paluch Napisano Czerwiec 18, 2014 Zgłoszenie Share Napisano Czerwiec 18, 2014 (edytowane) Witam, zwracam sie z prosbą o pomoc, mianowicie nie mam dźwięku po instalacji Fedora20, sytem widzi kartę dźwiekową : alsamixer AlsaMixer v1.0.27.2 ─────────────────────────────┐ │ Card: Intel 82801DB-ICH4 F1: Help │ │ Chip: SigmaTel STAC9750,51 F2: System information │ │ View: F3:[Playback] F4: Capture F5: All F6: Select sound card │ │ Item: Master [dB gain: 0,00, 0,00] Esc: Exit F2: System information /proc/asound/cards ───────────────────────┐ → │ │ 0 [I82801DBICH4 ]: ICH4 - Intel 82801DB-ICH4 │ → │ │ Intel 82801DB-ICH4 with STAC9750,51 at irq 5│ → │ │ 1 [Modem ]: ICH-MODEM - Intel 82801DB-ICH4 Modem │ → │ │ Intel 82801DB-ICH4 Modem at irq 5 aplay -l **** List of PLAYBACK Hardware Devices **** card 0: I82801DBICH4 [Intel 82801DB-ICH4], device 0: Intel ICH [Intel 82801DB-ICH4] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: I82801DBICH4 [Intel 82801DB-ICH4], device 4: Intel ICH - IEC958 [Intel 82801DB-ICH4 - IEC958] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: Modem [Intel 82801DB-ICH4 Modem], device 0: Intel ICH - Modem [Intel 82801DB-ICH4 Modem - Modem] Subdevices: 1/1 Subdevice #0: subdevice #0 zastosowalem tez taki manewr : echo options snd-intel8x0 ac97_quirk=inv_eapd > /etc/modprobe.d/alsa.conf sudo -i kernel-sound-alsa -bash: kernel-sound-alsa: nie znaleziono polecenia [root@localhost ~]# cat /proc/asound/{version,cards,devices,hwdep,pcm,seq/clients} Advanced Linux Sound Architecture Driver Version k3.14.7-200.fc20.i686. 0 [I82801DBICH4 ]: ICH4 - Intel 82801DB-ICH4 Intel 82801DB-ICH4 with STAC9750,51 at irq 5 1 [Modem ]: ICH-MODEM - Intel 82801DB-ICH4 Modem Intel 82801DB-ICH4 Modem at irq 5 1: : sequencer 2: [ 0- 4]: digital audio playback 3: [ 0- 3]: digital audio capture 4: [ 0- 2]: digital audio capture 5: [ 0- 1]: digital audio capture 6: [ 0- 0]: digital audio playback 7: [ 0- 0]: digital audio capture 8: [ 0] : control 9: [ 1- 0]: digital audio playback 10: [ 1- 0]: digital audio capture 11: [ 1] : control 33: : timer cat: /proc/asound/hwdep: Nie ma takiego pliku ani katalogu 00-00: Intel ICH : Intel 82801DB-ICH4 : playback 1 : capture 1 00-01: Intel ICH - MIC ADC : Intel 82801DB-ICH4 - MIC ADC : capture 1 00-02: Intel ICH - MIC2 ADC : Intel 82801DB-ICH4 - MIC2 ADC : capture 1 00-03: Intel ICH - ADC2 : Intel 82801DB-ICH4 - ADC2 : capture 1 00-04: Intel ICH - IEC958 : Intel 82801DB-ICH4 - IEC958 : playback 1 01-00: Intel ICH - Modem : Intel 82801DB-ICH4 Modem - Modem : playback 1 : capture 1 Client info cur clients : 1 peak clients : 1 max clients : 192 Client 0 : "System" [Kernel] Port 0 : "Timer" (Rwe-) Port 1 : "Announce" (R-e-) Client 14 : "Midi Through" [Kernel] Port 0 : "Midi Through Port-0" (RWe-) Edytowane Czerwiec 18, 2014 przez WalDo Nie pisz postów pod swoimi własnymi - korzystaj z edycji. Kod wklejamy pomiedzy odpowiednie znaczniki "code" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 18, 2014 Zgłoszenie Share Napisano Czerwiec 18, 2014 Zacząłbym od trywialnego sprawdzenia czy w alsamixer nie masz po prostu wyciszonego któregoś wejścia lub wyjścia. Pomocny może być też wynik polecenia amixer -c 0 scontrols a potem dla każdego urządzenia amixer -c 0 sget 'xxxx' gdzie xxxx zastępujesz przez np. Master, Line itd Sprawdź czy masz w ogóle załadowany moduł lsmod | grep snd 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
paluch Napisano Czerwiec 18, 2014 Autor Zgłoszenie Share Napisano Czerwiec 18, 2014 (edytowane) Zacząłbym od trywialnego sprawdzenia czy w alsamixer nie masz po prostu wyciszonego któregoś wejścia lub wyjścia. Pomocny może być też wynik polecenia amixer -c 0 scontrols a potem dla każdego urządzenia amixer -c 0 sget 'xxxx' gdzie xxxx zastępujesz przez np. Master, Line itd Sprawdź czy masz w ogóle załadowany moduł lsmod | grep snd [root@localhost ~]# cat /proc/asound/cards 0 [i82801DBICH4 ]: ICH4 - Intel 82801DB-ICH4 Intel 82801DB-ICH4 with STAC9750,51 at irq 5 1 [Modem ]: ICH-MODEM - Intel 82801DB-ICH4 Modem Intel 82801DB-ICH4 Modem at irq 5 [root@localhost ~]# autoloader aliases -bash: autoloader: nie znaleziono polecenia [root@localhost ~]# cat /proc/asound/modules 0 snd_intel8x0 1 snd_intel8x0m [root@localhost ~]# amixer -c 0 scontrols Simple mixer control 'Master',0 Simple mixer control 'Master Mono',0 Simple mixer control 'Headphone',0 Simple mixer control '3D Control - Center',0 Simple mixer control '3D Control - Depth',0 Simple mixer control '3D Control - Switch',0 Simple mixer control 'PCM',0 Simple mixer control 'PCM Out Path & Mute',0 Simple mixer control 'Line',0 Simple mixer control 'CD',0 Simple mixer control 'Mic',0 Simple mixer control 'Mic Boost (+20dB)',0 Simple mixer control 'Mic Select',0 Simple mixer control 'Video',0 Simple mixer control 'Phone',0 Simple mixer control 'IEC958',0 Simple mixer control 'IEC958 Playback AC97-SPSA',0 Simple mixer control 'Beep',0 Simple mixer control 'Aux',0 Simple mixer control 'Mono Output Select',0 Simple mixer control 'Capture',0 Simple mixer control 'Mix',0 Simple mixer control 'Mix Mono',0 Simple mixer control 'External Amplifier',0 [root@localhost ~]# amixer -c 0 sget Master Simple mixer control 'Master',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on] [root@localhost ~]# lsmod | grep snd snd_intel8x0 33069 1 snd_intel8x0m 18382 1 snd_ac97_codec 104827 2 snd_intel8x0,snd_intel8x0m ac97_bus 12602 1 snd_ac97_codec snd_seq 54679 0 snd_seq_device 13824 1 snd_seq snd_pcm 83092 3 snd_ac97_codec,snd_intel8x0,snd_intel8x0m snd_timer 23750 2 snd_pcm,snd_seq snd 59277 11 snd_ac97_codec,snd_intel8x0,snd_timer,snd_pcm,snd_seq,snd_seq_device,snd_intel8x0m soundcore 14123 1 snd niby takie cos poustawiane...dodam jeszcze, ze w wersji testowej f20 live, dzwiek normalnie dziala Edytowane Czerwiec 18, 2014 przez WalDo usunięcie zduplikowanych "wklejek" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 18, 2014 Zgłoszenie Share Napisano Czerwiec 18, 2014 (edytowane) Jeszcze raz prośba o stosowanie znaczników - na razie grzeczna, potem będę brutalnie usuwał posty. Po drugie nie musisz wklejać dwa razy tej samej treści Po trzecie wklejanie wyniku amixer -c 0 scontrols nic nie daje - istotne jest wykonanie sget na obiektach pokazanych tym pierwszym poleceniem: 'Master' 'Master Mono' itd. Spróbuj może wersji łatwiejszej. Uruchom alsamixer #bez parametrów i sprawdź czy Pulseaudio nie jest wyciszone.Potem wyjdź i uruchom alsamixer -c 0 Skorzystaj z kursorów - część kontrolek może być (i zapewne jest) ukryta poza ekranem. Edytowane Czerwiec 18, 2014 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
paluch Napisano Czerwiec 18, 2014 Autor Zgłoszenie Share Napisano Czerwiec 18, 2014 jezeli chodzi o # alsamixer to wszystko mam dobrze ustawione, mialem juz doswiadczenie w ustawianiu np. w Puppy Linux, a Pulseaudio usunalem poniewaz nie widzial w ogole karty dzwiekowej, wiec po Panskiej uwadze zainstalowalem od nowa Pulseaudio i jest to [paluch@localhost ~]$ pulseaudio W: [pulseaudio] core-util.c: Failed to open configuration file '/home/paluch/.config/pulse//daemon.conf': Brak dostępu W: [pulseaudio] daemon-conf.c: Otwarcie pliku konfiguracji się nie powiodło: Brak dostępu [root@localhost ~]# pulseaudio W: [pulseaudio] main.c: Ten program nie powinien być uruchamiany jako root (chyba, że podano --system). E: [pulseaudio] pid.c: Daemon already running. E: [pulseaudio] main.c: pa_pid_file_create() się nie powiodło. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 18, 2014 Zgłoszenie Share Napisano Czerwiec 18, 2014 alsamixer oraz alsamixer -c 0 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Czerwiec 18, 2014 Zgłoszenie Share Napisano Czerwiec 18, 2014 Zobacz może bardziej szczegłółowo co ci powie pulseaudio: pulseaudio -vvv Z doświadczenia wiem, że mając działające pulseaudio czasami wystarczyć pobawić się Pavucontrol -> zakładka konfiguracja. Pulse może wybierać domyślnie złą kartę np. w moim wypadku ustawił wyjście HDMI z karty graficznej. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
paluch Napisano Czerwiec 19, 2014 Autor Zgłoszenie Share Napisano Czerwiec 19, 2014 Zobacz może bardziej szczegłółowo co ci powie pulseaudio: Z doświadczenia wiem, że mając działające pulseaudio czasami wystarczyć pobawić się Pavucontrol -> zakładka konfiguracja. Pulse może wybierać domyślnie złą kartę np. w moim wypadku ustawił wyjście HDMI z karty graficznej. D: [pulseaudio] alsa-mixer.c: Probe of element 'Front' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Side' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Center' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'CLFE' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'External Amplifier' succeeded (volume=0, switch=4, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Boost' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958 Optical Raw' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Analog Output' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-lineout', none of required-any elements preset. D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-speaker' D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Phantom Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=2, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=2, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Desktop Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Front' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Side' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Center' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Center Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'CLFE' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'External Amplifier' succeeded (volume=0, switch=4, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Boost' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958 Optical Raw' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Analog Output' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-speaker', none of required-any elements preset. D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-desktop-speaker' D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=2, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=3, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Desktop Speaker' failed. D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones' D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Phantom Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Phantom Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Mic Jack' succeeded (not found) D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=2, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Line HP Swap' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Desktop Speaker' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Front' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Side' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Center' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'External Amplifier' succeeded (volume=0, switch=4, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Boost' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958 Optical Raw' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Analog Output' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones-2' D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=1, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=2, switch=2, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=3, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' failed. D: [pulseaudio] alsa-mixer.c: Removing path 'analog-output' as it is a subset of 'analog-output-headphones'. D: [pulseaudio] alsa-mixer.c: Available mixer paths (after tidying): D: [pulseaudio] alsa-mixer.c: Path Set 0xb957f6a0, direction=1 D: [pulseaudio] alsa-mixer.c: Path analog-output-headphones (Słuchawki), direction=1, priority=90, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=31, min_dB=-127,5, max_dB=12 D: [pulseaudio] alsa-mixer.c: Element Master, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element Master Mono, direction=1, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x7ffffffffffff, n_channels=1, override_map=no D: [pulseaudio] alsa-mixer.c: Element Headphone, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element PCM, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element External Amplifier, direction=1, switch=4, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Option on (output-amplifier-on/Amplituner) index=1, priority=10 D: [pulseaudio] alsa-mixer.c: Option off (output-amplifier-off/Brak amplitunera) index=0, priority=0 D: [pulseaudio] alsa-mixer.c: Element IEC958, direction=1, switch=2, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Jack Front Headphone, alsa_name='Front Headphone Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Front Headphone Phantom, alsa_name='Front Headphone Phantom Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone, alsa_name='Headphone Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone Phantom, alsa_name='Headphone Phantom Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone Mic, alsa_name='Headphone Mic Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Setting output-amplifier-on (Amplituner) priority=10 D: [pulseaudio] alsa-mixer.c: Setting output-amplifier-off (Brak amplitunera) priority=0 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-stereo+input:analog-mono - will not be able to open input:analog-mono D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo+input:analog-stereo D: [pulseaudio] alsa-mixer.c: Checking for recording on Analogowe stereo (analog-stereo) D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open front:0 D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 371 ms D: [pulseaudio] alsa-util.c: Set buffer size first (to 4408 samples), period size second (to 1102 samples). D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo supported. D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-stereo+input:iec958-stereo - will not be able to open input:iec958-stereo D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-40 D: [pulseaudio] alsa-mixer.c: Checking for playback on Analogowe surround 4.0 (analog-surround-40) D: [pulseaudio] alsa-util.c: Trying surround40:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround40:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying surround40:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround40:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround40:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround40:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround40:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround40:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround40:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-40+input:analog-mono - will not be able to open output:analog-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-40+input:analog-stereo - will not be able to open output:analog-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-40+input:iec958-stereo - will not be able to open output:analog-surround-40 D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-41 D: [pulseaudio] alsa-mixer.c: Checking for playback on Analogowe surround 4.1 (analog-surround-41) D: [pulseaudio] alsa-util.c: Trying surround41:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround41:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying surround41:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround41:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround41:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround41:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround41:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround41:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround41:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-41 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-41+input:analog-mono - will not be able to open output:analog-surround-41 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-41+input:analog-stereo - will not be able to open output:analog-surround-41 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-41+input:iec958-stereo - will not be able to open output:analog-surround-41 D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-50 D: [pulseaudio] alsa-mixer.c: Checking for playback on Analogowe surround 5.0 (analog-surround-50) D: [pulseaudio] alsa-util.c: Trying surround50:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround50:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying surround50:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround50:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround50:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround50:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround50:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround50:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround50:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-50 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-50+input:analog-mono - will not be able to open output:analog-surround-50 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-50+input:analog-stereo - will not be able to open output:analog-surround-50 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-50+input:iec958-stereo - will not be able to open output:analog-surround-50 D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-51 D: [pulseaudio] alsa-mixer.c: Checking for playback on Analogowe surround 5.1 (analog-surround-51) D: [pulseaudio] alsa-util.c: Trying surround51:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround51:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying surround51:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open surround51:0 D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround51:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround51:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument D: [pulseaudio] alsa-util.c: Trying plug:surround51:0 without SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open plug:surround51:0 I: [pulseaudio] (alsa-lib)pcm_params.c: Slave PCM not usable D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_any() failed: Zły argument I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround51:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-51+input:analog-mono - will not be able to open output:analog-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-51+input:analog-stereo - will not be able to open output:analog-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-51+input:iec958-stereo - will not be able to open output:analog-surround-51 D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-71 D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 7.1 (analog-surround-71) D: [pulseaudio] alsa-util.c: Trying surround71:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM surround71:0 I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-71 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-71+input:analog-mono - will not be able to open output:analog-surround-71 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-71+input:analog-stereo - will not be able to open output:analog-surround-71 D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-71+input:iec958-stereo - will not be able to open output:analog-surround-71 D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo D: [pulseaudio] alsa-mixer.c: Checking for playback on Cyfrowe stereo (IEC958) (iec958-stereo) D: [pulseaudio] alsa-util.c: Trying iec958:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open iec958:0 D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 341 ms D: [pulseaudio] alsa-util.c: Set buffer size first (to 4797 samples), period size second (to 1199 samples). I: [pulseaudio] alsa-util.c: Device iec958:0 doesn't support 44100 Hz, changed to 48000 Hz. D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo supported. I: [pulseaudio] (alsa-lib)control.c: Invalid CTL iec958:0 I: [pulseaudio] alsa-util.c: Unable to attach to mixer iec958:0: Nie ma takiego pliku ani katalogu I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0' D: [pulseaudio] alsa-mixer.c: Probing path 'iec958-stereo-output' D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=1, enumeration=0). D: [pulseaudio] alsa-mixer.c: Available mixer paths (after tidying): D: [pulseaudio] alsa-mixer.c: Path Set 0xb95855f0, direction=1 D: [pulseaudio] alsa-mixer.c: Path iec958-stereo-output (Wyjście cyfrowe (S/PDIF)), direction=1, priority=0, probed=yes, supported=yes, has_mute=yes, has_volume=no, has_dB=no, min_volume=0, max_volume=0, min_dB=inf, max_dB=-inf D: [pulseaudio] alsa-mixer.c: Element IEC958, direction=1, switch=1, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-stereo+input:analog-mono - will not be able to open input:analog-mono D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo+input:analog-stereo D: [pulseaudio] alsa-mixer.c: Checking for recording on Analogowe stereo (analog-stereo) D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open front:0 D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 371 ms D: [pulseaudio] alsa-util.c: Set buffer size first (to 4408 samples), period size second (to 1102 samples). D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:analog-stereo supported. D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-stereo+input:iec958-stereo - will not be able to open input:iec958-stereo D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-40 D: [pulseaudio] alsa-mixer.c: Checking for playback on Cyfrowe surround 4.0 (IEC958/AC3) (iec958-ac3-surround-40) D: [pulseaudio] alsa-util.c: Trying a52:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:0 I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: Nie ma takiego pliku ani katalogu D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:analog-mono - will not be able to open output:iec958-ac3-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:analog-stereo - will not be able to open output:iec958-ac3-surround-40 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-40 D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-51 D: [pulseaudio] alsa-mixer.c: Checking for playback on Cyfrowe surround 5.1 (IEC958/AC3) (iec958-ac3-surround-51) D: [pulseaudio] alsa-util.c: Trying a52:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:0 I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: Nie ma takiego pliku ani katalogu D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:analog-mono - will not be able to open output:iec958-ac3-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:analog-stereo - will not be able to open output:iec958-ac3-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-51 D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-dts-surround-51 D: [pulseaudio] alsa-mixer.c: Checking for playback on Cyfrowe surround 5.1 (IEC958/DTS) (iec958-dts-surround-51) D: [pulseaudio] alsa-util.c: Trying dca:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:0 I: [pulseaudio] alsa-util.c: Error opening PCM device dca:0: Nie ma takiego pliku ani katalogu D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-dts-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:analog-mono - will not be able to open output:iec958-dts-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:analog-stereo - will not be able to open output:iec958-dts-surround-51 D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:iec958-stereo - will not be able to open output:iec958-dts-surround-51 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo) D: [pulseaudio] alsa-util.c: Trying hdmi:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:analog-mono - will not be able to open output:hdmi-stereo D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:analog-stereo - will not be able to open output:hdmi-stereo D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:iec958-stereo - will not be able to open output:hdmi-stereo D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround) D: [pulseaudio] alsa-util.c: Trying hdmi:0 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:analog-mono - will not be able to open output:hdmi-surround D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:analog-stereo - will not be able to open output:hdmi-surround D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:iec958-stereo - will not be able to open output:hdmi-surround D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra1 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo-extra1) D: [pulseaudio] alsa-util.c: Trying hdmi:0,1 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,1 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,1 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,1: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:analog-mono - will not be able to open output:hdmi-stereo-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:analog-stereo - will not be able to open output:hdmi-stereo-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra1 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra1 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround-extra1) D: [pulseaudio] alsa-util.c: Trying hdmi:0,1 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,1 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,1 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,1: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:analog-mono - will not be able to open output:hdmi-surround-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:analog-stereo - will not be able to open output:hdmi-surround-extra1 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:iec958-stereo - will not be able to open output:hdmi-surround-extra1 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra2 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo-extra2) D: [pulseaudio] alsa-util.c: Trying hdmi:0,2 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,2 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,2 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,2: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:analog-mono - will not be able to open output:hdmi-stereo-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:analog-stereo - will not be able to open output:hdmi-stereo-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra2 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra2 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround-extra2) D: [pulseaudio] alsa-util.c: Trying hdmi:0,2 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,2 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,2 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,2: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:analog-mono - will not be able to open output:hdmi-surround-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:analog-stereo - will not be able to open output:hdmi-surround-extra2 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:iec958-stereo - will not be able to open output:hdmi-surround-extra2 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra3 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo-extra3) D: [pulseaudio] alsa-util.c: Trying hdmi:0,3 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,3 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,3 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,3: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:analog-mono - will not be able to open output:hdmi-stereo-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:analog-stereo - will not be able to open output:hdmi-stereo-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra3 D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra3 D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround-extra3) D: [pulseaudio] alsa-util.c: Trying hdmi:0,3 with SND_PCM_NO_AUTO_FORMAT ... I: [pulseaudio] (alsa-lib)conf.c: Unknown parameters 0,3 I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:0,3 I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,3: Zły argument D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:analog-mono - will not be able to open output:hdmi-surround-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:analog-stereo - will not be able to open output:hdmi-surround-extra3 D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:iec958-stereo - will not be able to open output:hdmi-surround-extra3 D: [pulseaudio] alsa-mixer.c: Profile set 0xb951c0c0, auto_profiles=yes, probed=yes, n_mappings=2, n_profiles=5, n_decibel_fixes=0 D: [pulseaudio] alsa-mixer.c: Mapping analog-stereo (Analogowe stereo), priority=60, channel_map=front-left,front-right, supported=yes, direction=0 D: [pulseaudio] alsa-mixer.c: Mapping iec958-stereo (Cyfrowe stereo (IEC958)), priority=55, channel_map=front-left,front-right, supported=yes, direction=0 D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo (Wejście Analogowe stereo), priority=60, supported=yes n_input_mappings=1, n_output_mappings=0 D: [pulseaudio] alsa-mixer.c: Input analog-stereo D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo (Wyjście Analogowe stereo), priority=6000, supported=yes n_input_mappings=0, n_output_mappings=1 D: [pulseaudio] alsa-mixer.c: Output analog-stereo D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo (Analogowy dupleks stereo), priority=6060, supported=yes n_input_mappings=1, n_output_mappings=1 D: [pulseaudio] alsa-mixer.c: Input analog-stereo D: [pulseaudio] alsa-mixer.c: Output analog-stereo D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo (Wyjście Cyfrowe stereo (IEC958)), priority=5500, supported=yes n_input_mappings=0, n_output_mappings=1 D: [pulseaudio] alsa-mixer.c: Output iec958-stereo D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:analog-stereo (Wyjście Cyfrowe stereo (IEC958) + Wejście Analogowe stereo), priority=5560, supported=yes n_input_mappings=1, n_output_mappings=1 D: [pulseaudio] alsa-mixer.c: Input analog-stereo D: [pulseaudio] alsa-mixer.c: Output iec958-stereo I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_00_1f.5. I: [pulseaudio] card.c: Created 0 "alsa_card.pci-0000_00_1f.5" D: [pulseaudio] module-alsa-card.c: Found 0 jacks. D: [pulseaudio] reserve-wrap.c: Successfully create reservation lock monitor for device 'Audio0' D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open front:0 I: [pulseaudio] alsa-util.c: cannot disable ALSA period wakeups D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 371 ms D: [pulseaudio] alsa-util.c: Set buffer size first (to 88200 samples), period size second (to 88200 samples). I: [pulseaudio] alsa-util.c: ALSA period wakeups were not disabled I: [pulseaudio] alsa-sink.c: Successfully opened device front:0. I: [pulseaudio] alsa-sink.c: Selected mapping 'Analogowe stereo' (analog-stereo). I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode. I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode. I: [pulseaudio] (alsa-lib)control.c: Invalid CTL front:0 I: [pulseaudio] alsa-util.c: Unable to attach to mixer front:0: Nie ma takiego pliku ani katalogu I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0' D: [pulseaudio] alsa-mixer.c: Added 2 ports D: [pulseaudio] module-device-restore.c: Database contains invalid data for key: sink:alsa_output.pci-0000_00_1f.5.analog-stereo:null I: [pulseaudio] sink.c: Created sink 0 "alsa_output.pci-0000_00_1f.5.analog-stereo" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right I: [pulseaudio] sink.c: alsa.resolution_bits = "16" I: [pulseaudio] sink.c: device.api = "alsa" I: [pulseaudio] sink.c: device.class = "sound" I: [pulseaudio] sink.c: alsa.class = "generic" I: [pulseaudio] sink.c: alsa.subclass = "generic-mix" I: [pulseaudio] sink.c: alsa.name = "Intel 82801DB-ICH4" I: [pulseaudio] sink.c: alsa.id = "Intel ICH" I: [pulseaudio] sink.c: alsa.subdevice = "0" I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0" I: [pulseaudio] sink.c: alsa.device = "0" I: [pulseaudio] sink.c: alsa.card = "0" I: [pulseaudio] sink.c: alsa.card_name = "Intel 82801DB-ICH4" I: [pulseaudio] sink.c: alsa.long_card_name = "Intel 82801DB-ICH4 with STAC9750,51 at irq 5" I: [pulseaudio] sink.c: alsa.driver_name = "snd_intel8x0" I: [pulseaudio] sink.c: device.bus_path = "pci-0000:00:1f.5" I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:1f.5/sound/card0" I: [pulseaudio] sink.c: device.bus = "pci" I: [pulseaudio] sink.c: device.vendor.id = "8086" I: [pulseaudio] sink.c: device.vendor.name = "Intel Corporation" I: [pulseaudio] sink.c: device.product.id = "24c5" I: [pulseaudio] sink.c: device.product.name = "82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller" I: [pulseaudio] sink.c: device.form_factor = "internal" I: [pulseaudio] sink.c: device.string = "front:0" I: [pulseaudio] sink.c: device.buffering.buffer_size = "65536" I: [pulseaudio] sink.c: device.buffering.fragment_size = "65536" I: [pulseaudio] sink.c: device.access_mode = "mmap+timer" I: [pulseaudio] sink.c: device.profile.name = "analog-stereo" I: [pulseaudio] sink.c: device.profile.description = "Analogowe stereo" I: [pulseaudio] sink.c: device.description = "Wbudowany dźwięk Analogowe stereo" I: [pulseaudio] sink.c: alsa.mixer_name = "SigmaTel STAC9750,51" I: [pulseaudio] sink.c: alsa.components = "AC97a:83847650" I: [pulseaudio] sink.c: module-udev-detect.discovered = "1" I: [pulseaudio] sink.c: device.icon_name = "audio-card-pci" D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event. I: [pulseaudio] source.c: Created source 0 "alsa_output.pci-0000_00_1f.5.analog-stereo.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right I: [pulseaudio] source.c: device.description = "Monitor of Wbudowany dźwięk Analogowe stereo" I: [pulseaudio] source.c: device.class = "monitor" I: [pulseaudio] source.c: alsa.card = "0" I: [pulseaudio] source.c: alsa.card_name = "Intel 82801DB-ICH4" I: [pulseaudio] source.c: alsa.long_card_name = "Intel 82801DB-ICH4 with STAC9750,51 at irq 5" I: [pulseaudio] source.c: alsa.driver_name = "snd_intel8x0" I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:1f.5" I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:1f.5/sound/card0" I: [pulseaudio] source.c: device.bus = "pci" I: [pulseaudio] source.c: device.vendor.id = "8086" I: [pulseaudio] source.c: device.vendor.name = "Intel Corporation" I: [pulseaudio] source.c: device.product.id = "24c5" I: [pulseaudio] source.c: device.product.name = "82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller" I: [pulseaudio] source.c: device.form_factor = "internal" I: [pulseaudio] source.c: device.string = "0" I: [pulseaudio] source.c: module-udev-detect.discovered = "1" I: [pulseaudio] source.c: device.icon_name = "audio-card-pci" I: [pulseaudio] alsa-sink.c: Using 1,0 fragments of size 65536 bytes (371,52ms), buffer size is 65536 bytes (371,52ms) I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20,00ms D: [pulseaudio] alsa-sink.c: hwbuf_unused=0 D: [pulseaudio] alsa-sink.c: setting avail_min=15502 D: [pulseaudio] alsa-mixer.c: Activating path analog-output-headphones D: [pulseaudio] alsa-mixer.c: Path analog-output-headphones (Słuchawki), direction=1, priority=90, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=31, min_dB=-127,5, max_dB=12 D: [pulseaudio] alsa-mixer.c: Element Master, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element Master Mono, direction=1, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x7ffffffffffff, n_channels=1, override_map=no D: [pulseaudio] alsa-mixer.c: Element Headphone, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element PCM, direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element External Amplifier, direction=1, switch=4, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Option on (output-amplifier-on/Amplituner) index=1, priority=10 D: [pulseaudio] alsa-mixer.c: Option off (output-amplifier-off/Brak amplitunera) index=0, priority=0 D: [pulseaudio] alsa-mixer.c: Element IEC958, direction=1, switch=2, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Jack Front Headphone, alsa_name='Front Headphone Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Front Headphone Phantom, alsa_name='Front Headphone Phantom Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone, alsa_name='Headphone Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone Phantom, alsa_name='Headphone Phantom Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Headphone Mic, alsa_name='Headphone Mic Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Setting output-amplifier-on (Amplituner) priority=10 D: [pulseaudio] alsa-mixer.c: Setting output-amplifier-off (Brak amplitunera) priority=0 I: [pulseaudio] alsa-sink.c: Successfully enabled deferred volume. I: [pulseaudio] alsa-sink.c: Hardware volume ranges from -127,50 dB to 12,00 dB. I: [pulseaudio] alsa-sink.c: Fixing base volume to -12,00 dB I: [pulseaudio] alsa-sink.c: Using hardware volume control. Hardware dB scale supported. I: [pulseaudio] alsa-sink.c: Using hardware mute control. D: [pulseaudio] alsa-util.c: snd_pcm_dump(): D: [pulseaudio] alsa-util.c: Hardware PCM card 0 'Intel 82801DB-ICH4' device 0 subdevice 0 D: [pulseaudio] alsa-util.c: Its setup is: D: [pulseaudio] alsa-util.c: stream : PLAYBACK D: [pulseaudio] alsa-util.c: access : MMAP_INTERLEAVED D: [pulseaudio] alsa-util.c: format : S16_LE D: [pulseaudio] alsa-util.c: subformat : STD D: [pulseaudio] alsa-util.c: channels : 2 D: [pulseaudio] alsa-util.c: rate : 44100 D: [pulseaudio] alsa-util.c: exact rate : 44100 (44100/1) D: [pulseaudio] alsa-util.c: msbits : 16 D: [pulseaudio] alsa-util.c: buffer_size : 16384 D: [pulseaudio] alsa-util.c: period_size : 16384 D: [pulseaudio] alsa-util.c: period_time : 371519 D: [pulseaudio] alsa-util.c: tstamp_mode : ENABLE D: [pulseaudio] alsa-util.c: period_step : 1 D: [pulseaudio] alsa-util.c: avail_min : 16384 D: [pulseaudio] alsa-util.c: period_event : 0 D: [pulseaudio] alsa-util.c: start_threshold : -1 D: [pulseaudio] alsa-util.c: stop_threshold : 1073741824 D: [pulseaudio] alsa-util.c: silence_threshold: 0 D: [pulseaudio] alsa-util.c: silence_size : 0 D: [pulseaudio] alsa-util.c: boundary : 1073741824 D: [pulseaudio] alsa-util.c: appl_ptr : 0 D: [pulseaudio] alsa-util.c: hw_ptr : 0 D: [pulseaudio] alsa-sink.c: Read hardware volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB D: [alsa-sink-Intel ICH] alsa-sink.c: Thread starting up D: [alsa-sink-Intel ICH] core-util.c: SCHED_RR|SCHED_RESET_ON_FORK worked. I: [alsa-sink-Intel ICH] core-util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5. I: [alsa-sink-Intel ICH] alsa-sink.c: Starting playback. D: [alsa-sink-Intel ICH] alsa-sink.c: Cutting sleep time for the initial iterations by half. D: [alsa-sink-Intel ICH] alsa-sink.c: Cutting sleep time for the initial iterations by half. D: [alsa-sink-Intel ICH] alsa-sink.c: Cutting sleep time for the initial iterations by half. D: [alsa-sink-Intel ICH] alsa-sink.c: Cutting sleep time for the initial iterations by half. D: [pulseaudio] module-device-restore.c: Could not set format on sink alsa_output.pci-0000_00_1f.5.analog-stereo D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ... D: [pulseaudio] alsa-util.c: Managed to open front:0 I: [pulseaudio] alsa-util.c: cannot disable ALSA period wakeups D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 371 ms D: [pulseaudio] alsa-util.c: Set buffer size first (to 88200 samples), period size second (to 88200 samples). I: [pulseaudio] alsa-util.c: ALSA period wakeups were not disabled I: [pulseaudio] alsa-source.c: Successfully opened device front:0. I: [pulseaudio] alsa-source.c: Selected mapping 'Analogowe stereo' (analog-stereo). I: [pulseaudio] alsa-source.c: Successfully enabled mmap() mode. I: [pulseaudio] alsa-source.c: Successfully enabled timer-based scheduling mode. I: [pulseaudio] (alsa-lib)control.c: Invalid CTL front:0 I: [pulseaudio] alsa-util.c: Unable to attach to mixer front:0: Nie ma takiego pliku ani katalogu I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0' D: [pulseaudio] alsa-mixer.c: Added 5 ports D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event. D: [pulseaudio] module-device-restore.c: Database contains invalid data for key: source:alsa_input.pci-0000_00_1f.5.analog-stereo:null I: [pulseaudio] source.c: Created source 1 "alsa_input.pci-0000_00_1f.5.analog-stereo" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right I: [pulseaudio] source.c: alsa.resolution_bits = "16" I: [pulseaudio] source.c: device.api = "alsa" I: [pulseaudio] source.c: device.class = "sound" I: [pulseaudio] source.c: alsa.class = "generic" I: [pulseaudio] source.c: alsa.subclass = "generic-mix" I: [pulseaudio] source.c: alsa.name = "Intel 82801DB-ICH4" I: [pulseaudio] source.c: alsa.id = "Intel ICH" I: [pulseaudio] source.c: alsa.subdevice = "0" I: [pulseaudio] source.c: alsa.subdevice_name = "subdevice #0" I: [pulseaudio] source.c: alsa.device = "0" I: [pulseaudio] source.c: alsa.card = "0" I: [pulseaudio] source.c: alsa.card_name = "Intel 82801DB-ICH4" I: [pulseaudio] source.c: alsa.long_card_name = "Intel 82801DB-ICH4 with STAC9750,51 at irq 5" I: [pulseaudio] source.c: alsa.driver_name = "snd_intel8x0" I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:1f.5" I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:1f.5/sound/card0" I: [pulseaudio] source.c: device.bus = "pci" I: [pulseaudio] source.c: device.vendor.id = "8086" I: [pulseaudio] source.c: device.vendor.name = "Intel Corporation" I: [pulseaudio] source.c: device.product.id = "24c5" I: [pulseaudio] source.c: device.product.name = "82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller" I: [pulseaudio] source.c: device.form_factor = "internal" I: [pulseaudio] source.c: device.string = "front:0" I: [pulseaudio] source.c: device.buffering.buffer_size = "65536" I: [pulseaudio] source.c: device.buffering.fragment_size = "65536" I: [pulseaudio] source.c: device.access_mode = "mmap+timer" I: [pulseaudio] source.c: device.profile.name = "analog-stereo" I: [pulseaudio] source.c: device.profile.description = "Analogowe stereo" I: [pulseaudio] source.c: device.description = "Wbudowany dźwięk Analogowe stereo" I: [pulseaudio] source.c: alsa.mixer_name = "SigmaTel STAC9750,51" I: [pulseaudio] source.c: alsa.components = "AC97a:83847650" I: [pulseaudio] source.c: module-udev-detect.discovered = "1" I: [pulseaudio] source.c: device.icon_name = "audio-card-pci" I: [pulseaudio] alsa-source.c: Using 1,0 fragments of size 65536 bytes (371,52ms), buffer size is 65536 bytes (371,52ms) I: [pulseaudio] alsa-source.c: Time scheduling watermark is 20,00ms D: [pulseaudio] alsa-source.c: hwbuf_unused=0 D: [pulseaudio] alsa-source.c: setting avail_min=15502 D: [pulseaudio] alsa-mixer.c: Activating path analog-input-mic D: [pulseaudio] alsa-mixer.c: Path analog-input-mic (Mikrofon), direction=2, priority=87, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=15, min_dB=0, max_dB=22,5 D: [pulseaudio] alsa-mixer.c: Element Capture, direction=2, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=yes D: [pulseaudio] alsa-mixer.c: Element Mic, direction=2, switch=1, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x0, n_channels=0, override_map=yes D: [pulseaudio] alsa-mixer.c: Element Mic Select, direction=2, switch=0, volume=0, volume_limit=-1, enumeration=1, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Option Mic1 (input-microphone-1/Mikrofon 1) index=0, priority=20 D: [pulseaudio] alsa-mixer.c: Option Mic2 (input-microphone-2/Mikrofon 2) index=1, priority=19 D: [pulseaudio] alsa-mixer.c: Element Line, direction=2, switch=2, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Element Aux, direction=2, switch=2, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Element Video, direction=2, switch=2, volume=0, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=no D: [pulseaudio] alsa-mixer.c: Jack Mic, alsa_name='Mic Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Jack Mic Phantom, alsa_name='Mic Phantom Jack', detection unavailable D: [pulseaudio] alsa-mixer.c: Setting input-microphone-1 (Mikrofon 1) priority=20 D: [pulseaudio] alsa-mixer.c: Setting input-microphone-2 (Mikrofon 2) priority=19 I: [pulseaudio] alsa-source.c: Successfully enabled deferred volume. I: [pulseaudio] alsa-source.c: Hardware volume ranges from 0,00 dB to 22,50 dB. I: [pulseaudio] alsa-source.c: Fixing base volume to -22,50 dB I: [pulseaudio] alsa-source.c: Using hardware volume control. Hardware dB scale supported. I: [pulseaudio] alsa-source.c: Using hardware mute control. D: [pulseaudio] alsa-util.c: snd_pcm_dump(): D: [pulseaudio] alsa-util.c: Hardware PCM card 0 'Intel 82801DB-ICH4' device 0 subdevice 0 D: [pulseaudio] alsa-util.c: Its setup is: D: [pulseaudio] alsa-util.c: stream : CAPTURE D: [pulseaudio] alsa-util.c: access : MMAP_INTERLEAVED D: [pulseaudio] alsa-util.c: format : S16_LE D: [pulseaudio] alsa-util.c: subformat : STD D: [pulseaudio] alsa-util.c: channels : 2 D: [pulseaudio] alsa-util.c: rate : 44100 D: [pulseaudio] alsa-util.c: exact rate : 44100 (44100/1) D: [pulseaudio] alsa-util.c: msbits : 16 D: [pulseaudio] alsa-util.c: buffer_size : 16384 D: [pulseaudio] alsa-util.c: period_size : 16384 D: [pulseaudio] alsa-util.c: period_time : 371519 D: [pulseaudio] alsa-util.c: tstamp_mode : ENABLE D: [pulseaudio] alsa-util.c: period_step : 1 D: [pulseaudio] alsa-util.c: avail_min : 16384 D: [pulseaudio] alsa-util.c: period_event : 0 D: [pulseaudio] alsa-util.c: start_threshold : -1 D: [pulseaudio] alsa-util.c: stop_threshold : 1073741824 D: [pulseaudio] alsa-util.c: silence_threshold: 0 D: [pulseaudio] alsa-util.c: silence_size : 0 D: [pulseaudio] alsa-util.c: boundary : 1073741824 D: [pulseaudio] alsa-util.c: appl_ptr : 0 D: [pulseaudio] alsa-util.c: hw_ptr : 0 D: [pulseaudio] alsa-source.c: Read hardware volume: front-left: 65535 / 100% / -0,00 dB, front-right: 65535 / 100% / -0,00 dB D: [alsa-source-Intel ICH] alsa-source.c: Thread starting up D: [alsa-source-Intel ICH] core-util.c: SCHED_RR|SCHED_RESET_ON_FORK worked. I: [alsa-source-Intel ICH] core-util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5. I: [alsa-source-Intel ICH] alsa-source.c: Starting capture. I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #6; argument: "device_id="0" name="pci-0000_00_1f.5" card_name="alsa_card.pci-0000_00_1f.5" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""). I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:1f.5/sound/card0 (alsa_card.pci-0000_00_1f.5) module loaded. D: [pulseaudio] module-udev-detect.c: Ignoring /devices/pci0000:00/0000:00:1f.6/sound/card1, because it is a modem. I: [pulseaudio] module-udev-detect.c: Found 1 cards. I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: ""). D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-jackdbus-detect.so': failure D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-bluetooth-policy.so': failure D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-bluetooth-discover.so': failure D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-esound-protocol-unix.so': success I: [pulseaudio] module.c: Loaded "module-esound-protocol-unix" (index: #7; argument: ""). I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #8; argument: ""). D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-gconf.so': failure D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event. I: [pulseaudio] module-default-device-restore.c: Restored default sink 'alsa_output.pci-0000_00_1f.5.analog-stereo'. D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event. I: [pulseaudio] module-default-device-restore.c: Restored default source 'alsa_input.pci-0000_00_1f.5.analog-stereo'. I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #9; argument: ""). I: [pulseaudio] module.c: Loaded "module-rescue-streams" (index: #10; argument: ""). I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #11; argument: ""). I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #12; argument: ""). D: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.pci-0000_00_1f.5.analog-stereo becomes idle, timeout in 5 seconds. D: [pulseaudio] module-suspend-on-idle.c: Source alsa_input.pci-0000_00_1f.5.analog-stereo becomes idle, timeout in 5 seconds. I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #13; argument: ""). D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-console-kit.so': success D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-4.0/modules/module-systemd-login.so': success I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #14; argument: ""). I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #15; argument: ""). D: [pulseaudio] module-role-cork.c: Using role 'phone' as trigger role. D: [pulseaudio] module-role-cork.c: Using roles 'music' and 'video' as cork roles. I: [pulseaudio] module.c: Loaded "module-role-cork" (index: #16; argument: ""). I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #17; argument: ""). I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #18; argument: ""). D: [pulseaudio] main.c: Got org.PulseAudio1! D: [pulseaudio] main.c: Got org.pulseaudio.Server! I: [pulseaudio] main.c: Ukończono uruchamianie usługi. D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC0 is accessible: yes D: [pulseaudio] module-udev-detect.c: Resuming all sinks and sources of card alsa_card.pci-0000_00_1f.5. D: [alsa-sink-Intel ICH] alsa-sink.c: Wakeup from ALSA! I: [alsa-sink-Intel ICH] alsa-sink.c: Underrun! I: [alsa-sink-Intel ICH] alsa-sink.c: Increasing wakeup watermark to 30,00 ms D: [alsa-sink-Intel ICH] alsa-sink.c: Wakeup from ALSA! I: [alsa-sink-Intel ICH] alsa-sink.c: Underrun! I: [alsa-sink-Intel ICH] alsa-sink.c: Increasing wakeup watermark to 40,00 ms D: [alsa-sink-Intel ICH] alsa-sink.c: Wakeup from ALSA! I: [alsa-sink-Intel ICH] alsa-sink.c: Underrun! I: [alsa-sink-Intel ICH] alsa-sink.c: Increasing wakeup watermark to 50,00 ms D: [alsa-sink-Intel ICH] alsa-sink.c: Wakeup from ALSA! I: [alsa-sink-Intel ICH] alsa-sink.c: Increasing wakeup watermark to 60,00 ms I: [alsa-source-Intel ICH] alsa-source.c: Increasing wakeup watermark to 30,00 ms I: [alsa-sink-Intel ICH] alsa-sink.c: Increasing wakeup watermark to 70,00 ms I: [alsa-source-Intel ICH] alsa-source.c: Increasing wakeup watermark to 40,00 ms I: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.pci-0000_00_1f.5.analog-stereo idle for too long, suspending ... D: [pulseaudio] sink.c: Suspend cause of sink alsa_output.pci-0000_00_1f.5.analog-stereo is 0x0004, suspending I: [alsa-sink-Intel ICH] alsa-sink.c: Device suspended... D: [pulseaudio] core.c: Hmm, no streams around, trying to vacuum. D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC0 is accessible: yes D: [pulseaudio] module-udev-detect.c: Resuming all sinks and sources of card alsa_card.pci-0000_00_1f.5. I: [pulseaudio] module-suspend-on-idle.c: Source alsa_input.pci-0000_00_1f.5.analog-stereo idle for too long, suspending ... D: [pulseaudio] source.c: Suspend cause of source alsa_input.pci-0000_00_1f.5.analog-stereo is 0x0004, suspending I: [alsa-source-Intel ICH] alsa-source.c: Device suspended... D: [pulseaudio] core.c: Hmm, no streams around, trying to vacuum. D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC0 is accessible: yes D: [pulseaudio] module-udev-detect.c: Resuming all sinks and sources of card alsa_card.pci-0000_00_1f.5. to jest po pulseaudio -vvv jakas masakra :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Czerwiec 19, 2014 Zgłoszenie Share Napisano Czerwiec 19, 2014 Zainstaluj teraz pavucontrol yum install pavucontroll -y Odpal i w zakładce "Konfiguracja" oraz "Urządzenia Wyjściowe" pobaw się wyjściami. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
paluch Napisano Czerwiec 19, 2014 Autor Zgłoszenie Share Napisano Czerwiec 19, 2014 Zainstaluj teraz pavucontrol Odpal i w zakładce "Konfiguracja" oraz "Urządzenia Wyjściowe" pobaw się wyjściami. mam cos pokrecone, pewnie reinstalacja pakietow mnie czeka [root@localhost pavucontrol-2.0]# pavucontrol (pavucontrol:1816): Gtk-CRITICAL **: gtk_main_quit: assertion 'main_loops != NULL' failed (pavucontrol:1816): Gtk-CRITICAL **: gtk_main_quit: assertion 'main_loops != NULL' failed Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Czerwiec 19, 2014 Zgłoszenie Share Napisano Czerwiec 19, 2014 Hmm, to już jest faktycznie dziwne, zrób może update całego systemu, ale jeżeli to nie pomoże to od swojej strony poleciłbym ci "Windows-repair-everything-way" czyli reinstall systemu. Ewentualnie, możesz jeszczesz dodać nowego użyszkodznika i zobaczyć czy z jego poziomu cokolwiek ruszy, bo może to być jakiś problem z confingami. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Subaru Napisano Czerwiec 20, 2014 Zgłoszenie Share Napisano Czerwiec 20, 2014 Ja też dorzucę coś z cyklu "trywialne sposoby". Sprawdź proszę czy masz zainstalowany alsa-plugins-pulseaudio. Ewentualnie możesz poszaleć na ostrożnego z metodą wyłączającą PulseAudio na rzecz ALSA. http://mondogrigio.blogspot.com/2012/06/how-to-disable-pulseaudio-and-enable.html Na tym blogu miły pan bardzo kulturalnie (hehe) pokazał jak to zrobić :3 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Bawetta Napisano Sierpień 30, 2014 Zgłoszenie Share Napisano Sierpień 30, 2014 Zacząłbym od trywialnego sprawdzenia czy w alsamixer nie masz po prostu wyciszonego któregoś wejścia lub wyjścia. Pomocny może być też wynik polecenia amixer -c 0 scontrols a potem dla każdego urządzenia amixer -c 0 sget 'xxxx' gdzie xxxx zastępujesz przez np. Master, Line itd Sprawdź czy masz w ogóle załadowany moduł lsmod | grep snd Cokolwiek robi polecenie amixer - u mnie też zadziałało. :-) Nie było dźwięku i się zrobił. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
