alkuzad Napisano Listopad 18, 2011 Zgłoszenie Share Napisano Listopad 18, 2011 @Geto A czemu nie skoro F16 to min. GNOME3.2 ? Pokaz historie yuma, dmesg, lsmod, lsusb. Prawdopodobnie rozjechaly sie aktualizacje kernela i paczek odpowiedzialnych za karty sieciowe ale mozemy narazie tylko gdybac. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 18, 2011 Zgłoszenie Share Napisano Listopad 18, 2011 Historia yuma Loaded plugins: langpacks, presto, refresh-packagekit ID | Login user | Date and time | Action(s) | Altered ------------------------------------------------------------------------------- 14 | System <unset> | 2011-11-18 10:55 | Install | 1 ## 13 | System <unset> | 2011-11-18 10:55 | Install | 1 ## 12 | System <unset> | 2011-11-18 00:15 | I, O, U | 409 EE 11 | System <unset> | 2011-11-17 23:25 | Install | 1 10 | System <unset> | 2011-11-17 23:13 | I, U | 58 9 | Dominik <dominik> | 2011-06-22 21:20 | I, U | 4 8 | Dominik <dominik> | 2011-06-22 20:58 | Install | 5 7 | Dominik <dominik> | 2011-06-22 20:44 | I, U | 3 6 | System <unset> | 2011-06-22 20:37 | I, U | 14 5 | Dominik <dominik> | 2011-06-22 20:28 | Install | 1 4 | Dominik <dominik> | 2011-06-22 20:23 | Update | 2 3 | Dominik <dominik> | 2011-06-22 20:21 | Install | 19 2 | Dominik <dominik> | 2011-06-22 20:16 | I, U | 14 EE 1 | root <root> | 2011-05-13 21:41 | Install | 1096 history list dmesg (nie mam całego) -bash: [: missing `]' [root@dominik ~]# [ 2.795509] -bash: [: missing `]' [root@dominik ~]# [ 2.795513] ata2.00: 625140335 sectors, multi 16: LBA48 NCQ (depth 0/32) -bash: syntax error near unexpected token `(' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 2.844652] scsi 1:0:0:0: Direct-Access ATA ST3320613AS CC2H -bash: [: missing `]' [root@dominik ~]# [ 2.844906] sd 1:0:0:0: Attached scsi generic sg0 type 0 -bash: [: missing `]' [root@dominik ~]# [ 2.845260] sd -bash: [: missing `]' [root@dominik ~]# [ 2.845327] sd 1:0:0:0: [sda] Write Protect is off -bash: [: missing `]' [root@dominik ~]# [ 2.845331] sd 1:0:0 -bash: [: missing `]' [root@dominik ~]# [ 2.845360] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, does -bash: [: missing `]' [root@dominik ~]# [ 2.888334] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 > -bash: syntax error near unexpected token `newline' [root@dominik ~]# [ 2.889150] sd 1:0:0: -bash: [: missing `]' [root@dominik ~]# [ 3.009027] usb 2-4: device descriptor read/64, error -62 -bash: [: missing `]' [root@dominik ~]# [ 3.148024] ata4: SA -bash: [: missing `]' [root@dominik ~]# [ 3.267026] usb 2-4: new full speed USB device number 4 using ohci_hcd -bash: [: missing `]' [root@dominik ~]# [ 3.302 -bash: [: missing `]' [root@dominik ~]# [ 3.302326] ata6: nv_mode_filter: 0x1f39f&0x1f39f->0x1f39f, BIOS=0x1f000 (0xc500) -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 3.308245] ata6.00: configured for UDMA/66 -bash: [: missing `]' [root@dominik ~]# [ 3.310260] scsi 5:0:0:0: CD-ROM -bash: [: missing `]' [root@dominik ~]# [ 3.312341] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 3.312512] sr 5:0:0:0: Attached scsi CD-ROM sr0 -bash: [: missing `]' [root@dominik ~]# [ 3.312600] s -bash: [: missing `]' [root@dominik ~]# [ 3.318338] firewire_ohci 0000:01:0a.0: PCI INT A -> Link[APC3] -> GSI -bash: [: missing `]' [root@dominik ~]# [ 3.369068] firewire_ohci: Added fw-ohci devi -bash: [: missing `]' [root@dominik ~]# [ 3.673027] usb 2-4: device not accepting address 4, error -62 -bash: [: missing `]' [root@dominik ~]# [ 3.830248] usb 2 -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 4.236025] usb 2-4: device not accepting address 5, -bash: [: missing `]' [root@dominik ~]# [ 4.236041] hub 2-0:1.0: unable to enumerate USB devi -bash: [: missing `]' [root@dominik ~]# [ 4.497025] usb 2-9: new full speed USB device number 6 usi -bash: [: missing `]' [root@dominik ~]# [ 4.685037] usb 2-9: New USB device found, idVen -bash: [: missing `]' [root@dominik ~]# [ 4.685041] usb 2-9: New USB device strings: M -bash: [: missing `]' [root@dominik ~]# [ 4.685045] usb -bash: [: missing `]' [root@dominik ~]# [ 4.698855] usbcore: registered new interface driver uas -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 4.700696] scsi6 : usb-storage 2-9:1.2 -bash: [: missing `]' [root@dominik ~]# [ 4.7 -bash: [: missing `]' [root@dominik ~]# [ 4.701112] USB Mass Storage support registered. -bash: [: missing `]' [root@dominik ~]# [ 4.753955] usb 1-8 -bash: [: missing `]' [root@dominik ~]# [ 4.795236] EXT4- -bash: [: missing `]' [root@dominik ~]# [ 4.852568] usb 1-8.1: New USB device foun -bash: [: missing `]' [root@dominik ~]# [ 4.852574] usb 1-8.1: New USB device st -bash: [: missing `]' [root@dominik ~]# [ 4.852579] usb 1-8.1: Product: USB2.0 WLAN -bash: [: missing `]' [root@dominik ~]# [ 4.8 -bash: [: missing `]' [root@dominik ~]# [ 4.852584] usb 1-8.1: SerialNumber: 12345 -bash: [: missing `]' [root@dominik ~]# [ 4.874941] d -bash: [: missing `]' [root@dominik ~]# [ 4.874974] dracut: fsck -T -t noopts=_ -bash: [: missing `]' [root@dominik ~]# [ 4.916326] dracut: _Fedora-15-x86_6: clean, 136115/9666 -bash: [: missing `]' [root@dominik ~]# [ 4.916518] dracut: Remounting / -bash: [: missing `]' [root@dominik ~]# [ 4.918967] usb 1-8.2: new full speed USB de -bash: [: missing `]' [root@dominik ~]# [ 4.957285] EXT4-fs (sda3): mounted filesystem -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 4.983981] dracut: Mounted root filesystem /dev/ -bash: [: missing `]' [root@dominik ~]# [ 4.997194] usb 1-8.2: New USB device found, idVendor=046d, idProduct -bash: [: missing `]' [root@dominik ~]# [ 4.997200] usb 1-8.2: New USB device stri -bash: [: missing `]' [root@dominik ~]# [ 4.997203] usb 1-8.2: Product: Camera -bash: [: missing `]' [root@dominik ~]# [ 4. -bash: [: missing `]' [root@dominik ~]# [ 5.0629 -bash: [: missing `]' [root@dominik ~]# [ 5.121839] dracut: Switching root -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 5.141082] usb 1-8.3: New USB device strings: Mfr=0, Product=0, SerialN -bash: [: missing `]' [root@dominik ~]# [ 5.204952] -bash: [: missing `]' [root@dominik ~]# [ 5.284072] usb 1-8.4: New USB device fo -bash: [: missing `]' [root@dominik ~]# [ 5.28407 -bash: [: missing `]' [root@dominik ~]# [ 5.284082] usb 1-8.4: Product: USB2.0 Hu -bash: [: missing `]' [root@dominik ~]# [ 5.284 -bash: [: missing `]' [root@dominik ~]# [ 5.284815] hub 1-8.4:1.0: 4 ports detected -bash: [: missing `]' [root@dominik ~]# [ 5.57863 -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 5.728072] scsi 6:0:0:0: Direct-Access Brother -bash: [: missing `]' [root@dominik ~]# [ 5.728749] sd 6:0:0:0: Attached scsi generic sg2 typ -bash: [: missing `]' [root@dominik ~]# [ 5.785344] SELinux: 2048 avtab hash slots, 2 -bash: [: missing `]' [root@dominik ~]# [ 5.798066] sd 6:0:0:0: [sdb] Attached SCSI r -bash: [: missing `]' [root@dominik ~]# [ 6.613329] SELinux: 9 users, 13 role -bash: [: missing `]' [root@dominik ~]# [ 6.613336] SELinux: 81 classes, 225907 rules -bash: [: missing `]' [root@dominik ~]# [ 6.621685] -bash: [: missing `]' [root@dominik ~]# [ 6.621690] SELinux: Setti -bash: [: missing `]' [root@dominik ~]# [ 6.621705] SELinux: i -bash: [: missing `]' [root@dominik ~]# [ 6.621714] SELinux: initialized (dev rootf -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.621730] SELinux: initializ -bash: [: missing `]' [root@dominik ~]# [ 6.621739] SELinux: initialized (dev proc, type -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.621751] SELinux: initialized (dev tmpfs, type tmpfs), use -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.621791] SELinux: initialized (dev devtmpfs, type devtmpfs -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.622881] SELinux: init -bash: [: missing `]' [root@dominik ~]# [ 6.622888] SELinux: initia -bash: [: missing `]' [root@dominik ~]# [ 6.623835] SELinux: initializ -bash: [: missing `]' [root@dominik ~]# [ 6.623845] SELinux: initialized (dev anon_inodefs, type anon_inodefs), use -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.62 -bash: [: missing `]' [root@dominik ~]# [ 6.623892] SELinux: initialized (dev hugetlbfs, type hugetlbf -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.623914] SEL -bash: [: missing `]' [root@dominik ~]# [ 6.623929] SELinux: initial -bash: [: missing `]' [root@dominik ~]# [ 6.623950] SELinux: initialize -bash: [: missing `]' [root@dominik ~]# [ 6.623958] SELinux: initialized (dev securityfs, type -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6.623965] SELinux: initialized (dev sysfs, type sysfs), -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 6 -bash: [: missing `]' [root@dominik ~]# [ 6.624421] SELinux: initialized (dev tmpfs, type tmpfs), -bash: syntax error near unexpected token `(' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 6.628937] type=1403 audit(1321618893.222:3): policy loaded auid=4294 -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7. -bash: [: missing `]' [root@dominik ~]# [ 7.265537] SELinux: initialized (dev cgroup, type cgroup), use -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.622895] SELinux: initialized (dev cgroup, type cgroup), uses genfs -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.623659] -bash: [: missing `]' [root@dominik ~]# [ 7.624400] SELinux: initialized (dev cgroup, type cgroup), uses genfs_c -bash: syntax error near unexpected token `(' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 7.626430] SELinux: initialized (dev cgroup, type cgroup), uses genfs_con -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.627253] SELinux: initialized (dev cgroup, type cgrou -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.627949] SE -bash: [: missing `]' [root@dominik ~]# [ 7.628722] SELinux: initialized (dev cgroup, type -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.629475] SELinux: -bash: [: missing `]' [root@dominik ~]# [ 7.677378] systemd[1]: systemd 26 running in system mode. (+PAM +LIBWRAP +AU -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 7.910549] NET: Registered protocol family 10 -bash: [: missing `]' [root@dominik ~]# [ 7.93 -bash: [: missing `]' [root@dominik ~]# [ 9.000821] SELinux: -bash: [: missing `]' [root@dominik ~]# [ 9.004733] SELinux: initialized (dev autofs, type autofs -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 9.005857] SELinux: -bash: [: missing `]' [root@dominik ~]# [ 9.008606] SELinux: initialized (dev autofs, type autofs), uses genfs -bash: syntax error near unexpected token `(' [root@dominik ~]# [ 9.010 -bash: [: missing `]' [root@dominik ~]# [ 13.163786] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs -bash: syntax error near unexpected token `(' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 16.276430] udev[435]: starting version 167 -bash: [: missing `]' [root@dominik ~]# [ 16.694104] forcedeth: Reverse Eng -bash: [: missing `]' [root@dominik ~]# [ 16.694321] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23 -bash: [: missing `]' [root@dominik ~]# [ 16.694329] forc -bash: [: missing `]' [root@dominik ~]# [ -bash: [: missing `]' [root@dominik ~]# [ 16.716372] mtp-probe[498]: checking bus 1, devi -bash: [: missing `]' [root@dominik ~]# [ 16.716693] m -bash: [: missing `]' [root@dominik ~]# [ 16.718442] mtp-probe[499]: checking bus 2, device 6: "/sys/devices/pc > [ 16.814124] mtp-probe[497]: bus: 1, device: 5 > [ 16.818998] mtp-probe[498]: bus: 1, device: 6 was not an MTP d > [ 16.903923] parpo > [ 1 > [ 16.958676] Bluetooth: Core ver 2.16 > [ 16.971807] > [ 16.971812] Bluetooth: HCI device and connection mana > [ 16.971816] Bluetooth: HCI socket layer initialized > [ 16. > [ 16.974056] Bluetooth: SCO socket layer initiali > [ 16.974506] Bluetooth: Generic Bluetooth USB d > [ 16.976827] usb > [ 17.085657] MCE: In-kernel MCE decoding enabled. > [ 17. > [ > [ 17.216732] forcedeth 0000:00:0a.0: hig > [ 17.2 > [ 17.220184] i2c i2c-4: nForce2 SMBus adapter at > [ 17.249850] AMD64 E > [ 17.276436] EDAC > [ 17.276443] EDAC amd64: ECC disabled in th > [ 17.276446] Either enable ECC checking > [ 17.276448] (Note that use of the override > [ 17.3 > [ 17.560040] ppdev: user-space parallel por > [ 17.583072] L > [ 17.590710] ACPI: PCI Interrupt Link [A > [ 17.590719] Intel ICH 0000:00:04.0: PCI INT A -> Link[AP > [ 17.590762] Intel ICH 0000:00:04 > [ 17.593303] Linux video capture interface: v > [ 17.598918] cfg80211: Calling CRDA to update w > [ 17.599117] gspca: v2.13.0 registered > [ 17.6208 > [ 17.621646] usbcore: registered new interface driver spca561 > [ 17.6 > [ 17.698521] cfg80211: (start_freq - en > [ 17.698525] cfg80211: (2402000 KHz > [ 17. > [ 17.6985 > [ 17.698537] cfg80211: (5170000 > [ > [ 17.820169] mtp-probe[499]: bus: 2, device: 6 was not an MTP device > [ > [ 17.916421] > [ 17.925642] intel8x0_measure_ac97_clock: > [ 17.92564 > [ 17.961263] usblp0: USB Bidirectional pri > [ 17.962 > [ 17.987492] udev-configure-printer[695]: ad > [ 17.99823 > [ 1 > [ 18.268160] Adding 3071996k swap on /dev/sda7. Prior > [ 18.326962] systemd-fsck[682]: /dev/sda2: clean, 47/1 > [ 18.338070] ath9k_htc 1-8.1:1.0: ath9k_htc: H > [ 18.377485] systemd-fsck[701]: /dev/sda6: cle > [ 18.558816] EXT4-fs (sda6): mounted fi > [ 18.558833] SELinux: initialized (dev sda6, ty > [ 18.560492] > [ 18.575921] SELinux: initia > [ 18.589445] ath9k_htc > [ 18.589451] ath9k_htc 1-8.1:1.0: ath9k_htc: > [ 18.590073] Failed to initiali > [ 18.599085] ath9k_htc: probe of 1-8.1:1.0 failed > [ 18.599632] usbcore: registered new interface driver ath9k_ht > [ 21.366559] bluetoothd[765]: bluetoothd[765]: Bluetooth deamo > [ 21.366592] bluetoothd[76 > [ 21.553168] ntpd[766]: ntpd > [ 21.553927] ntpd[766]: proto: > [ 21.564744] ntpd[766]: 0.0.0.0 c01d 0d kern kernel time sync enabled > [ 21 > [ 21.57 > [ 21.653148] ntpd[766]: Listen and drop on 1 v6wildcard :: UDP > [ 21.658064] ntp > [ 21.658873] avahi-daemon[772 > [ 21.659457] ntpd[766]: Listen n > [ 21.659808] ntpd[766]: peers refreshed > [ 21.660250] > [ 21.666298] avahi-daemon[772]: Successfully dropped root > [ 21 > [ 21.707825] ntpd[766]: Deferring DNS for 0.fedora.pool.nt > [ > [ 21.741273] ntpd[766]: Deferring DNS for 2.fedora.pool.ntp.org 1 > [ 2 > [ 21. > [ 21.752223] ntpd[766]: 0.0.0.0 c012 02 freq_set kernel -42.821 > [ 21.752496] ntpd[787]: signal_no_reset: signal 17 had flags 4000000 > [ > [ 21.774202] > [ 21.849974] dbus[784]: avc: netlink poll: error 4 > [ 21.904182] Networ > [ > [ 21.905761] NetworkManager[776]: <info> VPN: loaded org.freedesktop.Networ > [ 21.905977] NetworkManager[776]: <info> VPN: loaded org. > [ 21.911759] bl > [ 21.911927] bluetoothd[765]: Starting SDP server > [ > [ 21.935310] avahi-da > [ 21.935324] avahi-daemon[772]: Successfully dropped remaining capabilities. > [ > [ 21.935345] avahi-daemon[772]: Loading service > [ 21.93 > [ 21.936601] avahi-dae > [ 21.936823] avahi-daemon[772]: Server startup complete. H > [ 21.936944] avahi-da > [ 21.937050] avahi-daemon[772]: Service "dominik" (/services/ssh.servic > [ 22.050 > [ 22.050754] Bluetooth: BNEP filters: protocol multicast > [ 22.212476] Bluetoo > [ > [ 22.212488] Bluetooth: RFCOMM ver 1.11 > [ > [ 22.413165] ADDRCONF(NETDEV_UP): e > [ 23.159623] nf_conntrack version 0.5.0 (16384 buckets, 65536 > [ 23.191294] ip6_ > [ > [ 26.143664] powernow-k8: Found 1 AMD Athlon(tm) > [ 26.143731] p > [ 26.143734] powernow-k8: fid 0x2 (1000 MHz), vid 0x12 > [ 29.113595] [ > [ 29.123802] [drm] nouveau 0000:05:00.0: 0xC24 > [ 29.173822] [drm] nouveau 0000:05:00.0: Setting dpms mode 0 on > [ 29.173827] [drm] > [ 3 > [ 31.416239] SELinux: initialized (de > [ 31.656078] > [ 57.226655] SELinux: initialized (dev sda5, type fuse lsmod Module Size Used by fuse 62381 5 cpufreq_ondemand 5934 1 powernow_k8 21534 0 mperf 1449 1 powernow_k8 8021q 17170 0 garp 6075 1 8021q stp 1927 1 garp llc 4738 2 garp,stp ip6t_REJECT 3992 2 nf_conntrack_ipv6 7730 1 nf_defrag_ipv6 9083 1 nf_conntrack_ipv6 ip6table_filter 1655 1 ip6_tables 16908 1 ip6table_filter nf_conntrack_ipv4 8358 1 nf_defrag_ipv4 1513 1 nf_conntrack_ipv4 xt_state 1306 2 nf_conntrack 67613 3 nf_conntrack_ipv6,nf_conntrack_ipv4,xt_state rfcomm 59280 4 bnep 14635 2 usblp 10758 0 ath9k_htc 50165 0 mac80211 247272 1 ath9k_htc ath9k_common 2496 1 ath9k_htc ath9k_hw 271261 2 ath9k_htc,ath9k_common ath 15098 2 ath9k_htc,ath9k_hw gspca_spca561 9008 0 gspca_main 18960 1 gspca_spca561 cfg80211 148145 3 ath9k_htc,mac80211,ath videodev 72120 1 gspca_main snd_intel8x0 28261 2 snd_ac97_codec 115725 1 snd_intel8x0 ac97_bus 1314 1 snd_ac97_codec media 11611 1 videodev v4l2_compat_ioctl32 7377 1 videodev snd_seq 52322 0 ppdev 7508 0 snd_seq_device 5941 1 snd_seq snd_pcm 78520 2 snd_intel8x0,snd_ac97_codec edac_core 40186 0 k8temp 3735 0 edac_mce_amd 13234 0 btusb 14828 2 bluetooth 191587 23 rfcomm,bnep,btusb parport_pc 21184 0 parport 32342 2 ppdev,parport_pc rfkill 16436 4 cfg80211,bluetooth snd_timer 19372 2 snd_seq,snd_pcm snd 63380 10 snd_intel8x0,snd_ac97_codec,snd_seq,snd_seq_device,snd_pcm,snd_timer soundcore 6267 1 snd snd_page_alloc 7343 2 snd_intel8x0,snd_pcm i2c_nforce2 5918 0 forcedeth 47520 0 ipv6 284698 19 ip6t_REJECT,nf_conntrack_ipv6,nf_defrag_ipv6 usb_storage 46091 0 uas 7775 0 firewire_ohci 26085 0 pata_acpi 3419 0 ata_generic 3635 0 firewire_core 49191 1 firewire_ohci crc_itu_t 1547 1 firewire_core pata_amd 11200 0 sata_nv 20272 5 nouveau 545674 3 ttm 55273 1 nouveau drm_kms_helper 26474 1 nouveau drm 193955 5 nouveau,ttm,drm_kms_helper i2c_algo_bit 5006 1 nouveau i2c_core 25712 6 videodev,i2c_nforce2,nouveau,drm_kms_helper,drm,i2c_algo_bit mxm_wmi 1727 1 nouveau wmi 9033 1 mxm_wmi video 12340 1 nouveau lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 002 Device 006: ID 04f9:01ce Brother Industries, Ltd DCP-135C Bus 001 Device 005: ID 0cf3:1006 Atheros Communications, Inc. TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271] Bus 001 Device 006: ID 046d:0928 Logitech, Inc. QuickCam Express Bus 001 Device 007: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) Bus 001 Device 008: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Troche się zdziwiłem, że aż tyle błędów, wykazał dmesg, że się w terminalu wszystko nie zmieściło. Chyba faktycznie przejście na nowy system to sensowne rozwiązanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 18, 2011 Zgłoszenie Share Napisano Listopad 18, 2011 Chcesz powiedzieć, że polecenie dmesg zwróciło Ci coś takiego jak wyżej? o_O Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 18, 2011 Zgłoszenie Share Napisano Listopad 18, 2011 Tak, jeszcze dłuższe i się nie zmieściło w terminalu ^ ^" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Niektóre rzeczy wygladaja jakbys kleil do terminala linijki z dmesg [root@dominik ~]# [ 16.694104] forcedeth: Reverse Eng -bash: [: missing `]' [root@dominik ~]# [ 16.694321] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23 -bash: [: missing `]' Tak czy inaczej zupelnie bezuzyteczne, tym bardziej ze lsusb pokazuje, ze karta jest widziana w systemie. Czy karta dzialala wczesnei w F15 i nagle przestala czy nie uruchomiles nigdy? Skoro trzymasz sie F15 to sprawdz czy nie ma zgloszonych jakichs bledów na bugzilli. Mam identyczny model i dzialal bez zarzutu. Co do historii yuma, to raczej chodzilo o sprawdzenie /ver/log/yum.log (tylko nie wklejaj tutaj zawartosci calego pliku, a na przyszlosc jesli wklejasz dlugi tekst to korzystaj ze znacznika codebox a nie code. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Rozumiem, że radzicie przejście na 16? Tak, karta działała wcześniej na F15, po zaktualizowaniu pakietów przestała działać. Zedytuję post i dam bugzille. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Zedytuje post i dam bugzille.Nie spiesz sie tak. Najpierw sprawdz log yuma i zobacz czy byla aktualizacja sterowników? Aktualizacji jadra raczej sie nie spodziewam, ale kto wie kiedy robiles poprzednia aktualizacje. Zanim cokolwiek zglosisz upewnij sie, ze nie widzisz karty w zakladce "bezprzewodowe" w nm-connection-editor, sprawdz czy mozesz dodac polaczenia itd. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Karty generalnie nie widać, widać tylko router, ale u góry na pasku w połączeniu z internetem jest tylko "przewodowe - brak połączeń", gdzie przed aktualizacją było "bezprzewodowe - [mój router]". Dodawać urządzenia w tej zakładce mogę. Co do aktualizacji: sam zainstalowałem rpm ze sterownikami ogólnymi, ale to nic nie pomogło, ale sprawdzę czy była jeszcze jedna aktualizacja, przed moją. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Dodawać urządzenia w tej zakładce mogę.To spróbuj dodać na nowo. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Ale dodaję router, a nie kartę sieciową. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Ale dodaję router, a nie kartę sieciową. Możesz określić z czym masz problem? Napisz od początku podając szczegóły konfiguracji swojej sieci. Wbrew temu co piszesz kartę widać Bus 001 Device 005: ID 0cf3:1006 Atheros Communications, Inc. TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271] Może ktoś inny zrozumie z czym masz problem, bo ja wymiękam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 19, 2011 Zgłoszenie Share Napisano Listopad 19, 2011 Gdy jestem na Windowsie lampka na karcie mruga, widać, że działa, mam internet. Gdy miałem niezaktualizowane pakiety na F15 sprawa wyglądała identycznie. Teraz, po zaktualizowaniu system jakby.. nie dopuszcza karty. Jest zainstalowana, bo to by było nielogiczne, gdyby podczas aktualizacji sterowniki zostały wywalone, ale to wygląda tak, jakby karta została blokowana, a dioda NIE MIGA. Jeśli mówiąc o konfiguracji swojej sieci masz na myśli w jaki sposób jest co podłączone to mam 1 komputer podłączony przez kabel ethernet do routera w drugim pokoju, oraz mój komputer podłączony przez kartę sieciową usb. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 20, 2011 Zgłoszenie Share Napisano Listopad 20, 2011 Czyli problem jest z karta, wiec zostawmy router w spokoju. Napisz jeszcze raz po kolei i nie pisz o innych urzadzeniach, które sa w tej chwili bez znaczenia. Czy po wlaczeniu nm-connection-editor, przejsciu na zakladke "bezprzewodowe" i wcisnieciu "Dodaj" masz mozliwosc dodania polaczenia? Powinienes miec. Klikasz, otwiera sie kolejne okienko. Zakladka "Bezprzewodowe": wpisz SSID swojej sieci bezprzewodowej i zaznacz checkbox "Laczenie automatyczne" a reszte zostaw tak jak jest, przejdz na "Zabezpieczenia", wybierz zabezpieczenia jakie sa ustawione w Twojej sieci, podaj haslo i wg mnie powinno dzialac. [EDIT] Oczywiscie karta powinna byc wetknieta do gniazdka Po wykonaniu tych czynnosci pokaz co widac po wykonaniu jako root polecen iwconfig, ifconfig Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Geto Napisano Listopad 20, 2011 Zgłoszenie Share Napisano Listopad 20, 2011 Zrobiłem co poleciłeś i nadal nie działa. [dominik@dominik ~]$ iwconfig lo no wireless extensions. eth0 no wireless extensions. [dominik@dominik ~]$ ifconfig eth0 Link encap:Ethernet HWaddr 00:0F:EA:89:0A:8C UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 Interrupt:23 Base address:0xe000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:160 errors:0 dropped:0 overruns:0 frame:0 TX packets:160 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:11980 (11.6 KiB) TX bytes:11980 (11.6 KiB) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 20, 2011 Zgłoszenie Share Napisano Listopad 20, 2011 A to jeszcze pytanie masz zainstalowany zd1211-firmware? U mnie chyba dopiero po zainstalowaniu tego karta ruszyła. Jako root yum install zd1211-firmware Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
