Brak Połączenia Sieciwego Przy Aktualizacji
qwert45
hello_world: "Magiczno kulo powiedz nam więcej ponieważ qwerty45 nie raczył nas zapoznać szerzej z problemem"
Magiczna kula: "proszę pzrekazać qwerty45 aby pokazał najważniejsze listingi z poleceń, które mają wplyw na ustawienia sieciowe"
hello-world: "Wiesz co magiczno kulo tyle to i ja wiem ale przecież qwertemu45 dziala i niedziala internet i co ty na to"
1) tak
2)
razem 16
-rw-r--r--. 1 root root 1785 05-12 00:45 fedora-rawhide.repo
-rw-r--r--. 1 root root 1144 05-12 00:45 fedora.repo
-rw-r--r--. 1 root root 1105 05-12 00:45 fedora-updates.repo
-rw-r--r--. 1 root root 1163 05-12 00:45 fedora-updates-testing.repo
3)
[main]
cachedir=/var/cache/yum
keepcache=0
debuglevel=2
logfile=/var/log/yum.log
exactarch=1
obsoletes=1
gpgcheck=1
plugins=1
installonly_limit=3
# This is the default, if you make this bigger yum won't see if the metadata
# is newer on the remote and so you'll "gain" the bandwidth of not having to
# download the new metadata and "pay" for it by yum not having correct
# information.
# It is esp. important, to have correct metadata, for distributions like
# Fedora which don't keep old packages around. If you don't like this checking
# interupting your command line usage, it's much better to have something
# manually check the metadata once an hour (yum-updatesd will do this).
# metadata_expire=90m
# PUT YOUR REPOS HERE OR IN separate files named file.repo
# in /etc/yum.repos.d
[updates]
name=Fedora $releasever - $basearch - Updates
failovermethod=priority
#baseurl=http://download.fedoraproject.org/pub/fedora/linux/updates/$releasever/$basearch/
mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=updates-released-f$releasever&arch=$basearch
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora-$basearch
[updates-debuginfo]
name=Fedora $releasever - $basearch - Updates - Debug
#baseurl=http://download.fedoraproject.org/pub/fedora/linux/updates/$releasever/$basearch/debug/
mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=updates-released-debug-f$releasever&arch=$basearch
enabled=0
gpgcheck=1
[updates-source]
name=Fedora $releasever - Updates Source
#baseurl=http://download.fedoraproject.org/pub/fedora/linux/updates/$releasever/SRPMS/
mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=updates-released-source-f$releasever&arch=$basearch
enabled=0
gpgcheck=1
Zrobiłem to jeszcze raz, wypisało mi co zastanie zaktualizowane a (_puźniej_ → później) ORT:
PackageKit-glib-0.4.6-8.fc11.i586 z installed ma problemy z rozwiązywaniem zależności
--> Brakująca zależność: PackageKit = 0.4.6-8.fc11 jest wymagane przez pakiet PackageKit-glib-0.4.6-8.fc11.i586 (installed)
4:perl-libs-5.10.0-68.fc11.i586 z installed ma problemy z rozwiązywaniem zależności
--> Brakująca zależność: perl = 4:5.10.0-68.fc11 jest wymagane przez pakiet 4:perl-libs-5.10.0-68.fc11.i586 (installed)
Błąd: Brakująca zależność: PackageKit = 0.4.6-8.fc11 jest wymagane przez pakiet PackageKit-glib-0.4.6-8.fc11.i586 (installed)
Błąd: Brakująca zależność: perl = 4:5.10.0-68.fc11 jest wymagane przez pakiet 4:perl-libs-5.10.0-68.fc11.i586 (installed)
Powinieneś spróbować użyć --skip-broken, aby obejść problem
Można spróbować wykonać: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
