Krzak Z Tła W Ekranie Logowania (Fedora 20)
Elll
Mam takie coś w ekranie logowania, tylko po włączeniu komputera. Po wylogowaniu wszystko jest ok. Próbowałam zmienić tło... tło się zmieniło, ale krzak przy uruchamianiu został. Macie na to jakąś radę?
Podaję wszystko, bo niestety nie znam się na tym:
boot.log:
[#[32m OK #[0m] Started dracut initqueue hook.
[#[32m OK #[0m] Found device ST3500418AS.
Mounting /sysroot...
[#[32m OK #[0m] Mounted /sysroot.
[#[32m OK #[0m] Reached target Initrd Root File System.
Starting Reload Configuration from the Real Root...
[#[32m OK #[0m] Started Reload Configuration from the Real Root.
[#[32m OK #[0m] Reached target Initrd File Systems.
[#[32m OK #[0m] Started Show Plymouth Boot Screen.
[#[32m OK #[0m] Reached target Paths.
[#[32m OK #[0m] Reached target Basic System.
[#[32m OK #[0m] Reached target Initrd Default Target.
Welcome to #[0;34mFedora 20 (Heisenbug)#[0m!
[#[32m OK #[0m] Stopped Switch Root.
[#[32m OK #[0m] Stopped target Switch Root.
[#[32m OK #[0m] Stopped target Initrd File Systems.
[#[32m OK #[0m] Stopped target Initrd Root File System.
Starting Collect Read-Ahead Data...
Starting Replay Read-Ahead Data...
[#[32m OK #[0m] Created slice User and Session Slice.
[#[32m OK #[0m] Created slice system-getty.slice.
[#[32m OK #[0m] Reached target Login Prompts.
[#[32m OK #[0m] Reached target Remote File Systems.
[#[32m OK #[0m] Reached target Slices.
[#[32m OK #[0m] Listening on /dev/initctl Compatibility Named Pipe.
[#[32m OK #[0m] Listening on Delayed Shutdown Socket.
Mounting Debug File System...
[#[32m OK #[0m] Set up automount Arbitrary Executable File Formats File System Automount Point.
Mounting Huge Pages File System...
Mounting POSIX Message Queue File System...
Starting Create list of required static device nodes for the current kernel...
[#[32m OK #[0m] Listening on udev Kernel Socket.
[#[32m OK #[0m] Listening on udev Control Socket.
Starting udev Coldplug all Devices...
[#[32m OK #[0m] Listening on LVM2 metadata daemon socket.
[#[32m OK #[0m] Listening on Device-mapper event daemon FIFOs.
Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[#[32m OK #[0m] Reached target Swap.
Mounting Temporary Directory...
[#[32m OK #[0m] Stopped Trigger Flushing of Journal to Persistent Storage.
Stopping Journal Service...
[#[32m OK #[0m] Stopped Journal Service.
Starting Journal Service...
[#[32m OK #[0m] Started Journal Service.
[#[32m OK #[0m] Started Collect Read-Ahead Data.
[#[32m OK #[0m] Started Create list of required static device nodes for the current kernel.
Starting Create static device nodes in /dev...
[#[32m OK #[0m] Started Replay Read-Ahead Data.
Starting Set Up Additional Binary Formats...
Mounting Configuration File System...
Starting Apply Kernel Variables...
Starting File System Check on Root Device...
Mounting Arbitrary Executable File Formats File System...
[#[32m OK #[0m] Mounted Temporary Directory.
[#[32m OK #[0m] Mounted Debug File System.
[#[32m OK #[0m] Mounted Huge Pages File System.
[#[32m OK #[0m] Mounted POSIX Message Queue File System.
[#[32m OK #[0m] Mounted Configuration File System.
[#[32m OK #[0m] Started udev Coldplug all Devices.
Starting udev Wait for Complete Device Initialization...
[#[32m OK #[0m] Started Apply Kernel Variables.
[#[32m OK #[0m] Mounted Arbitrary Executable File Formats File System.
[#[32m OK #[0m] Started Create static device nodes in /dev.
Starting udev Kernel Device Manager...
[#[32m OK #[0m] Started udev Kernel Device Manager.
Starting LVM2 metadata daemon...
[#[32m OK #[0m] Started LVM2 metadata daemon.
[ 4.147462] systemd-fsck[206]: /dev/sda3: czysty, 170866/17285120 plików, 23505441/69119744 bloków
[#[32m OK #[0m] Started File System Check on Root Device.
Starting Remount Root and Kernel File Systems...
[#[32m OK #[0m] Started Set Up Additional Binary Formats.
[#[32m OK #[0m] Started Remount Root and Kernel File Systems.
Starting Configure read-only root support...
Starting Import network configuration from initramfs...
[#[32m OK #[0m] Reached target Local File Systems (Pre).
Starting Load/Save Random Seed...
[#[32m OK #[0m] Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[#[32m OK #[0m] Started Load/Save Random Seed.
[#[32m OK #[0m] Started Import network configuration from initramfs.
[#[32m OK #[0m] Started Configure read-only root support.
[#[32m OK #[0m] Started udev Wait for Complete Device Initialization.
Starting Activation of DM RAID sets...
[#[32m OK #[0m] Reached target Sound Card.
[#[32m OK #[0m] Started Activation of DM RAID sets.
[#[32m OK #[0m] Reached target Local File Systems.
Starting Recreate Volatile Files and Directories...
Starting Tell Plymouth To Write Out Runtime Data...
Starting Trigger Flushing of Journal to Persistent Storage...
Starting Security Auditing Service...
[#[32m OK #[0m] Reached target Encrypted Volumes.
[#[32m OK #[0m] Started Trigger Flushing of Journal to Persistent Storage.
[#[32m OK #[0m] Started Tell Plymouth To Write Out Runtime Data.
[#[32m OK #[0m] Started Recreate Volatile Files and Directories.
[#[32m OK #[0m] Started Security Auditing Service.
Starting Update UTMP about System Reboot/Shutdown...
[#[32m OK #[0m] Started Update UTMP about System Reboot/Shutdown.
[#[32m OK #[0m] Reached target System Initialization.
[#[32m OK #[0m] Reached target Timers.
Starting Manage Sound Card State (restore and store)...
[#[32m OK #[0m] Started Manage Sound Card State (restore and store).
[#[32m OK #[0m] Listening on Open-iSCSI iscsiuio Socket.
[#[32m OK #[0m] Listening on Open-iSCSI iscsid Socket.
[#[32m OK #[0m] Listening on CUPS Printing Service Sockets.
[#[32m OK #[0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[#[32m OK #[0m] Listening on D-Bus System Message Bus Socket.
[#[32m OK #[0m] Reached target Sockets.
Starting LSB: Init script for live image....
Starting firewalld - dynamic firewall daemon...
Starting Permit User Sessions...
Starting Accounts Service...
Starting RealtimeKit Scheduling Policy Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting irqbalance daemon...
[#[32m OK #[0m] Started irqbalance daemon.
Starting System Logging Service...
Starting Hardware RNG Entropy Gatherer Daemon...
[#[32m OK #[0m] Started Hardware RNG Entropy Gatherer Daemon.
Starting Modem Manager...
Starting Machine Check Exception Logging Daemon...
Starting NTP client/server...
Starting Login Service...
Starting D-Bus System Message Bus...
[#[32m OK #[0m] Started D-Bus System Message Bus.
[#[32m OK #[0m] Started LSB: Init script for live image..
[#[32m OK #[0m] Started Permit User Sessions.
Starting Terminate Plymouth Boot Screen...
Starting Command Scheduler...
[#[32m OK #[0m] Started Command Scheduler.
Starting Job spooling tools...
[#[32m OK #[0m] Started Job spooling tools.
Starting Wait for Plymouth Boot Screen to Quit...
Starting SYSV: Late init script for live image....
Xorg.0.log:
http://pastebin.com/hhfMX2yU
Problem leży w samym gdm. W związku z Twoim innym wątkiem na forum podejrzewam, że mogłaś popełnić jakiś błąd przy próbie zamiany domyślnej grafiki. Zanim poproszę Cię o loga gdm, spróbuj ponownie zdefiniować tło. Wybierz plik .jpg, najlepiej w rozdzielczości odpowiadającej Twoim obecnym ustawieniom monitora. Nazwij go tlo.jpg i wrzuć do '/usr/share/backgrounds/'. Następnie z roota:
gdm -s /bin/bash
Pojawi się prompt basha. Wklej:
`dbus-launch | sed "s/^/export /"`
wciśnij enter, oraz:
http://pastebin.com/HB2vds5n
i enter. Zrestartuj system i sprawdź, czy tło wyświetla się prawidłowo. Jeśli tak, przy następnej zmianie wystarczy podmienić tlo.jpg. Jeśli nie, pokaż zawartość /var/log/gdm/:0.log (już po restarcie).
Edit: trzecią linijkę kodu wrzuciłem na pastebin, ponieważ znacznik code nie potrafi sobie z nią poradzić.
(prawdopodobnie dlatego, że nie mam GNOME, a MATE) ...
Nawet na pewno. To co widać w na zdjęciu w #1 to ekran logowania lightdm. Ale możesz się zalogować, uruchomić jakiś emulator terminala i wykonać polecenia podane wyżej przez Sorrora.
Poza tym, jak patrzę na Twoj Xorg.0.log i widoczne tam wpisy typu
[ 22205.801] (II) NOUVEAU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
to mam wrażenie, że robiłeś jakieś kombinacje z nouveau albo próbowałeś (bez powodzenia) zainstalować zamknięte stery Nvidii.
Opisz dokładnie co robiłeś z systemem w zakresie instalacji lub zmiany sterowników grafiki. Jaką masz kartę?
Sprawdź czy masz plik /etc/X11/xorg.conf i jeśli jest, to pokaż tutaj jego zawartość. Możesz też sprawdzić czy w /etc/X11/xorg.conf.d nie ma jakichś plików konfiguracyjnych związanych z grafiką.
[root@localhost elka]# lightdm -s /bin/bash
Unknown option -s
Run 'lightdm --help' to see a full list of available command line options.
Nie było żadnych kombinacji z driverami.
I jeszcze karta:
[root@localhost elka]# lshw -C display
  *-display
       description: VGA compatible controller
       product: G96 [GeForce 9500 GT]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:16 memory:e2000000-e2ffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:c000(size=128) memory:e3000000-e307ffff
xorg.conf nie ma. W xorg.conf.d jest tylko plik 00-keyboard.conf.
Ja mam 8400GS i bez problemów.
Jeśli tak to wygląda na nouveau, to może zainstaluj sobie zamknięte stery od Nvidii? → http://wiki.fedora.pl/wiki/Poradnik#Nvidia
P.S. Myślę, że Sorrorowi bardziej chodziło o wykonanie poleceń dbus-launch oraz tego zamieszczonego na pastebin. Zapewne ze zmianą tlo.jpg na nazwę obrazka w odpowiedniej rozdzielczości. Tak się składa, że Linux nie Windows i trzeba myśleć ;)
Niestety splash z graficznego zmienił się na tekstowy...
Chodzi Ci o to, że informacje o starcie systemu były wcześniej ukryte pod graficznym tłem z ikoną Fedory po środku?
Jeśli tak, to sprawdź czy w parametrach uruchamiania w /boot/grub2/grub.conf masz parametr "rhgb". DO naprawy tego były jakieś magiczne zaklęcia, ale nie pamiętam, bo akurat graficzny start, to pierwsze co wyłączam. Szukaj haseł "graphical boot", "plymouth" albo poczekaj aż ktoś tu coś dopisze.
Tutaj coś? → http://www.if-not-true-then-false.com/2014/fedora-20-nvidia-guide/
