Kde Partition Manager Problem 2 Problemy Libparted
foreste
Witam
mam problem z kde partition manager z repoz i source
1 z repoz f16
Błędy rozwiązywania zależności:
Pakiet: kde-partitionmanager-1.0.3-2.fc15.i686 (fedora)
   Wymaga: libparted.so.0
z source
root@dom build# cmake ..
-- Found Qt-Version 4.8.0 (using /usr/bin/qmake-qt4)
-- Found X11: /usr/lib/libX11.so
-- Found KDE 4.7 include dir: /usr/include/kde4
-- Found KDE 4.7 library dir: /usr/lib/kde4/devel
-- Found the KDE4 kconfig_compiler4 preprocessor: /usr/bin/kconfig_compiler4
-- Found automoc4: /usr/bin/automoc4
-- checking for module 'uuid'
--   found uuid, version 2.20.0
-- checking for module 'blkid'
--   found blkid, version 2.20.0
CMake Error at /usr/share/kde4/apps/cmake/modules/FindPackageHandleStandardArgs.cmake:198 (MESSAGE):
 Could NOT find LIBPARTED (missing: LIBPARTED_LIBRARY LIBPARTED_INCLUDE_DIR)
Call Stack (most recent call first):
 cmake/modules/FindLIBPARTED.cmake:29 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
 CMakeLists.txt:41 (find_package)
-- Configuring incomplete, errors occurred!
-- Found LIBPARTED: /usr/lib/libparted.so
-- KDE Partition Manager 1.0.3 will be built for install into /usr/local
-- Looking for dgettext
-- Looking for dgettext - found
-- Found Gettext: built in libc
-- Configuring done
-- Generating done
-- Build files have been written to: /home/foreste/wypakowane/partitionmanager-1.0.3/build
root@dom build# make
Scanning dependencies of target partitionmanager
[  0%] Built target partitionmanager
Scanning dependencies of target partitionmanagerprivate_automoc
Generating moc_job.cpp
Generating moc_parttablewidget.cpp
Generating moc_restoreoperation.cpp
Generating moc_partpropsdialog.cpp
Generating moc_resizedialog.cpp
Generating moc_device.cpp
Generating moc_setfilesystemlabeloperation.cpp
Generating moc_treelog.cpp
Generating moc_progressdialog.cpp
Generating moc_sizedialogbase.cpp
Generating moc_partresizerwidget.cpp
Generating moc_partitionnode.cpp
Generating moc_copyoperation.cpp
Generating moc_sizedialogwidget.cpp
Generating moc_partwidget.cpp
Generating moc_createfilesystemoperation.cpp
Generating moc_operation.cpp
Generating moc_partitionmanagerwidget.cpp
Generating moc_mainwindow.cpp
Generating moc_listdevices.cpp
Generating moc_newoperation.cpp
Generating moc_operationrunner.cpp
Generating moc_progressdetailswidget.cpp
Generating moc_globallog.cpp
Generating moc_insertdialog.cpp
Generating moc_checkoperation.cpp
Generating moc_listoperations.cpp
Generating moc_filesystemsupportdialog.cpp
Generating moc_createpartitiontableoperation.cpp
Generating moc_deleteoperation.cpp
Generating moc_report.cpp
Generating moc_setpartflagsoperation.cpp
Generating moc_resizeoperation.cpp
Generating moc_backupoperation.cpp
Generating moc_externalcommand.cpp
Generating moc_newdialog.cpp
[  0%] Built target partitionmanagerprivate_automoc
[  1%] Generating config.h, config.cpp
[  1%] Generating ui_listoperationsbase.h
[  2%] Generating ui_filesystemsupportdialogwidgetbase.h
[  3%] Generating ui_partitionmanagerwidgetbase.h
[  4%] Generating ui_partpropswidgetbase.h
[  5%] Generating ui_sizedialogwidgetbase.h
/home/foreste/wypakowane/partitionmanager-1.0.3/src/gui/sizedialogwidgetbase.ui: Warning: Z-order assignment: 'verticalSpacer' is not a valid widget.
[  5%] Generating ui_listdevicesbase.h
[  6%] Generating ui_progressdialogwidgetbase.h
[  7%] Generating ui_progressdetailswidgetbase.h
[  8%] Generating ui_treelogbase.h
[  8%] Generating ui_mainwindowbase.h
[  9%] Generating ui_partitionmanagerkcmbase.h
[ 10%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/partitionmanagerprivate_automoc.o
[ 11%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/copytargetfile.o
[ 11%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/copysourcefile.o
[ 12%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/copytarget.o
[ 13%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/copytargetdevice.o
[ 14%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/operationstack.o
[ 15%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/partition.o
[ 15%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/partitionnode.o
[ 16%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/partitionrole.o
[ 17%] Building CXX object src/CMakeFiles/partitionmanagerprivate.dir/core/libparted.o
/home/foreste/wypakowane/partitionmanager-1.0.3/src/core/libparted.cpp: In function ‘qint64 readSectorsUsedLibParted(PedDisk*, const Partition&)’:
/home/foreste/wypakowane/partitionmanager-1.0.3/src/core/libparted.cpp:131:74: error: ‘ped_file_system_open’ was not declared in this scope
/home/foreste/wypakowane/partitionmanager-1.0.3/src/core/libparted.cpp:135:90: error: ‘ped_file_system_get_resize_constraint’ was not declared in this scope
/home/foreste/wypakowane/partitionmanager-1.0.3/src/core/libparted.cpp:141:39: error: ‘ped_file_system_close’ was not declared in this scope
make[2]: *** [src/CMakeFiles/partitionmanagerprivate.dir/core/libparted.o] Błąd 1
make[1]: *** [src/CMakeFiles/partitionmanagerprivate.dir/all] Błąd 2
make: *** [all] Błąd 2
jak to naprawic ?.
Skąd wziąłeś plik /usr/lib/libparted.so? Przy pierwszym cmake Ci go nie znalazł.
Możesz spróbować:
cd
wget http://download.fedoraproject.org/pub/fedora/linux/updates/15/i386/parted-2.3-11.fc15.i686.rpm
rpmdev-extract parted-2.3-11.fc15.i686.rpm
sudo cp -dv parted-2.3-11.fc15.i686/lib/* /lib
I spróbować kompilację ponownie.
Możesz spróbować:
cd
Zainstalowałem parted devel
Sprawa nie jest prosta - link. Na dzisiaj rozwiązanie to
su -c "yum install svn libatasmart-devel"
svn co svn://anonsvn.kde.org/home/kde/trunk/extragear/sysadmin/partitionmanager/
Pobrana wersja się skompiluje, ale pamiętaj że to rewizja svn i zmiany nie są kosmetyczne. Używasz na własną odpowiedzialność.
Działa ;)
Dziękuje
A jak zrobić proste rpm żeby nie zaśmiecać systemu ?
Checkinstall działa na f16 ?
lub jakis konfigurator spec jest ?
Jak zrobisz rpm zgodnie z ZEN :) to możesz instalować tam gdzie Ci się podoba.
# rpm --prefix=/opt -ivh paczka.rpm
To się nazywa relocatable package http://www.cyberciti.biz/faq/rpm-relocatable-packages/
i w praktyce sprowadza się do wpisania w spec parametru Prefix i wstawieniu %{prefix} przed ścieżkami (z automake to drugie jest pewnie zrobione domyślnie).
Do tego możesz mieć niezależna, używaną z poziomu użytkownika bazę rpm. Ale uwaga, ta baza będzie miała własne zależności, więc to raczej do własnych paczek.
1. ustaw jakiś root
ROOT=/home/lucas/local
2. w nim trzeba zainicjować bazę rpm
DBPATH=$ROOT/var/lib/rpm
mkdir -p $DBPATH
rpm --dbpath $DBPATH --initdb
3. zrób teraz 2 skrypty
- do wszystkiego poza instalacją: myrpm
#!/bin/bash
rpm --dbpath $DBPATH $*
- do instalacji: myrpm-install
#!/bin/bash
rpm --dbpath $DBPATH --prefix $ROOT $*
u mnie bangla, dla własnych paczek.
Dlaczego nie użyć opcji --root ?
Bo ta opcja służy do budowania bazy w chroot i rpm przestaje widzieć jakiekolwiek programy (nawet mkdir nie zadziała ot tak) spoza katalogu ustawionego jako root.
Dziekuje za pomoc w tym :)
PROGRAM SKOPILOWANY I ZROBIONA PACZKA RPM:)
A tu moj spec,ktory przerobilem z wadliwej paczki kde partitionmanager z f15
Summary: KDE Partition Manager
Version: 1.0.60
Release: 1%{?dist}
License: GPL v2
Group: Applications/System
Source0:  kde-partitionmanager-%{version}.tar.gz
Packager: foreste
Distribution: Fedora
Url: http://my.opera.com/Foreste
Vendor: Poland
BuildRoot:	%{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
# upstreamable patches
BuildRequires:	parted-devel, e2fsprogs-devel, pkgconfig, gettext, kdelibs4-devel, cmake
%if 0%{?fedora} >= 12
BuildRequires:	libuuid-devel libblkid-devel
%endif
Requires:	parted, e2fsprogs, reiserfs-utils
%global kde4_version %((kde4-config --version 2>/dev/null || echo "KDE 4.3.0") | grep ^KDE | cut -d' ' -f2)
%{?_kde4_macros_api:Requires: kde4-macros(api) = %{_kde4_macros_api} }
%description
KDE Partition Manager is a utility program to help you manage the disk devices,
partitions and file systems on your computer. It allows you to easily create,
copy, move, delete, resize without losing data, backup and restore partitions.
KDE Partition Manager supports a large number of file systems,
including ext2/3/4, reiserfs, NTFS, FAT16/32, jfs, xfs and more.
 It makes use of external programs to get its job done, so you might have to
 install additional software (preferably packages from your distribution)
 to make use of all features and get full support for all file systems
%prep
%setup -q
%build
%{cmake_kde4} .
make %{?_smp_mflags}
%install
%{__rm} -rf %{buildroot}
make install DESTDIR="%{buildroot}"
%files
%defattr(-,root,root)
%{_bindir}/
%{_libdir}/
%{_datadir}/
##%doc
## %changelog
