Fedora 14
waldis
  • 3 weeks later...
Tego posta piszę z poziomu fedory 14 live ;
[root@localhost ~]# uname -a
Linux localhost.localdomain 2.6.35.4-28.fc14.x86_64 #1 SMP Wed Sep 15 01:56:54 UTC 2010 x86_64 x86_64 x86_64 GNU/Linux
Czy na tej wersji systemu da rade zainstalować stery do grafiki Ati ?
Na domyślnym sterowniku radeon to ptrogram tvtime nie chce sie uruchamiasć ;
[root@localhost ~]# tvtime
Running tvtime 1.0.2.
Reading configuration from /etc/tvtime/tvtime.xml
Reading configuration from /root/.tvtime/tvtime.xml
xvoutput: No XVIDEO port found which supports YUY2 images.
*** tvtime requires hardware YUY2 overlay support from your video card
*** driver.  If you are using an older NVIDIA card (TNT2), then
*** this capability is only available with their binary drivers.
*** For some ATI cards, this feature may be found in the experimental
*** GATOS drivers: http://gatos.souceforge.net/
*** If unsure, please check with your distribution to see if your
*** X driver supports hardware overlay surfaces.
[root@localhost ~]#
Nie uruchamia sie też zynaddsubfx ;
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
ERROR: Cannot make a jack client (possible reasons: JACK server is not running or jackd is launched by root and zynaddsubfx by another user.).
[root@localhost ~]#
Ani wymagany JACK ;
JackAudioDriver::ProcessAsync: read error, skip cycle
alsa_driver_xrun_recovery
11:51:07.887 JACK is stopping...
jack main caught signal 15
Using port names patch v0.1 (07.04.2010)
Released audio card Audio0
audio_reservation_finish
11:51:07.967 JACK was stopped successfully.
11:51:07.967 Post-shutdown script...
11:51:07.968 killall jackd
jackd: no process found
11:51:08.436 Post-shutdown script terminated with exit status=256.
Czy do wersji finalnej te błędy poprawią :unsure:
  • Downvote 4
[root@localhost ~]#
Ani wymagany JACK ;
Zaczynam mieć ochotę Cię poprostu udusić za te posty. ZynAddSubFX nie możesz uruchomić bez uruchomienia JACKa wcześniej, i musi byc uruchomione z _tego samego użytkownika co JACK_. Ty uruchamiasz z roota (co jest już dziwne).
Druga sprawa, to dowiedz się jak poprawnie skonfigurować JACKa, bo najwyraźniej nie potrafisz tego poprostu zrobić. ProcessAsync z tego co kojarze jest problemem związanym z kartami Realteka (HDA). Najprościej spróbuj uruchomić jacka w trybie Playback Only jeśli nie potrzebujesz nagrywania, a jeśli potrzebujesz to poszukaj w sieci jak ominąć błąd na tych kartach.
Otóż właśnie Waldo mam dla ciebie radosną wiadomość ; na najnowszym *buntu 10.10
też jest źle ;
darecki@darecki-JV71TR:~$ cat /etc/issue
Ubuntu 10.10 \n \l
Using OSS instead.
ERROR - I can't open the /dev/dsp.
!! :angry:
