[F19] Problem Z Budowaniem Modułu Nvidii Przez Akmods
Amos
Mam zainstalowany pakiet akmod-nvidia-304xx.
Niestety dla kernela 3.11.1 nie da się zbudować odpowiedniego modułu.
Oto kawałek logów akmods:
19 wrz 15:32:09 akmods: Building RPM using the command '/bin/akmodsbuild --target i686 --kernels 3.11.1-200.fc19.i686.PAE /usr/src/akmods/nvidia-304xx-kmod.latest'
                 from include/linux/types.h:5,
                 from include/uapi/linux/capability.h:16,
                 from include/linux/capability.h:15,
                 from include/linux/sched.h:13,
                 from include/linux/utsname.h:5,
                 from /tmp/akmodsbuild.hrnajPlZ/BUILD/nvidia-304xx-kmod-304.88/_kmod_build_3.11.1-200.fc19.i686.PAE/kernel/nv-linux.h:40,
                 from /tmp/akmodsbuild.hrnajPlZ/BUILD/nvidia-304xx-kmod-304.88/_kmod_build_3.11.1-200.fc19.i686.PAE/kernel/os-mtrr.c:15:
/usr/src/kernels/3.11.1-200.fc19.i686.PAE/arch/x86/include/asm/uaccess_32.h: In function 'copy_from_user':
/usr/src/kernels/3.11.1-200.fc19.i686.PAE/arch/x86/include/asm/uaccess_32.h:208:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
  if (likely(sz == -1 || sz >= n))
include/linux/compiler.h:152:40: note: in definition of macro 'likely'
 # define likely(x) __builtin_expect((x), 1)
  if [ "-pg" = "-pg" ]; then if [ /tmp/akmodsbuild.hrnajPlZ/BUILD/nvidia-304xx-kmod-304.88/_kmod_build_3.11.1-200.fc19.i686.PAE/kernel/os-mtrr.o != "scripts/mod/empty.o" ]; then /usr/src/kernels/3.11.1-200.fc19.i686.PAE/scripts/recordmcount  "/tmp/akmodsbuild.hrnajPlZ/BUILD/nvidia-304xx-kmod-304.88/_kmod_build_3.11.1-200.fc19.i686.PAE/kernel/os-mtrr.o"; fi; fi;
make[2]: *** [_module_/tmp/akmodsbuild.hrnajPlZ/BUILD/nvidia-304xx-kmod-304.88/_kmod_build_3.11.1-200.fc19.i686.PAE/kernel] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [module] Error 2
błąd: Błędny stan wyjścia z /var/tmp/rpm-tmp.JpRKlW (%build)
Da się jakoś zaradzić, czy trzeba czekać na kmod-nvidia w RPM Fusion bądź na nowe jajko?
