portals Napisano Wrzesień 28, 2011 Zgłoszenie Share Napisano Wrzesień 28, 2011 Witam Mam znowu problem system bardzo czesto zawiesza sie. Nie jest to zawieszenie KDE bo na klawiaturze nacisniecie Caps Lock nie powoduje zapalenie sie kontroli a ctrl+f1,f2 nic nie daje . lspci 00:00.0 Host bridge: Advanced Micro Devices [AMD] RS880 Host Bridge 00:02.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (ext gfx port 0) 00:0a.0 PCI bridge: Advanced Micro Devices [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5) 00:11.0 SATA controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40) 00:12.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:12.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:13.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:13.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 41) 00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) (rev 40) 00:14.3 ISA bridge: ATI Technologies Inc SB7x0/SB8x0/SB9x0 LPC host controller (rev 40) 00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (rev 40) 00:14.5 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI2 Controller 00:15.0 PCI bridge: ATI Technologies Inc SB700/SB800 PCI to PCI bridge (PCIE port 0) 00:16.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller 00:16.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller 00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration 00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control 00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control 01:00.0 VGA compatible controller: ATI Technologies Inc Cayman PRO [AMD Radeon 6900 Series] 01:00.1 Audio device: ATI Technologies Inc Device aa80 02:00.0 SATA controller: JMicron Technology Corp. JMB361 AHCI/IDE (rev 02) 02:00.1 IDE interface: JMicron Technology Corp. JMB361 AHCI/IDE (rev 02) 03:07.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0) 04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06) Problem sprzetowy odpada bo na windowsie dziala ok. Jak trzeba cos podac to podam, ja nie mam juz pomyslów. System aktualny [piotrek@piotrek-pc ~]$ uname -r 2.6.40.4-5.fc15.x86_64 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
8xxa_FC Napisano Wrzesień 28, 2011 Zgłoszenie Share Napisano Wrzesień 28, 2011 zamiast ze startu wklejać lspci proponuję obejrzeć (OBEJRZEĆ - nie wklejać!) logi które są w /var/log - czasami da się coś z nich wyczytać.. ew. wkleić FRAGMENTY tych z nich, które twoim zdaniem mają związek z występowaniem problemu. z dodatkowych informacji wynika, że jednym z efektów jest blokowanie klawiatury - a ta jest na ps2 czy usb? tylko nie doklejaj lsusb... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
portals Napisano Wrzesień 28, 2011 Autor Zgłoszenie Share Napisano Wrzesień 28, 2011 ps2 Jak przegladalem tematy o zawieszeniu prosba o lspci zawsze padala dlatego dodalem. EDIT: Moze to cos waznego(ale tez chyba nie): Sep 28 18:23:33 piotrek-pc kernel: [ 0.000000] Your BIOS doesn't leave a aperture memory hole Sep 28 18:23:33 piotrek-pc kernel: [ 0.000000] Please enable the IOMMU option in the BIOS setup Sep 28 18:23:33 piotrek-pc kernel: [ 0.000000] This costs you 64 MB of RAM Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 28, 2011 Zgłoszenie Share Napisano Wrzesień 28, 2011 Drugi problem jest taki ze system nie pozwala wysunac plyta z napedu po jego uzyciu. Nie dziala eject anie przycisk na napedzie.Zasada ogólna na forum (chyba kazdym nie tylko tu): jeden problem - jeden temat. Ale skoro zaczalem pisac to o ile pamietam eject nie zadziala jesli plyta jest w uzyciu tzn. jest zamontowana (automount?) a w szczególnosci jesli jest otwarty jakis katalog z plyty w napedzie. "Otwarty" oznacza zarówno w jakimis np. graficznym menedzerze plików jak i w terminalu po wykonaniu polecenia cd /media/<plyta>/<katalog> Prosze jednak nie kontynuowac tutaj tych rozwazan. @portals zalóz nowy watek. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
portals Napisano Październik 1, 2011 Autor Zgłoszenie Share Napisano Październik 1, 2011 Sprawa z napedem nie jest wazna(i usunalem wszystko co jej dotyczy ). Wazna jest sprawa z tym zawieszaniem bo niestety nie moge korzystac normalnie z systemu. Ma ktos jeszcze jakies pomysly? Uzywam zamknietych sterowników ATI. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Październik 1, 2011 Zgłoszenie Share Napisano Październik 1, 2011 Jeśli używasz zamkniętych sterowników to nawet nikt na bugzilli Ci nie pomoże, bo Twój kernel jest oznaczony jako tainted. Spróbuj chwilowo przejść na otwarty sterownik i zobacz czy system nadal się zawiesza. W ogóle to jest najnowszy catalyst, bo z tego co pamiętam to repo rpmfusion ostatnio nie wytrzymywało tempa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
portals Napisano Październik 1, 2011 Autor Zgłoszenie Share Napisano Październik 1, 2011 Sprawdzę ale na otwartych sterowniach po kilku minutach robią się artefakty Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Październik 1, 2011 Zgłoszenie Share Napisano Październik 1, 2011 Wyłącz akcelerację 3D, jeśli jest włączona, lub odwrotnie włącz, jeśli wyłączona. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
