piotrino Napisano Czerwiec 26, 2010 Zgłoszenie Share Napisano Czerwiec 26, 2010 Witam przy próbie aktualizacji systemu komendą yum updade otrzymuję koncowe takie błędy: root@server piotrino]# yum update Loaded plugins: presto, refresh-packagekit Setting up Update Process Resolving Dependencies --> Running transaction check ---> Package empathy.i686 0:2.30.1.1-1.fc13 set to be updated ---> Package evolution.i686 0:2.30.2-1.fc13 set to be updated --> Processing Dependency: libedataserver-1.2.so.11 for package: empathy-2.30.1.1-1.fc13.i686 --> Processing Dependency: libedataserver-1.2.so.11 for package: nautilus-sendto-2.28.4-1.fc13.i686 --> Processing Dependency: libedataserver-1.2.so.11 for package: gnome-panel-2.30.0-1.fc13.i686 ---> Package evolution-data-server.i686 0:2.30.2-2.fc13 set to be updated ---> Package evolution-help.noarch 0:2.30.2-1.fc13 set to be updated --> Finished Dependency Resolution Error: Package: empathy-2.30.1.1-1.fc13.i686 (updates) Requires: libedataserver-1.2.so.11 Removing: evolution-data-server-2.30.1-2.fc13.i686 (@anaconda-InstallationRepo-201005130056.i386) Error: Package: gnome-panel-2.30.0-1.fc13.i686 (@anaconda-InstallationRepo-201005130056.i386) Requires: libedataserver-1.2.so.11 Removing: evolution-data-server-2.30.1-2.fc13.i686 (@anaconda-InstallationRepo-201005130056.i386) Error: Package: nautilus-sendto-2.28.4-1.fc13.i686 (@anaconda-InstallationRepo-201005130056.i386) Requires: libedataserver-1.2.so.11 Removing: evolution-data-server-2.30.1-2.fc13.i686 (@anaconda-InstallationRepo-201005130056.i386) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest [root@server piotrino]# rpm -Va --nofiles --nodigest [root@server piotrino]# yum install libedataserver-1.2.so.11 Loaded plugins: presto, refresh-packagekit Setting up Install Process Package evolution-data-server-2.30.1-2.fc13.i686 already installed and latest version Nothing to do [root@server piotrino]# Przy próbie rozwiązania tego problemu j.w . mam nadal te same komunikaty....Jak mogę rozwiązać ten problem.....? Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
borzole Napisano Czerwiec 26, 2010 Zgłoszenie Share Napisano Czerwiec 26, 2010 Nie wiem, ale u mnie też jest podobny burdel. Radziłbym zaczekać kilka dni, może się wyklaruje sytuacja w repo. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Czerwiec 26, 2010 Zgłoszenie Share Napisano Czerwiec 26, 2010 Potwierdzam. Wróciłem sobie z krótkiego urlopu i kaszanka Pomaga sugestia (_yum'a_ → yuma) ORT "--skip-broken". Jak napisał borzole trzeba poczekać i za parę dni będzie już OK. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotrino Napisano Czerwiec 26, 2010 Autor Zgłoszenie Share Napisano Czerwiec 26, 2010 Dzięki. Już myślalem ze coś poknociłem w systemie.... Poczekam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dl.wi Napisano Czerwiec 27, 2010 Zgłoszenie Share Napisano Czerwiec 27, 2010 Gdy chce zaktualizowac system za pomocą komendy w terminalu pojawia mi sie taki błąd: Resolving Dependencies --> Running transaction check ---> Package empathy.x86_64 0:2.30.1.1-1.fc13 set to be updated ---> Package evolution.x86_64 0:2.30.2-1.fc13 set to be updated --> Processing Dependency: libedataserver-1.2.so.11()(64bit) for package: gnome-panel-2.30.0-1.fc13.x86_64 --> Processing Dependency: libedataserver-1.2.so.11()(64bit) for package: empathy-2.30.1.1-1.fc13.x86_64 --> Processing Dependency: libedataserver-1.2.so.11()(64bit) for package: nautilus-sendto-2.28.4-1.fc13.x86_64 ---> Package evolution-data-server.x86_64 0:2.30.2-2.fc13 set to be updated ---> Package evolution-help.noarch 0:2.30.2-1.fc13 set to be updated --> Finished Dependency Resolution Error: Package: gnome-panel-2.30.0-1.fc13.x86_64 (@anaconda-InstallationRepo-201005130101.x86_64) Requires: libedataserver-1.2.so.11()(64bit) Removing: evolution-data-server-2.30.1-2.fc13.x86_64 (@anaconda-InstallationRepo-201005130101.x86_64) Error: Package: empathy-2.30.1.1-1.fc13.x86_64 (updates) Requires: libedataserver-1.2.so.11()(64bit) Removing: evolution-data-server-2.30.1-2.fc13.x86_64 (@anaconda-InstallationRepo-201005130101.x86_64) Error: Package: nautilus-sendto-2.28.4-1.fc13.x86_64 (@anaconda-InstallationRepo-201005130101.x86_64) Requires: libedataserver-1.2.so.11()(64bit) Removing: evolution-data-server-2.30.1-2.fc13.x86_64 (@anaconda-InstallationRepo-201005130101.x86_64) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Raven Napisano Czerwiec 27, 2010 Zgłoszenie Share Napisano Czerwiec 27, 2010 Tutaj yum podaje ci rozwiązanie problemu: You could try using --skip-broken to work around the problem Swoją drogą dlaczego masz yuma po angielsku? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dl.wi Napisano Czerwiec 28, 2010 Zgłoszenie Share Napisano Czerwiec 28, 2010 bo mam fedore w jezyku angielskim, caly czas ucze sie tego jezyka i osobiscie wychodze z zalozenia ze im wiecej stycznosci z nim, tym szybciej moge sie go nauczyc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Materid Napisano Czerwiec 29, 2010 Zgłoszenie Share Napisano Czerwiec 29, 2010 Tutaj yum podaje ci rozwiązanie problemu:You could try using --skip-broken to work around the problem Swoją drogą dlaczego masz yuma po angielsku? Jak uzyc tego skip broken bo mam ten sam prolem i to samo rozwiazanie? ___ Doszedlem do tego sam "yum upgrade --skip-broken" - to tak jezeli ktos mialby problem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Saxon Napisano Lipiec 1, 2010 Zgłoszenie Share Napisano Lipiec 1, 2010 yum -y update --skip-broken po prostu skopiuj i wklej w terminalu. -y - oznacza, że od razu wyrażasz zgodę na zaktualizowanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jusko Napisano Lipiec 1, 2010 Zgłoszenie Share Napisano Lipiec 1, 2010 yum -y update --skip-broken po prostu skopiuj i wklej w terminalu. -y - oznacza że od razu wyrażasz zgodę na zaktualizowanie. Problemu z zależnościami już nie ma od chwili czasu. Niemniej informacja może komuś się przyda odnośnie pomijania :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotrino Napisano Lipiec 21, 2010 Autor Zgłoszenie Share Napisano Lipiec 21, 2010 Dzięki. Już myślalem ze coś poknociłem w systemie.... Poczekam A jednak znowu mam inny problem z aktualizacją Loaded plugins: presto, refresh-packagekit Could not get metalink https://mirrors.fedoraproject.org/metalink?repo=updates-released-f13&arch=i386 error was 14: PYCURL ERROR 7 - "" virtualbox | 951 B 00:00 Setting up Update Process No Packages marked for Update Z czym to jest związanie...Z tego co wnioskuję błąd jest po stronie Fedory... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Lipiec 21, 2010 Zgłoszenie Share Napisano Lipiec 21, 2010 Zakomentuj w pliku konfiguracji repo "mirrorlist" i odkomentuj "baseurl" - poszukaj na forum jak nie wiesz jak to zrobić, bo to już było wiele razy opisywane. Albo po prostu poczekaj jakiś czas, bo problem jest prawdopodobnie przejściowy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Lipiec 31, 2010 Zgłoszenie Share Napisano Lipiec 31, 2010 Dzisiaj robiłem dużą aktualizację na kompie rodziców i też wystąpił ten problem. Udało się załatwić sprawę w ten sposób: yum -y update rpm yum -y update empathy gnome-panel nautilus-sendto pidgin-evolution yum -y update Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
