KasiK Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 Witam, Mam problem jak w temacie Paczka yum-priorities pobrana została ze str. http://faq.fedorapl.org/f7/#yumconf Z tego co zrozumiałam nie są odczylywalne pliki xhml Tak wygląda okno terminala przy próbie instalacji jakiegokolwiek programu bash-3.2# yum update fedora 100% |=========================| 2.1 kB 00:00 Could not retrieve mirrorlist http://www.dfm.uninsubria.it/compiz/mirror-f7-x86_64 error was [Errno 14] HTTP Error 404: Date: Sat, 10 May 2008 01:26:19 GMT Server: Apache/2.0.52 (Red Hat) Content-Length: 309 Connection: close Content-Type: text/html; charset=iso-8859-1 Error: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again Ponadto, przy próbie aktualizacji softu wyskakuje lista pokaźna błędów: Component: Software Updater Summary: TBaa62cbac yumRepo.py:770:_getRepoXML:RepoError: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again Traceback (most recent call last): File "/usr/sbin/pup", line 647, in <module> main() File "/usr/sbin/pup", line 640, in main pup = PackageUpdater(not options.autoapply) File "/usr/sbin/pup", line 88, in __init__ GraphicalYumBase.__init__(self, False) File "/usr/lib/python2.5/site-packages/pirut/__init__.py", line 123, in __init__ self.reset() File "/usr/lib/python2.5/site-packages/pirut/__init__.py", line 222, in reset self.doTsSetup() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 72, in doTsSetup return self._getTs() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 85, in _getTs self._getTsInfo() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 91, in _getTsInfo self._tsInfo.setDatabases(self.rpmdb, self.pkgSack) File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 529, in <lambda> pkgSack = property(fget=lambda self: self._getSacks(), File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 384, in _getSacks self.repos.populateSack(which=repos) File "/usr/lib/python2.5/site-packages/yum/repos.py", line 242, in populateSack sack.populate(repo, mdtype, callback, cacheonly) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 142, in populate if self._check_db_version(repo, mydbtype): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 199, in _check_db_version if repo.repoXML.repoData.has_key(mdtype): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 774, in <lambda> repoXML = property(fget=lambda self: self._getRepoXML(), File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 770, in _getRepoXML raise Errors.RepoError, msg RepoError: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again Local variables in innermost frame: msg: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again self: fusion e: Cannot find a valid baseurl for repo: fusion W oknie dodaj /usuń programy sytuacja jest podobna Component: Software Manager Summary: TBaa62cbac yumRepo.py:770:_getRepoXML:RepoError: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again Traceback (most recent call last): File "/usr/sbin/pirut", line 428, in <module> main() File "/usr/sbin/pirut", line 421, in main pm = PackageManager(options.config, options.onlyrepo) File "/usr/sbin/pirut", line 61, in __init__ GraphicalYumBase.__init__(self, False, config) File "/usr/lib/python2.5/site-packages/pirut/__init__.py", line 123, in __init__ self.reset() File "/usr/lib/python2.5/site-packages/pirut/__init__.py", line 222, in reset self.doTsSetup() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 72, in doTsSetup return self._getTs() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 85, in _getTs self._getTsInfo() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 91, in _getTsInfo self._tsInfo.setDatabases(self.rpmdb, self.pkgSack) File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 529, in <lambda> pkgSack = property(fget=lambda self: self._getSacks(), File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 384, in _getSacks self.repos.populateSack(which=repos) File "/usr/lib/python2.5/site-packages/yum/repos.py", line 242, in populateSack sack.populate(repo, mdtype, callback, cacheonly) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 142, in populate if self._check_db_version(repo, mydbtype): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 199, in _check_db_version if repo.repoXML.repoData.has_key(mdtype): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 774, in <lambda> repoXML = property(fget=lambda self: self._getRepoXML(), File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 770, in _getRepoXML raise Errors.RepoError, msg RepoError: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again Local variables in innermost frame: msg: Cannot retrieve repository metadata (repomd.xml) for repository: fusion. Please verify its path and try again self: fusion e: Cannot find a valid baseurl for repo: fusion Co mam zrobić aby wszystko dobrze działało?! Posidam: KDE 3.5.7-0.1fc Fedora, 2.6.20-2936.fc7xen, x-86_64 Proszę o łopatologiczne instrukcje, krok po kroku (Tego systemu chyba nidy nie rozkminię - czarna magia) Pozdrawiam i błagam o pomoc !! !! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morsik Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 Pisze wyraźnie ze nie może pobrać listy mirrorow repozytorium fusion. Przyczyną może być na przykład usunięcie repozytorium, ponieważ już nie długo zostanie wydana Fedora 9 a wersja 7 przestanie być wspierana. Najprostszy sposób: w pliku /etc/yum.repos.d/fusion.repo (możliwe że jest inna u Ciebie) wszędzie gdzie jest pole enabled daj 0 (zero, nie litera 'o'). Oczywiście z roota, a potem spróbuj znów zaaktualizować. I pamiętaj: czytaj błędy bo w nich wszystko pisze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
multics Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 ewentualnie możesz spróbować yum update --disablerepo fusion* Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 To mogły być tymczasowe błędy. Ja jeszcze dzisiaj aktualizowałem compiz z tego repo. Co prawda dla F8, morsik może mieć rację. Czas na update do F9 Na razie wyłącz to repo i aktualizuj system. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 Lub po prostu problemy z netem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
arni Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 To już jest koniec repo compiz-fusion dla F7: http://www.dfm.uninsubria.it/compiz/fusion/ dlatego masz takie błędy przy aktualizacji. Czas przejść na F8 lub F9. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 EOL dla Fedory 7 nastąpi 13 czerwca, także polecam zastosować się do wskazówki arniego, i uaktualnić system do F9 - ukaże się 13 maja. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
KasiK Napisano Maj 10, 2008 Autor Zgłoszenie Share Napisano Maj 10, 2008 Oczywiście z roota, a potem spróbuj znów zaaktualizować. Żaden sposób nie pomógł. Jak się edytuje plik z możliwością zapisu spod roota? :?: U mnie szwankuje chyba plik copiz-fuzion, bo to on został utworzony dwa dni temu PS Miało być łopatologicznie :?: !! A jak i czy mgę wywalić compoz-fuzion, może wtedy będzie tak jak dawniej :?: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morsik Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 Oczywiście możesz wywalić. Tylko nie wywalaj nic co ma w nazwie livna albo fedora Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 A jak (...)A poleceniem rm. Podstawy linuksa się kłaniają Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
KasiK Napisano Maj 10, 2008 Autor Zgłoszenie Share Napisano Maj 10, 2008 /etc/yum.repos.d/fusion.repo (możliwe że jest inna u Ciebie) wszędzie gdzie jest pole enabled daj 0 (zero, nie litera 'o'). Oczywiście z roota, a potem spróbuj znów zaaktualizować. Dzięki, pomogło! Trochę się naszukałam aby znależć sposób edytowania spod roota!! A prosiłam, łopatologicznie - byłoby szybciej! wpisałam: gedit /etc/yum.repos.d/compiz-fusion.repo i wszysto działa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 A prosiłam, łopatologicznie - byłoby szybciej! A widzisz, jak byś się choć trochę zainteresowała sama podstawami linuksa, to byłoby jeszcze szybciej, i bez zbędnej pisaniny na forum. Nikt za Ciebie się podstaw nie nauczy, jeśli tego nie zrobisz sama. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
