@Sorror Napisano Październik 28, 2005 Zgłoszenie Share Napisano Październik 28, 2005 W xorg.conf wywal: Option "RenderAccel" "on" Option "AllowGLXWithComposite" "true" A dodaj w sekcji "Device": Option "ForcePCIMode" ATI ma czasami problemy z Composite, to oficjalne stanowisko developerów EDIT: Option "backingstore" "true" jest? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Październik 29, 2005 Autor Zgłoszenie Share Napisano Październik 29, 2005 zrobilem tak jak napisales sorror ale nadal to samo moze ja cos mam zle w xorg.conf a nie widze tego? zobacz sam: Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" VendorName "Videocard vendor" BoardName "ATI Radeon 9500 Pro" Option "mtrr" "on" Option "UseInternalAGPGART" "no" Option "VideoOverlay" "on" Option "backingstore" "true" # Option "RenderAccel" "on" # Option "AllowGLXWithComposite" "true" Option "ForcePCIMode" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Section "Extensions" Option "Composite" "Enable" EndSection Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 And, after reading people’s frustrating posts about Linux, ATI video cards, and getting composite out to work in X, what should I do? Why, drop it! Time to move on to another video chipset. So, nVidia has excellent Linux support compared to other video cards brands. Tak mówi Tony i ma rację perl: w logu widzimy: (II) fglrx(0): Composite extension enabled, disabling direct rendering Jeśli w tym problem to niedobrze: At this time (ati-drivers 8.14.13-r2), enabling Composite extension disables direct rendering (ie hardware OpenGL support) I jeszcze jeden cytat: Composite is not yet supported for the ATI-drivers (version 8.14.13-r2). Tak więc sprawdź wersję, nie mam ATI więc nie mam pojęcia czy 8.14.13-r2 to staroć czy nie. Jeśli się okaże, iż z wersją wszystko ok pomyślimy dalej... Btw: na jakim środowisku testujesz? lysyr: jaki numer wersji KDE? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Październik 29, 2005 Autor Zgłoszenie Share Napisano Październik 29, 2005 ja mam wersje: OpenGL version string: 1.3.5395 (X4.3.0-8.18.6) wedlug livna jest to wersja: 8.18.6.1, czyli nowsze od tych ktore opisales , ehhh cos czuje ze z tego nici beda, znajac postawe ati, dostosowanie sterownikow potrwa conajmniej rok Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 Czarny humor: Pyt: Biorąc pod uwagę to, że zainteresowanie ATI skierowane jest głównie na klientów biznesowych, wydaje się, że pierwszeństwo ma wydajność i funkcjonalność 2D. Czy ATI przewiduje w swoich planach nowe opracowania desktopowe, takie jak rozszerzenie Composite X.org? Odp: Będziemy odpowiadać na potrzeby w miarę umiejscawiania się technologii na rynku. Aktualnie, zapotrzebowanie na rozszerzenie Composite itp. jest minimalne[...] Cóż, nvidia rox :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Październik 29, 2005 Autor Zgłoszenie Share Napisano Październik 29, 2005 Czarny humor: Pyt: Biorąc pod uwagę to, że zainteresowanie ATI skierowane jest głównie na klientów biznesowych, wydaje się, że pierwszeństwo ma wydajność i funkcjonalność 2D. Czy ATI przewiduje w swoich planach nowe opracowania desktopowe, takie jak rozszerzenie Composite X.org? Odp: Będziemy odpowiadać na potrzeby w miarę umiejscawiania się technologii na rynku. Aktualnie, zapotrzebowanie na rozszerzenie Composite itp. jest minimalne[...] Cóż, nvidia rox :-) bez kitu napisze chyba jakis "milutki" list do centrali w Polsce i Kanadzie za jednym zamachem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 ati-fglrx-8.18.6.1-0.lvn.1.4.x86_64.rpm -> 13 october. Wychodziłoby na to, iż jest to wersja mająca w teorii wyjść na przeciw wymaganiom użytkowników z okresu do maja tego roku, czyli mówimy tu o okresie dużego zainteresowania już nie tyle Composite co ogólnie tuningiem... Naprawdę nie rozumiem polityki ati Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lysyr Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 sorrow: 3.4.2 czy bede mial przezroczystosc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 Lysyr: sorror nie sorrow Tak, od wersji 3.4 KDE ma support dla Composite więc nie tu leży problem. Hm, Composite + KDE zżera naprawdę dużo zasobów, być może po prostu Twój sprzęt nie wytrzymuje... Innego racjonalnego wyjaśnienia nie widzę. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lysyr Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 sorry... w sumie moj sprzet nie odbiega od innych... xp 2200 512 ramu powinnien pociagnac bezproblemu kde i jeszcze inne wielkie rzeczy ;] wiec mysle ze to nie to... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 29, 2005 Zgłoszenie Share Napisano Październik 29, 2005 Cóż, Composite jak i jego obsługa w KDE jest wciąż w fazie experymentalnej. Jeśli ktoś ma z tym rozszerzeniem problemy na tym środowisku i nie znajduje ich rozwiązania w tym topicu może jedynie czekać na następne wersje. Taka jest prawda. Topic w sumie można przykleić, podobne problemy na pewno nieraz jeszcze się na forum pojawią Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
durny Napisano Październik 30, 2005 Zgłoszenie Share Napisano Październik 30, 2005 Witam udało mi się zedytować Xorg.conf tak by działo rozszerzenie Composite, zainstalowałem z źródeł xcompmgr ale niewpisywałem tego polecenia: patch --dry-run -p1 < kwinxcompmgr3.3.2.diff ponieważ wyskakuje coś takiego [root@localhost spinner]# patch --dry-run -p1 < kwinxcompmgr3.3.2.diff can't find file to patch at input line 4 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |diff -updr -x '*~' -x '*.in' -x '*.moc' -x '*.la' -x '*.o' -x '*.lo' -x Makefile -x '*.orig' -x '.*' kwin-backup/activation.cpp kwin/activation.cpp |--- kwin-backup/activation.cpp 2004-12-17 22:20:13.000000000 +0100 |+++ kwin/activation.cpp 2005-01-08 18:44:56.000000000 +0100 -------------------------- File to patch: i jaki plik mam tu podać ? Po ponownym uruchomieniu serwera X-ów, owszem przezroczystość była ale dla aktywnych okien 100% a dla nieaktywnych 95% tak na oko oczywiście. Nic niemogę zrobić bo nic niewidzę nawet konsoli Siedzę teraz na Gnomie, którego obiecałem sobie nigdy niedoktnąć ale niewyszło. W jakich plikach mam pozmieniać ustawienia przezroczystości? A i jeszcze do czego słóży ów transset-df bo mój angielski trochę kuleje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 30, 2005 Zgłoszenie Share Napisano Październik 30, 2005 Nowa moda? Jeśli piszesz posta na forum nie ślij pmów Transsetdf służy do tego samego co transset, czyli do transparencji ->spróbuj. Tutaj masz rozwiązanie problemu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
durny Napisano Październik 31, 2005 Zgłoszenie Share Napisano Październik 31, 2005 sorror: uniżenie proszę o wybaczenie, coś mi odbiło . Z tym problemem sobie poradziłem, wyłączyłem najpierw Composite a potem w centrum sterowania poustawiałem wszytko jak trzeba, po czym znowy dodałem osługę Composite. Ale kiedy byłem już wniebowzięty tym, że wszystko działa pojawił się ZONK: nie działaja mi aplikacje OpenGL takie jak gry, wygaszacze, wizualizacje. Po uruchomieniu aplikacji OpenGL wywala mnie z X-ów do ekranu logowania Wie ktos jak to rozwiązać? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Październik 31, 2005 Zgłoszenie Share Napisano Październik 31, 2005 Option "AllowGLXWithComposite" "true" Czytaj uważnie tematy, pod które się podpinasz. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
