Mplayer -> Teraz To Już Totalnie Zgłupiałem :/
milosz1987
witam.
po długiej batalii udało mi się zainstalować mplayera. chcę uruchomić jakikolwiek film:
[milosz@andromeda ~] mplayer The\ Best\ Of\ 2Pac\ DVDrip.avi
MPlayer 1.0pre6-RPM-3.4.2 (C) 2000-2004 MPlayer Team
CPU: Intel Celeron Covington/Pentium II Deschutes,Tonga/Pentium II Xeon (Family: 6, Stepping: 2)
Detected cache-line size is 32 bytes
CPUflags:  MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Warning unknown option cache_min at line 144
Warning unknown option cache_prefill at line 147
Linux RTC init error in ioctl (rtc_irqp_set 1024): Brak dostępu
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Playing The Best Of 2Pac DVDrip.avi.
Cache fill:  0,00% (0 bytes)    AVI file format detected.
VIDEO:  [DIV3]  640x416  24bpp  23,976 fps  1094,4 kbps (133,6 kbyte/s)
Clip info:
Software: Nandub v1.0rc2
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
MPlayer interrupted by signal 4 in module: init_audio_codec
- MPlayer crashed by an 'Illegal Instruction'.
 It usually happens when you run it on a CPU different than the one it was
 compiled/optimized for.
 Verify this!
- MPlayer crashed by bad usage of CPU/FPU/RAM.
 Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
 disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
 It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
 gcc version. If you think it's MPlayer's fault, please read
 DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
 won't help unless you provide this information when reporting a possible bug.
znajomy mi powiedział żebym uruchomił mp3... ten sam problem
pomóżcie bo już świra dostaję a na dysku mam tyyyyyyyyyyyyyle fajnych filmów :(:(:(
#yum install mplayer gui <- dla trybu graficznego
lub
# yum update mplayer <- moze masz starą wesje
z audio tez miałem problem ale sam sie rozwiazał jak zaistalowałem kodek dla mp3 xmms
# yum install xmms-mp3
ale trza miec odpowiednie repozytoria http://www.fedora.pl/site/forum/index.php?showforum=19
i moje pytanie czamu z konsoli odpalasz ?w graficznym trybie tez jest
lub
mam xmms-mp3
[QOUTE=Rathann,13.07.2005 - 21:40]
Podaj więcej szczegółów: która wersja fedory, które jądro, jaki procek, którą paczkę zainstalowałeś i jak oraz wynik
rpm -q --queryformat '%{name}-%{version}-%{release}.%{arch}\n' mplayer
[/QOUTE]
mam Fedore Core 3, procek: PII Deschutes 400 Mhz, ram: 128 mb, kernel: 2.6.11-1.35_FC3, kernel realase: #1 Mon Jun 13 00:52:08 EDT 2005
  • 2 weeks later...
Witam, podepnę się pod ten temat by nowego nie zaczynać i nie zaśmiecać forum. Mój problem jest następujący: zassałem kodeki, rozpakowałem, zmieniłem nazwę na win32 i przeniosłem to do /usr/lib. Mplayera instalowałem yum-em, mplayerplug-in mam z paczki rpm. Teledyski na interii odtwarza płynnie, filmiki z niektórych stron także. Dziś wszedłem na http://magazynligowy.interia.pl/ i postanowiłem odpalić któryś z klipów. Otrzymałem następujący komunikat
Twój system nie jest przystosowany do poprawnego odtwarzania plików multimedialnych w serwisie:
System operacyjny: Windows 98 / ME / 2000 / XP
Przeglądarka: IE 5 lub nowsza
Windows Media Player 9 lub nowszy.
Podobnie jest z teledyskami na www.neostrada.pl gdzie po wybraniu mplayera program się odpala i na tym sie kończy, niczego nie pokazuje. To samo z telewizją internetową, nic się nie dzieje poza uruchomieniem mplayera. Czy ktoś mógłby mi wskazać gdzie popełniam błąd??
