E1000E Brak Internetu Przewodowego
Gość
mam problem z internetem przewodowym. internet cały czas się łączy i łączy i nie uzyskuje połączenia z routerem.
karta ethernetowa:
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (2) I218-V
system:
Linux tokariew.pl 3.18.7-200.fc21.x86_64 #1 SMP Wed Feb 11 21:53:17 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
próbowałem aktualizacji sterownika e1000e, ale po zainstalowaniu i restarcie cały czas mam starą wersję, a bez restartu mam tak:
[    0.914379] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[    0.914381] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
[    0.914490] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    0.914503] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[    1.067754] e1000e 0000:00:19.0 eth0: registered PHC clock
[    1.067766] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) d0:50:99:34:55:32
[    1.067767] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    1.067792] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[    1.068326] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[   16.153035] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[   16.253051] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[   20.564053] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[   20.564064] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
[  265.851384] e1000e 0000:00:19.0 enp0s25: removed PHC
[  265.945365] e1000e: enp0s25 NIC Link is Down
[  310.174296] e1000e: module verification failed: signature and/or  required key missing - tainting kernel
[  310.175028] e1000e: Intel(R) PRO/1000 Network Driver - 3.1.0.2-NAPI
[  310.175030] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
[  310.175186] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[  310.175202] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[  310.344226] e1000e 0000:00:19.0 eth0: registered PHC clock
[  310.344239] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) d0:50:99:34:55:32
[  310.344240] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[  310.344263] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[  310.346678] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[  310.444213] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[  310.545056] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[  314.694162] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[  314.694167] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
komputer po podłączeniu bezprzewodowej karty pod usb łączy się z siecią bez problemu. w menadżerze połączeń mam ustawienie dhcp przy adresach
lut 28 01:10:33 tokariew.pl NetworkManager[834]: <info>  startup complete
lut 28 01:10:33 tokariew.pl NetworkManager[834]: <info>  Connectivity check for uri 'https://fedoraproject.org/static/hotspot.txt' failed with 'Błąd podczas rozwiązywania "fedoraproject.org": Ta nazwa lub usługa jest nieznana'.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) starting connection 'Połączenie przewodowe 1'
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 1 of 5 (Device Prepare) scheduled...
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 1 of 5 (Device Prepare) started...
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): device state change: disconnected -> prepare (reason 'none') [30 40 0]
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  NetworkManager state is now CONNECTING
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 2 of 5 (Device Configure) scheduled...
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 1 of 5 (Device Prepare) complete.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 2 of 5 (Device Configure) starting...
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): device state change: prepare -> config (reason 'none') [40 50 0]
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 2 of 5 (Device Configure) successful.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 2 of 5 (Device Configure) complete.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 3 of 5 (IP Configure Start) scheduled.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 3 of 5 (IP Configure Start) started...
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): device state change: config -> ip-config (reason 'none') [50 70 0]
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Beginning DHCPv4 transaction (timeout in 45 seconds)
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  dhclient started with pid 3363
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Beginning DHCPv6 transaction (timeout in 45 seconds)
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  dhclient started with pid 3364
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 3 of 5 (IP Configure Start) complete.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): DHCPv4 state changed nbi -> preinit
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): DHCPv6 state changed nbi -> preinit6
lut 28 01:10:46 tokariew.pl dhclient[3364]: Can't bind to dhcp address: Cannot assign requested address
lut 28 01:10:46 tokariew.pl dhclient[3364]: Please make sure there is no other dhcp server
lut 28 01:10:46 tokariew.pl dhclient[3364]: running and that there's no entry for dhcp or
lut 28 01:10:46 tokariew.pl dhclient[3364]: bootp in /etc/inetd.conf.   Also make sure you
lut 28 01:10:46 tokariew.pl dhclient[3364]: are not running HP JetAdmin software, which
lut 28 01:10:46 tokariew.pl dhclient[3364]: includes a bootp server.
lut 28 01:10:46 tokariew.pl dhclient[3364]: This version of ISC DHCP is based on the release available
lut 28 01:10:46 tokariew.pl dhclient[3364]: on ftp.isc.org.  Features have been added and other changes
lut 28 01:10:46 tokariew.pl dhclient[3364]: have been made to the base software release in order to make
lut 28 01:10:46 tokariew.pl dhclient[3364]: it work better with this distribution.
lut 28 01:10:46 tokariew.pl dhclient[3364]: Please report for this software via the Red Hat Bugzilla site:
lut 28 01:10:46 tokariew.pl dhclient[3364]: http://bugzilla.redhat.com
lut 28 01:10:46 tokariew.pl dhclient[3364]: exiting.
lut 28 01:10:46 tokariew.pl NetworkManager[834]: <info>  (enp0s25): DHCPv6 client pid 3364 exited with status 1
lut 28 01:10:46 tokariew.pl dhclient[3363]: DHCPDISCOVER on enp0s25 to 255.255.255.255 port 67 interval 3 (xid=0xc1ac770b)
lut 28 01:10:46 tokariew.pl dhclient[3363]: DHCPREQUEST on enp0s25 to 255.255.255.255 port 67 (xid=0xc1ac770b)
lut 28 01:10:46 tokariew.pl dhclient[3363]: DHCPOFFER from 192.168.1.1
lut 28 01:10:46 tokariew.pl dhclient[3363]: DHCPNAK from 192.168.1.1 (xid=0xc1ac770b)
lut 28 01:10:53 tokariew.pl dhclient[3363]: DHCPREQUEST on enp0s25 to 255.255.255.255 port 67 (xid=0xc1ac770b)
lut 28 01:10:53 tokariew.pl dhclient[3363]: DHCPNAK from 192.168.1.1 (xid=0xc1ac770b)
lut 28 01:11:14 tokariew.pl dhclient[3363]: DHCPDISCOVER on enp0s25 to 255.255.255.255 port 67 interval 4 (xid=0xa2a93027)
lut 28 01:11:14 tokariew.pl dhclient[3363]: DHCPREQUEST on enp0s25 to 255.255.255.255 port 67 (xid=0xa2a93027)
lut 28 01:11:14 tokariew.pl dhclient[3363]: DHCPOFFER from 192.168.1.1
lut 28 01:11:14 tokariew.pl dhclient[3363]: DHCPNAK from 192.168.1.1 (xid=0xa2a93027)
lut 28 01:11:19 tokariew.pl dhclient[3363]: DHCPREQUEST on enp0s25 to 255.255.255.255 port 67 (xid=0xa2a93027)
lut 28 01:11:19 tokariew.pl dhclient[3363]: DHCPNAK from 192.168.1.1 (xid=0xa2a93027)
lut 28 01:11:32 tokariew.pl NetworkManager[834]: <warn>  (enp0s25): DHCPv4 request timed out.
lut 28 01:11:32 tokariew.pl NetworkManager[834]: <info>  (enp0s25): canceled DHCP transaction, DHCP client pid 3363
lut 28 01:11:32 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 4 of 5 (IPv4 Configure Timeout) scheduled...
lut 28 01:11:32 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 4 of 5 (IPv4 Configure Timeout) started...
lut 28 01:11:32 tokariew.pl NetworkManager[834]: <info>  Activation (enp0s25) Stage 4 of 5 (IPv4 Configure Timeout) complete.
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  WiFi hardware radio set enabled
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  WiFi now enabled by radio killswitch
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6) supports 4 scan SSIDs
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: starting -> ready
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
lut 28 01:12:28 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: ready -> disconnected
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Auto-activating connection 'tokariew'.
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) starting connection 'tokariew'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 1 of 5 (Device Prepare) scheduled...
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 1 of 5 (Device Prepare) started...
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: disconnected -> prepare (reason 'none') [30 40 0]
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 2 of 5 (Device Configure) scheduled...
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 1 of 5 (Device Prepare) complete.
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 2 of 5 (Device Configure) starting...
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: prepare -> config (reason 'none') [40 50 0]
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6/wireless): access point 'tokariew' has security, but secrets are required.
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: config -> need-auth (reason 'none') [50 60 0]
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 2 of 5 (Device Configure) complete.
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: disconnected -> inactive
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: need-auth -> prepare (reason 'none') [60 40 0]
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6/wireless): connection 'tokariew' has security, and secrets exist.  No new secrets needed.
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: added 'ssid' value 'tokariew'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: added 'scan_ssid' value '1'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: added 'key_mgmt' value 'WPA-PSK'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: added 'psk' value '<omitted>'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: added 'proto' value 'WPA RSN'
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  Config: set interface ap_scan to 1
lut 28 01:12:29 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: inactive -> scanning
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: scanning -> authenticating
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: authenticating -> associated
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): supplicant interface state: associated -> completed
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6/wireless) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'tokariew'.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 3 of 5 (IP Configure Start) scheduled.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 3 of 5 (IP Configure Start) started...
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: config -> ip-config (reason 'none') [50 70 0]
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Beginning DHCPv4 transaction (timeout in 45 seconds)
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  dhclient started with pid 3418
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 3 of 5 (IP Configure Start) complete.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): DHCPv4 state changed nbi -> preinit
lut 28 01:12:30 tokariew.pl dhclient[3418]: DHCPREQUEST on wlp0s20u6 to 255.255.255.255 port 67 (xid=0x8f3a9334)
lut 28 01:12:30 tokariew.pl dhclient[3418]: DHCPACK from 192.168.1.1 (xid=0x8f3a9334)
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): DHCPv4 state changed preinit -> reboot
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    address 192.168.1.104
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    plen 24 (255.255.255.0)
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    gateway 192.168.1.1
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    server identifier 192.168.1.1
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    lease time 259200
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    hostname 'dhcppc4'
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    nameserver '8.8.8.8'
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>    nameserver '8.8.8.4'
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 5 of 5 (IPv4 Commit) started...
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 5 of 5 (IPv4 Commit) complete.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: ip-check -> secondaries (reason 'none') [80 90 0]
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  (wlp0s20u6): device state change: secondaries -> activated (reason 'none') [90 100 0]
lut 28 01:12:30 tokariew.pl dhclient[3418]: bound to 192.168.1.104 -- renewal in 105341 seconds.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Policy set 'tokariew' (wlp0s20u6) as default for IPv4 routing and DNS.
lut 28 01:12:30 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) successful, device activated.
lut 28 01:13:02 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
lut 28 01:13:02 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 4 of 5 (IPv6 Configure Timeout) started...
lut 28 01:13:02 tokariew.pl NetworkManager[834]: <info>  Activation (wlp0s20u6) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Ale chodzi ci w końcu o przewodowy czy bezprzewodowy?
Może wystarczy kliknąć w ikonę NM, rozłączyć WiFi i włączyć ethernet?
Przy podawaniu logów też lepiej wyłączyć WiFi, bo tylko zaciemnia obraz.
Wg mnie nowy sterownik albo źle zainstalowany albo sobie nie radzi z tą kartą. Wróć do starego jeśli działał.
Autorowi chodzi o połączenie przewodowe, spójrz na pierwszy post, sterownik jest jest w kernelu (nie wiem co auto miał na myśli mówiąc "próbowałem aktualizacji sterownika e1000e") i działa prawidłowo, mam taką samą kartę, działającą na tym samym sterowniku.
Do autora wątku, problemem są te komunikaty
  Cytuj
co zwraca polecenie ifconfig, spróbuj usunąć z NetworkManagera interface enp0s25 i dodać go ponownie.
ifconfig:
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::d250:99ff:fe34:5532  prefixlen 64  scopeid 0x20<link>
        ether d0:50:99:34:55:32  txqueuelen 1000  (Ethernet)
        RX packets 44  bytes 7872 (7.6 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 14  bytes 3614 (3.5 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf7d00000-f7d20000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 0  (Local Loopback)
        RX packets 424  bytes 35784 (34.9 KiB)
        TX packets 424  bytes 35784 (34.9 KiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 8a:f6:12:a9:7f:6b  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0
        TX packets 0  bytes 0 (0.0
co do aktualizacji, z strony intela pobrałem najnowszą wersję, zbudowałem bez problemu paczkę rpm i ją zainstalowałem w systemie, ale nadal jest używana ta bazowa. jak usunąć intrface z networkmenagera?
ok po konfiguracji ręcznej połączenia przewodowego poszło, ale czemu przez dhcp nie działa to nie wiem.
Edytowane przez tokariew
