Przezroczystosc W Linuksie.
perl
probowalem ten "eksperyment" z przezroczytoscia kozystajac z tego linka:
http://www.haxite.org/index.php3?site=arty...kul_view&id=516
niestety po wpisaniu
Section "Extensions"
    Option "Composite" "Enable"
EndSection
do xorg.conf nie chca sie odpalic X'y
mial ktos podobny problem ? wkleic jakis log albo zawartosc xorg ??
  • Odpowiedzi 100
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
moj xorg.conf
# Xorg configuration created by system-config-display
Section "ServerLayout"
Identifier     "single head configuration"
Screen      0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath      "/usr/X11R6/lib/X11/rgb"
ModulePath   "/usr/X11R6/lib/modules/extensions/nvidia"
ModulePath   "/usr/X11R6/lib/modules"
FontPath     "unix/:7100"
FontPath     "/usr/X11R6/lib/X11/fonts/TTF/"
FontPath     "/usr/X11R6/lib/X11/fonts/local/"
EndSection
Section "Module"
Load  "dbe"
Load  "extmod"
Load  "fbdevhw"
Load  "record"
Load  "freetype"
Load  "type1"
Load  "glx"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#	Option	"Xleds"  "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#	Option	"XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#	Option	"XkbModel"	"pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#	Option	"XkbModel"	"microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#	Option	"XkbLayout"	"de"
# or:
#	Option	"XkbVariant"	"nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#	Option	"XkbOptions"	"ctrl:swapcaps"
# Or if you just want both to be control, use:
#	Option	"XkbOptions"	"ctrl:nocaps"
Identifier  "Keyboard0"
Driver      "kbd"
Option     "XkbModel" "pc104"
Option     "XkbLayout" "pl"
Option     "XkbRules" "xorg"
EndSection
Identifier  "Mouse0"
Driver      "mouse"
Option     "Protocol" "IMPS/2"
Option     "Device" "/dev/input/mice"
Option     "ZAxisMapping" "4 5"
Option     "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "SyncMaster"
DisplaySize  340	270
HorizSync    30.0 - 81.0
VertRefresh  56.0 - 75.0
Option     "dpms"
EndSection
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
VendorName  "Videocard vendor"
BoardName   "NVIDIA GeForce FX (generic)"
EndSection
Section "Screen"
Identifier "Screen0"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     24
SubSection "Display"
 Viewport   0 0
 Depth     16
 Modes    "800x600" "640x480"
EndSubSection
 Viewport   0 0
 Depth     24
 Modes    "1280x1024" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "DRI"
Group        0
Mode         0666
EndSection
EDIT: edit na początku dla odmiany: wyrzuć tego loga, jest niepotrzebny.
Sprawa jest prosta jak pół kilometra sznurka w kieszeni. Zaczynasz zawsze standardowo, czyli:
- W Section "Device" następujące wpisy:
Driver      "nvidia"
Option     "RenderAccel" "on"
Option  "AllowGLXWithComposite" "true"
- W Section "Module":
Load  "glx"
- A na końcu pliku:
EndSection
I teraz jeśli masz problemy, pierwszą rzeczą jaką powinienneś zrobić jest sprawdzenie czy glx się nie gryzie, czyli nadanie wartości "false" w sekcji Device, Option "AllowGLXWithComposite".
Jeśli nadal dzieją się rzeczy nadprzyrodzone nie ładuj modułu glx czyli w sekcji "Module" kasujesz linijkę Load "glx" (i oczywiście "AllowGLXWithComposite" nadajesz wartość "false").
Te czynności pozwolą nam sprawdzić, czy to nieszczęsne glx jest przyczyną zmartwień. Jeśli nie, pomyślimy dalej smile.gif
