Instalacja Sterownika Dla Karty Sieciowej 1G En 9235Tx
Janusz Zaba
Witam
Zakupiłem ostatnio do firmy karte sieciowa 1G en-9235tx i nie moge do niej zainstalowac sterowników.
Sterowniki sa do sciagniecia ze strony:
http://www.edimax.pl/pl/support_detail.php?pd_id=300&pl1_id=2&pl2_id=9#01
Mam zainstalowana fedore 15 kernel 2.6.43.8-1.fc15.i686
Czy ktos mogl by sprobowac w domu zainstalowac te sterowniki i sprawdzic czy to sie wogula da zrobic :)
U mnie wyskakuja takie bledy i nie wiem co mam dalej zrobic :)
[root@localhost a]# make clean modules
make -C src/ clean
make[1]: Entering directory `/home/a/src'
rm -rf *.o *.ko *~ core* .dep* .*.d .*.cmd *.mod.c *.a *.s .*.flags .tmp_versions Module.symvers Modules.symvers rset modules.order
make[1]: Leaving directory `/home/a/src'
make -C src/ modules
make -C /lib/modules/2.6.43.8-1.fc15.i686/build SUBDIRS=/home/a/src modules
make[2]: Entering directory `/usr/src/kernels/2.6.43.8-1.fc15.i686'
CC [M] /home/a/src/r8169_n.o
/home/a/src/r8169_n.c:1112:2: error: unknown field ‘get_rx_csum’ specified in initializer
/home/a/src/r8169_n.c:1112:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1112:2: warning: (near initialization for ‘rtl8169_ethtool_ops.nway_reset’) [enabled by default]
/home/a/src/r8169_n.c:1113:2: error: unknown field ‘set_rx_csum’ specified in initializer
/home/a/src/r8169_n.c:1113:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1113:2: warning: (near initialization for ‘rtl8169_ethtool_ops.get_link’) [enabled by default]
/home/a/src/r8169_n.c:1114:2: error: unknown field ‘get_tx_csum’ specified in initializer
/home/a/src/r8169_n.c:1114:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1114:2: warning: (near initialization for ‘rtl8169_ethtool_ops.get_eeprom_len’) [enabled by default]
/home/a/src/r8169_n.c:1115:2: error: unknown field ‘set_tx_csum’ specified in initializer
/home/a/src/r8169_n.c:1115:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1115:2: warning: (near initialization for ‘rtl8169_ethtool_ops.get_eeprom’) [enabled by default]
/home/a/src/r8169_n.c:1116:2: error: unknown field ‘get_sg’ specified in initializer
/home/a/src/r8169_n.c:1116:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1116:2: warning: (near initialization for ‘rtl8169_ethtool_ops.set_eeprom’) [enabled by default]
/home/a/src/r8169_n.c:1117:2: error: unknown field ‘set_sg’ specified in initializer
/home/a/src/r8169_n.c:1117:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1117:2: warning: (near initialization for ‘rtl8169_ethtool_ops.get_coalesce’) [enabled by default]
/home/a/src/r8169_n.c:1119:2: error: unknown field ‘get_tso’ specified in initializer
/home/a/src/r8169_n.c:1119:14: error: ‘ethtool_op_get_tso’ undeclared here (not in a function)
/home/a/src/r8169_n.c:1120:2: error: unknown field ‘set_tso’ specified in initializer
/home/a/src/r8169_n.c:1120:14: error: ‘ethtool_op_set_tso’ undeclared here (not in a function)
/home/a/src/r8169_n.c:1126:2: error: unknown field ‘get_stats_count’ specified in initializer
/home/a/src/r8169_n.c:1126:2: warning: initialization from incompatible pointer type [enabled by default]
/home/a/src/r8169_n.c:1126:2: warning: (near initialization for ‘rtl8169_ethtool_ops.set_phys_id’) [enabled by default]
/home/a/src/r8169_n.c: In function ‘rtl8169_netpoll’:
/home/a/src/r8169_n.c:1498:2: error: implicit declaration of function ‘disable_irq’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c:1504:2: error: implicit declaration of function ‘enable_irq’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c: In function ‘rtl8169_init_one’:
/home/a/src/r8169_n.c:2604:5: error: ‘struct net_device’ has no member named ‘do_ioctl’
/home/a/src/r8169_n.c:2614:5: error: ‘struct net_device’ has no member named ‘open’
/home/a/src/r8169_n.c:2615:5: error: ‘struct net_device’ has no member named ‘hard_start_xmit’
/home/a/src/r8169_n.c:2616:5: error: ‘struct net_device’ has no member named ‘get_stats’
/home/a/src/r8169_n.c:2618:5: error: ‘struct net_device’ has no member named ‘stop’
/home/a/src/r8169_n.c:2619:5: error: ‘struct net_device’ has no member named ‘tx_timeout’
/home/a/src/r8169_n.c:2620:5: error: ‘struct net_device’ has no member named ‘set_multicast_list’
/home/a/src/r8169_n.c:2624:5: error: ‘struct net_device’ has no member named ‘change_mtu’
/home/a/src/r8169_n.c:2625:5: error: ‘struct net_device’ has no member named ‘set_mac_address’
/home/a/src/r8169_n.c:2640:5: error: ‘struct net_device’ has no member named ‘poll_controller’
/home/a/src/r8169_n.c: In function ‘rtl8169_open’:
/home/a/src/r8169_n.c:2728:2: error: implicit declaration of function ‘request_irq’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c:2728:52: error: ‘IRQF_SHARED’ undeclared (first use in this function)
/home/a/src/r8169_n.c:2728:52: note: each undeclared identifier is reported only once for each function it appears in
/home/a/src/r8169_n.c:2781:2: error: implicit declaration of function ‘free_irq’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c: In function ‘rtl8169_xmit_frags’:
/home/a/src/r8169_n.c:3232:3: error: incompatible type for argument 1 of ‘page_address’
include/linux/mm.h:755:7: note: expected ‘const struct page *’ but argument is of type ‘struct <anonymous>’
/home/a/src/r8169_n.c: In function ‘rtl8169_interrupt’:
/home/a/src/r8169_n.c:3658:4: error: implicit declaration of function ‘netif_rx_schedule_prep’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c:3659:5: error: implicit declaration of function ‘__netif_rx_schedule’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c:3690:9: error: expected expression before ‘)’ token
/home/a/src/r8169_n.c:3690:2: warning: ‘return’ with a value, in function returning void [enabled by default]
/home/a/src/r8169_n.c: In function ‘rtl8169_poll’:
/home/a/src/r8169_n.c:3711:3: error: implicit declaration of function ‘netif_rx_complete’ [-Werror=implicit-function-declaration]
/home/a/src/r8169_n.c: In function ‘rtl8169_down’:
/home/a/src/r8169_n.c:3731:15: warning: unused variable ‘poll_locked’ [-Wunused-variable]
/home/a/src/r8169_n.c: In function ‘rtl8169_set_rx_mode’:
/home/a/src/r8169_n.c:3836:17: error: ‘struct net_device’ has no member named ‘mc_count’
/home/a/src/r8169_n.c:3847:27: error: ‘struct net_device’ has no member named ‘mc_list’
/home/a/src/r8169_n.c:3847:55: error: ‘struct net_device’ has no member named ‘mc_count’
/home/a/src/r8169_n.c:3848:28: error: dereferencing pointer to incomplete type
/home/a/src/r8169_n.c:3849:17: error: dereferencing pointer to incomplete type
/home/a/src/r8169_n.c: At top level:
/home/a/src/r8169_n.c:2330:1: warning: ‘rtl8169_phy_power_down’ defined but not used [-Wunused-function]
cc1: some warnings being treated as errors
make[3]: *** [/home/a/src/r8169_n.o] Error 1
make[2]: *** [_module_/home/a/src] Error 2
make[2]: Leaving directory `/usr/src/kernels/2.6.43.8-1.fc15.i686'
make[1]: *** [modules] Error 2
make: *** [modules] Error 2
[root@localhost a]#
Janusz Zaba
No wiem ale mi tak karta dziala z predkoscia 100Mb/s tylko nie chce dzialac z predkoscia 1000Mb/s.
root@localhost janusz]# ethtool p1p1
Settings for p1p1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
[root@localhost janusz]#
Jak widac karta dziala z predkoscia 100Mb/s ale ja chce miec 1000Mb/s :)
Tez mam karte oparta na tym chipsecie i u mnie tryb 1000baseT/Full jest obslugiwany, wiec to raczej nie jest wina sterownika, raczej sprzetu. Ewentualnie jest taka mozliwosc, ze masz bardzo stare jadro i dopiero w kolejnych wersjach zostaly wprowadzone zmiany w sterowniku (aktualnie stabilna wersja kernela to 3.5, a Ty masz 2.6.43). Zaktualizuj Fedore do najnowszej wersji. Mozesz nawet sciagnac wersje Live odpalic z USB i tam sprawdzic jak system widzi Twoja karte.
Moze z karta cos jest zle?
Ja mam wprawdzie nieco inna, ale tez na r8169 na 64-bitowej F17 mam 1Gbps
[root@F17 ~]# lshw -C network
 *-network
      description: Ethernet interface
      product: RTL8111/8168B PCI Express Gigabit Ethernet controller
      vendor: Realtek Semiconductor Co., Ltd.
      physical id: 0
      bus info: pci@0000:02:00.0
      logical name: em1
      version: 01
      serial: aa:bb:cc:dd:ee:ff
      capacity: 1Gbit/s
      width: 64 bits
      clock: 33MHz
      capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
      configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=N/A ip=<tu moje ip> latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
      resources: irq:42 ioport:dc00(size=256) memory:fddff000-fddfffff memory:fdc00000-fdc1ffff
i ethtool pokazuje m.in.
                        1000baseT/Half 1000baseT/Full
