Nvidia + Nowy Kernel = Bum
fsosport
Witam,
wczoraj polecialy mi aktalizacje i widze ze wgralo nowy kernel 2.6.29.6-213.fc11.i586
dotychczas mialem 2.6.29.5-191.fc11.i586
i po restarcie systemu, zaladowal sie z sterownikami 'vesta'. wklepalem nvidia-xconfig i poszlo z bledami
Using X configuration file: "/etc/X11/xorg.conf".
WARNING: No Screen specified, constructing implicit screen section.
WARNING: No Layout specified, constructing implicit layout section using screen
         "Default Screen".
WARNING: Unable to find CorePointer in X configuration; attempting to add new
         CorePointer section.
WARNING: The CorePointer device was not specified explicitly in the layout;
         using the first mouse device.
WARNING: Unable to find CoreKeyboard in X configuration; attempting to add new
         CoreKeyboard section.
WARNING: The CoreKeyboard device was not specified explicitly in the layout;
         using the first keyboard device.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
i teraz po restarcie zaraz po tym pasku loading trzy kolorowym pojawia sie w lewym gornym ekranie migajacy kursor i tak stoi... no i to by bylo na tyle.
co najlepsza wlaczylem stary kernel i dziala ... ale... przy compizie znikenly obramowania/belki ktorych nie da sie przywrocic, wykonalem tutaj tez nvidia-xconfig poszlo bez bledow ale belek jak nie bylo tak nie ma. probowalem usunac kmod-nvidia i zainstalowac jeszcze raz ale nic to nie dalo
konfiguracja xorga na starym kelnerze gdziue nie dzialaja belki..
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder63)  Wed May 27 03:15:36 PDT 2009
# Xorg configuration created by livna-config-display
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen         "Default Screen" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    ModulePath      "/usr/lib/xorg/modules"
EndSection
Section "ServerFlags"
    Option         "AIGLX" "on"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Keyboard0"
    Driver         "keyboard"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Videocard0"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Default Screen"
    Device         "Videocard0"
    Monitor        "Monitor0"
    SubSection     "Display"
        Modes      "nvidia-auto-select"
    EndSubSection
EndSection
Section "Extensions"
    Option         "Composite" "Enable"
EndSection
ktos ma jakis pomysl ? bo mnie tu juz .... :]
A próbowałeś zainstalować "kmod-nvidia" dla tego nowego jądra .
Sprawdź yumem czy jest on dostępny .
tak, usuwalem i instalowalem na nowo na tym nowym :] wersja 185.18.14
bo mimo wszystko jak wrzuce w xorga 'vesa' to dziala ... ale rozdzialka jest porazajaca :)
literowka
kawalek loga:
Checking for module nvidia.ko: [60G[[0;32m  OK  [0;39m]
Enabling the nvidia driver: *** glibc detected *** /usr/bin/python: free(): invalid pointer: 0x00e7e24a ***
Miałem dokładnie to samo i też odpalałem system na poprzedniej wersji kernela. Wszystko wróciło do normy następnego dnia, kiedy wyszła aktualizacja kmod-nvidii do obecnej wersji kernela.
Po prostu czasami warto zaczekać z aktualizacja - mój błąd był taki, że nie sprawdziłem dokładnie co się aktualizuje (zazwyczaj sprawdzam) i dlatego po restarcie miałem niespodziankę. ;)
JoleKK
wielkie dzieki
zainstalowalem wersje na to jadro z tej strony i dziala wszystko :)
z repo jak instalowalem za cholere nie chcialo ruszyc :)
Nie chciało ruszyć, bo nie było odpowiedniej paczki dla nowego jądra na tych mirrorach, z których akurat Ty korzystasz a na tuniv.szczecin.pl już się zreplikowało.
Wystarczy poczekać dzień-dwa i wszystko wraca do normy. A jak nie możesz żyć przez 2 dni bez sterów to do czasu wydania nowych pracuj na starym jajku.
A ja daję polecenie "yum install kmod-nvidia" i mi odpowiada że takiego pakietu wcale nie ma :o
A chciałem zainstalować ten ściągniety ręcznie to mi wywaliło tak ;
[root@localhost ~]# rpm -ivh kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm
ostrzeżenie: kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm: Podpis Nagłówek V3 RSA/SHA256: NOKEY, identyfikator klucza 8dc43844
        nvidia-kmod-common >= 185.18.14 jest wymagany przez kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586
[root@localhost ~]# yum install nvidia-kmod-common
Wczytane wtyczki: refresh-packagekit
Ustawianie procesu instalacji
Nie ma pakietu nvidia-kmod-common.
Nie ma niczego do zrobienia
[root@localhost ~]#
Co robię źle ? repo rpmfuzion dodałem :(
Po pierwsze, To instaluj paczek bezpośrednio przez RPM-a, do instalacji paczek tylko yuma przez:
yum localinstall paczka.rpm
Po drugie kmod-nvidia krzyczy o stery czyli xorg-x11-drv-nvidia i xorg-x11-drv-nvidia-libs. Jeżeli Yum nie odświeży repozytoriów to daj:
wget http://download1.rpmfusion.org/nonfree/fedora/updates/11/i386/xorg-x11-drv-nvidia-185.18.14-3.fc11.i586.rpm http://download1.rpmfusion.org/nonfree/fedora/updates/11/i386/xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586.rpm http://download1.rpmfusion.org/nonfree/fedora/updates/11/i386/kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm
I:
yum localinstall xorg-x11-drv-nvidia-185.18.14-3.fc11.i586.rpm xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586.rpm kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm
Będziesz miał mniej burdelu.
Zastosowałem sie Piotrek23 do twojej porady i prosze co wychodzi z tego
[root@localhost ~]# yum localinstall xorg-x11-drv-nvidia-185.18.14-3.fc11.i586.rpm xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586.rpm kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm
Ustawianie procesu lokalnego pakietu
Sprawdzanie xorg-x11-drv-nvidia-185.18.14-3.fc11.i586.rpm: xorg-x11-drv-nvidia-185.18.14-3.fc11.i586
Oznaczanie xorg-x11-drv-nvidia-185.18.14-3.fc11.i586.rpm do zainstalowania
Sprawdzanie xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586.rpm: xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586
Oznaczanie xorg-x11-drv-nvidia-libs-185.18.14-3.fc11.i586.rpm do zainstalowania
Sprawdzanie kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm: kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586
Oznaczanie kmod-nvidia-2.6.29.6-213.fc11.i586-185.18.14-1.fc11.2.i586.rpm do zainstalowania
Rozwiązywanie zależności
--> Wykonywanie sprawdzania transakcji
---> Pakiet kmod-nvidia-2.6.29.6-213.fc11.i586.i586 0:185.18.14-1.fc11.2 zostanie zaktualizowany
---> Pakiet xorg-x11-drv-nvidia.i586 0:185.18.14-3.fc11 zostanie zaktualizowany
--> Przetwarzanie zależności: livna-config-display >= 0.0.21 dla pakietu: xorg-x11-drv-nvidia-185.18.14-3.fc11.i586
--> Przetwarzanie zależności: livna-config-display dla pakietu: xorg-x11-drv-nvidia-185.18.14-3.fc11.i586
---> Pakiet xorg-x11-drv-nvidia-libs.i586 0:185.18.14-3.fc11 zostanie zaktualizowany
--> Zakończono rozwiązywanie zależności
xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 z /xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 ma problemy z rozwiązywaniem zależności
  --> Brakująca zależność: livna-config-display jest wymagane przez pakiet xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 (/xorg-x11-drv-nvidia-185.18.14-3.fc11.i586)
  --> Brakująca zależność: livna-config-display >= 0.0.21 jest wymagane przez pakiet xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 (/xorg-x11-drv-nvidia-185.18.14-3.fc11.i586)
Błąd: Brakująca zależność: livna-config-display >= 0.0.21 jest wymagane przez pakiet xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 (/xorg-x11-drv-nvidia-185.18.14-3.fc11.i586)
Błąd: Brakująca zależność: livna-config-display jest wymagane przez pakiet xorg-x11-drv-nvidia-185.18.14-3.fc11.i586 (/xorg-x11-drv-nvidia-185.18.14-3.fc11.i586)
Powinieneś spróbować użyć --skip-broken, aby obejść problem
Można spróbować wykonać: package-cleanup --problems
                          package-cleanup --dupes
                          rpm -Va --nofiles --nodigest
[root@localhost ~]#
Jednak na ubuntu nie ma takich problemów z instalacją sterów nvidii i programem zynaddsubfx
