F19 Sterowniki Amd Radeon Mobility
Krystian Kiermasz
Witam.
Jądro - 3.11.7 ze wszystkimi możliwymi dodatkowymi pakietami
Pakiet gcc zainstalowany
Sterowniki ściągnięte z oficjalnej strony AMD, natomiast po instalacji wyświetlił się błąd a logi niestety nic mi nie mówią....
Check if system has the tools required for installation.
Uninstalling any previously installed drivers.
[Message] Kernel Module : Trying to install a precompiled kernel module.
[Message] Kernel Module : Precompiled kernel module version mismatched.
[Message] Kernel Module : Found kernel module build environment, generating kernel module now.
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.a .??* *.symvers
make -C /lib/modules/3.11.7-200.fc19.i686/build SUBDIRS=/usr/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Wejście do katalogu `/usr/src/kernels/3.11.7-200.fc19.i686'
  CC [M]  /usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
In file included from /usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:464:0:
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h: In function â€FGLDRM_proc_init’:
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:98:2: error: implicit declaration of function â€create_proc_entry’ [-Werror=implicit-function-declaration]
  if (!minor) root = create_proc_entry("dri", S_IFDIR, NULL);
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:98:19: warning: assignment makes pointer from integer without a cast [enabled by default]
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:105:12: warning: assignment makes pointer from integer without a cast [enabled by default]
  *dev_root = create_proc_entry(name, S_IFDIR, root);
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:112:7: warning: assignment makes pointer from integer without a cast [enabled by default]
   ent = create_proc_entry(DRM(proc_list)[i].name,
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:124:6: error: dereferencing pointer to incomplete type
   ent->read_proc = DRM(proc_list)[i].f;
/usr/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:125:6: error: dereferencing pointer to incomplete type
   ent->data      = dev;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function â€firegl_proc_init’:
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:586:14: warning: assignment makes pointer from integer without a cast [enabled by default]
         root = create_proc_entry("ati", S_IFDIR, NULL);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:598:13: warning: assignment makes pointer from integer without a cast [enabled by default]
         ent = create_proc_entry("major", S_IFREG|S_IRUGO, root);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:605:12: error: dereferencing pointer to incomplete type
         ent->read_proc = (read_proc_t*)firegl_major_proc_read;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:605:27: error: â€read_proc_t’ undeclared (first use in this function)
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:605:27: note: each undeclared identifier is reported only once for each function it appears in
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:605:39: error: expected expression before â€)’ token
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:609:15: warning: assignment makes pointer from integer without a cast [enabled by default]
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:619:13: warning: assignment makes pointer from integer without a cast [enabled by default]
         ent = create_proc_entry(list->name, S_IFREG|S_IRUGO, *dev_root);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:639:16: error: dereferencing pointer to incomplete type
             ent->read_proc = (read_proc_t*)list->f;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:639:43: error: expected expression before â€)’ token
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:644:16: error: dereferencing pointer to incomplete type
             ent->proc_fops = (struct file_operations*)list->fops;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:648:16: error: dereferencing pointer to incomplete type
             ent->data = (dev->pubdev.signature == FGL_DEVICE_SIGNATURE)? firegl_find_device(minor) : (dev);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:657:13: warning: assignment makes pointer from integer without a cast [enabled by default]
         ent = create_proc_entry("debug", S_IFREG|S_IRUGO, root);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:660:16: error: dereferencing pointer to incomplete type
             ent->read_proc = (read_proc_t*)firegl_debug_proc_read_wrap;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:660:43: error: expected expression before â€)’ token
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:661:16: error: dereferencing pointer to incomplete type
             ent->write_proc = (write_proc_t*)firegl_debug_proc_write_wrap;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:661:32: error: â€write_proc_t’ undeclared (first use in this function)
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:661:45: error: expected expression before â€)’ token
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:662:16: error: dereferencing pointer to incomplete type
             ent->data = dev;
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function â€KCL_MEM_AllocLinearAddrInterval’:
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2152:5: error: implicit declaration of function â€do_mmap’ [-Werror=implicit-function-declaration]
     vaddr = (void *) do_mmap(file, 0, len, prot, flags, pgoff);
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function â€KCL_MEM_VM_MapRegion’:
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3700:39: error: â€VM_RESERVED’ undeclared (first use in this function)
             vma->vm_flags |= VM_SHM | VM_RESERVED; /* Don't swap */
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: At top level:
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:511:16: warning: â€firegl_debug_proc_read_wrap’ defined but not used [-Wunused-function]
 READ_PROC_WRAP(firegl_debug_proc_read)
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:496:12: note: in definition of macro â€READ_PROC_WRAP’
 static int func##_wrap(char *buf, char **start, kcl_off_t offset,      \
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:516:12: warning: â€firegl_debug_proc_write_wrap’ defined but not used [-Wunused-function]
 static int firegl_debug_proc_write_wrap(void* file, const char *buffer, unsigned long count, void *data)
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:534:12: warning: â€firegl_major_proc_read’ defined but not used [-Wunused-function]
 static int firegl_major_proc_read(char *buf, char **start, kcl_off_t offset,
cc1: some warnings being treated as errors
make[2]: *** [/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o] Błąd 1
make[1]: *** [_module_/usr/lib/modules/fglrx/build_mod/2.6.x] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/kernels/3.11.7-200.fc19.i686'
make: *** [kmod_build] Błąd 2
build failed with return value 2
[Error] Kernel Module : Failed to compile kernel module - please consult readme.
[Reboot] Kernel Module : dracut
Edit (17.11.2013)
Nikt nic nie wie? Cały czas nie mogę sobie z tym poradzić. Mam Ati mobility radeon hd 3470.
  • 1 month later...
Rozumiem, że już dużo nie da się zrobić w tej sprawie. A czy jest może jakieś jądro które współpracuje dobrze z zamkniętymi sterami od AMD? System na otwartych chodzi mi płynnie i nie mam tu zastrzeżeń, jednak chciałem przetestować sobie steam na linuxa a tam nawet najbardziej prymitywne gry mi się zacinają niemiłosiernie.
W tej sprawie albo faktycznie masz rację i nie jesteś na bieżąco, albo ja źle to robię, ale nie mogę zainstalować sterownika przez yum bo zwyczajnie go nie ma. Yum podaje że nie ma niczego do zrobienia, a próbowałem już wszelakich kombinacji. Na stronie głównej AMD sterowniki do mojej karty zakończyły się na wersji 13.1 która nie działa już od Fedory 19 z uwagi na wersję Xservera. No chyba że to w związku z tym yum tak podaje. Mam Ati mobility hd 3470, i wiem że postaram się nie kupić już komputera z kartą Ati, chociaż zauważyłem że jeżeli chodzi o laptopy to większość niestety ma radeony. Chociaż z drugiej strony złego słowa nie mogę powiedzieć o otwartych sterownikach - kawał dobrej roboty bo przy codziennej pracy wszystko działa jak należy. Platforma steam jest na tyle przełomem w dziejach linuxa, że chciałem zwyczajnie przetestować tą aplikację. Dziwi mnie tylko fakt, ciągłego podkreślania że oficjalnie wspiera tylko system Ubuntu. To trochę takie dzielenie i tak podzielonego świata tego systemu, oraz ogromna reklama i promowanie jednego systemu.
Masz na pewno RPM Fusion zainstalowane? Bo o ile mogę się mylić co do działania lub nie działania tego kmoda, to przed napisaniem posta sprawdziłem czy paczka jest w repo - jest, zacząłem nawet instalację, która dociągnęła zależności.
A może masz już ten pakiet zainstalowany?
[root@localhost ~]# yum repolist
Wczytane wtyczki: langpacks, refresh-packagekit
identyfikator repozytorium                nazwa repozytorium            stan
adobe-linux-i386                          Adobe Systems Incorporated           2
fedora/20/i386                            Fedora 20 - i386              32475+18
google-chrome                             google-chrome                        3
playonlinux                               PlayOnLinux Official reposito       38
rpmfusion-free/20/i386                    RPM Fusion for Fedora 20 - Fr      391
rpmfusion-free-updates/20/i386            RPM Fusion for Fedora 20 - Fr        0
rpmfusion-free-updates-testing/20/i386    RPM Fusion for Fedora 20 - Fr        0
rpmfusion-nonfree/20/i386                 RPM Fusion for Fedora 20 - No      178
rpmfusion-nonfree-updates/20/i386         RPM Fusion for Fedora 20 - No        0
rpmfusion-nonfree-updates-testing/20/i386 RPM Fusion for Fedora 20 - No        0
russianfedora-free/20/i386                Russian Fedora for Fedora 20        54
russianfedora-free-updates/20/i386        Russian Fedora for Fedora 20         0
russianfedora-nonfree/20/i386             Russian Fedora for Fedora 20        19
russianfedora-nonfree-updates/20/i386     Russian Fedora for Fedora 20         0
updates/20/i386                           Fedora 20 - i386 - Updates        2214
repolist: 35374
[root@localhost ~]# yum search  kmod-catalyst
Ostrzeżenie: nie odnaleziono wyników dla: kmod-catalyst
No matches found
[root@localhost ~]# yum search  kmod-catalyst xorg-x11-drv-catalyst
Ostrzeżenie: nie odnaleziono wyników dla: xorg-x11-drv-catalyst
No matches found
I nic. Nie mam pojęcia o co może chodzić.
Teraz znalazłem takie coś
[root@localhost ~]# rpm -qa kmod
kmod-15-1.fc20.i686
Czy to oznacza zamknięty sterownik?
raczej sprawdź
rpm -qa | grep kmod
Polecenie, które podałeś sprawdza czy zainstalowany jest pakiet kmod. Dokładnie o takiej nazwie. Pominie np. kmod-catalyst, kmod-wl itp
[EDIT]
OK, znowu niespójność tematu z postem - sprawdzałem na F19. Możliwe, że na F20 nie ma jeszcze kmoda Sprawdziłem, nie ma paczki dla F20.
A w przypadku czarnego ekranu albo innych przykrych niespodzianek jest jakiś prosty sposób na przywrócenie obecnego sterownika?
Tak/Nie/Może.
Wybierz sam odpowiedź, wszystko zależy od twoich umiejętności/determinacji/wiedzy. Jeżeli nie usuniesz fizycznie sterownika zawartego w kernelu, tylko dodasz go do blacklisty, to teoretycznie w razie problemów wystarczy uruchomić w trybie rescue/single usunąć z blacklisty stary moduł i odinstalować ten sprawiający problemy.
