Bob3k Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 Witam, mam nastepujacy problem z pendrivem. Dzialal normalnie - automatycznie sie montowal, nie bylo problemow z zapisem i odczytem. Nie wiem co sie wydarzylo, ale teraz pen nie montuje sie ani automatycznie, ani recznie. Probowalem go odpalic w Windzie, system stwierdza ze nie jest sformatowany. Reczne montowanie zwraca nastepujacy komunikat: [root@localhost /]# mount -t vfat /dev/sdb /media/usb mount: wrong fs type, bad option, bad superblock on /dev/sdb, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so Zapis z logu i dmesg: ot@localhost /]# tail -f var/log/messages Jan 7 17:11:51 localhost kernel: sd 7:0:0:0: [sdb] Write Protect is off Jan 7 17:11:51 localhost kernel: sd 7:0:0:0: [sdb] Assuming drive cache: write through Jan 7 17:11:51 localhost kernel: sdb: sdb1 Jan 7 17:11:51 localhost kernel: sd 7:0:0:0: [sdb] Attached SCSI removable disk Jan 7 17:11:51 localhost kernel: sd 7:0:0:0: Attached scsi generic sg2 type 0 Jan 7 17:12:30 localhost acpid: received event "thermal_zone TZ 00000081 00000000" Jan 7 17:12:30 localhost acpid: notifying client 2274[68:68] Jan 7 17:12:30 localhost acpid: notifying client 2467[0:0] Jan 7 17:12:30 localhost acpid: completed event "thermal_zone TZ 00000081 00000000" Jan 7 17:16:18 localhost kernel: usb 1-1: USB disconnect, address 7 Jan 7 17:17:21 localhost kernel: usb 1-1: new full speed USB device using ohci_hcd and address 8 Jan 7 17:17:21 localhost kernel: usb 1-1: configuration #1 chosen from 1 choice Jan 7 17:17:21 localhost kernel: scsi8 : SCSI emulation for USB Mass Storage devices Jan 7 17:17:26 localhost kernel: scsi 8:0:0:0: Direct-Access Kingston DataTraveler 2.0 1.00 PQ: 0 ANSI: 2 Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] 7823296 512-byte hardware sectors (4006 MB) Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] Write Protect is off Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] Assuming drive cache: write through Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] 7823296 512-byte hardware sectors (4006 MB) Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] Write Protect is off Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] Assuming drive cache: write through Jan 7 17:17:26 localhost kernel: sdb: sdb1 Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: [sdb] Attached SCSI removable disk Jan 7 17:17:26 localhost kernel: sd 8:0:0:0: Attached scsi generic sg2 type 0 [root@localhost /]# dmesg|tail sd 8:0:0:0: [sdb] Write Protect is off sd 8:0:0:0: [sdb] Mode Sense: 65 44 09 30 sd 8:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 sd 8:0:0:0: [sdb] Attached SCSI removable disk sd 8:0:0:0: Attached scsi generic sg2 type 0 FAT: invalid media value (0x00) VFS: Can't find a valid FAT filesystem on dev sdb. FAT: bogus logical sector size 65535 VFS: Can't find a valid FAT filesystem on dev sdb1. Z tego co udalo mi sie ustalic to to ze informacja o systemie plikow na USB zostala uszkodzona albo nadpisana. (tak przypuszczam) Czy da sie cos z tym zrobic i uratowac dane na pendrivie? Dzialam na Fedorze 8 USB : Kingston DT100 4GB Pozdrawiam Bob3k Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 Załóż od nową partycję, filesystem i powinno być po kłopocie chyba. Jako root: fdisk /dev/sdb #usun istniejące partycje, załóż na nowo, zapisz mkfs.vfat /dev/sdb1 A może wystarczy fsck -f /dev/sdb1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arabski Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 Brakuje numerków panowie! Wszędzie poza fdiskiem powinno być /dev/sdb1 a jak widać nie jest. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 Brakuje numerków panowie!Ech... tak mi czasem mózg zatyka Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arabski Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 No i jeszcze: Z tego co udalo mi sie ustalic to to ze informacja o systemie plikow na USB zostala uszkodzona albo nadpisana. (tak przypuszczam) Czy da sie cos z tym zrobic i uratowac dane na pendrivie? Załóż od nową partycję, filesystem i powinno być po kłopocie chyba. I po danych również Kolego autorze - musisz sięgnąć po program do odzyskiwania danych. Tylko obawiam się, że będziesz musiał się w tym celu posłużyć Windą, bo ja osobiście nie znam programów do naprawy/odzyskiwania danych dla nielota. (proszę nie bić za sugestię) Frywolne fsck tego pendriva może spowodować pożegnanie się z danymi na stałe. (Że o zakładaniu partycji i fs'a nie wpomnę). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 I po danych również O cholera... Za to muszę przeprosić - mam nadzieję, że nie po fakcie. Nie zwróciłem uwagi na "uratowac dane na pendrivie". W ramach przeprosin proponuję skorzystać z testdisk - jest w repozytoriach Fedory, a tu kilka słów o programie → http://www.cgsecurity.org/wiki/TestDisk Dodam, że przy jego pomocy odtworzyłem jakiś czas temu partycje i dane ze sformatowanego dysku (przed ponownym zapisem danych po sformatowaniu). Mam nadzieję, że jakby co to się przyda. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Bob3k Napisano Styczeń 7, 2009 Autor Zgłoszenie Share Napisano Styczeń 7, 2009 Hmm.. no po fakcie... Szczesliwie nic strasznego sie nie stalo, bo pen jest nowy i dopiero poprzerzucalem na niego rozne dokumenty z dotychczas uzywanych flashow. Backup jest wiec nie trzeba niczego odzyskiwac. W kazdym badz razie i tak dzieje sie dziwna rzecz. Przeprowadzilem zgodnie z instrukcjami fdisk -> usuniecie , nowa partycja,zapis mkfs.vfat (nota bene wymusil uzycie parametru -I) Dysk sie automatycznie montuje, ale wolne miejsce 3,7 GB zamiast 4 A fdisk pokazuje teraz brak partycji. Zapis na dysku jest mozliwy I jeszcze jedna rzecz: Zmienila sie chyba "struktura dysku", w sensie zmienily sie liczby cylindrow, heads,sectors, Np dla cylindrow 3880 na 1017 . Czy to jakos wplywa na szybkosc zapisu/odczytu? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arabski Napisano Styczeń 7, 2009 Zgłoszenie Share Napisano Styczeń 7, 2009 Dysk sie automatycznie montuje, ale wolne miejsce 3,7 GB zamiast 4 A fdisk pokazuje teraz brak partycji. ... Zmienila sie chyba "struktura dysku", w sensie zmienily sie liczby cylindrow, heads,sectors, Np dla cylindrow 3880 na 1017 . Czy to jakos wplywa na szybkosc zapisu/odczytu? A wcześniej było więcej? Może chodzi o oszukane gigabajty? Co do struktury - czasami się tak miesza. Nie ma się czym przejmować. Żeby wyjaśnić do końca, mógłbyś dać wyniki df -k df -h fdisk -l /dev/jaki_tam_ten_pen_ma_sd Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Bob3k Napisano Styczeń 8, 2009 Autor Zgłoszenie Share Napisano Styczeń 8, 2009 Szczerze to glowy sobie nie dam uciac za te 4 GB, bo nie mam tego na papierze. Ale wydaje mi sie ze jednak byly pelne 4. A to wyniki z komend: [root@localhost /]# df -k System plików bl. 1K B użyte dostępne %uż. zamont. na /dev/sda2 9920624 3873444 5535112 42% / /dev/sda5 17786848 10261408 6607328 61% /home tmpfs 111392 12 111380 1% /dev/shm /dev/sr0 3344482 3344482 0 100% /media/Fedora 8 i386 DVD /dev/sdb 3904004 8 3903996 1% /media/disk [root@localhost /]# df -h System plików rozm. użyte dost. %uż. zamont. na /dev/sda2 9,5G 3,7G 5,3G 42% / /dev/sda5 17G 9,8G 6,4G 61% /home tmpfs 109M 12K 109M 1% /dev/shm /dev/sr0 3,2G 3,2G 0 100% /media/Fedora 8 i386 DVD /dev/sdb 3,8G 8,0K 3,8G 1% /media/disk [root@localhost /]# fdisk -l /dev/sdb Disk /dev/sdb: 4005 MB, 4005527552 bytes 124 heads, 62 sectors/track, 1017 cylinders Units = cylinders of 7688 * 512 = 3936256 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System [root@localhost /]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 Z polecenia "fdisk -l /dev/sdb" wynika, że znowu jest tak jak napisałem początkowo (ŹLE!!!) i na co zwrócił mi uwagę Arabski: /dev/sdb zamiast /dev/sdb1. Poprawiłem to w swoim pierwszym poście. Powinieneś założyć partycję /dev/sdb1 typu - o ile się nie mylę - "b" (FAT32) na dysku /dev/sdb. Wtedy nie będzie potrzebna również opcja "-I" przy tworzeniu filesystemu, bo będzie on tworzony na partycji a nie na całym dysku. W szczególnym przypadku oczywiście partycja może zajmować cały dysk i najlepiej tak właśnie zrób. Od razu struktura się pewnie zmieni. Pojemność jest ewidentnie oszukana 4005527552 bajtów (widoczne w fdisk) liczą jako 4GB czyli tak naprawdę to w przybliżeniu jest 3,7GB. Dość istotna różnica między 1024*1024*1024 a 1000*1000*1000 Znany numer również - a może przede wszystkim - z fałszowaniem pojemności dysków twardych. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 Do odzyskiwania danych mozna użyć http://www.cgsecurity.org/wiki/TestDisk_Download Jest w repo. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 Z tą pojemnością to sytuacja całkiem normalna od zawsze dla producentów dysków podstawą w obliczaniu pojemności była 10, a nie 2. Na 90% z dyskiem twardym masz taką samą sytuację. Tylko oczywiście im większa pojemność tym strata jest mniej odczuwalna. Mnie na pendrive 4gb okradli na 70MB Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arabski Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 Jako efekt tego "oszustwa" Seagate swego czasu udostępniło Acronis True Imge do zassania za darmo (link). Tylko oczywiście im większa pojemność tym strata jest mniej odczuwalna. Wręcz przeciwnie. Im większy dysk, tym większa strata Popatrz na ile mnie okradli /dev/hda1 699G 374G 325G 54% /export/vol75a /dev/hdb1 699G 670G 30G 96% /export/vol75b /dev/hdc1 699G 670G 29G 96% /export/vol75c /dev/hdd1 187G 185G 1.7G 100% /export/vol20a [root@nodezero ~]# fdisk -l | grep Disk Disk /dev/hda: 750.1 GB, 750156374016 bytes Disk /dev/hdb: 750.1 GB, 750156374016 bytes Disk /dev/hdc: 750.1 GB, 750156374016 bytes Disk /dev/hdd: 400.0 GB, 400088457216 bytes Po 51GB z każdego :lammer: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 Do odzyskiwania danych mozna użyćMówiłem... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Styczeń 8, 2009 Zgłoszenie Share Napisano Styczeń 8, 2009 OMG Arabski co Ty trzymasz tych dyskach? Przynaję się WalDo, nie czytałem całego wątku. To już ostatni raz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
