ansgar Napisano Wrzesień 16, 2017 Zgłoszenie Share Napisano Wrzesień 16, 2017 Witajcie. Zainstalowałem hashcat z repo gita, niestety nie mogę go zmusić do działania. #hashcat test hashcat (v3.6.0-480-g0675f72c) starting... X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 clGetDeviceIDs(): CL_DEVICE_NOT_FOUND X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 clGetDeviceIDs(): CL_DEVICE_NOT_FOUND * Device #1: Not a native Intel OpenCL runtime. Expect massive speed loss. You can use --force to override, but do not report related errors. clGetDeviceIDs(): CL_DEVICE_NOT_FOUND X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 clGetDeviceIDs(): CL_DEVICE_NOT_FOUND No devices found/left. Started: Sat Sep 16 12:31:33 2017 Stopped: Sat Sep 16 12:31:33 2017 Szukałem też dodatkowego info o błędach ocl w darktable: #gdb darktable GNU gdb (GDB) Fedora 8.0.1-26.fc26 Copyright (C) 2017 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-redhat-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from darktable...Reading symbols from /usr/lib/debug/usr/bin/darktable.debug...done. done. (gdb) run Starting program: /usr/bin/darktable Missing separate debuginfos, use: dnf debuginfo-install glibc-2.25-10.fc26.x86_64 [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib64/libthread_db.so.1". WARNING: either your user id or the effective user id are 0. are you running darktable as root? [New Thread 0x7fffd80c5700 (LWP 15758)] [New Thread 0x7fffcffff700 (LWP 15759)] [New Thread 0x7fffd78c4700 (LWP 15760)] [New Thread 0x7fffd70c3700 (LWP 15761)] [New Thread 0x7fffd68c2700 (LWP 15762)] [New Thread 0x7fffbc61e700 (LWP 15763)] [New Thread 0x7fffbbe1d700 (LWP 15764)] [New Thread 0x7fffbb61c700 (LWP 15765)] [New Thread 0x7fffbae1b700 (LWP 15766)] [Thread 0x7fffbb61c700 (LWP 15765) exited] [Thread 0x7fffbbe1d700 (LWP 15764) exited] [Thread 0x7fffbc61e700 (LWP 15763) exited] [Thread 0x7fffbae1b700 (LWP 15766) exited] X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 [New Thread 0x7fffbae1b700 (LWP 15767)] [New Thread 0x7fffbb61c700 (LWP 15768)] [New Thread 0x7fffbbe1d700 (LWP 15769)] [New Thread 0x7fffbc61e700 (LWP 15770)] X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument Assuming 131072kB available aperture size. May lead to reduced performance or incorrect rendering. get chip id failed: -1 [22] param: 4, val: 0 cl_get_gt_device(): error, unknown device: 0 [New Thread 0x7fffb9d58700 (LWP 15771)] [New Thread 0x7fffb9557700 (LWP 15772)] [New Thread 0x7fffb8d56700 (LWP 15773)] [New Thread 0x7fff9ebaf700 (LWP 15775)] [Thread 0x7fff9ebaf700 (LWP 15775) exited] [New Thread 0x7fff9ebaf700 (LWP 15778)] [Thread 0x7fff9ebaf700 (LWP 15778) exited] [New Thread 0x7fff9ebaf700 (LWP 15779)] [Thread 0x7fff9ebaf700 (LWP 15779) exited] [New Thread 0x7fff9ebaf700 (LWP 15780)] [Thread 0x7fff9ebaf700 (LWP 15780) exited] Detaching after fork from child process 15781. [New Thread 0x7fff9ebaf700 (LWP 15782)] [New Thread 0x7fff9a2b9700 (LWP 15783)] [Thread 0x7fffb9557700 (LWP 15772) exited] [Thread 0x7fff9a2b9700 (LWP 15783) exited] Jednak nie wiele przychodzi do głowy, sterowniki zainstalowane mam chyba poprawnie, "chyba" ponieważ w modułach kernelu mam nadal nouveau, ale kernel driver używany od nvidii więc nie jestem pewien czy to ma związek. #lspci -k | grep -iA 3 vga 01:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2) Subsystem: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] Kernel driver in use: nvidia Kernel modules: nouveau, nvidia_drm, nvidia Sam nie wiem co o tym myśleć, na fedorze jestem od niedawna.Na archu\antergosie\manjaro jeszcze jakiś czas temu nie miałem problemów.Wiecie może jak to rozwiązać? Pozdrawiam! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fredro Napisano Wrzesień 16, 2017 Zgłoszenie Share Napisano Wrzesień 16, 2017 A jakie środowisko i czy korzystasz z Wayland. Może to być zwykły bug, po którejś ze stron, sprawdzałeś na bugzilli Fedory? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ansgar Napisano Wrzesień 16, 2017 Autor Zgłoszenie Share Napisano Wrzesień 16, 2017 Cześć. Gnome, menagera okien nie zmieniałem więc pewnie domyślny GDM. Nie sprawdzałem na tego na bugzilli, ogólnie nie jestem z bugzillą zaznajomiony, z reguły wystarczało mi google czy ew. irc do znaleziania rozwiązań problemów. Jak używam domyślnej sesji Gnome Fedory to jest z waylandem czy nie? ps aux | grep wayland pokazuje że : root 21487 0.0 0.0 119452 992 pts/0 S+ 21:18 0:00 grep wayland Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fredro Napisano Wrzesień 17, 2017 Zgłoszenie Share Napisano Wrzesień 17, 2017 Ja to sprawdzam tym echo $XDG_SESSION_TYPE Ewentualnie tym sposobem. Gdzie numer usera przy SESSION wpisujesz w drugim poleceniu. W tym przypadku jest to 4 loginctl loginctl show-session 4 -p Type Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ansgar Napisano Wrzesień 18, 2017 Autor Zgłoszenie Share Napisano Wrzesień 18, 2017 Ten pierwszy sposób wypluwa mi jedynie pustą linijkę. Natomiast drugi: #loginctl SESSION UID USER SEAT TTY c3 42 gdm seat0 /dev/tty1 4 1000 joker seat0 /dev/tty2 #Loginctl show-session 4 -p Type Type=x11 Ale chyba coś kojarzę ze w f26 defaultowa sesja to powinien być wayland bo sporo osób na nią narzeka i odpala z xorga Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Wrzesień 18, 2017 Zgłoszenie Share Napisano Wrzesień 18, 2017 Dnia 16.09.2017 o 12:43, ansgar napisał: Jednak nie wiele przychodzi do głowy, sterowniki zainstalowane mam chyba poprawnie, "chyba" ponieważ w modułach kernelu mam nadal nouveau, ale kernel driver używany od nvidii więc nie jestem pewien czy to ma związek. Na pewno masz nie poprawnie skonfigurowany/zainstalowany sterownik nvidi, skoro załadowany masz moduł nouveau, ale pierwsze co się rzuca w oczy to: Dnia 16.09.2017 o 12:43, ansgar napisał: X server found. dri2 connection failed! DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument * Device #1: Not a native Intel OpenCL runtime. Expect massive speed loss. co zwraca polecenie hashcat -I (duże i, nie małe el) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ansgar Napisano Wrzesień 19, 2017 Autor Zgłoszenie Share Napisano Wrzesień 19, 2017 Ale lipa że ja to przeoczyłem.Sterowniki do grafiki zawsze instaluje pierwsze bo nie mam na tym pc żadnego rsynca na zapasową partycje ani nic żeby go szybko podnieśc jak padnie, a już przy pierwszym moim spotkaniu z F26 system się wyhuśtał po zainstalowaniu sterowników nvidii komendą z oficjalnego poradnika Fedory.Więc po skonfigurowaniu sobie systemu to mi się już rzucać monetą nie chce i chyba sobie odpuszczę.Swoją drogą to też trzeba zostawić bez komentarza że na Archu łatwiej zainstalować stery niż na Fedorze, nie wspominając nawet o Manjaro czy innym Antergosie gdzie przy instalacji je wybierasz i masz spokój.Eh Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
