p4v3u Napisano Listopad 7, 2007 Zgłoszenie Share Napisano Listopad 7, 2007 NIe moge zainstalowac wg opisu z http://fedorasolved.org/post-install-solut...headset-config/ przy [root@xxx btsco]# ./configure dostaje taki output [root@xxx btsco]# ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking for a BSD-compatible install... /usr/bin/install -c checking for ranlib... ranlib checking how to run the C preprocessor... gcc -E checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking bluetooth/bluetooth.h usability... yes checking bluetooth/bluetooth.h presence... yes checking for bluetooth/bluetooth.h... yes checking for hci_open_dev in -lbluetooth... yes checking for sdp_connect in -lbluetooth... yes checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for a sed that does not truncate output... /bin/sed checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking the maximum length of command line arguments... 32768 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... (cached) ranlib checking for strip... strip checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool checking for ALSA CFLAGS... checking for ALSA LDFLAGS... -lasound -lm -ldl -lpthread checking for libasound headers version >= 1.0.3... found. checking for snd_ctl_open in -lasound... yes checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for GLIB... yes checking for DBUS... configure: error: Package requirements (dbus-1 >= 0.36, dbus-glib-1 >= 0.36) were not met: No package 'dbus-glib-1' found Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix. Alternatively, you may set the environment variables DBUS_CFLAGS and DBUS_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details. [root@xxx btsco]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Listopad 7, 2007 Zgłoszenie Share Napisano Listopad 7, 2007 NIe moge zainstalowac wg opisu z http://fedorasolved.org/post-install-solut...headset-config/ przy [root@xxx btsco]# ./configure dostaje taki output [root@xxx btsco]# ./configure --->8---- No package 'dbus-glib-1' found [root@xxx btsco]# Proponuję yum install dbus-glib-devel Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 7, 2007 Autor Zgłoszenie Share Napisano Listopad 7, 2007 a teraz dalej [root@xxx kernel]# make make: *** /lib/modules/2.6.22.9-91.fc7/build: Nie ma takiego pliku ani katalogu. Stop. make: *** [default] Błąd 2 [root@xxx kernel]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 yum intall kernel-devel Powinno pomóc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 8, 2007 Autor Zgłoszenie Share Napisano Listopad 8, 2007 [root@xxx kernel]# make make: *** /lib/modules/2.6.22.9-91.fc7/build: Nie ma takiego pliku ani katalogu. Stop. make: *** [default] Błąd 2 [root@xxx kernel]# dalej to samo. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 dalej to samo yum install kernel-headers powinno zalatwic sprawe... Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 yum install kernel-headers powinno zalatwic sprawe...A jak nie to jeszcze kernel-devel... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 8, 2007 Autor Zgłoszenie Share Napisano Listopad 8, 2007 [root@xxx kernel]# yum -y install kernel-headers Setting up Install Process Parsing package install arguments Resolving Dependencies --> Running transaction check ---> Package kernel-headers.i386 0:2.6.23.1-10.fc7 set to be updated --> Finished Dependency Resolution Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kernel-headers i386 2.6.23.1-10.fc7 updates 644 k Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 644 k Downloading Packages: http://sunsite.icm.edu.pl/pub/Linux/fedora...0.fc7.i386.rpm: [Errno 14] HTTP Error 404: Date: Thu, 08 Nov 2007 10:38:09 GMT Server: Apache/2.0.55 (Unix) Content-Length: 357 Content-Type: text/html; charset=iso-8859-1 Trying other mirror. (1/1): kernel-headers-2.6 100% |=========================| 644 kB 00:01 Running rpm_check_debug Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: kernel-headers ######################### [1/1] Installed: kernel-headers.i386 0:2.6.23.1-10.fc7 Complete! [root@xxx kernel]# make make: *** /lib/modules/2.6.22.9-91.fc7/build: Nie ma takiego pliku ani katalogu. Stop. make: *** [default] Błąd 2 [root@xxx kernel]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 [root@xxx kernel]# yum -y install kernel-headers ... Installed: kernel-headers.i386 0:2.6.23.1-10.fc7 Complete! [root@xxx kernel]# make make: *** /lib/modules/2.6.22.9-91.fc7/build: Nie ma takiego pliku ani katalogu. Stop. make: *** [default] Błąd 2 Zdecyduj sie dla jakiego jadra chcesz to kompilowac! Najnowszy zainstalowany w systemie to 2.6.23.1-10 (i dla niego wlasnie yum dociagnal pliki z naglowkami) a kompilujesz nie wiedziec czemu dla 2.6.22.9-91 (uruchamiasz system na starszym jadrze?) ... Zrob porzadek z kernelami (czemu nie uzywasz najnowszego?) i dopiero kompiluj... Powodzenia BTW: WalDo - kernel-devel juz mu kolega InIrudeBwoy proponowal... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 8, 2007 Autor Zgłoszenie Share Napisano Listopad 8, 2007 omg, czekaj, czekaj, to moje pierwsze proby kompilowania czegokolwiek powiedz mi jesli mozesz jak mam to zrobic na najnowszym jadrze. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 Nie wiem co Ty tam masz, ale zacznijmy od tych 3 polecen: uname -a rpm -qa | grep kernel |sort cat /boot/grub/grub.conf i wszystko bedzie jasne... a przynajmniej tak mi sie zdaje Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 8, 2007 Autor Zgłoszenie Share Napisano Listopad 8, 2007 [root@xxx ~]# uname -a Linux xxx 2.6.22.9-91.fc7 #1 SMP Thu Sep 27 23:10:59 EDT 2007 i686 athlon i386 GNU/Linux [root@xxx ~]# rpm -qa | grep kernel |sort kernel-2.6.22.9-91.fc7 kernel-2.6.23.1-10.fc7 kernel-devel-2.6.23.1-21.fc7 kernel-headers-2.6.23.1-10.fc7 kernel-xen-2.6.20-2925.9.fc7 kernel-xen-2.6.20-2936.fc7 [root@xxx ~]# cat /boot/grub/grub.conf # grub.conf generated by anaconda # # Note that you do not have to rerun grub after making changes to this file # NOTICE: You have a /boot partition. This means that # all kernel and initrd paths are relative to /boot/, eg. # root (hd0,1) # kernel /vmlinuz-version ro root=/dev/VolGroup00/LogVol00 # initrd /initrd-version.img #boot=/dev/mapper/pdc_cgbfcjgb default=2 timeout=5 splashimage=(hd0,1)/grub/splash.xpm.gz hiddenmenu title Fedora (2.6.23.1-10.fc7) root (hd0,1) kernel /vmlinuz-2.6.23.1-10.fc7 ro root=/dev/VolGroup00/LogVol00 rhgb quiet initrd /initrd-2.6.23.1-10.fc7.img title Fedora (2.6.20-2936.fc7xen) root (hd0,1) kernel /xen.gz-2.6.20-2936.fc7 module /vmlinuz-2.6.20-2936.fc7xen ro root=/dev/VolGroup00/LogVol00 rhgb quiet module /initrd-2.6.20-2936.fc7xen.img title Fedora (2.6.22.9-91.fc7) root (hd0,1) kernel /vmlinuz-2.6.22.9-91.fc7 ro root=/dev/VolGroup00/LogVol00 rhgb quiet initrd /initrd-2.6.22.9-91.fc7.img title Fedora (2.6.20-2925.9.fc7xen) root (hd0,1) kernel /xen.gz-2.6.20-2925.9.fc7 module /vmlinuz-2.6.20-2925.9.fc7xen ro root=/dev/VolGroup00/LogVol00 rhgb quiet module /initrd-2.6.20-2925.9.fc7xen.img title winda rootnoverify (hd0,0) chainloader +1 [root@xxx ~]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 No dobra, wiec zacznijmy porzadki... Na dzien dobry w konsoli jako root gedit /boot/grub/grub.conf i w linijce nr 10 (jesli sie nie pomylilem w liczeniu...) default=2 zmien na default=0 Zapisz, zrestartuj, sprawdz czy wszystko dziala, jesli tak to jedziemy dalej - Teraz znow w konsoli, znow jako root yum remove kernel-xen* na wszelki wypadek przyjrzyj sie pakietom zaproponowanym do usuniecia bo zdarza sie, ze yum troche za szeroko rozwiazuje zaleznosci... jesli znajda sie tam tylko pakiety kernel-xen* to potwierdz usuniecie, jesli nie tylko - zaniechaj i pokaz co Ci wylistowal. Zaraz bedziemy w domu Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
p4v3u Napisano Listopad 8, 2007 Autor Zgłoszenie Share Napisano Listopad 8, 2007 zrobioioone Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 8, 2007 Zgłoszenie Share Napisano Listopad 8, 2007 Teraz (stanowczo polecane) yum update lub, jesli nie masz czasu to yum update kernel Jak sie skonczy - restart, po restarcie pokaz ponownie uname -a rpm -qa | grep kernel | sort cat /boot/grub/grub.conf Pozdro BTW - cos Ci sie 2 posty klepnely, zdublowany usunalem... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
