Po Zainstalowaniu Sterowników Do Ati, Zwolnienie Pracy I Brak Akceleracji
lukaszw17
wyniki lsmod
[lukasz@Acer-pc ~]$ lsmod
Module                  Size  Used by
fuse                   57233  2
sunrpc                198573  1
cpufreq_ondemand        8764  2
acpi_cpufreq            7693  1
freq_table              3955  2 cpufreq_ondemand,acpi_cpufreq
ip6t_REJECT             4111  2
nf_conntrack_ipv6      17856  2
ip6table_filter         1671  1
ip6_tables             17580  1 ip6table_filter
ipv6                  275768  28 ip6t_REJECT,nf_conntrack_ipv6
aes_x86_64              7742  2
aes_generic            27084  1 aes_x86_64
xts                     2455  1
gf128mul                7282  1 xts
dm_crypt               11354  1
uinput                  7455  0
snd_hda_codec_atihdmi     2727  1
snd_hda_codec_realtek   297127  1
snd_hda_intel          23960  2
snd_hda_codec          85624  3 snd_hda_codec_atihdmi,snd_hda_codec_realtek,snd_hda_intel
arc4                    1433  2
ecb                     2087  2
ath9k                  79156  0
ath9k_common            2487  1 ath9k
mac80211              220214  2 ath9k,ath9k_common
snd_hwdep               6454  1 snd_hda_codec
snd_seq                53005  0
snd_seq_device          6159  1 snd_seq
snd_pcm                80324  2 snd_hda_intel,snd_hda_codec
snd_timer              19882  2 snd_seq,snd_pcm
iTCO_wdt               11200  0
iTCO_vendor_support     2555  1 iTCO_wdt
uvcvideo               54628  0
videodev               35667  1 uvcvideo
v4l1_compat            12930  2 uvcvideo,videodev
v4l2_compat_ioctl32     9973  1 videodev
i2c_i801               10270  0
ath9k_hw              216431  2 ath9k,ath9k_common
tg3                   109556  0
ath                     9374  2 ath9k,ath9k_hw
snd                    62913  12 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_device,snd_pcm,snd_timer
acer_wmi               15004  0
soundcore               6390  1 snd
wmi                     6888  1 acer_wmi
serio_raw               4588  0
snd_page_alloc          7437  2 snd_hda_intel,snd_pcm
cfg80211              134041  4 ath9k,ath9k_common,mac80211,ath
rfkill                 17218  3 acer_wmi,cfg80211
joydev                  9771  0
microcode              18282  0
video                  21629  0
output                  2221  1 video
radeon                711597  0
ttm                    54819  1 radeon
drm_kms_helper         24738  1 radeon
drm                   176713  3 radeon,ttm,drm_kms_helper
i2c_algo_bit            5045  1 radeon
i2c_core               25709  6 videodev,i2c_i801,radeon,drm_kms_helper,drm,i2c_algo_bit
[lukasz@Acer-pc ~]$
i wyniki z pliku /var/log/Xorg.O.log
[    29.520]
X.Org X Server 1.8.2
Release Date: 2010-07-01
[    29.520] X Protocol Version 11, Revision 0
[    29.520] Build Operating System: x86-17 2.6.32-44.el6.x86_64
[    29.520] Current Operating System: Linux Acer-pc 2.6.34.7-56.fc13.x86_64 #1 SMP Wed Sep 15 03:36:55 UTC 2010 x86_64
[    29.521] Kernel command line: ro root=UUID=c1d7dc32-9349-4cd1-b06d-b5f15ac3cac8 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 nomodeset rhgb quiet
[    29.521] Build Date: 13 September 2010  07:04:16PM
[    29.521] Build ID: xorg-x11-server 1.8.2-4.fc13
[    29.521] Current version of pixman: 0.18.0
[    29.521]     Before reporting problems, check http://bodhi.fedoraproject.org/
[    29.522] Markers: (--) probed, (**) from config file, (==) default setting,
[    29.522] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 14 22:32:38 2010
[    29.599] (==) Using config file: "/etc/X11/xorg.conf"
[    29.599] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    29.599] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    29.636] (==) ServerLayout "aticonfig Layout"
[    29.637] (**) |-->Screen "aticonfig-Screen[0]-0" (0)
[    29.637] (**) |   |-->Monitor "aticonfig-Monitor[0]-0"
[    29.637] (**) |   |-->Device "aticonfig-Device[0]-0"
[    29.637] (==) Automatically adding devices
[    29.637] (==) Automatically enabling devices
[    29.637] (==) FontPath set to:
   catalogue:/etc/X11/fontpath.d,
   built-ins
[    29.637] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    29.637] (II) The server relies on udev to provide the list of input devices.
   If no devices become available, reconfigure udev or disable AutoAddDevices.
[    29.637] (II)
** Fedora switched to udev-based device detection with       **
** xorg-x11-server-1.7.99.901-1. Custom HAL configuration    **
** stored in /etc/hal/fdi/policy will not be seen by this    **
** server version. If you have such configuration you will   **
** need to update it to the new format.                      **
** For more information, see the Fedora wiki page            **
** https://fedoraproject.org/wiki/Input_device_configuration **
[    29.637] (II) Loader magic: 0x7ced20
[    29.637] (II) Module ABI versions:
[    29.637]     X.Org ANSI C Emulation: 0.4
[    29.637]     X.Org Video Driver: 7.0
[    29.637]     X.Org XInput driver : 9.0
[    29.637]     X.Org Server Extension : 3.0
[    29.646] (--) PCI:*(0:1:0:0) 1002:68c1:1025:0296 ATI Technologies Inc Redwood [Radeon HD 5600 Series] rev 0, Mem @ 0xd0000000/268435456, 0xf4000000/131072, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[    29.646] (II) "extmod" will be loaded by default.
[    29.646] (II) "dbe" will be loaded by default.
[    29.646] (II) "glx" will be loaded by default.
[    29.646] (II) "record" will be loaded by default.
[    29.646] (II) "dri" will be loaded by default.
[    29.646] (II) "dri2" will be loaded by default.
[    29.646] (II) LoadModule: "extmod"
[    29.704] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[    29.712] (II) Module extmod: vendor="X.Org Foundation"
[    29.712]     compiled for 1.8.2, module version = 1.0.0
[    29.712]     Module class: X.Org Server Extension
[    29.712]     ABI class: X.Org Server Extension, version 3.0
[    29.712] (II) Loading extension SELinux
[    29.712] (II) Loading extension MIT-SCREEN-SAVER
[    29.712] (II) Loading extension XFree86-VidModeExtension
[    29.712] (II) Loading extension XFree86-DGA
[    29.712] (II) Loading extension DPMS
[    29.712] (II) Loading extension XVideo
[    29.713] (II) Loading extension XVideo-MotionCompensation
[    29.713] (II) Loading extension X-Resource
[    29.713] (II) LoadModule: "dbe"
[    29.713] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[    29.720] (II) Module dbe: vendor="X.Org Foundation"
[    29.720]     compiled for 1.8.2, module version = 1.0.0
[    29.720]     Module class: X.Org Server Extension
[    29.720]     ABI class: X.Org Server Extension, version 3.0
[    29.720] (II) Loading extension DOUBLE-BUFFER
[    29.720] (II) LoadModule: "glx"
[    29.720] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    29.799] (II) Module glx: vendor="FireGL - ATI Technologies Inc."
[    29.822]     compiled for 7.5.0, module version = 1.0.0
[    29.822] (II) Loading extension GLX
[    29.822] (II) LoadModule: "record"
[    29.822] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[    29.850] (II) Module record: vendor="X.Org Foundation"
[    29.850]     compiled for 1.8.2, module version = 1.13.0
[    29.850]     Module class: X.Org Server Extension
[    29.850]     ABI class: X.Org Server Extension, version 3.0
[    29.850] (II) Loading extension RECORD
[    29.850] (II) LoadModule: "dri"
[    29.850] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[    29.891] (II) Module dri: vendor="X.Org Foundation"
[    29.891]     compiled for 1.8.2, module version = 1.0.0
[    29.891]     ABI class: X.Org Server Extension, version 3.0
[    29.891] (II) Loading extension XFree86-DRI
[    29.891] (II) LoadModule: "dri2"
[    29.891] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[    29.891] (II) Module dri2: vendor="X.Org Foundation"
[    29.891]     compiled for 1.8.2, module version = 1.2.0
[    29.892]     ABI class: X.Org Server Extension, version 3.0
[    29.892] (II) Loading extension DRI2
[    29.892] (II) LoadModule: "fglrx"
[    30.010] (II) Loading /usr/lib64/xorg/modules/drivers/fglrx_drv.so
[    30.314] (II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
[    30.322]     compiled for 1.7.1, module version = 8.77.5
[    30.322]     Module class: X.Org Video Driver
[    30.365] (II) Loading sub module "fglrxdrm"
[    30.365] (II) LoadModule: "fglrxdrm"
[    30.365] (II) Loading /usr/lib64/xorg/modules/linux/libfglrxdrm.so
[    30.403] (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
[    30.403]     compiled for 1.7.1, module version = 8.77.5
[    30.403] (II) ATI Proprietary Linux Driver Version Identifier:8.77.5
[    30.403] (II) ATI Proprietary Linux Driver Release Identifier: 8.771
[    30.403] (II) ATI Proprietary Linux Driver Build Date: Aug 25 2010 21:38:26
[    30.404] (++) using VT number 1
[    30.408] (II) Primary Device is: PCI 01@00:00:0
[    30.409] (WW) Falling back to old probe method for fglrx
[    30.423] (II) Loading PCS database from /etc/ati/amdpcsdb
[    30.424] (--) Chipset Supported AMD Graphics Processor (0x68C1) found
[    30.449] (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
[    30.449] (II) AMD Video driver is running on a device belonging to a group targeted for this release
[    30.449] (II) AMD Video driver is signed
[    30.450] (II) fglrx(0): pEnt->device->identifier=0x94b170
[    30.450] (II) fglrx(0): === [atiddxPreInit] === begin
[    30.450] (II) Loading sub module "vgahw"
[    30.450] (II) LoadModule: "vgahw"
[    30.451] (II) Loading /usr/lib64/xorg/modules/libvgahw.so
[    30.457] (II) Module vgahw: vendor="X.Org Foundation"
[    30.457]     compiled for 1.8.2, module version = 0.1.0
[    30.457]     ABI class: X.Org Video Driver, version 7.0
[    30.457] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[    30.457] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    30.457] (==) fglrx(0): Default visual is TrueColor
[    30.457] (**) fglrx(0): Option "DPMS" "true"
[    30.457] (==) fglrx(0): RGB weight 888
[    30.457] (II) fglrx(0): Using 8 bits per RGB
[    30.458] (==) fglrx(0): Buffer Tiling is ON
[    30.458] (II) Loading sub module "fglrxdrm"
[    30.458] (II) LoadModule: "fglrxdrm"
[    30.458] (II) Reloading /usr/lib64/xorg/modules/linux/libfglrxdrm.so
[    30.479] ukiDynamicMajor: failed to open /proc/ati/major
[    30.479] (==) fglrx(0): NoAccel = NO
[    30.479] (==) fglrx(0): ATI 2D Acceleration Architecture enabled
[    30.479] (--) fglrx(0): Chipset: "ATI Mobility Radeon HD 5600/5700 Series" (Chipset = 0x68c1)
[    30.479] (--) fglrx(0): (PciSubVendor = 0x1025, PciSubDevice = 0x0296)
[    30.479] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
[    30.480] (--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
[    30.480] (--) fglrx(0): MMIO registers at 0xf4000000
[    30.480] (--) fglrx(0): I/O port at 0x00002000
[    30.480] (==) fglrx(0): ROM-BIOS at 0x000c0000
[    30.498] (II) fglrx(0): Primary V_BIOS segment is: 0xc000
[    30.498] (EE) fglrx(0): ACPI: DRM connection failed
[    30.585] (II) Loading sub module "vbe"
[    30.585] (II) LoadModule: "vbe"
[    30.614] (II) Loading /usr/lib64/xorg/modules/libvbe.so
[    30.623] (II) Module vbe: vendor="X.Org Foundation"
[    30.623]     compiled for 1.8.2, module version = 1.1.0
[    30.623]     ABI class: X.Org Video Driver, version 7.0
[    30.623] (II) fglrx(0): VESA BIOS detected
[    30.623] (II) fglrx(0): VESA VBE Version 3.0
[    30.623] (II) fglrx(0): VESA VBE Total Mem: 16384 kB
[    30.623] (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
[    30.623] (II) fglrx(0): VESA VBE OEM Software Rev: 12.15
[    30.623] (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
[    30.623] (II) fglrx(0): VESA VBE OEM Product: MADISON
[    30.623] (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
[    30.662] (II) fglrx(0): ATI Video BIOS revision 9 or later detected
[    30.662] (--) fglrx(0): Video RAM: 1048576 kByte, Type: DDR3
[    30.662] (II) fglrx(0): PCIE card detected
[    30.662] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[    30.662] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[    30.662] (EE) fglrx(0): ACPI: DRM connection failed
[    30.662] (WW) fglrx(0): Hasn't establisted DRM connection
[    30.662] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x40000000)
[    30.662] (WW) fglrx(0): No DRM connection for driver fglrx.
[    30.662] (II) fglrx(0): RandR 1.2 support is enabled!
[    30.662] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[    30.662] (==) fglrx(0): Center Mode is disabled
[    30.662] (II) Loading sub module "fb"
[    30.662] (II) LoadModule: "fb"
[    30.662] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    30.676] (II) Module fb: vendor="X.Org Foundation"
[    30.676]     compiled for 1.8.2, module version = 1.0.0
[    30.676]     ABI class: X.Org ANSI C Emulation, version 0.4
[    30.676] (==) fglrx(0): Active stereo disabled
[    30.676] (II) Loading sub module "ddc"
[    30.676] (II) LoadModule: "ddc"
[    30.676] (II) Module "ddc" already built-in
[    30.851] (II) fglrx(0): Output LVDS using monitor section aticonfig-Monitor[0]-0
[    30.851] (II) fglrx(0): Output DFP1 has no monitor section
[    30.851] (II) fglrx(0): Output CRT1 has no monitor section
[    30.864] (II) Loading sub module "ddc"
[    30.864] (II) LoadModule: "ddc"
[    30.864] (II) Module "ddc" already built-in
[    30.864] (II) fglrx(0): Connected Display0: LVDS
[    30.864] (II) fglrx(0): Display0 EDID data ---------------------------
[    30.864] (II) fglrx(0): Manufacturer: SEC  Model: 3051  Serial#: 0
[    30.864] (II) fglrx(0): Year: 2008  Week: 0
[    30.864] (II) fglrx(0): EDID Version: 1.3
[    30.864] (II) fglrx(0): Digital Display Input
[    30.864] (II) fglrx(0): Max Image Size [cm]: horiz.: 39  vert.: 23
[    30.864] (II) fglrx(0): Gamma: 2.20
[    30.864] (II) fglrx(0): No DPMS capabilities specified
[    30.864] (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    30.864] (II) fglrx(0): First detailed timing is preferred mode
[    30.864] (II) fglrx(0): redX: 0.600 redY: 0.340   greenX: 0.310 greenY: 0.560
[    30.864] (II) fglrx(0): blueX: 0.150 blueY: 0.130   whiteX: 0.313 whiteY: 0.329
[    30.864] (II) fglrx(0): Manufacturer's mask: 0
[    30.864] (II) fglrx(0): Supported detailed timing:
[    30.864] (II) fglrx(0): clock: 107.8 MHz   Image Size:  398 x 232 mm
[    30.864] (II) fglrx(0): h_active: 1600  h_sync: 1648  h_sync_end 1680 h_blank_end 1892 h_border: 0
[    30.865] (II) fglrx(0): v_active: 900  v_sync: 902  v_sync_end 908 v_blanking: 950 v_border: 0
[    30.865] (II) fglrx(0): Unknown vendor-specific block f
[    30.865] (II) fglrx(0):  SAMSUNG
[    30.865] (II) fglrx(0):  173KT01-A01
[    30.865] (II) fglrx(0): EDID (in hex):
[    30.865] (II) fglrx(0):     00ffffffffffff004ca3513000000000
[    30.865] (II) fglrx(0):     00120103802717780a859599574f8f26
[    30.865] (II) fglrx(0):     21505400000001010101010101010101
[    30.865] (II) fglrx(0):     010101010101202a4024618432303020
[    30.865] (II) fglrx(0):     26008ee8100000190000000f00000000
[    30.865] (II) fglrx(0):     00000000001eb4027400000000fe0053
[    30.865] (II) fglrx(0):     414d53554e470a2020202020000000fe
[    30.865] (II) fglrx(0):     003137334b5430312d4130310a2000a4
[    30.865] (II) fglrx(0): End of Display0 EDID data --------------------
[    30.875] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    30.875] (II) fglrx(0): Printing DDC gathered Modelines:
[    30.875] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    30.875] (II) fglrx(0): Output LVDS connected
[    30.875] (II) fglrx(0): Output DFP1 disconnected
[    30.875] (II) fglrx(0): Output CRT1 disconnected
[    30.875] (II) fglrx(0): Using exact sizes for initial modes
[    30.875] (II) fglrx(0): Output LVDS using initial mode 1600x900
[    30.875] (II) fglrx(0): Display dimensions: (390, 230) mm
[    30.875] (II) fglrx(0): DPI set to (104, 99)
[    30.875] (II) fglrx(0): Adapter ATI Mobility Radeon HD 5600/5700 Series has 2 configurable heads and 1 displays connected.
[    30.875] (==) fglrx(0):  PseudoColor visuals disabled
[    30.875] (II) Loading sub module "ramdac"
[    30.875] (II) LoadModule: "ramdac"
[    30.875] (II) Module "ramdac" already built-in
[    30.875] (==) fglrx(0): NoDRI = NO
[    30.875] (==) fglrx(0): Capabilities: 0x00000000
[    30.875] (==) fglrx(0): CapabilitiesEx: 0x00000000
[    30.876] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[    30.876] (==) fglrx(0): UseFastTLS=0
[    30.876] (==) fglrx(0): BlockSignalsOnLock=1
[    30.876] (--) Depth 24 pixmap format is 32 bpp
[    30.876] (EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized.
[    30.876] (WW) fglrx(0): ***********************************************************
[    30.876] (WW) fglrx(0): * DRI initialization failed                               *
[    30.876] (WW) fglrx(0): * kernel module (fglrx.ko) may be missing or incompatible *
[    30.876] (WW) fglrx(0): * 2D and 3D acceleration disabled                         *
[    30.890] (II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x10000000
[    30.969] (II) fglrx(0): FBMM initialized for area (0,0)-(1600,8191)
[    30.969] (II) fglrx(0): FBMM auto alloc for area (0,0)-(1600,1600) (front color buffer - assumption)
[    30.969] (II) fglrx(0): Largest offscreen area available: 1600 x 6591
[    30.970] (==) fglrx(0): Backing store disabled
[    30.970] (II) Loading extension FGLRXEXTENSION
[    30.970] (**) fglrx(0): DPMS enabled
[    30.970] (II) fglrx(0): Initialized in-driver Xinerama extension
[    30.970] (WW) fglrx(0): Textured Video not supported without DRI enabled.
[    30.971] (II) LoadModule: "glesx"
[    30.971] (II) Loading /usr/lib64/xorg/modules/glesx.so
[    31.173] (II) Module glesx: vendor="X.Org Foundation"
[    31.173]     compiled for 1.7.1, module version = 1.0.0
[    31.173] (II) Loading extension GLESX
[    31.173] (II) fglrx(0): GLESX enableFlags = 576
[    31.173] (II) fglrx(0): Acceleration enabled
[    31.173] (II) LoadModule: "amdxmm"
[    31.173] (II) Loading /usr/lib64/xorg/modules/amdxmm.so
[    31.259] (II) Module amdxmm: vendor="X.Org Foundation"
[    31.259]     compiled for 1.7.1, module version = 1.0.0
[    31.260] (EE) fglrx(0): XMM failed to open CMMQS connection.
[    31.260] (EE) fglrx(0): XMM failed to initialize
[    31.260] (WW) fglrx(0): No XV video playback available
[    31.260] (II) fglrx(0): Enable composite support successfully
[    31.260] (WW) fglrx(0): Option "VendorName" is not used
[    31.260] (WW) fglrx(0): Option "ModelName" is not used
[    31.260] (==) fglrx(0): Silken mouse enabled
[    31.260] (==) fglrx(0): Using HW cursor of display infrastructure!
[    31.260] (II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
[    31.260] (II) fglrx(0): 'LVDS LCD' ConnectorType, abstracted as 'Panel'
[    31.260] (II) fglrx(0): 'eDP LCD' ConnectorType, abstracted as 'Panel'
[    31.780] (--) RandR disabled
[    31.780] (II) Initializing built-in extension Generic Event Extension
[    31.780] (II) Initializing built-in extension SHAPE
[    31.780] (II) Initializing built-in extension MIT-SHM
[    31.780] (II) Initializing built-in extension XInputExtension
[    31.780] (II) Initializing built-in extension XTEST
[    31.780] (II) Initializing built-in extension BIG-REQUESTS
[    31.780] (II) Initializing built-in extension SYNC
[    31.780] (II) Initializing built-in extension XKEYBOARD
[    31.780] (II) Initializing built-in extension XC-MISC
[    31.780] (II) Initializing built-in extension XINERAMA
[    31.780] (II) Initializing built-in extension XFIXES
[    31.780] (II) Initializing built-in extension RENDER
[    31.780] (II) Initializing built-in extension RANDR
[    31.780] (II) Initializing built-in extension COMPOSITE
[    31.780] (II) Initializing built-in extension DAMAGE
[    31.782] (II) SELinux: Disabled by boolean
[    31.784] (II) AIGLX: Screen 0 is not DRI capable
[    31.785] [glesx] __glESXExtensionInit: No GL ES2.0 capable screen found!
[    31.818] (II) fglrx(0): Setting screen physical size to 423 x 238
[    32.885] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    32.885] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    32.885] (**) Power Button: Applying InputClass "system-setup-keyboard"
[    32.885] (II) LoadModule: "evdev"
[    32.886] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[    32.903] (II) Module evdev: vendor="X.Org Foundation"
[    32.903]     compiled for 1.7.99.901, module version = 2.4.0
[    32.903]     Module class: X.Org XInput Driver
[    32.903]     ABI class: X.Org XInput driver, version 9.0
[    32.903] (**) Power Button: always reports core events
[    32.903] (**) Power Button: Device: "/dev/input/event2"
[    32.905] (II) Power Button: Found keys
[    32.905] (II) Power Button: Configuring as keyboard
[    32.905] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[    32.905] (**) Option "xkb_rules" "evdev"
[    32.905] (**) Option "xkb_model" "pc105"
[    32.905] (**) Option "xkb_layout" "pl"
[    32.905] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.182] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[    33.182] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    33.182] (**) Video Bus: Applying InputClass "system-setup-keyboard"
[    33.182] (**) Video Bus: always reports core events
[    33.182] (**) Video Bus: Device: "/dev/input/event6"
[    33.187] (II) Video Bus: Found keys
[    33.187] (II) Video Bus: Configuring as keyboard
[    33.187] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
[    33.187] (**) Option "xkb_rules" "evdev"
[    33.187] (**) Option "xkb_model" "pc105"
[    33.187] (**) Option "xkb_layout" "pl"
[    33.187] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.223] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    33.223] (II) No input driver/identifier specified (ignoring)
[    33.224] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    33.224] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    33.224] (**) Sleep Button: Applying InputClass "system-setup-keyboard"
[    33.224] (**) Sleep Button: always reports core events
[    33.224] (**) Sleep Button: Device: "/dev/input/event1"
[    33.228] (II) Sleep Button: Found keys
[    33.228] (II) Sleep Button: Configuring as keyboard
[    33.228] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
[    33.228] (**) Option "xkb_rules" "evdev"
[    33.228] (**) Option "xkb_model" "pc105"
[    33.228] (**) Option "xkb_layout" "pl"
[    33.228] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.237] (II) config/udev: Adding input device MLK TRACER EXCLUSIVE (/dev/input/event4)
[    33.237] (**) MLK TRACER EXCLUSIVE: Applying InputClass "evdev pointer catchall"
[    33.237] (**) MLK TRACER EXCLUSIVE: Applying InputClass "evdev keyboard catchall"
[    33.237] (**) MLK TRACER EXCLUSIVE: Applying InputClass "system-setup-keyboard"
[    33.237] (**) MLK TRACER EXCLUSIVE: always reports core events
[    33.237] (**) MLK TRACER EXCLUSIVE: Device: "/dev/input/event4"
[    33.240] (II) MLK TRACER EXCLUSIVE: Found 9 mouse buttons
[    33.240] (II) MLK TRACER EXCLUSIVE: Found scroll wheel(s)
[    33.240] (II) MLK TRACER EXCLUSIVE: Found relative axes
[    33.240] (II) MLK TRACER EXCLUSIVE: Found x and y relative axes
[    33.240] (II) MLK TRACER EXCLUSIVE: Found absolute axes
[    33.240] (II) MLK TRACER EXCLUSIVE: Found keys
[    33.240] (II) MLK TRACER EXCLUSIVE: Configuring as mouse
[    33.240] (II) MLK TRACER EXCLUSIVE: Configuring as keyboard
[    33.240] (**) MLK TRACER EXCLUSIVE: YAxisMapping: buttons 4 and 5
[    33.240] (**) MLK TRACER EXCLUSIVE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.240] (II) XINPUT: Adding extended input device "MLK TRACER EXCLUSIVE" (type: KEYBOARD)
[    33.240] (**) Option "xkb_rules" "evdev"
[    33.240] (**) Option "xkb_model" "pc105"
[    33.240] (**) Option "xkb_layout" "pl"
[    33.240] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.240] (**) MLK TRACER EXCLUSIVE: (accel) keeping acceleration scheme 1
[    33.240] (**) MLK TRACER EXCLUSIVE: (accel) acceleration profile 0
[    33.240] (**) MLK TRACER EXCLUSIVE: (accel) acceleration factor: 2.000
[    33.240] (**) MLK TRACER EXCLUSIVE: (accel) acceleration threshold: 4
[    33.240] (II) MLK TRACER EXCLUSIVE: initialized for relative axes.
[    33.240] (WW) MLK TRACER EXCLUSIVE: ignoring absolute axes.
[    33.241] (II) config/udev: Adding input device MLK TRACER EXCLUSIVE (/dev/input/mouse0)
[    33.241] (**) MLK TRACER EXCLUSIVE: Applying InputClass "system-setup-keyboard"
[    33.241] (II) No input driver/identifier specified (ignoring)
[    33.244] (II) config/udev: Adding input device Video WebCam (/dev/input/event7)
[    33.244] (**) Video WebCam: Applying InputClass "evdev keyboard catchall"
[    33.244] (**) Video WebCam: Applying InputClass "system-setup-keyboard"
[    33.244] (**) Video WebCam: always reports core events
[    33.244] (**) Video WebCam: Device: "/dev/input/event7"
[    33.247] (II) Video WebCam: Found keys
[    33.247] (II) Video WebCam: Configuring as keyboard
[    33.247] (II) XINPUT: Adding extended input device "Video WebCam" (type: KEYBOARD)
[    33.247] (**) Option "xkb_rules" "evdev"
[    33.247] (**) Option "xkb_model" "pc105"
[    33.247] (**) Option "xkb_layout" "pl"
[    33.247] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.253] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    33.253] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    33.253] (**) AT Translated Set 2 keyboard: Applying InputClass "system-setup-keyboard"
[    33.253] (**) AT Translated Set 2 keyboard: always reports core events
[    33.253] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[    33.257] (II) AT Translated Set 2 keyboard: Found keys
[    33.257] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[    33.257] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[    33.257] (**) Option "xkb_rules" "evdev"
[    33.257] (**) Option "xkb_model" "pc105"
[    33.257] (**) Option "xkb_layout" "pl"
[    33.257] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    33.258] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
[    33.258] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    33.258] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    33.258] (II) LoadModule: "synaptics"
[    33.259] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[    33.266] (II) Module synaptics: vendor="X.Org Foundation"
[    33.266]     compiled for 1.8.0, module version = 1.2.2
[    33.266]     Module class: X.Org XInput Driver
[    33.266]     ABI class: X.Org XInput driver, version 9.0
[    33.266] (II) Synaptics touchpad driver version 1.2.2
[    33.266] (**) Option "Device" "/dev/input/event5"
[    33.277] (II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
[    33.277] (II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
[    33.277] (II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    33.277] (II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
[    33.277] (II) SynPS/2 Synaptics TouchPad: buttons: left right
[    33.285] (--) SynPS/2 Synaptics TouchPad: touchpad found
[    33.285] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    33.289] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
[    33.289] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    33.289] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 0
[    33.289] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    33.289] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    33.297] (--) SynPS/2 Synaptics TouchPad: touchpad found
[    33.297] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[    33.297] (II) No input driver/identifier specified (ignoring)
[    33.325] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
[    36.456] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    36.457] (II) fglrx(0): Printing DDC gathered Modelines:
[    36.457] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    36.469] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    36.469] (II) fglrx(0): Printing DDC gathered Modelines:
[    36.469] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    36.540] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    36.540] (II) fglrx(0): Printing DDC gathered Modelines:
[    36.540] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    62.246] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    62.247] (II) fglrx(0): Printing DDC gathered Modelines:
[    62.247] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    62.259] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    62.259] (II) fglrx(0): Printing DDC gathered Modelines:
[    62.259] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    62.269] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    62.269] (II) fglrx(0): Printing DDC gathered Modelines:
[    62.269] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    66.036] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    66.036] (II) fglrx(0): Printing DDC gathered Modelines:
[    66.036] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    70.955] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    70.955] (II) fglrx(0): Printing DDC gathered Modelines:
[    70.955] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
próbowalem to usunac ale nie wiem do konca jak to zrobic...(...) "sh plik z sterownikami --unistall nie dziala bo wyskakuje mi jakas dziwna odpowiedz albo cos nie tak robie...
[root@Acer-pc lukasz]# sh /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run --unistall
Unrecognized flag : --unistall
Makeself version 2.1.3
1) Getting help or info about /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run :
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run -h|--help                     Print this message
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run -i|--info                     Print embedded info : title, default target directory, embedded script
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run -l|--list                     Print the list of files in the archive
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run -c|--check                    Checks integrity of the archive
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run --extract NewDirectory        Extract this package to NewDirectory only
2) Running /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run :
 /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run [options] [additional arguments to embedded script] with following options (in that order)
 --keep                              Do not erase target directory after running the embedded script
 Following arguments will be passed to the embedded script:
 --install                           Install the driver(default)
 --listpkg                           List all the generatable packages
 --buildpkg package                  Build "package" if generatable ("package" as returned by --listpkg)
 --buildandinstallpkg package        Build and Install "package" as returned by --listpkg
nadal to soma wyskakuje mimo że dobrze wpisalem, a (_wogole_ → w ogóle) ORT dobrze to robie bo wskazuje plik z steronikami tak powinno byc czy moze jakis konkretny pakiet ??
Jeśli tak dobrze to robisz jak piszesz, to robisz błąd mniej więcej co 10. kliknięcie w klawiaturę ;) Zamiast się chwalić, że dobrze piszesz wklej wyjście z tego "dobrze napisanego" tak jak poprzednio pokazałeś ze "źle napisanego". Z fusów nikt Ci nie wywróży co zrobiłeś.
Jeśli chcesz się upewnić, że "--uninstall" to poprawna opcja, to może wpisz "sh <plik ze sterownikami> --help". Z tego co pamiętam, to opcja jest poprawna, ale ja już od dawna przestałem (na szczęście rolleyes.gif ) walczyć ze sterami od tych badziewiaków z AMD, więc lepiej się upewnij.
root@Acer-pc lukasz]# sh /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run --help
nie widzę uninstall niestety
[root@Acer-pc lukasz]# sh /home/lukasz/Pobrane/ati-driver-installer-10-9-x86.x86_64.run --uninstall
Unrecognized flag : --uninstall
Postaram się pisać poprawnie jeżeli to uspokoi twoje nerwy :P
odinstalowalem i postepowalem zgodnie z poradnikiem i znowu to samo... chyba ze mam wykonac równiez te czynnosci po instalacji ? Bo to bylo wpisane w sekcji z sterownikami nvidi
Uwaga
Po instalacji sterowników nalezy zastosowac czynnosci wykonywane po instalacji.
   Zródla: rpmfusion [fedoraforum.org]
   * dezaktywacja sterownika nouveau.
Do opcji kernela w pliku /boot/grub/grub.conf nalezy dopisac rdblacklist=nouveau, np:
kernel /vmlinuz-2.6.31.5-127.fc12.i686 ro root=UUID=43e3ga46-2e21-3428a6aa-49e7c2223eg5
LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 LANG=pl_PL.UTF-8
SYSFONT=latarcyrheb-sun16 rghb quiet rdblacklist=nouveau
   * przebudowa initrd:
su -
mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img
dracut /boot/initramfs-$(uname -r).img $(uname -r)
   * ustawienie kontekstu SElinux:
su -c "setsebool -P allow_execstack on"
wyniki lsmod
[root@Acer-pc lukasz]# lsmod
Module                  Size  Used by
fuse                   57233  2
sunrpc                198573  1
acpi_cpufreq            7693  1
ip6t_REJECT             4111  2
aes_x86_64              7742  2
xts                     2455  1
gf128mul                7282  1 xts
dm_crypt               11354  1
uinput                  7455  0
arc4                    1433  2
ecb                     2087  2
snd_seq                53005  0
microcode              18282  0
acer_wmi               15004  0
ath9k                  79156  0
iTCO_wdt               11200  0
uvcvideo               54628  0
tg3                   109556  0
wmi                     6888  1 acer_wmi
i2c_i801               10270  0
joydev                  9771  0
serio_raw               4588  0
video                  21629  0
output                  2221  1 video
radeon                711597  0
ttm                    54819  1 radeon
wyniki z /var/log/ati/Xorg.O.log
[    42.136]
[    42.136] X Protocol Version 11, Revision 0
[    42.136] Build Operating System: x86-17 2.6.32-44.el6.x86_64
[    42.136] Current Operating System: Linux Acer-pc 2.6.34.7-56.fc13.x86_64 #1 SMP Wed Sep 15 03:36:55 UTC 2010 x86_64
[    42.137] Kernel command line: ro root=UUID=c1d7dc32-9349-4cd1-b06d-b5f15ac3cac8 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 nomodeset rhgb quiet radeon.modeset=0
[    42.137] Build Date: 13 September 2010  07:04:16PM
[    42.137] Build ID: xorg-x11-server 1.8.2-4.fc13
[    42.159] Current version of pixman: 0.18.0
[    42.159]     Before reporting problems, check http://bodhi.fedoraproject.org/
[    42.159] Markers: (--) probed, (**) from config file, (==) default setting,
[    42.159] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 15 21:35:33 2010
[    42.228] (==) Using config file: "/etc/X11/xorg.conf"
[    42.228] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    42.228] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    42.346] (==) ServerLayout "Default Layout"
[    42.346] (**) |-->Screen "Screen0" (0)
[    42.346] (**) |   |-->Monitor "<default monitor>"
[    42.346] (**) |   |-->Device "Videocard0"
[    42.346] (==) No monitor specified for screen "Screen0".
   Using a default monitor configuration.
[    42.346] (**) Option "AIGLX" "on"
[    42.346] (==) Automatically adding devices
[    42.346] (==) Automatically enabling devices
[    42.346] (==) FontPath set to:
   built-ins
[    42.346] (**) ModulePath set to "/usr/lib64/xorg/modules/extensions/catalyst,/usr/lib64/xorg/modules"
[    42.346] (**) Extension "Composite" is enabled
[    42.346] (II) The server relies on udev to provide the list of input devices.
[    42.347] (II)
[    42.347] (II) Loader magic: 0x7ced20
[    42.347] (II) Module ABI versions:
[    42.347]     X.Org ANSI C Emulation: 0.4
[    42.347]     X.Org Video Driver: 7.0
[    42.347]     X.Org XInput driver : 9.0
[    42.347]     X.Org Server Extension : 3.0
[    42.357] (--) PCI:*(0:1:0:0) 1002:68c1:1025:0296 ATI Technologies Inc Redwood [Radeon HD 5600 Series] rev 0, Mem @ 0xd0000000/268435456, 0xf4000000/131072, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[    42.358] (II) LoadModule: "extmod"
[    42.488] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[    42.536] (II) Module extmod: vendor="X.Org Foundation"
[    42.536]     compiled for 1.8.2, module version = 1.0.0
[    42.536]     Module class: X.Org Server Extension
[    42.536]     ABI class: X.Org Server Extension, version 3.0
[    42.536] (II) Loading extension SELinux
[    42.536] (II) Loading extension MIT-SCREEN-SAVER
[    42.536] (II) Loading extension XFree86-VidModeExtension
[    42.536] (II) Loading extension XFree86-DGA
[    42.536] (II) Loading extension DPMS
[    42.536] (II) Loading extension XVideo
[    42.536] (II) Loading extension XVideo-MotionCompensation
[    42.536] (II) Loading extension X-Resource
[    42.536] (II) LoadModule: "dbe"
[    42.537] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[    42.547] (II) Module dbe: vendor="X.Org Foundation"
[    42.548]     compiled for 1.8.2, module version = 1.0.0
[    42.548]     Module class: X.Org Server Extension
[    42.548]     ABI class: X.Org Server Extension, version 3.0
[    42.548] (II) Loading extension DOUBLE-BUFFER
[    42.548] (II) LoadModule: "glx"
[    42.548] (II) Loading /usr/lib64/xorg/modules/extensions/catalyst/libglx.so
[    42.649] (II) Module glx: vendor="FireGL - ATI Technologies Inc."
[    42.649]     compiled for 7.5.0, module version = 1.0.0
[    42.649] (II) Loading extension GLX
[    42.649] (II) LoadModule: "record"
[    42.651] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[    42.655] (II) Module record: vendor="X.Org Foundation"
[    42.655]     compiled for 1.8.2, module version = 1.13.0
[    42.655]     Module class: X.Org Server Extension
[    42.655]     ABI class: X.Org Server Extension, version 3.0
[    42.655] (II) Loading extension RECORD
[    42.655] (II) LoadModule: "dri"
[    42.657] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[    42.702] (II) Module dri: vendor="X.Org Foundation"
[    42.702]     compiled for 1.8.2, module version = 1.0.0
[    42.702]     ABI class: X.Org Server Extension, version 3.0
[    42.702] (II) Loading extension XFree86-DRI
[    42.702] (II) LoadModule: "dri2"
[    42.704] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[    42.705] (II) Module dri2: vendor="X.Org Foundation"
[    42.705]     compiled for 1.8.2, module version = 1.2.0
[    42.705]     ABI class: X.Org Server Extension, version 3.0
[    42.705] (II) Loading extension DRI2
[    42.705] (II) LoadModule: "fglrx"
[    42.732] (II) Loading /usr/lib64/xorg/modules/drivers/fglrx_drv.so
[    42.974] (II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
[    42.987]     compiled for 1.7.1, module version = 8.77.5
[    42.987]     Module class: X.Org Video Driver
[    43.000] (II) Loading sub module "fglrxdrm"
[    43.000] (II) LoadModule: "fglrxdrm"
[    43.001] (II) Loading /usr/lib64/xorg/modules/linux/libfglrxdrm.so
[    43.013] (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
[    43.013]     compiled for 1.7.1, module version = 8.77.5
[    43.013] (II) ATI Proprietary Linux Driver Version Identifier:8.77.5
[    43.013] (II) ATI Proprietary Linux Driver Release Identifier: 8.771
[    43.013] (II) ATI Proprietary Linux Driver Build Date: Aug 25 2010 21:38:26
[    43.013] (++) using VT number 1
[    43.018] (II) Primary Device is: PCI 01@00:00:0
[    43.018] (WW) Falling back to old probe method for fglrx
[    43.055] (II) Loading PCS database from /etc/ati/amdpcsdb
[    43.069] (--) Assigning device section with no busID to primary device
[    43.069] (--) Chipset Supported AMD Graphics Processor (0x68C1) found
[    43.081] (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
[    43.082] (II) AMD Video driver is running on a device belonging to a group targeted for this release
[    43.093] (II) AMD Video driver is signed
[    43.094] (II) fglrx(0): pEnt->device->identifier=0x15c1840
[    43.094] (II) fglrx(0): === [atiddxPreInit] === begin
[    43.094] (II) Loading sub module "vgahw"
[    43.094] (II) LoadModule: "vgahw"
[    43.096] (II) Loading /usr/lib64/xorg/modules/libvgahw.so
[    43.107] (II) Module vgahw: vendor="X.Org Foundation"
[    43.107]     compiled for 1.8.2, module version = 0.1.0
[    43.107]     ABI class: X.Org Video Driver, version 7.0
[    43.107] (II) fglrx(0): Creating default Display subsection in Screen section
   "Screen0" for depth/fbbpp 24/32
[    43.107] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[    43.107] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    43.107] (==) fglrx(0): Default visual is TrueColor
[    43.107] (**) fglrx(0): Option "OpenGLOverlay" "off"
[    43.107] (==) fglrx(0): RGB weight 888
[    43.107] (II) fglrx(0): Using 8 bits per RGB
[    43.107] (==) fglrx(0): Buffer Tiling is ON
[    43.108] (II) Loading sub module "fglrxdrm"
[    43.108] (II) LoadModule: "fglrxdrm"
[    43.109] (II) Reloading /usr/lib64/xorg/modules/linux/libfglrxdrm.so
[    43.130] ukiDynamicMajor: failed to open /proc/ati/major
[    43.131] ukiDynamicMajor: failed to open /proc/ati/major
[    43.131] (==) fglrx(0): NoAccel = NO
[    43.131] (==) fglrx(0): ATI 2D Acceleration Architecture enabled
[    43.131] (--) fglrx(0): Chipset: "ATI Mobility Radeon HD 5600/5700 Series" (Chipset = 0x68c1)
[    43.131] (--) fglrx(0): (PciSubVendor = 0x1025, PciSubDevice = 0x0296)
[    43.131] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
[    43.131] (--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
[    43.131] (--) fglrx(0): MMIO registers at 0xf4000000
[    43.131] (--) fglrx(0): I/O port at 0x00002000
[    43.131] (==) fglrx(0): ROM-BIOS at 0x000c0000
[    43.164] (II) fglrx(0): Primary V_BIOS segment is: 0xc000
[    43.165] (EE) fglrx(0): ACPI: DRM connection failed
[    43.251] (II) Loading sub module "vbe"
[    43.251] (II) LoadModule: "vbe"
[    43.275] (II) Loading /usr/lib64/xorg/modules/libvbe.so
[    43.284] (II) Module vbe: vendor="X.Org Foundation"
[    43.284]     compiled for 1.8.2, module version = 1.1.0
[    43.284]     ABI class: X.Org Video Driver, version 7.0
[    43.284] (II) fglrx(0): VESA BIOS detected
[    43.284] (II) fglrx(0): VESA VBE Version 3.0
[    43.284] (II) fglrx(0): VESA VBE Total Mem: 16384 kB
[    43.284] (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
[    43.284] (II) fglrx(0): VESA VBE OEM Software Rev: 12.15
[    43.284] (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
[    43.284] (II) fglrx(0): VESA VBE OEM Product: MADISON
[    43.284] (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
[    43.361] (II) fglrx(0): ATI Video BIOS revision 9 or later detected
[    43.361] (--) fglrx(0): Video RAM: 1048576 kByte, Type: DDR3
[    43.361] (II) fglrx(0): PCIE card detected
[    43.361] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[    43.361] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[    43.361] (EE) fglrx(0): ACPI: DRM connection failed
[    43.361] (WW) fglrx(0): Hasn't establisted DRM connection
[    43.361] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x40000000)
[    43.361] (WW) fglrx(0): No DRM connection for driver fglrx.
[    43.361] (II) fglrx(0): RandR 1.2 support is enabled!
[    43.361] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[    43.361] (==) fglrx(0): Center Mode is disabled
[    43.361] (II) Loading sub module "fb"
[    43.361] (II) LoadModule: "fb"
[    43.363] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    43.370] (II) Module fb: vendor="X.Org Foundation"
[    43.370]     compiled for 1.8.2, module version = 1.0.0
[    43.370]     ABI class: X.Org ANSI C Emulation, version 0.4
[    43.370] (==) fglrx(0): Active stereo disabled
[    43.370] (II) Loading sub module "ddc"
[    43.370] (II) LoadModule: "ddc"
[    43.370] (II) Module "ddc" already built-in
[    43.476] (II) fglrx(0): Output LVDS has no monitor section
[    43.476] (II) fglrx(0): Output DFP1 has no monitor section
[    43.476] (II) fglrx(0): Output CRT1 has no monitor section
[    43.494] (II) Loading sub module "ddc"
[    43.494] (II) LoadModule: "ddc"
[    43.494] (II) Module "ddc" already built-in
[    43.494] (II) fglrx(0): Connected Display0: LVDS
[    43.494] (II) fglrx(0): Display0 EDID data ---------------------------
[    43.494] (II) fglrx(0): Manufacturer: SEC  Model: 3051  Serial#: 0
[    43.494] (II) fglrx(0): Year: 2008  Week: 0
[    43.495] (II) fglrx(0): EDID Version: 1.3
[    43.495] (II) fglrx(0): Digital Display Input
[    43.495] (II) fglrx(0): Max Image Size [cm]: horiz.: 39  vert.: 23
[    43.495] (II) fglrx(0): Gamma: 2.20
[    43.495] (II) fglrx(0): No DPMS capabilities specified
[    43.495] (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    43.495] (II) fglrx(0): First detailed timing is preferred mode
[    43.495] (II) fglrx(0): redX: 0.600 redY: 0.340   greenX: 0.310 greenY: 0.560
[    43.495] (II) fglrx(0): blueX: 0.150 blueY: 0.130   whiteX: 0.313 whiteY: 0.329
[    43.495] (II) fglrx(0): Manufacturer's mask: 0
[    43.495] (II) fglrx(0): Supported detailed timing:
[    43.495] (II) fglrx(0): clock: 107.8 MHz   Image Size:  398 x 232 mm
[    43.495] (II) fglrx(0): h_active: 1600  h_sync: 1648  h_sync_end 1680 h_blank_end 1892 h_border: 0
[    43.495] (II) fglrx(0): v_active: 900  v_sync: 902  v_sync_end 908 v_blanking: 950 v_border: 0
[    43.495] (II) fglrx(0): Unknown vendor-specific block f
[    43.495] (II) fglrx(0):  SAMSUNG
[    43.495] (II) fglrx(0):  173KT01-A01
[    43.495] (II) fglrx(0): EDID (in hex):
[    43.495] (II) fglrx(0):     00ffffffffffff004ca3513000000000
[    43.495] (II) fglrx(0):     00120103802717780a859599574f8f26
[    43.495] (II) fglrx(0):     21505400000001010101010101010101
[    43.495] (II) fglrx(0):     010101010101202a4024618432303020
[    43.495] (II) fglrx(0):     26008ee8100000190000000f00000000
[    43.495] (II) fglrx(0):     00000000001eb4027400000000fe0053
[    43.495] (II) fglrx(0):     414d53554e470a2020202020000000fe
[    43.495] (II) fglrx(0):     003137334b5430312d4130310a2000a4
[    43.495] (II) fglrx(0): End of Display0 EDID data --------------------
[    43.505] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    43.505] (II) fglrx(0): Printing DDC gathered Modelines:
[    43.505] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    43.505] (II) fglrx(0): Output LVDS connected
[    43.505] (II) fglrx(0): Output DFP1 disconnected
[    43.505] (II) fglrx(0): Output CRT1 disconnected
[    43.505] (II) fglrx(0): Using exact sizes for initial modes
[    43.505] (II) fglrx(0): Output LVDS using initial mode 1600x900
[    43.505] (II) fglrx(0): Display dimensions: (390, 230) mm
[    43.505] (II) fglrx(0): DPI set to (104, 99)
[    43.505] (II) fglrx(0): Adapter ATI Mobility Radeon HD 5600/5700 Series has 2 configurable heads and 1 displays connected.
[    43.506] (==) fglrx(0):  PseudoColor visuals disabled
[    43.506] (II) Loading sub module "ramdac"
[    43.506] (II) LoadModule: "ramdac"
[    43.506] (II) Module "ramdac" already built-in
[    43.506] (==) fglrx(0): NoDRI = NO
[    43.506] (==) fglrx(0): Capabilities: 0x00000000
[    43.506] (==) fglrx(0): CapabilitiesEx: 0x00000000
[    43.506] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[    43.506] (==) fglrx(0): UseFastTLS=0
[    43.506] (==) fglrx(0): BlockSignalsOnLock=1
[    43.506] (--) Depth 24 pixmap format is 32 bpp
[    43.506] (EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized.
[    43.506] (WW) fglrx(0): ***********************************************************
[    43.506] (WW) fglrx(0): * DRI initialization failed                               *
[    43.506] (WW) fglrx(0): * kernel module (fglrx.ko) may be missing or incompatible *
[    43.506] (WW) fglrx(0): * 2D and 3D acceleration disabled                         *
[    43.518] (II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x10000000
[    43.599] (II) fglrx(0): FBMM initialized for area (0,0)-(1600,8191)
[    43.599] (II) fglrx(0): FBMM auto alloc for area (0,0)-(1600,1600) (front color buffer - assumption)
[    43.599] (II) fglrx(0): Largest offscreen area available: 1600 x 6591
[    43.600] (==) fglrx(0): Backing store disabled
[    43.600] (II) Loading extension FGLRXEXTENSION
[    43.601] (==) fglrx(0): DPMS enabled
[    43.601] (II) fglrx(0): Initialized in-driver Xinerama extension
[    43.601] (WW) fglrx(0): Textured Video not supported without DRI enabled.
[    43.601] (II) LoadModule: "glesx"
[    43.604] (II) Loading /usr/lib64/xorg/modules/glesx.so
[    43.799] (II) Module glesx: vendor="X.Org Foundation"
[    43.799]     compiled for 1.7.1, module version = 1.0.0
[    43.799] (II) Loading extension GLESX
[    43.799] (II) fglrx(0): GLESX enableFlags = 576
[    43.799] (II) fglrx(0): Acceleration enabled
[    43.799] (II) LoadModule: "amdxmm"
[    43.801] (II) Loading /usr/lib64/xorg/modules/amdxmm.so
[    43.818] (II) Module amdxmm: vendor="X.Org Foundation"
[    43.818]     compiled for 1.7.1, module version = 1.0.0
[    43.818] (EE) fglrx(0): XMM failed to open CMMQS connection.
[    43.818] (EE) fglrx(0): XMM failed to initialize
[    43.818] (WW) fglrx(0): No XV video playback available
[    43.819] (II) fglrx(0): Enable composite support successfully
[    43.819] (WW) fglrx(0): Option "VideoOverlay" is not used
[    43.819] (==) fglrx(0): Silken mouse enabled
[    43.819] (==) fglrx(0): Using HW cursor of display infrastructure!
[    43.819] (II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
[    43.819] (II) fglrx(0): 'LVDS LCD' ConnectorType, abstracted as 'Panel'
[    43.819] (II) fglrx(0): 'eDP LCD' ConnectorType, abstracted as 'Panel'
[    44.353] (--) RandR disabled
[    44.353] (II) Initializing built-in extension Generic Event Extension
[    44.353] (II) Initializing built-in extension SHAPE
[    44.353] (II) Initializing built-in extension MIT-SHM
[    44.353] (II) Initializing built-in extension XInputExtension
[    44.353] (II) Initializing built-in extension XTEST
[    44.353] (II) Initializing built-in extension BIG-REQUESTS
[    44.353] (II) Initializing built-in extension SYNC
[    44.353] (II) Initializing built-in extension XKEYBOARD
[    44.353] (II) Initializing built-in extension XC-MISC
[    44.353] (II) Initializing built-in extension XINERAMA
[    44.353] (II) Initializing built-in extension XFIXES
[    44.353] (II) Initializing built-in extension RENDER
[    44.353] (II) Initializing built-in extension RANDR
[    44.353] (II) Initializing built-in extension COMPOSITE
[    44.353] (II) Initializing built-in extension DAMAGE
[    44.356] (II) SELinux: Disabled by boolean
[    44.358] (II) AIGLX: Screen 0 is not DRI capable
[    44.359] [glesx] __glESXExtensionInit: No GL ES2.0 capable screen found!
[    44.405] (II) fglrx(0): Setting screen physical size to 423 x 238
[    45.389] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    45.389] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    45.389] (**) Power Button: Applying InputClass "system-setup-keyboard"
[    45.389] (II) LoadModule: "evdev"
[    45.391] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[    45.408] (II) Module evdev: vendor="X.Org Foundation"
[    45.408]     compiled for 1.7.99.901, module version = 2.4.0
[    45.409]     Module class: X.Org XInput Driver
[    45.409]     ABI class: X.Org XInput driver, version 9.0
[    45.409] (**) Power Button: always reports core events
[    45.409] (**) Power Button: Device: "/dev/input/event2"
[    45.412] (II) Power Button: Found keys
[    45.412] (II) Power Button: Configuring as keyboard
[    45.412] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[    45.412] (**) Option "xkb_rules" "evdev"
[    45.412] (**) Option "xkb_model" "pc105"
[    45.412] (**) Option "xkb_layout" "pl"
[    45.412] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.671] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[    45.671] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    45.671] (**) Video Bus: Applying InputClass "system-setup-keyboard"
[    45.671] (**) Video Bus: always reports core events
[    45.671] (**) Video Bus: Device: "/dev/input/event6"
[    45.674] (II) Video Bus: Found keys
[    45.674] (II) Video Bus: Configuring as keyboard
[    45.674] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
[    45.674] (**) Option "xkb_rules" "evdev"
[    45.674] (**) Option "xkb_model" "pc105"
[    45.674] (**) Option "xkb_layout" "pl"
[    45.674] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.719] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    45.719] (II) No input driver/identifier specified (ignoring)
[    45.720] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    45.720] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    45.720] (**) Sleep Button: Applying InputClass "system-setup-keyboard"
[    45.720] (**) Sleep Button: always reports core events
[    45.721] (**) Sleep Button: Device: "/dev/input/event1"
[    45.725] (II) Sleep Button: Found keys
[    45.725] (II) Sleep Button: Configuring as keyboard
[    45.725] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
[    45.725] (**) Option "xkb_rules" "evdev"
[    45.725] (**) Option "xkb_model" "pc105"
[    45.725] (**) Option "xkb_layout" "pl"
[    45.725] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.746] (II) config/udev: Adding input device MLK TRACER EXCLUSIVE (/dev/input/event4)
[    45.746] (**) MLK TRACER EXCLUSIVE: Applying InputClass "evdev pointer catchall"
[    45.746] (**) MLK TRACER EXCLUSIVE: Applying InputClass "evdev keyboard catchall"
[    45.746] (**) MLK TRACER EXCLUSIVE: Applying InputClass "system-setup-keyboard"
[    45.746] (**) MLK TRACER EXCLUSIVE: always reports core events
[    45.746] (**) MLK TRACER EXCLUSIVE: Device: "/dev/input/event4"
[    45.749] (II) MLK TRACER EXCLUSIVE: Found 9 mouse buttons
[    45.749] (II) MLK TRACER EXCLUSIVE: Found scroll wheel(s)
[    45.749] (II) MLK TRACER EXCLUSIVE: Found relative axes
[    45.749] (II) MLK TRACER EXCLUSIVE: Found x and y relative axes
[    45.749] (II) MLK TRACER EXCLUSIVE: Found absolute axes
[    45.749] (II) MLK TRACER EXCLUSIVE: Found keys
[    45.749] (II) MLK TRACER EXCLUSIVE: Configuring as mouse
[    45.749] (II) MLK TRACER EXCLUSIVE: Configuring as keyboard
[    45.749] (**) MLK TRACER EXCLUSIVE: YAxisMapping: buttons 4 and 5
[    45.749] (**) MLK TRACER EXCLUSIVE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    45.749] (II) XINPUT: Adding extended input device "MLK TRACER EXCLUSIVE" (type: KEYBOARD)
[    45.749] (**) Option "xkb_rules" "evdev"
[    45.749] (**) Option "xkb_model" "pc105"
[    45.749] (**) Option "xkb_layout" "pl"
[    45.749] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.749] (**) MLK TRACER EXCLUSIVE: (accel) keeping acceleration scheme 1
[    45.749] (**) MLK TRACER EXCLUSIVE: (accel) acceleration profile 0
[    45.749] (**) MLK TRACER EXCLUSIVE: (accel) acceleration factor: 2.000
[    45.749] (**) MLK TRACER EXCLUSIVE: (accel) acceleration threshold: 4
[    45.749] (II) MLK TRACER EXCLUSIVE: initialized for relative axes.
[    45.749] (WW) MLK TRACER EXCLUSIVE: ignoring absolute axes.
[    45.750] (II) config/udev: Adding input device MLK TRACER EXCLUSIVE (/dev/input/mouse0)
[    45.750] (**) MLK TRACER EXCLUSIVE: Applying InputClass "system-setup-keyboard"
[    45.750] (II) No input driver/identifier specified (ignoring)
[    45.754] (II) config/udev: Adding input device Video WebCam (/dev/input/event7)
[    45.754] (**) Video WebCam: Applying InputClass "evdev keyboard catchall"
[    45.754] (**) Video WebCam: Applying InputClass "system-setup-keyboard"
[    45.754] (**) Video WebCam: always reports core events
[    45.754] (**) Video WebCam: Device: "/dev/input/event7"
[    45.758] (II) Video WebCam: Found keys
[    45.758] (II) Video WebCam: Configuring as keyboard
[    45.758] (II) XINPUT: Adding extended input device "Video WebCam" (type: KEYBOARD)
[    45.758] (**) Option "xkb_rules" "evdev"
[    45.758] (**) Option "xkb_model" "pc105"
[    45.758] (**) Option "xkb_layout" "pl"
[    45.758] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.766] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    45.766] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    45.766] (**) AT Translated Set 2 keyboard: Applying InputClass "system-setup-keyboard"
[    45.766] (**) AT Translated Set 2 keyboard: always reports core events
[    45.766] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[    45.776] (II) AT Translated Set 2 keyboard: Found keys
[    45.776] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[    45.776] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
[    45.776] (**) Option "xkb_rules" "evdev"
[    45.776] (**) Option "xkb_model" "pc105"
[    45.776] (**) Option "xkb_layout" "pl"
[    45.776] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[    45.777] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
[    45.777] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    45.777] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    45.777] (II) LoadModule: "synaptics"
[    45.778] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[    45.815] (II) Module synaptics: vendor="X.Org Foundation"
[    45.815]     compiled for 1.8.0, module version = 1.2.2
[    45.815]     Module class: X.Org XInput Driver
[    45.815]     ABI class: X.Org XInput driver, version 9.0
[    45.816] (II) Synaptics touchpad driver version 1.2.2
[    45.816] (**) Option "Device" "/dev/input/event5"
[    45.826] (II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
[    45.826] (II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
[    45.826] (II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    45.826] (II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
[    45.826] (II) SynPS/2 Synaptics TouchPad: buttons: left right
[    45.834] (--) SynPS/2 Synaptics TouchPad: touchpad found
[    45.834] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    45.838] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
[    45.838] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    45.838] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 0
[    45.838] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    45.838] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    45.846] (--) SynPS/2 Synaptics TouchPad: touchpad found
[    45.846] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[    45.846] (II) No input driver/identifier specified (ignoring)
[    45.885] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
[    49.366] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    49.367] (II) fglrx(0): Printing DDC gathered Modelines:
[    49.367] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    49.378] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    49.378] (II) fglrx(0): Printing DDC gathered Modelines:
[    49.378] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    49.523] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    49.523] (II) fglrx(0): Printing DDC gathered Modelines:
[    49.523] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    65.252] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    65.254] (II) fglrx(0): Printing DDC gathered Modelines:
[    65.254] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    65.266] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    65.266] (II) fglrx(0): Printing DDC gathered Modelines:
[    65.266] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    65.276] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    65.276] (II) fglrx(0): Printing DDC gathered Modelines:
[    65.276] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    69.940] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    69.942] (II) fglrx(0): Printing DDC gathered Modelines:
[    69.942] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
[    72.231] (II) fglrx(0): EDID vendor "SEC", prod id 12369
[    72.231] (II) fglrx(0): Printing DDC gathered Modelines:
[    72.231] (II) fglrx(0): Modeline "1600x900"x0.0  107.84  1600 1648 1680 1892  900 902 908 950 -hsync -vsync (57.0 kHz)
