ALvarez Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 Witam. Nie moge uruchomic skalowania czestotliwosci CPU, caly czas pracuje z f=10000MHz Z Biosu: SYSTEM CPU Intel Core 2 duo Current Clock Speed 2.00 GHZ Minimum " 1.00 GHz Maximum " 2.00 GHz Dual Core Yes PERFORMANCE Multi Core Support Enabled SpeedStep Enabled Enabled Wszystko ponizej wykonywane z poziomu roota Wynik polecenia: cpupower --cpu all frequency-info cpupower --cpu all frequency-info analyzing CPU 0: driver: acpi-cpufreq CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: 10.0 us. hardware limits: 1000 MHz - 2.00 GHz available frequency steps: 2.00 GHz, 1.67 GHz, 1.33 GHz, 1000 MHz available cpufreq governors: userspace, performance current policy: frequency should be within 1000 MHz and 1000 MHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1000 MHz (asserted by call to hardware). boost state support: Supported: yes Active: no analyzing CPU 1: driver: acpi-cpufreq CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 1 maximum transition latency: 10.0 us. hardware limits: 1000 MHz - 2.00 GHz available frequency steps: 2.00 GHz, 1.67 GHz, 1.33 GHz, 1000 MHz available cpufreq governors: userspace, performance current policy: frequency should be within 1000 MHz and 1000 MHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1000 MHz (asserted by call to hardware). boost state support: Supported: yes Active: no Zawartosc /etc/rc.local touch /var/lock/subsys/local /sbin/modprobe acpi-cpufreq Zawartosc: /sys/devices/system/cpu/cpu0/cpufreq/bios_limit = 1000000 Próba zmiany zawartosci pliku bios_limit: echo 2000000 >/sys/devices/system/cpu/cpu0/cpufreq/bios_limit wynik: bash: /sys/devices/system/cpu/cpu0/cpufreq/bios_limit: Brak dostepu Plik bios_limit, prawa dla roota - rw Co tu jest zle, co robie zle??? Jakakolwiek próba zapisu do pliku /sys/devices/system/cpu/cpu0/cpufreq/bios_limit skutkuje komunikatem "Brak dostepu" lub "Blad wejscia/wyjscia" Jakies sugestie. Pozdrawiam. ALvarez Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 wynik: bash: /sys/devices/system/cpu/cpu0/cpufreq/bios_limit: Brak dostepu I bardzo dobrze, ze zablokowali mozliwosc recznej edycji. Masz polityke ondemand, która poprawnie skaluje i to powinno Ci wystarczyc. Nie ma najmniejszego powodu, aby wyreczac w skalowaniu kernel systemu czy cos jeszcze nizej. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 6, 2012 Autor Zgłoszenie Share Napisano Luty 6, 2012 W pliku /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor mam performance jezeli zmienie przez echo na ondemand to po restarcie mam juz performance. Ale chyba czestotliwosc blokuje bios_limit. nie wiem co mam zrobic Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 Ale jaki jest problem? Założyłeś już drugi wątek, we wcześniejszym nawet nikt nie odpowiadał, bo nikt nie rozumiał o co Ci właściwie chodzi. Co z tego, że przywraca performance, jeśli aktualna częstotliwość wynosi 1000MHz (tak napisałeś). Jak jest minimalna to ok. Może po prostu cpupower działa inaczej niż cpufrequtils. Daj sobie z tym spokój. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 Workaround: dopisz do /etc/rc.d./rc.local polecenie, które bedzie wpisywalo "ondemand" do pliku przy kazdym starcie. Swoja droga dziwne, bo ja mam [root@F16 ~]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor ondemand bez zadnego cudowania i czestotliwosc faktycznie podwyzsza sie lub maleje w miare potrzeby (dwurdzeniowy Athlon BE-2350). [EDIT] No i u mnie tez zazwyczaj jest w okolicach 1000MHz, ale w razie potrzeby "rozpedza" sie do 2100. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 6, 2012 Autor Zgłoszenie Share Napisano Luty 6, 2012 ale cały czas pracuje z częstotliwością 1 GHz a powinna się zmieniać do 2 GHz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 Nawet jak uruchamiasz kilka programów naraz? U mnie normalnie też jest 1000, ale jak uruchomiłem teraz digikam, firefoks + wirtualna maszynę na VBox to skoczyło na maksa # ------------ przed [root@F16 ~]# cpupower --cpu all frequency-info analyzing CPU 0: driver: powernow-k8 [...] current policy: frequency should be within 1000 MHz and 2.10 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 1000 MHz (asserted by call to hardware) [...] analyzing CPU 1: driver: powernow-k8 [...] current CPU frequency is 1000 MHz (asserted by call to hardware). [...] # ------------ w trakcie uruchamiania [root@F16 ~]# cpupower --cpu all frequency-info analyzing CPU 0: [...] current CPU frequency is 2.10 GHz (asserted by call to hardware). [...] analyzing CPU 1: [...] current CPU frequency is 2.10 GHz (asserted by call to hardware). [...] no i po uruchomieniu znowu spada do 1000. Zresztą u mnie to ładnie widać na desktopie w conky. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
FC4B Napisano Luty 6, 2012 Zgłoszenie Share Napisano Luty 6, 2012 Nie wiem po co się tak upierasz ze zmianą tego. Procesor który masz, w razie potrzeby będzie pracował na maksimum Hz, ale jeśli system nie jest obciążony, a procesor się nudzi to wg tej technologii pracuje na mniejszej częstotliwości, dzięki czemu zużywa mniej energii i mniej się nagrzewa. Ale jeśli naprawde tego chcesz i nie boisz się, że komputer Ci wybuchnie to polecam http://www.pantz.org/software/cpufreq/usingcpufreqonlinux.html Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 6, 2012 Autor Zgłoszenie Share Napisano Luty 6, 2012 Wlasnie wykonalem reset kompa cpupower --cpu all frequency-info pokazuje ondemand current policy: frequency should be within 1000 MHz and 1000 MHz. Na drugim kompie plik bios-limit pokazuje fmax i wszystko jest ok. Dlaczego bios pokazuje 2GHz a bios-limit 1GHz do FC4B pracuje na f min niezaleznie od obciazenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 7, 2012 Autor Zgłoszenie Share Napisano Luty 7, 2012 witam. Będę upierdliwy. Wykonałem wszystko wg FC4B - http://www.pantz.org...reqonlinux.html i w dalszym ciągu bez efektu. WalDo jaką masz f w pliku /sys/devices/system/cpu/cpu0/cpufreq/bios_limit?? Na drugim kompie plik bios-limit pokazuje fmax i wszystko działa tak jak to wyżej pokazał WalDo. Porównałem plik config, są podobne, moduły wczytane odpowiednie, różnica tylko w bios_limit 1000000 zamiast 2000000. Nic z tego nie rozumiem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 7, 2012 Zgłoszenie Share Napisano Luty 7, 2012 Jak wrócę do domu to sprawdzę i napiszę, a na razie to tylko pytanie czy czytałeś sobie tutaj → http://docs.fedoraproject.org/en-US/Fedora/14/html/Power_Management_Guide/cpufreq_governors.html Może tam znajdziesz jakieś wskazówki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 7, 2012 Autor Zgłoszenie Share Napisano Luty 7, 2012 Własnie czytam od f15 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 7, 2012 Zgłoszenie Share Napisano Luty 7, 2012 WalDo jaka masz f w pliku /sys/devices/system/cpu/cpu0/cpufreq/bios_limit??Maksimum tego co fabryka dala 2100000. [EDIT] A tak jeszcze glupio moze zapytam a propos bios_limit: zagladales do BIOS-u? Moze tam masz po prostu "limit"? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 7, 2012 Autor Zgłoszenie Share Napisano Luty 7, 2012 Wszystkie znaki na niebie i ziemi wskazują, że u mnie powinno być 2000000 a nie 1000000. Nie wiem ale nie widzę jakichś różnić między tym co mam a tym co jest opisane w Fedora 15 Power Management Guide Chyba poczekam aż ktoś mądrzejszy to rozgryzie, systemu reinstalował nie będę. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ALvarez Napisano Luty 7, 2012 Autor Zgłoszenie Share Napisano Luty 7, 2012 Tak, zaglądałem przed rozpoczęciem tematu i teraz sprawdzałem jeszcze raz. Jest tak jak napisałem na początku. Żadnego limity nie widzę. Jutro sprawdzę jeszcze kilka pomysłów. Fedora 15 Power Management Guide jest ciekawy, z moim angielskim trochę się zejdzie. Na dzisiaj dziękuję Pozdrawiam. ALvarez Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
