Jak Zainstalować Computer Temperature Monitor?
leymann
Witam. Chciałem sobie zainstalować jakiś monitor temperatur i szukałem po googlach no i znalazłem, taki jak w temacie. Znalazłem strone skąd pobrać program, ale nie wiem jak go zainstalować. Korzystałem więc z tej strony http://computertemp.berlios.de/help.php i wykonując te polecenia:
$ tar xzvf computertemp-0.9.0-tar.gz
$ cd computertemp-0.9.0/
$ ./configure --prefix /usr (this is for most distros)
$ make
$ sudo make install (or su -c "make install")
mój terminal wygląda tak:
[leymann@ASUS ~]$ cd computertemp-0.9.6.1/
[leymann@ASUS computertemp-0.9.6.1]$ ./configure --prefix /usr
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for python... /usr/bin/python
checking for python version... 2.6
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.6/site-packages
checking for python extension module directory... ${exec_prefix}/lib64/python2.6/site-packages
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for PYGTK... configure: error: Package requirements (pygtk-2.0) were not met:
No package 'pygtk-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables PYGTK_CFLAGS
and PYGTK_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
[leymann@ASUS computertemp-0.9.6.1]$ make
make: *** Nie podano obiektów i nie znaleziono makefile. Stop.
[leymann@ASUS computertemp-0.9.6.1]$ sudo make install
[sudo] password for leymann:
leymann is not in the sudoers file.  This incident will be reported.
[leymann@ASUS computertemp-0.9.6.1]$ su -c "make install"
Hasło:
make: *** Brak reguł do wykonania obiektu `install'. Stop.
Hasło:
[root@ASUS computertemp-0.9.6.1]# make
[root@ASUS computertemp-0.9.6.1]# sudo make install
[root@ASUS computertemp-0.9.6.1]# su -c "make install"
(_na prawde_ → naprawdę) ORT nie wiem o co chodzi
Dodam, że samodzielne kompilacje, spoza dystrybucji jeśli nie są pakowane do RPM, to zwyczajowo umieszcza się w /usr/local, więc
./configure --prefix /usr/local
Oczywiście z /usr też będzie działać (jak już się skompiluje ;)), ale po co śmietnik w systemie. To nie Windows, porządek może być.
A co lm_sensors nie wystarcza?
chodzi mi o to, żeby mieć podstawowe temperatury (proc,dysk, grafa) w pasku zadań, a jeśli chodzi o lm_sensors to (_wogole_ ? w ogóle) ORT nie wim o co chodzi z tym programem, niby jakiś pakiet narzędzi omiarowych, a jak to w ogole włączyć? podejrzewam, że jest to standarwowo w 11 zreszta czytałem to gdzieś, ale jak to uruchomić ?
przeczytałem całą strone http://forum.slackware.pl/viewtopic.php?t=5055 i wnoskuje, że uruchamia sie to poleceniem sensor w terminalu, ale jak sie myle to poprawcie mnie, bo wpisuje to polecenie do terminala i nic
jeszcze jedno pytanie jak mam zainstalować pygtk-2.0? krórą paczkę mam pobrać stąd http://ftp.gnome.org/pub/GNOME/sources/pygtk/2.14/ i jak to uruchomić w terminalu? bo daje :
[root@ASUS leymann]# yum install pygtk-2.0
Wczytane wtyczki: refresh-packagekit
Ustawianie procesu instalacji
Nie ma pakietu pygtk-2.0.
Nie ma niczego do zrobienia
aaa i gdzie powinien sie znajdować ten folder na komputerze, zeby terminal go widział
Procesor i sensory na płycie głównej: sensors (oczywiście po wcześniejszym odpaleniu sensors-detect)
Dysk twardy: hddtemp /dev/sda (lub smartctl)
Grafika to zależy od karty, ale dla nvidii: nvidia-settings -q gpucoretemp | grep '):' | awk '{print $4}' | cut -c -2
To wszystko możesz wrzucić do konfiguracji conky, albo dodać gotowe aplety do panelu gnome. Inne rozwiązania to np. gkrellm. Nie widzę sensu kompilowania czegoś skoro są dobre aplikacje w repozytoriach.
EDIT: Teraz zobaczyłem link z Twojego pierwszego posta i aplety ze screenów można znaleźć w repozytorium tylko nie wiem jak dokładnie się nazywają.
@ leymann
Czeka Cię jeszcze długa droga. Proponuję zacząć od nauki posługiwania się yumem i zarządzania pakietami (zapraszam na wiki). Poczytaj też o kompilacji programów ze źródeł. A odnośnie pygtk to:
yum search pygtk
pygtk2.i686 : Python bindings for GTK+
pygtk2-codegen.i686 : The code generation program for PyGTK
pygtk2-devel.i686 : Development files for building add-on libraries
pygtk2-doc.noarch : Documentation files for pygtk2
pygtk2-libglade.i686 : A wrapper for the libglade library for use with PyGTK
sorka panowie, że nie pisałem, ale nie miałem czasu. Ponownie odswieżam temat i wkurzylem sie troche i poszukalem innego programu mianowicie gkrellm i muszę powiedizec, że bardzo mi sie podoba tylko mam mały problem, nie widze w nim temperatury twardgo dysku co mnie matrwi, jak to zmienic?
program instalowalem wg tej strony:
http://fedorasolved.org/Members/realz/hard...ng-with-gkrellm
a następnie znalazlem taki temat:
http://forums.fedoraforum.org/showthread.php?t=182821
zmieniłem te wartości tak jak tam i po wpisaniu w terminalu: hddtemp /dev/sda
ładie mi sie wyświetla temperaturka i nazwa dysku, tylko jak mam teraz zrobić, żeby gkrellm wyswietlal mi tą temperature?
