Krytycznie Wolne Wifi
64 bytes from wp.pl (212.77.100.101): icmp_req=1 ttl=247 time=26.3 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=2 ttl=247 time=24.0 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=4 ttl=247 time=29.9 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=8 ttl=247 time=22.6 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=12 ttl=247 time=38.8 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=13 ttl=247 time=23.0 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=15 ttl=247 time=19.4 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=16 ttl=247 time=22.7 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=17 ttl=247 time=45.0 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=18 ttl=247 time=22.9 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=22 ttl=247 time=21.0 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=23 ttl=247 time=88.5 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=24 ttl=247 time=103 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=25 ttl=247 time=33.5 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=41 ttl=247 time=26.0 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=42 ttl=247 time=25.8 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=43 ttl=247 time=43.4 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=46 ttl=247 time=120 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=47 ttl=247 time=22.2 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=48 ttl=247 time=25.9 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=49 ttl=247 time=19.5 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=50 ttl=247 time=105 ms
64 bytes from wp.pl (212.77.100.101): icmp_req=51 ttl=247 time=20.3 ms
^C
--- wp.pl ping statistics ---
52 packets transmitted, 23 received, 55% packet loss, time 51030ms
rtt min/avg/max/mdev = 19.486/40.490/120.618/30.550 ms
lspci
0c:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02
Proszę o pomoc, nie da się pracować z taką jakością połączenia, pod każdym innym systemem wifi jest bardzo ok
Ja widzę że pingi są dość nierówne .
U mnie takie zjawisko powoduje spowolnione ładowanie się stron .
U mnie takie coś westępuje gdy antenki routera lub Accespointa nie są ustawione pod optymalnymi kątami . Poruszaj delikatnie antenką WI FI routera i zobacz przy jakim położeniu pingi są najbardziej równomierne
Do tego zrób krąg z soli wokół routera. Zapobiegniesz ingerencji złego.
Ja mam podobny ping i nie powoduje to jakichś problemów. Niech się zainteresowany wypowie co nie dział u niego.
Myślę że problemem jest: 55% packet loss.
Tylko nie wiem czemu akurat na Fedorze miał by być problem. Mała moc ustawiona, jakiś tryb oszczędzania energii?
Ping jest ok.
Hmmm Panowie, jeżeli uważacie, że pingi skaczące od 20ms do ponad 100ms przy żadnym obciążeniu interfejsu są ok to jestem lekko zaskoczony. Nie wiem czy zauważyliście, ale jest tam również podsumowanie, które mówi o 55% start...(jednie te starty zauważył użytkownik 3k_PL)
Założyłem ten wątek, bo nie wiem gdzie może być problem w konfiguracji karty bezprzewodowej...
A może napiszesz czy objawia się to wolne wi-fi?
Tym, że problemem jest nawet otworzenie strony wp.pl a co dopiero np przegranie czegoś z/na serwer FTP...
Co masz na myśli mówiąc mała moc ustawiona? Masz na myśli ustawienia routera? Sygnał jest na maksa, nie korzystam również z żadnego trybu oszczędzania
:D
Możesz pokazać iwconfig dla tego interfejsu? Jeśli na innym Linuksie działa OK, to sprawdź jak tam wyglądają ustawienia.
Nigdy się z tym nie bawiłem, ale w "man iwconfig" wyczytałem m.in.
txpower
For cards supporting multiple transmit powers, sets the transmit
power in dBm. If W is the power in Watt, the power in dBm is P =
30 + 10.log(W). If the value is postfixed by mW, it will be
automatically converted to dBm.
In addition, on and off enable and disable the radio, and auto
and fixed enable and disable power control (if those features
are available).
Examples :
iwconfig eth0 txpower 15
iwconfig eth0 txpower 30mW
iwconfig eth0 txpower auto
iwconfig eth0 txpower off
frag[mentation_threshold]
Fragmentation allows to split an IP packet in a burst of smaller
fragments transmitted on the medium. In most cases this adds
overhead, but in a very noisy environment this reduces the error
penalty and allow packets to get through interference bursts.
Może warto coś z tymi opcjami pokombinować? :unsure:
wlan0     IEEE 802.11abg  ESSID:"Home"
         Mode:Managed  Frequency:2.417 GHz  Access Point: MAC ADDRESS
         Bit Rate=54 Mb/s   Tx-Power=15 dBm
         Retry  long limit:7   RTS thr:off   Fragment thr:off
         Encryption key:off
         Power Management:off
         Link Quality=66/70  Signal level=-44 dBm
         Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
         Tx excessive retries:0  Invalid misc:0   Missed beacon:0
Nie moge skopiowac ustawien, poniewaz pozostale systemy nie sa spod znaku pingwina, ale na nich WiFi dziala bez problemu.
Z tego co widac, z pingów, pakiety (23ok) wchodza jeden po drugim, czyli straty byly na poczatku, moze pingowales w trakcie nawiazywania polaczenia?
Pakiety nie wychodza jeden po drugim, przyklad powyzej, skok z 25 na 47...
Czy masz fizyczny dostep do AP? Czy w poblizu sa inne Wi-Fi na tych samych kanalach?
Tak mam fizyczny dostep do AP (jest to mój AP) W poblizu sa inne WiFi (sasiadów), ale ich nie uzywam i nigdy sie do nich nie laczylem chociazby dlatego, ze sa zabiezpieczone.
Coraz bardziej podejrzewam, ze problem moze byc w urzadzeniu AP, tylko nie wiem dlaczego, mialby nie dzialac stabilnie z Fedora...
