Po Zainstalowaniu Sterowników Do Ati, Zwolnienie Pracy I Brak Akceleracji
lukaszw17
to w takim razie czekam aż ktos bedzie mial jakis pomysl...
Wyskakuje jeszcze coś takiego w pasku " boot meesages "
Welcome to Fedora
               Press 'I' to enter interactive startup.
Starting udev: 	[  OK  ]
Setting hostname Acer-pc:      [  OK  ]
Setting up Logical Volume Management:   No volume groups found
   [  OK  ]
Checking filesystems
/dev/sda5: clean, 21568/1011840 files, 342037/4042339 blocks
/dev/mapper/luks-5a8dc3f6-c28f-42ca-9580-926a3b9f2337: clean, 2013/29163520 files, 1924351/116653575 blocks
/home: clean, 121425/2220032 files, 8695375/8865864 blocks
   [  OK  ]
Remounting root filesystem in read-write mode:      [  OK  ]
Mounting local filesystems:      [  OK  ]
Enabling local filesystem quotas:      [  OK  ]
Enabling /etc/fstab swaps:      [  OK  ]
Przechodzenie do uruchamiania nieinteraktywnego
Checking kmods exist for 2.6.34.7-56.fc13.x86_64    [  OK  ]
Ignoring catalyst-kmod as it failed earlier    [OSTRZEŻENIE]
Hint: Some kmods were ignored or failed to build or install.
You can try to rebuild and install them by by calling
'/usr/sbin/akmods --force' as root.
Checking for module fglrx.ko: 	[NIEUDANE]
fglrx.ko for kernel 2.6.34.7-56.fc13.x86_64 was not found.    [OSTRZEŻENIE]
catalyst DRI will not be enabled until one is found.    [OSTRZEŻENIE]
ip6tables: zastosowywanie reguł zapory sieciowej: 	[  OK  ]
iptables: zastosowywanie reguł zapory sieciowej: 	[  OK  ]
Uruchamianie auditd: 	[  OK  ]
Uruchamianie portreserve: 	[  OK  ]
Uruchamianie dziennika systemowego: 	[  OK  ]
Enabling ondemand cpu frequency scaling: 	[  OK  ]
Uruchamianie irqbalance: 	[  OK  ]
Uruchamianie rpcbind: 	[  OK  ]
Uruchamianie mdmonitor: 	[  OK  ]
Uruchamianie magistrali komunikatów systemowych: 	[  OK  ]
Ustawianie parametrów sieci... 	[  OK  ]
Uruchamianie demona menedżera sieci: 	[  OK  ]
Uruchamianie demona Avahi... 	[  OK  ]
Uruchamianie NFS statd: 	[  OK  ]
Uruchamianie RPC idmapd: 	[  OK  ]
Uruchamianie cups: 	[  OK  ]
Uruchamianie demona ACPI: 	[  OK  ]
Uruchamianie demona HAL: 	[  OK  ]
Ponowne wywoływanie nieudanych zdarzeń udev    [  OK  ]
Uruchamianie demona kart smart PC/SC (pcscd): 	[  OK  ]
Włączanie urządzeń Bluetooth:
Uruchamianie sshd: 	[  OK  ]
Uruchamianie sendmail: 	[  OK  ]
Uruchamianie sm-client: 	[  OK  ]
Uruchamianie demona abrt: 	[  OK  ]
Uruchamianie crond: 	[  OK  ]
Uruchamianie atd: 	[  OK  ]
   [  OK  ]
Starting ATI External Events Daemon: 	[  OK  ]
próbowałem tej komendy ale to nie pomaga...
[root@Acer-pc lukasz]# /usr/sbin/akmods --force
Building and installing catalyst-kmod                      [NIEUDANE]
Building rpms failed; see /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed.log for details
czekam na sugestie
szczegóły tej nie udanej próby przebudowy lub instalacji
5 paź 22:36:40 akmods: Building RPM using the command '/usr/bin/akmodsbuild --target x86_64 --kernels 2.6.34.7-56.fc13.x86_64 /usr/src/akmods/catalyst-kmod.latest'
+ cp -a fglrxpkg/ _kmod_build_2.6.34.7-56.fc13.x86_64
+ exit 0
Wykonywanie(%build): /bin/sh -e /var/tmp/rpm-tmp.D6JzOr
+ umask 022
+ cd /tmp/akmodsbuild.CYNPr2pT//BUILD
+ cd catalyst-kmod-10.9
+ for kernel_version in 2.6.34.7-56.fc13.x86_64___/usr/src/kernels/2.6.34.7-56.fc13.x86_64
+ pushd _kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x
/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9
+ make CC=gcc PAGE_ATTR_FIX=0 KVER=2.6.34.7-56.fc13.x86_64 KDIR=/usr/src/kernels/2.6.34.7-56.fc13.x86_64
make -C /usr/src/kernels/2.6.34.7-56.fc13.x86_64 SUBDIRS=/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/kernels/2.6.34.7-56.fc13.x86_64'
 CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
 CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
 CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
 CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
 CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c: In function 'KCL_IOCTL_AllocUserSpace32':
/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: error: implicit declaration of function 'compat_alloc_user_space'
/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: warning: return makes pointer from integer without a cast
make[2]: *** [/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o] Error 1
make[1]: *** [_module_/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x] Error 2
make[1]: Leaving directory `/usr/src/kernels/2.6.34.7-56.fc13.x86_64'
make: *** [kmod_build] Error 2
błąd: Błędny stan wyjścia z /var/tmp/rpm-tmp.D6JzOr (%build)
Błędy budowania pakietu RPM:
   użytkownik mockbuild nie istnieje - używanie roota
   grupa mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: * Rebuilding /usr/src/akmods/catalyst-kmod.latest for kernel(s) 2.6.34.7-56.fc13.x86_64: ostrzeżenie: użytkownik mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: ostrzeżenie: grupa mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: ostrzeżenie: użytkownik mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: Instalowanie /usr/src/akmods/catalyst-kmod.latest
15 paź 22:36:52 akmodsbuild: Budowanie dla platform: x86_64
15 paź 22:36:52 akmodsbuild: Budowanie dla x86_64
15 paź 22:36:52 akmodsbuild: Wykonywanie(%prep): /bin/sh -e /var/tmp/rpm-tmp.wAsoRN
15 paź 22:36:52 akmodsbuild: + umask 022
15 paź 22:36:52 akmodsbuild: + cd /tmp/akmodsbuild.CYNPr2pT//BUILD
15 paź 22:36:52 akmodsbuild: + kmodtool --target x86_64 --repo rpmfusion --kmodname catalyst-kmod --filterfile /tmp/akmodsbuild.CYNPr2pT/SOURCES/catalyst-kmodtool-excludekernel-filterfile --for-kernels 2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: %package   	-n kmod-catalyst-2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: Summary:          catalyst kernel module(s) for 2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: Group:            System Environment/Kernel
15 paź 22:36:52 akmodsbuild: Provides: 		kernel-modules-for-kernel = 2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: Provides: 		catalyst-kmod = %{?epoch:%{epoch}:}%{version}-%{release}
15 paź 22:36:52 akmodsbuild: Requires: 		catalyst-kmod-common >= %{?epoch:%{epoch}:}%{version}
15 paź 22:36:52 akmodsbuild: Requires(post):   /sbin/depmod
15 paź 22:36:52 akmodsbuild: Requires(postun): /sbin/depmod
15 paź 22:36:52 akmodsbuild: Requires: 		kernel-uname-r = 2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: BuildRequires:      kernel-devel-uname-r = 2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: %post          -n kmod-catalyst-2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: /sbin/depmod -aeF /boot/System.map-2.6.34.7-56.fc13.x86_64 2.6.34.7-56.fc13.x86_64 > /dev/null || :
15 paź 22:36:52 akmodsbuild: %postun        -n kmod-catalyst-2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: /sbin/depmod  -aF /boot/System.map-2.6.34.7-56.fc13.x86_64 2.6.34.7-56.fc13.x86_64 &> /dev/null || :
15 paź 22:36:52 akmodsbuild: %description  -n kmod-catalyst-2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: This package provides the catalyst kernel modules built for the Linux
15 paź 22:36:52 akmodsbuild: kernel 2.6.34.7-56.fc13.x86_64 for the %{_target_cpu} family of processors.
15 paź 22:36:52 akmodsbuild: %files        -n kmod-catalyst-2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: %defattr(644,root,root,755)
15 paź 22:36:52 akmodsbuild: /lib/modules/2.6.34.7-56.fc13.x86_64/extra/catalyst/
15 paź 22:36:52 akmodsbuild: %define kmodinstdir_prefix  /lib/modules/
15 paź 22:36:52 akmodsbuild: %define kmodinstdir_postfix /extra/catalyst/
15 paź 22:36:52 akmodsbuild: %define kernel_versions 	2.6.34.7-56.fc13.x86_64___%{_usrsrc}/kernels/2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: + cd /tmp/akmodsbuild.CYNPr2pT/BUILD
15 paź 22:36:52 akmodsbuild: + rm -rf catalyst-kmod-10.9
15 paź 22:36:52 akmodsbuild: + /bin/mkdir -p catalyst-kmod-10.9
15 paź 22:36:52 akmodsbuild: + cd catalyst-kmod-10.9
15 paź 22:36:52 akmodsbuild: + /usr/bin/bzip2 -dc /tmp/akmodsbuild.CYNPr2pT/SOURCES/catalyst-kmod-data-10.9.tar.bz2
15 paź 22:36:52 akmodsbuild: + /bin/tar -xf -
15 paź 22:36:52 akmodsbuild: + STATUS=0
15 paź 22:36:52 akmodsbuild: + '[' 0 -ne 0 ']'
15 paź 22:36:52 akmodsbuild: + /bin/chmod -Rf a+rX,u+w,g-w,o-w .
15 paź 22:36:52 akmodsbuild: + cp -p /usr/lib/rpm/find-debuginfo.sh .
15 paź 22:36:52 akmodsbuild: + sed -i -e 's|strict=true|strict=false|' find-debuginfo.sh
15 paź 22:36:52 akmodsbuild: + mkdir fglrxpkg
15 paź 22:36:52 akmodsbuild: + cp -r fglrx/common/lib fglrx/common/usr fglrx/arch/x86_64/lib fglrxpkg/
15 paź 22:36:52 akmodsbuild: + find fglrxpkg/lib/modules/fglrx/build_mod/ -type f -print0
15 paź 22:36:52 akmodsbuild: + xargs -0 chmod 0644
15 paź 22:36:52 akmodsbuild: + for kernel_version in 2.6.34.7-56.fc13.x86_64___/usr/src/kernels/2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: + cp -a fglrxpkg/ _kmod_build_2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: + exit 0
15 paź 22:36:52 akmodsbuild: Wykonywanie(%build): /bin/sh -e /var/tmp/rpm-tmp.D6JzOr
15 paź 22:36:52 akmodsbuild: + pushd _kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x
15 paź 22:36:52 akmodsbuild: /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9
15 paź 22:36:52 akmodsbuild: + make CC=gcc PAGE_ATTR_FIX=0 KVER=2.6.34.7-56.fc13.x86_64 KDIR=/usr/src/kernels/2.6.34.7-56.fc13.x86_64
15 paź 22:36:52 akmodsbuild: make -C /usr/src/kernels/2.6.34.7-56.fc13.x86_64 SUBDIRS=/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x modules
15 paź 22:36:52 akmodsbuild: make[1]: Entering directory `/usr/src/kernels/2.6.34.7-56.fc13.x86_64'
15 paź 22:36:52 akmodsbuild: CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
15 paź 22:36:52 akmodsbuild: CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
15 paź 22:36:52 akmodsbuild: CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
15 paź 22:36:52 akmodsbuild: CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
15 paź 22:36:52 akmodsbuild: CC [M]  /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
15 paź 22:36:52 akmodsbuild: /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c: In function 'KCL_IOCTL_AllocUserSpace32':
15 paź 22:36:52 akmodsbuild: /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: error: implicit declaration of function 'compat_alloc_user_space'
15 paź 22:36:52 akmodsbuild: /tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: warning: return makes pointer from integer without a cast
15 paź 22:36:52 akmodsbuild: make[2]: *** [/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o] Error 1
15 paź 22:36:52 akmodsbuild: make[1]: *** [_module_/tmp/akmodsbuild.CYNPr2pT/BUILD/catalyst-kmod-10.9/_kmod_build_2.6.34.7-56.fc13.x86_64/lib/modules/fglrx/build_mod/2.6.x] Error 2
15 paź 22:36:52 akmodsbuild: make[1]: Leaving directory `/usr/src/kernels/2.6.34.7-56.fc13.x86_64'
15 paź 22:36:52 akmodsbuild: make: *** [kmod_build] Error 2
15 paź 22:36:52 akmodsbuild: błąd: Błędny stan wyjścia z /var/tmp/rpm-tmp.D6JzOr (%build)
15 paź 22:36:52 akmodsbuild: Błędy budowania pakietu RPM:
15 paź 22:36:52 akmodsbuild: użytkownik mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: grupa mockbuild nie istnieje - używanie roota
15 paź 22:36:52 akmodsbuild: Błędny stan wyjścia z /var/tmp/rpm-tmp.D6JzOr (%build)
15 paź 22:36:52 akmods: Building rpms failed; see /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed.log for details
prosze bardzo mam nalepke na laptopie chyba ze mnie w konia zrobili :P
root@Acer-pc lukasz]# /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed
bash: /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed: Nie ma takiego pliku ani katalogu
[root@Acer-pc lukasz]# /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed.
bash: /var/cache/akmods/catalyst/10.9-1-for-2.6.34.7-56.fc13.x86_64.failed.: Nie ma takiego pliku ani katalogu
[root@Acer-pc lukasz]# lspci
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.3 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation ICH9M/M-E SATA AHCI Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: ATI Technologies Inc Redwood [Radeon HD 5600 Series]
01:00.1 Audio device: ATI Technologies Inc Redwood HDMI Audio [Radeon HD 5600 Series]
02:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5784M Gigabit Ethernet PCIe (rev 10)
03:00.0 Network controller: Atheros Communications Inc. AR928X Wireless Network Adapter (PCI-Express) (rev 01)
Nawet nie chciało Ci się wysilić i poszukać http://www.google.pl/search?hl=pl&client=opera&rls=en&q=kcl_ioctl.c%3A196%3A+error%3A+implicit+declaration+of+function+%27compat_alloc_user_space%27&aq=f&aqi=&aql=&oq=&gs_rfai= . W skrócie można powiedzieć, że AMD już tradycyjnie jest opóźnione w rozwoju. Zamiast budować samemu moduł skorzystaj już ze zbudowanego kmoda przez ludzi z rpmfusion http://download1.rpmfusion.org/nonfree/fedora/updates/13/i386/repoview/K.group.html i zainstaluj go na odpowiednim jądrze.
Nie wiem, ale możesz spróbować automatyczny sposób, czyli uruchom komputer na najnowszym jądrze i wpisz yum downgrade kernel (szczerze mówiąc to nie wiem czy rezultat będzie taki jakiego oczekujesz). A sposób ręczny to po prostu zwykłe pobranie pakietów z serwerów lustrzanych repozytorium fedory i instalacja przez yum localinstall /pakiet/na/dysku/kernel*.rpm
  • Upvote 1
Nie wiem Jak już wspomniałem wyrzuciłem g.... AMD Zablokowanie sterownika nouveau dotyczy wg mnie tylko kart nvidia. Jeśli się mylę, to na pewno ktoś mnie poprawi, Jeśli nie, to potwierdzi moje zdanie.
Tak, chyba ten nouveau to nVidia exclusive, acz mam go zablokowanego (rdblacklist czy jakośtak) w GRUB mimo karty AMD i działać działa jak należy, więc przynajmniej nie wpływa ta blokada negatywnie na pracę
Nie ma niczego do zrobienia
[root@Acer-pc lukasz]# yum localinstall home/lukasz/Pobrane/kernel-devel-2.6.34.6-54.fc13.x86_64.rpm
Wczytane wtyczki: presto, refresh-packagekit
Ustawianie procesu lokalnego pakietu
Nie można otworzyć: home/lukasz/Pobrane/kernel-devel-2.6.34.6-54.fc13.x86_64.rpm. Pomijanie.
Robię coś nie tak ??
