Brak X-Ów Po Migracji Z Ati > Nvidia
borzole
Wypialem dysk z kompa gdzie byla karta ATI, przelozylem do takiego z NVidia i nie banglaja X
Nie zalezy mi na akceleracji, chce na chwile uruchomic X, posprzatac i dysk wraca do PC z ATI
#startx
xauth:  creating new authority file /root/.serverauth.12660
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/jedral.horus:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
X.Org X Server 1.9.5
Release Date: 2011-03-17
X Protocol Version 11, Revision 0
Build Operating System: x86-07 2.6.32-131.2.1.el6.x86_64
Current Operating System: Linux jedral.horus 2.6.35.14-106.fc14.x86_64 #1 SMP Wed Nov 23 13:07:52 UTC 2011 x86_64
Kernel command line: ro root=/dev/sda3 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet selinux=0 vga=794 radeon.modeset=0
Build Date: 13 October 2011  02:24:00PM
Build ID: xorg-x11-server 1.9.5-2.fc14
Current version of pixman: 0.18.4
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 15 20:28:59 2012
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE) No supported AMD display adapters were found
(EE) No devices detected.
Fatal server error:
no screens found
Please consult the Fedora Project support
	at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
giving up.
xinit:  Connection refused (errno 111):  unable to connect to X server
xinit:  No such process (errno 3):  Server error.
Xorg.0.log
[   348.995] _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
[   348.998] _XSERVTransOpen: transport open failed for inet6/jedral.horus:0
[   349.000] _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
[   349.002]
[   349.011] X Protocol Version 11, Revision 0
[   349.014] Build Operating System: x86-07 2.6.32-131.2.1.el6.x86_64
[   349.017] Current Operating System: Linux jedral.horus 2.6.35.14-106.fc14.x86_64 #1 SMP Wed Nov 23 13:07:52 UTC 2011 x86_64
[   349.020] Kernel command line: ro root=/dev/sda3 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet selinux=0 vga=794 radeon.modeset=0
[   349.023] Build Date: 13 October 2011  02:24:00PM
[   349.026] Build ID: xorg-x11-server 1.9.5-2.fc14
[   349.029] Current version of pixman: 0.18.4
[   349.032] 	Before reporting problems, check http://wiki.x.org
[   349.038] Markers: (--) probed, (**) from config file, (==) default setting,
[   349.047] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 15 19:57:33 2012
[   349.050] (==) Using config file: "/etc/X11/xorg.conf"
[   349.053] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   349.057] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   349.060] (==) ServerLayout "Default Layout"
[   349.060] (**) |-->Screen "Screen0" (0)
[   349.060] (**) |   |-->Monitor ""
[   349.060] (**) |   |-->Device "Videocard0"
[   349.060] (==) No monitor specified for screen "Screen0".
Using a default monitor configuration.
[   349.060] (**) Option "AIGLX" "on"
[   349.060] (==) Automatically adding devices
[   349.060] (==) Automatically enabling devices
[   349.060] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[   349.060] (**) ModulePath set to "/usr/lib64/xorg/modules/extensions/catalyst,/usr/lib64/xorg/modules"
[   349.060] (**) Extension "Composite" is enabled
[   349.060] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[   349.061] (II)
** Fedora switched to udev-based device detection with   	**
** xorg-x11-server-1.7.99.901-1. Custom HAL configuration    **
** stored in /etc/hal/fdi/policy will not be seen by this    **
** server version. If you have such configuration you will   **
** need to update it to the new format.                      **
** For more information, see the Fedora wiki page            **
** https://fedoraproject.org/wiki/Input_device_configuration **
[   349.061] (II) Loader magic: 0x7d32c0
[   349.061] (II) Module ABI versions:
[   349.061] 	X.Org ANSI C Emulation: 0.4
[   349.061] 	X.Org Video Driver: 8.0
[   349.061] 	X.Org XInput driver : 11.0
[   349.061] 	X.Org Server Extension : 4.0
[   349.061] (--) PCI:*(0:1:0:0) 10de:0de1:10b0:0401 rev 161, Mem @ 0xfd000000/16777216, 0xe8000000/134217728, 0xe6000000/33554432, I/O @ 0x0000ec00/128, BIOS @ 0x????????/524288
[   349.062] (II) LoadModule: "extmod"
[   349.062] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[   349.063] (II) Module extmod: vendor="X.Org Foundation"
[   349.063] 	compiled for 1.9.5, module version = 1.0.0
[   349.063] 	Module class: X.Org Server Extension
[   349.063] 	ABI class: X.Org Server Extension, version 4.0
[   349.063] (II) Loading extension SELinux
[   349.063] (II) Loading extension MIT-SCREEN-SAVER
[   349.063] (II) Loading extension XFree86-VidModeExtension
[   349.063] (II) Loading extension XFree86-DGA
[   349.063] (II) Loading extension DPMS
[   349.063] (II) Loading extension XVideo
[   349.063] (II) Loading extension XVideo-MotionCompensation
[   349.063] (II) Loading extension X-Resource
[   349.063] (II) LoadModule: "dbe"
[   349.063] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[   349.063] (II) Module dbe: vendor="X.Org Foundation"
[   349.063] (II) Loading extension DOUBLE-BUFFER
[   349.063] (II) LoadModule: "glx"
[   349.064] (II) Loading /usr/lib64/xorg/modules/extensions/catalyst/libglx.so
[   349.064] (II) Module glx: vendor="Advanced Micro Devices, Inc."
[   349.064] 	compiled for 6.9.0, module version = 1.0.0
[   349.064] (II) Loading extension GLX
[   349.064] (II) LoadModule: "record"
[   349.065] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[   349.065] (II) Module record: vendor="X.Org Foundation"
[   349.065] 	compiled for 1.9.5, module version = 1.13.0
[   349.065] 	Module class: X.Org Server Extension
[   349.065] 	ABI class: X.Org Server Extension, version 4.0
[   349.065] (II) Loading extension RECORD
[   349.065] (II) LoadModule: "dri"
[   349.065] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[   349.065] (II) Module dri: vendor="X.Org Foundation"
[   349.065] 	compiled for 1.9.5, module version = 1.0.0
[   349.065] (II) Loading extension XFree86-DRI
[   349.065] (II) LoadModule: "dri2"
[   349.066] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[   349.066] (II) Module dri2: vendor="X.Org Foundation"
[   349.066] 	compiled for 1.9.5, module version = 1.2.0
[   349.066] 	ABI class: X.Org Server Extension, version 4.0
[   349.066] (II) Loading extension DRI2
[   349.066] (II) LoadModule: "fglrx"
[   349.066] (II) Loading /usr/lib64/xorg/modules/drivers/fglrx_drv.so
[   349.091] (II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
[   349.091] 	compiled for 1.4.99.906, module version = 8.89.4
[   349.091] 	Module class: X.Org Video Driver
[   349.091] (II) Loading sub module "fglrxdrm"
[   349.091] (II) LoadModule: "fglrxdrm"
[   349.092] (II) Loading /usr/lib64/xorg/modules/linux/libfglrxdrm.so
[   349.092] (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
[   349.092] 	compiled for 1.4.99.906, module version = 8.89.4
[   349.092] (II) ATI Proprietary Linux Driver Version Identifier:8.89.4
[   349.092] (II) ATI Proprietary Linux Driver Release Identifier: 8.892
[   349.092] (II) ATI Proprietary Linux Driver Build Date: Sep 14 2011 10:36:30
[   349.092] (--) using VT number 7
[   349.100] (WW) Falling back to old probe method for fglrx
[   349.108] (II) Loading PCS database from /etc/ati/amdpcsdb
[   349.108] (EE) No supported AMD display adapters were found
[   349.108] (EE) No devices detected.
[   349.108]
Fatal server error:
[   349.108] no screens found
[   349.108]
for help.
[   349.108] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   349.108]
# lspci | grep VGA
01:00.0 VGA compatible controller: nVidia Corporation Device 0de1 (rev a1)
# lsmod
Module                  Size  Used by
irnet                  18308  0
ppp_generic            22309  1 irnet
slhc                    4894  1 ppp_generic
irtty_sir       		3959  0
sir_dev                10262  1 irtty_sir
ircomm_tty     		18014  0
ircomm                  9571  1 ircomm_tty
irda                  106668  4 irnet,sir_dev,ircomm_tty,ircomm
crc_ccitt       		1573  1 irda
tun                    14455  0
fcoe           		19383  0
libfcoe                12501  1 fcoe
libfc                  76726  2 fcoe,libfcoe
scsi_transport_fc      43993  2 fcoe,libfc
scsi_tgt       		10848  1 scsi_transport_fc
vboxnetadp              5649  0
vboxnetflt     		17469  0
vboxdrv              1792474  2 vboxnetadp,vboxnetflt
8021q                  21648  0
garp                    6373  1 8021q
stp             		2034  1 garp
llc             		4802  2 garp,stp
cpufreq_ondemand        9278  4
acpi_cpufreq            7345  0
freq_table              3955  2 cpufreq_ondemand,acpi_cpufreq
mperf           		1481  1 acpi_cpufreq
kvm_intel              41918  0
kvm           		257420  1 kvm_intel
uinput                  7368  0
snd_hda_codec_nvhdmi    13724  4
snd_hda_codec_realtek   298556  1
iTCO_wdt       		11256  0
iTCO_vendor_support 	2610  1 iTCO_wdt
snd_hda_intel          24495  0
ppdev           		8380  0
snd_hda_codec          86743  3 snd_hda_codec_nvhdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep       		6392  1 snd_hda_codec
parport_pc     		21573  0
atl1           		30604  0
parport                31926  2 ppdev,parport_pc
mii             		4310  1 atl1
snd_seq                53791  0
snd_seq_device          6191  1 snd_seq
snd_pcm                80190  2 snd_hda_intel,snd_hda_codec
snd_timer              19892  2 snd_seq,snd_pcm
snd                    64032  9 snd_hda_codec_nvhdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_device,snd_pcm,snd_timer
soundcore       		6576  1 snd
snd_page_alloc          7559  2 snd_hda_intel,snd_pcm
i2c_i801       		11088  0
asus_atk0110   		15404  0
microcode              18662  0
usb_storage            46243  0
nouveau       		411931  1
ttm                    55166  1 nouveau
drm_kms_helper 		25961  1 nouveau
drm           		178014  3 nouveau,ttm,drm_kms_helper
i2c_algo_bit            5205  1 nouveau
video                  21637  1 nouveau
output                  2253  1 video
i2c_core       		27212  5 i2c_i801,nouveau,drm_kms_helper,drm,i2c_algo_bit
#dmesg | grep -i vga
[	0.000000] Command line: ro root=/dev/sda3 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet selinux=0 vga=794 radeon.modeset=0
[	0.000000] Kernel command line: ro root=/dev/sda3 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet selinux=0 vga=794 radeon.modeset=0
[	0.286644] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[	0.286648] vgaarb: loaded
[	0.632089] fb0: VESA VGA frame buffer device
[	1.273963] fb: conflicting fb hw usage nouveaufb vs VESA VGA - removing generic driver
Co sie z tym robi ? :)
Ja bym zajrzal do /etc/X11/xorg.conf. Zeby nie instalowac binarnych sterowników do nvidii to chyba jest driver "nv", ale musi byc zainstalowana paczka xorg-x11-drv-nv-2.1.18-8.fc16
Czyli w /etc/X11/xorg.conf powinno byc cos takiego:
Section "Device"
Identifier "Videocard0"
Driver "nv"
EndSection
Oznaczenie (**) w Xorg.0.log oznacza, ze sa to linie "from config file".
W F16 (a nawet w F15 chyba) przy nvidii i sterownikach z repo nie jest potrzebny plik xorg.conf. Ja bym zaczął od usunięcia w trybie tekstowym /etc/X11/xorg.conf
W dalszych krokach warto sprawdzić czy masz zainstalowaną paczkę xorg-x11-drv-nouveau (nie pamiętam czy dokładnie tak się nazywa, ale po południu mogę sprawdzić).
Ale tak czuję, że usunięcie xorg.conf załatwi sprawę.
