-2.6.35.6-45.fc14.x86_64
kernel-devel-2.6.35.6-48.fc14.x86_64
[root@fedora Admin]# yum install kernel-header
Loaded plugins: langpacks, presto, refresh-packagekit
Adding en_US to language list
Setting up Install Process
No package kernel-header available.
Done.
Makefile:159: *** Error: unable to find the sources of your current Linux kerne$
[root@fedora Admin]# /var/lib/dkms/vboxhost/3.2.10/source ->  /usr/src/vboxhost-3.2.10
Kurcze moze dlatego mi virtualbox nie dziala, bo na koncu dopiero aktualizowalem system....
Udalo mi sie w koncu, temat do zamkniecia...
P.S Udalo mi sie sciagnac te narzedzie, i skonfigurowalem juz interfejs virtualny, tylko pozostal mi problem z virtualboxem....
