Gość Napisano Luty 24, 2023 Zgłoszenie Share Napisano Luty 24, 2023 Musiałem postawić na moim kompie na kilka dni Wind11, ale po skasowaniu go z dysku i postawieniu Fedory nie mogę nic zapisać i skasować z "jego" dysków NTFS. Przesyłam wynik z terminala... [alieno@alieno-pc ~]$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 476,9G 0 disk ├─sda1 8:1 0 600M 0 part /boot/efi ├─sda2 8:2 0 1G 0 part /boot └─sda3 8:3 0 475,4G 0 part /home / sdb 8:16 0 953,9G 0 disk ├─sdb1 8:17 0 200G 0 part ├─sdb2 8:18 0 300G 0 part └─sdb3 8:19 0 323,9G 0 part zram0 252:0 0 7,7G 0 disk [SWAP] [alieno@alieno-pc ~]$ mount proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime,seclabel) devtmpfs on /dev type devtmpfs (rw,nosuid,seclabel,size=4096k,nr_inodes=1048576,mode=755,inode64) securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,seclabel,inode64) devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,seclabel,gid=5,mode=620,ptmxmode=000) tmpfs on /run type tmpfs (rw,nosuid,nodev,seclabel,size=1605148k,nr_inodes=819200,mode=755,inode64) cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,seclabel,nsdelegate,memory_recursiveprot) pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime,seclabel) efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime) bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700) /dev/sda3 on / type btrfs (rw,relatime,seclabel,compress=zstd:1,ssd,space_cache=v2,subvolid=257,subvol=/root) selinuxfs on /sys/fs/selinux type selinuxfs (rw,nosuid,noexec,relatime) systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=35,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16906) mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime,seclabel) hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,seclabel,pagesize=2M) debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime,seclabel) tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime,seclabel) fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime) configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,seclabel,size=4012872k,nr_inodes=1048576,inode64) /dev/sda3 on /home type btrfs (rw,relatime,seclabel,compress=zstd:1,ssd,space_cache=v2,subvolid=256,subvol=/home) /dev/sda2 on /boot type ext4 (rw,relatime,seclabel) /dev/sda1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=winnt,errors=remount-ro) binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime) sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw,relatime) tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,seclabel,size=802572k,nr_inodes=200643,mode=700,uid=1000,gid=1000,inode64) gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000) portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000) [alieno@alieno-pc ~]$ Dodam, że dyski są na stałe podpięte do kompa. W terminologii M$ to dyski D, E itd. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 24, 2023 Zgłoszenie Share Napisano Luty 24, 2023 Generalnie to musisz zainstalować pakiet ntfs-3g, z tego co przedstawiłeś, to w nie masz zamontowanych, żadnych partycji ntfs, więc dobrze byłoby je zamontować i dopiero wtedy przedstawić wyniki polecenia mount. Generalnie najlepiej gdybyś w jednej konsoli (jako root) uruchomił polecenie journalctl -f w celu obserwacji logów i czy nie ma jakiś informacji o problemie z systemem plików, a w drugiej uruchomił polecenie mount np mount /dev/partycja_ntfs /punkt_gdzie chcesz zamontować w przypadku problemów, możesz też spróbować dodać odpowiednie opcje dla polecenia mount takie jak mount -t ntfs-3g /dev/partycja_ntfs /punkt_gdzie chcesz zamontować Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 24, 2023 Zgłoszenie Share Napisano Luty 24, 2023 Wkleiłem pierwsze polecenie i terminal się zawiesił. Gdzie chcę zamontować ? Na komputerze. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 24, 2023 Zgłoszenie Share Napisano Luty 24, 2023 28 minut temu, xarx napisał: Gdzie chcę zamontować ? Na komputerze. No to oczywiste, ale tym miejscem jest jakiś katalog np /mnt podobnie pisząc /dev/partycja_ntfs chodziło mi oto, abyś to ty wpisał odpowiednie urządzenie, ba ja nie wiem czy partycja ntfs którą chcesz zamontować jest na /dev/sdb1 /dev/sdb2 czy może /dev/sdb3 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Fedoras Napisano Luty 25, 2023 Zgłoszenie Share Napisano Luty 25, 2023 Oprócz lsblk przydatnym poleceniem jest blkid Sprawdź gdzie masz system plików ntfs, np. su blkid | grep -i ntfs a dalej już tak jak napisał @sunrise W linuksie czy dysk (partycja) znajduje się w Casablance, u sąsiada czy w twoim komputerze trzeba go zamontować do jakiegoś folderu. Inaczej go nie ma. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 25, 2023 Zgłoszenie Share Napisano Luty 25, 2023 Nic nie rozumiem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 12 godzin temu, xarx napisał: Nic nie rozumiem To może pokaże na moim przykładzie. Wszystkie polecenia wykonuję jako root, jeżeli będziesz je wykonywać jako zwykły użytkownik to każde polecenie musisz poprzedzić poleceniem sudo. mount -t ntfs /dev/mapper/vg_virtstorage-win10p2 /mnt/sysimage/ Gdzie: /dev/mapper/vg_virtstorage-win10p2 - partycja sformatowana jako ntfs w twoim przypadku będzie to prawdopodobnie /dev/sdb1 lub /dev/sdb2 lub /dev/sdb3 /mnt/sysimage/ - punkt w którym zostanie zamontowana, w twoim przypadku proponuje /mnt Przechodzę do zamontowanej partycji cd /mnt/sysimage/ i teraz mogę już przeglądać dane znajdujące się na tej partycji np je wylistować # ll razem 1703988 drwxrwxrwx. 1 root root 0 02-18 21:06 '$Recycle.Bin' drwxrwxrwx. 1 root root 0 02-18 19:43 '$WinREAgent' lrwxrwxrwx. 2 root root 19 02-18 19:29 'Documents and Settings' -> /mnt/sysimage/Users -rwxrwxrwx. 2 root root 8192 02-24 22:30 DumpStack.log.tmp -rwxrwxrwx. 1 root root 1476395008 02-24 22:30 pagefile.sys drwxrwxrwx. 1 root root 0 2019-12-07 PerfLogs drwxrwxrwx. 1 root root 8192 02-18 21:01 'Program Files' drwxrwxrwx. 1 root root 4096 02-18 20:59 'Program Files (x86)' drwxrwxrwx. 1 root root 4096 02-18 21:08 ProgramData drwxrwxrwx. 1 root root 0 02-18 21:06 Recovery -rwxrwxrwx. 1 root root 268435456 02-24 22:30 swapfile.sys drwxrwxrwx. 1 root root 4096 02-18 19:31 'System Volume Information' drwxrwxrwx. 1 root root 4096 02-18 21:02 Users drwxrwxrwx. 1 root root 16384 02-18 21:24 Windows drwxrwxrwx. 1 root root 4096 02-18 21:06 Windows.old W dniu 24.02.2023 o 19:41, xarx napisał: Wkleiłem pierwsze polecenie Dobrze by było gdybyś pokazał jakie polecenie wkleiłeś. Czy zainstalowałeś pakiet ntfs-3g Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 Podpiąłem dyski odwrotnie i już mogę na partycjach NTFS zapisywać i kasować. Dziwne, bo bootuje dysk z danymi (NTFS)... Próbowałem zainstalować ntfs-3g, ale wyskoczył komunikat, że już jest. Możliwe, że coś źle zrobiłem... Teraz chciałbym, żeby nie trzeba było wklepywać haseł przy wchodzeniu na partycje NTFS. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 31 minut temu, xarx napisał: Teraz chciałbym, żeby nie trzeba było wklepywać haseł przy wchodzeniu na partycje NTFS. Zakładam, że montujesz ją "klikając na nią w Gnome" i jesteś (znaczy twój użytkownik) w grupie wheel, a raczej jesteś. Musisz utworzyć odpowiednia politykę dla PolicyKit (tak wiem brzmi strasznie, ale nie jest trudne). W konsoli musisz uruchomić edytor, w tym przypadku nano, ale może to być dowolny np. gedit czy vim sudo nano /etc/polkit-1/rules.d/10-udisks2.rules Wpisujesz taką zawartość: // Allow udisks2 to mount devices without authentication // for users in the "wheel" group. polkit.addRule(function(action, subject) { if ((action.id == "org.freedesktop.udisks2.filesystem-mount-system" || action.id == "org.freedesktop.udisks2.filesystem-mount") && subject.isInGroup("wheel")) { return polkit.Result.YES; } }); zapisujesz i tyle. Wszystkie dostępne działania (actions), są opisane w tym dokumencie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 Działa Wielkie dzięki. Super. Podpiąłem dyski tak jak powinny być i Linux oczywiście uruchamia się, ale partycje ntfs read only... ;( Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 7 godzin temu, xarx napisał: Podpiąłem dyski tak jak powinny być i Linux oczywiście uruchamia się, ale partycje ntfs read only... ;( Uruchom w terminalu poleceniev sudo journalctl -f i zamontuj dysk, następnie przejrzyj komunikaty które pojawią się w terminalu, szczególnie w tych miejscach gdzie pojawiają się wpisy o ntfs-3g Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 [alieno@alieno-pc ~]$ sudo journalctl -f [sudo] hasło użytkownika alieno: lut 26 18:26:12 alieno-pc systemd[1]: Starting fprintd.service - Fingerprint Authentication Daemon... lut 26 18:26:12 alieno-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 18:26:12 alieno-pc systemd[1]: Started fprintd.service - Fingerprint Authentication Daemon. lut 26 18:26:16 alieno-pc audit[4660]: USER_AUTH pid=4660 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:authentication grantors=pam_usertype,pam_localuser,pam_unix acct="alieno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 18:26:16 alieno-pc audit[4660]: USER_ACCT pid=4660 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:accounting grantors=pam_unix,pam_localuser acct="alieno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 18:26:16 alieno-pc audit[4660]: USER_CMD pid=4660 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='cwd="/home/alieno" cmd=6A6F75726E616C63746C202D66 exe="/usr/bin/sudo" terminal=pts/0 res=success' lut 26 18:26:16 alieno-pc sudo[4660]: alieno : TTY=pts/0 ; PWD=/home/alieno ; USER=root ; COMMAND=/usr/bin/journalctl -f lut 26 18:26:16 alieno-pc audit[4660]: CRED_REFR pid=4660 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 18:26:16 alieno-pc sudo[4660]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000) lut 26 18:26:16 alieno-pc audit[4660]: USER_START pid=4660 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_keyinit,pam_limits,pam_systemd,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 18:26:42 alieno-pc systemd[1]: fprintd.service: Deactivated successfully. lut 26 18:26:42 alieno-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 18:26:42 alieno-pc audit: BPF prog-id=91 op=UNLOAD Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 Ale jeszcze musisz zamontować dysk i dopiero wtedy w logach pojawią się odpowiednie komunikaty. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Napisano Luty 26, 2023 Zgłoszenie Share Napisano Luty 26, 2023 [alieno@alieno-pc ~]$ sudo journalctl -f [sudo] hasło użytkownika alieno: lut 26 20:06:52 alieno-pc systemd[1]: Starting fprintd.service - Fingerprint Authentication Daemon... lut 26 20:06:52 alieno-pc systemd[1]: Started fprintd.service - Fingerprint Authentication Daemon. lut 26 20:06:52 alieno-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 20:06:57 alieno-pc audit[3125]: USER_AUTH pid=3125 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:authentication grantors=pam_usertype,pam_localuser,pam_unix acct="alieno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 20:06:57 alieno-pc audit[3125]: USER_ACCT pid=3125 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:accounting grantors=pam_unix,pam_localuser acct="alieno" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 20:06:57 alieno-pc audit[3125]: USER_CMD pid=3125 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='cwd="/home/alieno" cmd=6A6F75726E616C63746C202D66 exe="/usr/bin/sudo" terminal=pts/0 res=success' lut 26 20:06:57 alieno-pc sudo[3125]: alieno : TTY=pts/0 ; PWD=/home/alieno ; USER=root ; COMMAND=/usr/bin/journalctl -f lut 26 20:06:57 alieno-pc audit[3125]: CRED_REFR pid=3125 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 20:06:57 alieno-pc audit[3125]: USER_START pid=3125 uid=1000 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_keyinit,pam_limits,pam_systemd,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success' lut 26 20:06:57 alieno-pc sudo[3125]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000) lut 26 20:07:22 alieno-pc systemd[1]: fprintd.service: Deactivated successfully. lut 26 20:07:22 alieno-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 20:07:22 alieno-pc audit: BPF prog-id=85 op=UNLOAD lut 26 20:09:08 alieno-pc systemd[1467]: Created slice background.slice - User Background Tasks Slice. lut 26 20:09:09 alieno-pc systemd[1467]: Starting systemd-tmpfiles-clean.service - Cleanup of User's Temporary Files and Directories... lut 26 20:09:09 alieno-pc systemd[1467]: Finished systemd-tmpfiles-clean.service - Cleanup of User's Temporary Files and Directories. lut 26 20:13:23 alieno-pc chronyd[813]: Selected source 193.70.94.182 (2.fedora.pool.ntp.org) lut 26 20:14:21 alieno-pc systemd[1]: flatpak-system-helper.service: Deactivated successfully. lut 26 20:14:21 alieno-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 20:19:09 alieno-pc systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup of Temporary Directories... lut 26 20:19:09 alieno-pc systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully. lut 26 20:19:09 alieno-pc systemd[1]: Finished systemd-tmpfiles-clean.service - Cleanup of Temporary Directories. lut 26 20:19:09 alieno-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' lut 26 20:19:09 alieno-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' Teraz powinno być dobrze. Sprawdź proszę. Ale musiałem na drugim dysku postawić Wind10. Domyślnie uruchamia się Fedora. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@sunrise Napisano Luty 27, 2023 Zgłoszenie Share Napisano Luty 27, 2023 8 godzin temu, xarx napisał: Teraz powinno być dobrze. Niestety nadal nic nie ma o montowaniu dysku, w logach powinieneś mieć bp coś takiego: ntfs-3g[995091]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/mapper/vg_virtstorage-win10p2,blkdev,blksize=4096 Może, pokaż co zwraca polecenie sudo journalctl|grep ntfs Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
