thof Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 Ehh a ja myślałem, że już wszędzie dają darmowe routery... Rozłącz, a potem podłącz na nowo urządzenie i załaduj moduł (chociaż powinien być ładowany automatycznie) i wrzuć tu co pojawi się w konsoli po wydaniu komendy dmesg Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 (edytowane) Zrobilem: [root@Moj-Komputer Linnet]# modprobe speedtch [root@Moj-Komputer Linnet]# /sbin/lsmod | grep speedtch speedtch 12196 0 usbatm 14572 1 speedtch [root@Moj-Komputer Linnet]# rmmod speedtch [root@Moj-Komputer Linnet]# modprobe speedtch [root@Moj-Komputer Linnet]# /sbin/lsmod | grep speedtch speedtch 12196 0 usbatm 14572 1 speedtch [root@Moj-Komputer Linnet]# pppd call linnet Plugin pppoatm.so loaded. PPPoATM plugin_init PPPoATM setdevname_pppoatm - SUCCESS:0.35 Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. [root@Moj-Komputer Linnet]# dodam tylko ze w trakcie tej czynnosci dioda miga, o ile ma to znaczenie zas modem w usb wpiety Edytowane Maj 27, 2010 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 to oczywiscie zrobilem zanim pojawil sie post thof'a, ide zawalczyc raz jeszcze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 Diody nie mogą migać, bo to oznacza brak synchronizacji z linią. Napisz w jaki sposób logujesz się na roota oraz wklej zawartości plików cat /etc/ppp/peers/linnet i cat /etc/ppp/chap-secrets . Tego dmesg wklej po wykonaniu próby połączenie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 (edytowane) oj, zapaskudze cala strone tym wpisem, ale ok: po wpisaniu dmesg: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver uhci_hcd: USB Universal Host Controller Interface driver uhci_hcd 0000:00:1d.0: power state changed by ACPI to D0 uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11 uhci_hcd 0000:00:1d.0: setting latency timer to 64 uhci_hcd 0000:00:1d.0: UHCI Host Controller uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 uhci_hcd 0000:00:1d.0: irq 11, io base 0x00001820 usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: UHCI Host Controller usb usb2: Manufacturer: Linux 2.6.31.5-127.fc12.i686 uhci_hcd usb usb2: SerialNumber: 0000:00:1d.0 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected uhci_hcd 0000:00:1d.1: power state changed by ACPI to D0 ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11 uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11 uhci_hcd 0000:00:1d.1: setting latency timer to 64 uhci_hcd 0000:00:1d.1: UHCI Host Controller uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001840 usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb3: Product: UHCI Host Controller usb usb3: Manufacturer: Linux 2.6.31.5-127.fc12.i686 uhci_hcd usb usb3: SerialNumber: 0000:00:1d.1 usb usb3: configuration #1 chosen from 1 choice hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11 uhci_hcd 0000:00:1d.2: setting latency timer to 64 uhci_hcd 0000:00:1d.2: UHCI Host Controller uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001860 usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb4: Product: UHCI Host Controller usb usb4: Manufacturer: Linux 2.6.31.5-127.fc12.i686 uhci_hcd usb usb4: SerialNumber: 0000:00:1d.2 usb usb4: configuration #1 chosen from 1 choice hub 4-0:1.0: USB hub found hub 4-0:1.0: 2 ports detected PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12 serio: i8042 KBD port at 0x60,0x64 irq 1 serio: i8042 AUX port at 0x60,0x64 irq 12 mice: PS/2 mouse device common for all mice rtc_cmos 00:06: RTC can wake from S4 rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0 rtc0: alarms up to one month, y3k, 114 bytes nvram device-mapper: uevent: version 1.0.3 device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: [email protected] cpuidle: using governor ladder cpuidle: using governor menu usbcore: registered new interface driver hiddev usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver nf_conntrack version 0.5.0 (8046 buckets, 32184 max) CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or sysctl net.netfilter.nf_conntrack_acct=1 to enable it. ip_tables: © 2000-2006 Netfilter Core Team TCP cubic registered Initializing XFRM netlink socket NET: Registered protocol family 17 Using IPI No-Shortcut mode PM: Resume from disk failed. registered taskstats version 1 No TPM chip found, activating TPM-bypass! Magic number: 10:883:336 tty tty57: hash matches rtc_cmos 00:06: setting system clock to 2010-05-27 15:18:20 UTC (1274973500) Initalizing network drop monitor service input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4 ata2.00: ATAPI: MATSHITADVD-RAM UJ-830S, 1.02, max UDMA/33 ata1.00: ATA-6: TOSHIBA MK4026GAX RoHS, PA107E, max UDMA/100 ata1.00: 78140160 sectors, multi 16: LBA ata2.00: configured for UDMA/33 ata1.00: configured for UDMA/100 scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK4026GA PA10 PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: scsi 1:0:0:0: CD-ROM MATSHITA DVD-RAM UJ-830S 1.02 PQ: 0 ANSI: 5 sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray Uniform CD-ROM driver Revision: 3.20 sr 1:0:0:0: Attached scsi CD-ROM sr0 sr 1:0:0:0: Attached scsi generic sg1 type 5 sda1 sda2 sd 0:0:0:0: [sda] Attached SCSI disk Freeing unused kernel memory: 432k freed Write protecting the kernel text: 3496k Write protecting the kernel read-only data: 1696k psmouse serio1: ID: 10 00 64 dracut: dracut-002-13.4.git8f397a9b.fc12 udev: starting version 145 input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:03/input/input5 ACPI: Video Device [VID] (multi-head: yes rom: no post: no) [drm] Initialized drm 1.1.0 20060810 i915 0000:00:02.0: power state changed by ACPI to D0 i915 0000:00:02.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11 i915 0000:00:02.0: setting latency timer to 64 [drm] DAC-6: set mode 640x480 0 usb 3-2: new low speed USB device using uhci_hcd and address 2 fbcon: inteldrmfb (fb0) is primary device render error detected, EIR: 0x00000010 [drm:i915_handle_error] *ERROR* EIR stuck: 0x00000010, masking render error detected, EIR: 0x00000010 [drm] LVDS-8: set mode 1024x768 d Console: switching to colour frame buffer device 128x48 fb0: inteldrmfb frame buffer device registered panic notifier [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0 usb 3-2: New USB device found, idVendor=062a, idProduct=0000 usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 usb 3-2: configuration #1 chosen from 1 choice input: HID 062a:0000 as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input6 generic-usb 0003:062A:0000.0001: input,hidraw0: USB HID v1.10 Mouse [HID 062a:0000] on usb-0000:00:1d.1-2/input0 dracut: Starting plymouth daemon IBM TrackPoint firmware: 0x0e, buttons: 3/3 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/input/input7 dracut: rd_NO_MDIMSM: no MD RAID for imsm/isw raids yenta_cardbus 0000:02:00.0: CardBus bridge found [1014:0512] yenta_cardbus 0000:02:00.0: Using INTVAL to route CSC interrupts to PCI yenta_cardbus 0000:02:00.0: Routing CardBus interrupts to PCI yenta_cardbus 0000:02:00.0: TI: mfunc 0x01d21022, devctl 0x64 yenta_cardbus 0000:02:00.0: ISA IRQ mask 0x04f8, PCI irq 11 yenta_cardbus 0000:02:00.0: Socket status: 30000007 yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge I/O window: 0x3000 - 0x7fff pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x7fff: clean. yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0xd0200000 - 0xdfffffff yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0xf0000000 - 0xf7ffffff dracut: Scanning devices sda2 for LVM volume groups dracut: Reading all physical volumes. This may take a while... dracut: Found volume group "vg_mojkomputer" using metadata type lvm2 dracut: 2 logical volume(s) in volume group "vg_mojkomputer" now active EXT4-fs (dm-0): barriers enabled kjournald2 starting: pid 250, dev dm-0:8, commit interval 5 seconds EXT4-fs (dm-0): delayed allocation enabled EXT4-fs: file extents enabled EXT4-fs: mballoc enabled EXT4-fs (dm-0): mounted filesystem with ordered data mode dracut: Mounted root filesystem /dev/mapper/vg_mojkomputer-lv_root dracut: Loading SELinux policy type=1404 audit(1274973504.704:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 SELinux: 8192 avtab hash slots, 144734 rules. SELinux: 8192 avtab hash slots, 144734 rules. SELinux: 8 users, 12 roles, 2941 types, 136 bools, 1 sens, 1024 cats SELinux: 75 classes, 144734 rules SELinux: Completing initialization. SELinux: Setting up existing superblocks. SELinux: initialized (dev dm-0, type ext4), uses xattr SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs SELinux: initialized (dev securityfs, type securityfs), uses genfs_contexts SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs SELinux: initialized (dev devpts, type devpts), uses transition SIDs SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts SELinux: initialized (dev pipefs, type pipefs), uses task SIDs SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts SELinux: initialized (dev sockfs, type sockfs), uses task SIDs SELinux: initialized (dev proc, type proc), uses genfs_contexts SELinux: initialized (dev bdev, type bdev), uses genfs_contexts SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts type=1403 audit(1274973505.107:3): policy loaded auid=4294967295 ses=4294967295 dracut: Switching root udev: starting version 145 i801_smbus 0000:00:1f.3: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11 intel_rng: FWH not detected iTCO_vendor_support: vendor-support=0 iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05 iTCO_wdt: Found a ICH4-M TCO device (Version=1, TCOBASE=0x1060) iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) lib80211: common routines for IEEE802.11 drivers lib80211_crypt: registered algorithm 'NULL' e100: Intel® PRO/100 Network Driver, 3.5.24-k2-NAPI e100: Copyright© 1999-2006 Intel Corporation ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11 e100 0000:02:08.0: PCI INT A -> Link[LNKE] -> GSI 11 (level, low) -> IRQ 11 e100 0000:02:08.0: PME# disabled e100: eth0: e100_probe: addr 0xd0201000, irq 11, MAC addr 00:0a:e4:39:bd:5c parport_pc 00:09: reported by Plug and Play ACPI parport0: PC-style at 0x3bc, irq 7 [PCSPP,TRISTATE] ieee80211: 802.11 data/management/control stack, git-1.1.13 ieee80211: Copyright © 2004-2005 Intel Corporation <[email protected]> ipw2200: Intel® PRO/Wireless 2200/2915 Network Driver, 1.2.2kmprq ipw2200: Copyright© 2003-2006 Intel Corporation ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11 ipw2200 0000:02:02.0: PCI INT A -> Link[LNKF] -> GSI 11 (level, low) -> IRQ 11 ipw2200: Detected Intel PRO/Wireless 2200BG Network Connection ipw2200 0000:02:02.0: firmware: requesting ipw2200-bss.fw thinkpad_acpi: ThinkPad ACPI Extras v0.23 thinkpad_acpi: http://ibm-acpi.sf.net/ thinkpad_acpi: ThinkPad BIOS 1WET82WW (2.02 ), EC 1VHT28WW-1.04 thinkpad_acpi: IBM ThinkPad R50e, model 1834SXG Registered led device: tpacpi::thinklight Registered led device: tpacpi::power Registered led device: tpacpi::standby thinkpad_acpi: brightness: will use unverified default: brightness_mode=2 thinkpad_acpi: brightness: please report to [email protected] whether it works well or not on your ThinkPad input: ThinkPad Extra Buttons as /devices/virtual/input/input8 Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11 Intel ICH 0000:00:1f.5: setting latency timer to 64 pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean. pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7 pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean. pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean. pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean. intel8x0_measure_ac97_clock: measured 50168 usecs (2418 samples) intel8x0: clocking to 48000 Intel ICH Modem 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11 Intel ICH Modem 0000:00:1f.6: setting latency timer to 64 ppdev: user-space parallel port driver ALSA sound/pci/ac97/ac97_codec.c:2163: MC'97 1 converters and GPIO not ready (0xff00) ipw2200: Detected geography ZZR (14 802.11bg channels, 0 802.11a channels) device-mapper: multipath: version 1.1.0 loaded EXT4-fs (dm-0): internal journal on dm-0:8 EXT4-fs (sda1): barriers enabled kjournald2 starting: pid 757, dev sda1:8, commit interval 5 seconds EXT4-fs (sda1): internal journal on sda1:8 EXT4-fs (sda1): delayed allocation enabled EXT4-fs: file extents enabled EXT4-fs: mballoc enabled EXT4-fs (sda1): mounted filesystem with ordered data mode SELinux: initialized (dev sda1, type ext4), uses xattr Adding 1015800k swap on /dev/mapper/vg_mojkomputer-lv_swap. Priority:-1 extents:1 across:1015800k SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts microcode: CPU0 sig=0x6d8, pf=0x20, revision=0x20 platform microcode: firmware: requesting intel-ucode/06-0d-08 Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba Microcode Update Driver: v2.00 removed. p4-clockmod: P4/Xeon CPU On-Demand Clock Modulation available NET: Registered protocol family 10 lo: Disabled Privacy Extensions ip6_tables: © 2000-2006 Netfilter Core Team ADDRCONF(NETDEV_UP): eth0: link is not ready [drm:drm_mode_rmfb] *ERROR* tried to remove a fb that we didn't own [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 eth1: no IPv6 routers present [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm:drm_mode_rmfb] *ERROR* tried to remove a fb that we didn't own [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 type=1305 audit(1274973610.894:32364): audit_enabled=0 old=1 auid=4294967295 ses=4294967295 subj=system_u:system_r:readahead_t:s0 res=1 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 fuse init (API version 7.12) SELinux: initialized (dev fuse, type fuse), uses genfs_contexts [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 usb 1-3: new high speed USB device using ehci_hcd and address 3 usb 1-3: New USB device found, idVendor=0951, idProduct=1625 usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-3: Product: DT 101 II usb 1-3: Manufacturer: Kingston usb 1-3: SerialNumber: 0014785448B1F9B0A75F0CE4 usb 1-3: configuration #1 chosen from 1 choice Initializing USB Mass Storage driver... scsi2 : SCSI emulation for USB Mass Storage devices usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usb-storage: device found at 3 usb-storage: waiting for device to settle before scanning usb-storage: device scan complete scsi 2:0:0:0: Direct-Access Kingston DT 101 II 1.00 PQ: 0 ANSI: 2 sd 2:0:0:0: Attached scsi generic sg2 type 0 sd 2:0:0:0: [sdb] 7818184 512-byte logical blocks: (4.00 GB/3.72 GiB) sd 2:0:0:0: [sdb] Write Protect is off sd 2:0:0:0: [sdb] Mode Sense: 03 00 00 00 sd 2:0:0:0: [sdb] Assuming drive cache: write through sd 2:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 sd 2:0:0:0: [sdb] Assuming drive cache: write through sd 2:0:0:0: [sdb] Attached SCSI removable disk SELinux: initialized (dev sdb1, type vfat), uses genfs_contexts usb 1-3: USB disconnect, address 3 FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush usb 3-1: new full speed USB device using uhci_hcd and address 3 usb 3-1: New USB device found, idVendor=06b9, idProduct=4061 usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 3-1: Product: Speed Touch 330 usb 3-1: Manufacturer: THOMSON usb 3-1: SerialNumber: 000E5091F810 usb 3-1: configuration #1 chosen from 1 choice NET: Registered protocol family 8 NET: Registered protocol family 20 usb 3-1: reset full speed USB device using uhci_hcd and address 3 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4.00 usbcore: registered new interface driver speedtch speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin speedtch 3-1:1.0: speedtch_find_firmware: no stage 1 firmware found! PPP generic driver version 2.4.2 usb 3-2: USB disconnect, address 2 usb 3-1: USB disconnect, address 3 Clocksource tsc unstable (delta = -67237133 ns) usb 3-2: new low speed USB device using uhci_hcd and address 4 usb 3-2: New USB device found, idVendor=062a, idProduct=0000 usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 usb 3-2: configuration #1 chosen from 1 choice input: HID 062a:0000 as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input9 generic-usb 0003:062A:0000.0002: input,hidraw0: USB HID v1.10 Mouse [HID 062a:0000] on usb-0000:00:1d.1-2/input0 usb 1-3: new high speed USB device using ehci_hcd and address 5 usb 1-3: New USB device found, idVendor=0951, idProduct=1625 usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-3: Product: DT 101 II usb 1-3: Manufacturer: Kingston usb 1-3: SerialNumber: 0014785448B1F9B0A75F0CE4 usb 1-3: configuration #1 chosen from 1 choice scsi3 : SCSI emulation for USB Mass Storage devices usb-storage: device found at 5 usb-storage: waiting for device to settle before scanning usb-storage: device scan complete scsi 3:0:0:0: Direct-Access Kingston DT 101 II 1.00 PQ: 0 ANSI: 2 sd 3:0:0:0: Attached scsi generic sg2 type 0 sd 3:0:0:0: [sdb] 7818184 512-byte logical blocks: (4.00 GB/3.72 GiB) sd 3:0:0:0: [sdb] Write Protect is off sd 3:0:0:0: [sdb] Mode Sense: 03 00 00 00 sd 3:0:0:0: [sdb] Assuming drive cache: write through sd 3:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 sd 3:0:0:0: [sdb] Assuming drive cache: write through sd 3:0:0:0: [sdb] Attached SCSI removable disk SELinux: initialized (dev sdb1, type vfat), uses genfs_contexts usb 1-3: USB disconnect, address 5 FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 usb 3-1: new full speed USB device using uhci_hcd and address 5 usb 3-1: New USB device found, idVendor=06b9, idProduct=4061 usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 3-1: Product: Speed Touch 330 usb 3-1: Manufacturer: THOMSON usb 3-1: SerialNumber: 000E5091F810 usb 3-1: configuration #1 chosen from 1 choice usb 3-1: reset full speed USB device using uhci_hcd and address 5 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4 speedtch 3-1:1.0: found stage 1 firmware speedtch-1.bin.4 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4 speedtch 3-1:1.0: found stage 2 firmware speedtch-2.bin.4 ATM dev 0: ADSL line is synchronising ATM dev 0: ADSL line is up (640 kb/s down | 160 kb/s up) ISO 9660 Extensions: Microsoft Joliet Level 3 ISO 9660 Extensions: RRIP_1991A SELinux: initialized (dev sr0, type iso9660), uses genfs_contexts usbcore: deregistering interface driver speedtch ATM dev 0: usbatm_complete: urb 0xdd98f780 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd98f280 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd98f580 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd98f600 failed (-2)! usbcore: registered new interface driver speedtch ATM dev 0: ADSL line is blocked? usbcore: deregistering interface driver speedtch ATM dev 0: usbatm_complete: urb 0xddd60480 failed (-2)! ATM dev 0: usbatm_complete: urb 0xddd60c00 failed (-2)! ATM dev 0: usbatm_complete: urb 0xddd60300 failed (-2)! ATM dev 0: usbatm_complete: urb 0xddd60880 failed (-2)! usbcore: registered new interface driver speedtch ATM dev 0: ADSL line is blocked? ATM dev 0: usbatm_complete: urb 0xdf33b780 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdf33b000 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdf33bb80 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdf33bf80 failed (-84)! usb 3-1: USB disconnect, address 5 usb 1-3: new high speed USB device using ehci_hcd and address 7 usb 1-3: New USB device found, idVendor=0951, idProduct=1625 usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-3: Product: DT 101 II usb 1-3: Manufacturer: Kingston usb 1-3: SerialNumber: 0014785448B1F9B0A75F0CE4 usb 1-3: configuration #1 chosen from 1 choice scsi4 : SCSI emulation for USB Mass Storage devices usb-storage: device found at 7 usb-storage: waiting for device to settle before scanning usb-storage: device scan complete scsi 4:0:0:0: Direct-Access Kingston DT 101 II 1.00 PQ: 0 ANSI: 2 sd 4:0:0:0: Attached scsi generic sg2 type 0 sd 4:0:0:0: [sdb] 7818184 512-byte logical blocks: (4.00 GB/3.72 GiB) sd 4:0:0:0: [sdb] Write Protect is off sd 4:0:0:0: [sdb] Mode Sense: 03 00 00 00 sd 4:0:0:0: [sdb] Assuming drive cache: write through sd 4:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 sd 4:0:0:0: [sdb] Assuming drive cache: write through sd 4:0:0:0: [sdb] Attached SCSI removable disk SELinux: initialized (dev sdb1, type vfat), uses genfs_contexts usb 1-3: USB disconnect, address 7 FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush FAT: bread failed in fat_clusters_flush [drm] DAC-6: set mode 640x480 0 [drm] DAC-6: set mode 640x480 0 usb 3-1: new full speed USB device using uhci_hcd and address 6 usb 3-1: New USB device found, idVendor=06b9, idProduct=4061 usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 3-1: Product: Speed Touch 330 usb 3-1: Manufacturer: THOMSON usb 3-1: SerialNumber: 000E5091F810 usb 3-1: configuration #1 chosen from 1 choice usb 3-1: reset full speed USB device using uhci_hcd and address 6 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4 speedtch 3-1:1.0: found stage 1 firmware speedtch-1.bin.4 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4 speedtch 3-1:1.0: found stage 2 firmware speedtch-2.bin.4 ATM dev 0: ADSL line is synchronising ATM dev 0: ADSL line is up (640 kb/s down | 160 kb/s up) usbcore: deregistering interface driver speedtch ATM dev 0: usbatm_complete: urb 0xdd6f6600 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd6f6a00 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd6f6200 failed (-2)! ATM dev 0: usbatm_complete: urb 0xdd6f6400 failed (-2)! usbcore: registered new interface driver speedtch ATM dev 0: ADSL line is blocked? ATM dev 0: usbatm_complete: urb 0xdd98f500 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98f700 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98ff00 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98fe00 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98f500 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98f700 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98ff00 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98fe00 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98f500 failed (-84)! ATM dev 0: usbatm_complete: urb 0xdd98f700 failed (-84)! usb 3-1: USB disconnect, address 6 usb 3-1: new full speed USB device using uhci_hcd and address 7 usb 3-1: New USB device found, idVendor=06b9, idProduct=4061 usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 3-1: Product: Speed Touch 330 usb 3-1: Manufacturer: THOMSON usb 3-1: SerialNumber: 000E5091F810 usb 3-1: configuration #1 chosen from 1 choice usb 3-1: reset full speed USB device using uhci_hcd and address 7 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4 speedtch 3-1:1.0: found stage 1 firmware speedtch-1.bin.4 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4 speedtch 3-1:1.0: found stage 2 firmware speedtch-2.bin.4 ATM dev 0: ADSL line is synchronising ATM dev 0: ADSL line is up (640 kb/s down | 160 kb/s up) __ratelimit: 2 callbacks suppressed ATM dev 0: usbatm_complete: urb 0xddd60700 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60480 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60080 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60900 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60700 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60480 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60080 failed (-84)! ATM dev 0: usbatm_complete: urb 0xddd60900 failed (-84)! usb 3-1: USB disconnect, address 7 usb 3-1: new full speed USB device using uhci_hcd and address 8 usb 3-1: New USB device found, idVendor=06b9, idProduct=4061 usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 3-1: Product: Speed Touch 330 usb 3-1: Manufacturer: THOMSON usb 3-1: SerialNumber: 000E5091F810 usb 3-1: configuration #1 chosen from 1 choice usb 3-1: reset full speed USB device using uhci_hcd and address 8 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-1.bin.4 speedtch 3-1:1.0: found stage 1 firmware speedtch-1.bin.4 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4.00 speedtch 3-1:1.0: firmware: requesting speedtch-2.bin.4 speedtch 3-1:1.0: found stage 2 firmware speedtch-2.bin.4 ATM dev 0: ADSL line is synchronising ATM dev 0: ADSL line is up (640 kb/s down | 160 kb/s up) z gory wybaczcie za tak ogromny wpis... Edytowane Maj 27, 2010 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 (edytowane) po wpisaniu tych komend: [root@Moj-Komputer Linnet]# cat /etc/ppp/peers/linnet user "tu moj login" lock noipdefault defaultroute hide-password lcp-echo-interval 20 lcp-echo-failure 3 connect /bin/true persist noauth noaccomp holdoff 4 default-asyncmap plugin pppoatm.so 0.35 usepeerdns [root@Moj-Komputer Linnet]# cat /etc/ppp/chap-secrets "login" * "moje haslo" * [root@Moj-Komputer Linnet]# zaczynam podejrzewac czy ja (_napewno_ → na pewno) ORT podalem wlasciwe haslo lub login podczas instalcji neo linnetem Edytowane Maj 27, 2010 przez WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 [OFF TOPIC] oj, zapaskudze cala strone tym wpisem, ale ok:Nie, nie jest OK. Przy wklejaniu długich listingów korzystaj ze znaczników codebox - po lewej stronie okna edycji link "Wstaw: CODEBOX" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 ok bede pamietac na przyszlosc poki co wciaz bez fedorowego netu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 [root@Moj-Komputer Linnet]# cat /etc/ppp/peers/linnet user "tu moj login" ... [root@Moj-Komputer Linnet]# cat /etc/ppp/chap-secrets "login" * "moje haslo" * Może jednak zastanów się jeszcze raz czy przesiadka na linuksa to dobry pomysł Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 hmmm, nie rozumiem czemu to zly pomysl, pewnie robie glupie bledy ale kazdy ma do tego prawo poza tym udalo mi sie z neostrada pod mandriva, co prawda z pomoca spolecznosci ale jednak, czyzby fedora az tak bardzo sie roznila? z cieakowsci wpisalem tak: root@Moj-Komputer Linnet]# ./linnet s _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl ppp0: error fetching interface information: Device not found ppp0: error fetching interface information: Device not found Twoj adres IP: Pakiety: Bledne pakiety(errors): Bledne pakiety(dropped): Bledne pakietow(overruns): Bledne pakietow(frame): Odebrane: MiB Wyslane: MiB [root@Moj-Komputer Linnet]# ./linnet p _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Plugin pppoatm.so loaded. PPPoATM plugin_init PPPoATM setdevname_pppoatm - SUCCESS:0.35 Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: permission denied CHAP authentication failed Connection terminated. Modem hangup [root@Moj-Komputer Linnet]# modprobe speedtch [root@Moj-Komputer Linnet]# /sbin/lsmod | grep speedtch speedtch 12196 0 usbatm 14572 1 speedtch [root@Moj-Komputer Linnet]# nie wiem czy czasem nie pdoalem blednego hasla lub loginu przy instalacje neo i stad ten balagan ale nie jestem pewien, wlasnie probuje sie dodzwonic do tp.sa by sprawdzic czy nie zrobilem podstawowego bledu... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 W tym miejscu: [root@Moj-Komputer Linnet]# cat /etc/ppp/peers/linnet user "tu moj login" ... [root@Moj-Komputer Linnet]# cat /etc/ppp/chap-secrets "login" * "moje haslo" * oczywiscie wpisalem "tu moj login", "login", "moje haslo" celowo bo nie chcialem ich podawac, o ile to nie jest wymagane by mi pomoc z ta neostrada jesli o to chodzi odnosnie moje zastanowienia sie nad linuksem... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
borzole Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 * raz w życiu podłączałem speedtouch i tak się tym zmęczyłem, że to opisałem http://wiki.fedora.pl/wiki/Modem_SpeedTouch_330 może Ci to coś rozjaśni, bo ten linet to czarna skrzynka dla mnie. * Twoje obycie z linuksem jest tak minimalne, że proponuję Ci: - zainstalować system na VirtualBox w minimalnym stanie (płytka netinstall będzie super), a ile się przy tym napłaczesz to głowa mała - ustawić na wirtualnej maszynie połączenie za NAT (chyba domyślnie jest włączony), dla ułatwienia - nauczyć się przez 2 tygodnie ile tylko można konsoli - pobrać na maszynkę wszystko co potrzeba do zrobienia połączenia modemu - wyłączyć NAT na wirtualce, zamiast tego udostępnić USB na którym jest modem bezpośrednio do wirtualnego systemu (to się da zwyczajnie wyklikać). - praktyka czyni mistrza, a klikaniem jeszcze się nikt niczego nie nauczył Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 chyba sie udalo: [root@Moj-Komputer Linnet]# ./linnet _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Parametry programu: i - instalacja p - polaczenie z internetem s - status polaczenia z internetem r - rozlaczenie z internetem a - dodanie programu do autostartu Dla przykladu: ./linnet -i [root@Moj-Komputer Linnet]# ./linnet -i _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Opcje instalacyjne. Wybierz wlasciwa: 1-Sprawdzenie systemu czy jest gotowy do instalacji 2-Instalacja(modemu+konfiguracja polaczenia) 3-Instalacja(modemu) 4-Instalacja(konfiguracja polaczenia) 2 Twoj modem to: Speedtouch Konfiguracja modemu zakonczona pomyslnie Prosze wybrac swojego dostawce internetu: 1-Neostrada 2-Netia(linia tp) 3-Netia(linia netii) 1 Podaj swoj login:[email protected] Podaj swoje haslo:xxxxxxx Polaczenie nawiazujemy poprzez wydanie komendy: "pppd call linnet" Lub poprzez uruchomienie ./linnet p [root@Moj-Komputer Linnet]# ./linnet p _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Plugin pppoatm.so loaded. PPPoATM plugin_init PPPoATM setdevname_pppoatm - SUCCESS:0.35 Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: duplicate address detected CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: duplicate address detected CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication failed: duplicate address detected CHAP authentication failed Connection terminated. Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication succeeded CHAP authentication succeeded local IP address 83.5.255.204 remote IP address 83.1.4.1 primary DNS address 194.204.159.1 secondary DNS address 194.204.152.34 [root@Moj-Komputer Linnet]# ./linnet s _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Twoj adres IP: 83.5.255.204 Pakiety: 4 Bledne pakiety(errors): 0 Bledne pakiety(dropped): 0 Bledne pakietow(overruns): 0 Bledne pakietow(frame): 0 Odebrane: 152.0 MiB Wyslane: 94.0 MiB [root@Moj-Komputer Linnet]# ./linnet s _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl Twoj adres IP: 83.5.255.204 Pakiety: 4 Bledne pakiety(errors): 0 Bledne pakiety(dropped): 0 Bledne pakietow(overruns): 0 Bledne pakietow(frame): 0 Odebrane: 152.0 MiB Wyslane: 94.0 MiB [root@Moj-Komputer Linnet]# ./linnet r _ _ _ ___ _ | (_)_ __ _ __ ___| |_ / _ \ / | | | | '_ \| '_ \ / _ \ __| | | | || | | | | | | | | | | __/ |_ | |_| || | |_|_|_| |_|_| |_|\___|\__| \___(_)_| Strona projektu: www.linnet.cba.pl [root@Moj-Komputer Linnet]# pppd call linnet Plugin pppoatm.so loaded. PPPoATM plugin_init PPPoATM setdevname_pppoatm - SUCCESS:0.35 Using interface ppp0 Connect: ppp0 <--> 0.35 CHAP authentication succeeded CHAP authentication succeeded local IP address 83.11.59.87 remote IP address 83.1.4.1 primary DNS address 194.204.159.1 secondary DNS address 194.204.152.34 [root@Moj-Komputer Linnet]# co moge zrobic dalej? czy to oznacza ze internet chodzi? firefox nie dziala, co moge zrobic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
borzole Napisano Maj 27, 2010 Zgłoszenie Share Napisano Maj 27, 2010 jeśli polecenie ping -c 4 onet.pl generuje 4 linie tej postaci 64 bytes from s4.m1r2.onet.pl (213.180.146.27): icmp_seq=1 ttl=58 time=56.7 ms ... to internet działa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linluke9 Napisano Maj 27, 2010 Autor Zgłoszenie Share Napisano Maj 27, 2010 [root@Moj-Komputer Linnet]# ping -c 4 onet.pl ping: unknown host onet.pl [root@Moj-Komputer Linnet]# czy to oznacza ze jednak nie dziala? gdy pisze ./linnet s top podaje ile odebral/wyslal Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
