Blad Bootowania Po Instalacji Fedory 14
samson32
Witam,
Przepraszzm za brak polskich znakow, pisze z live CD, przejde do rzeczy...
Mam dwa twarde dyski, na jednym zainstalowany jest Windowsa 7, na drugim byl zainstalowany Ubuntu. Uruchomilem Fedore 14 (64 bit) z live CD, sformatowalem partycje Ubuntu i na jego miejsce zainstalowalem Fedore. Po restarcie komputera, nie bootuje sie zaden system. Nie wiem co zrobic... Prosze o pomoc.
Dziekuje za chec pomocy,
wyskakiwal jakis blad bootowania i byla dostepna konsola gruba. Zainstalowalem fedore jeszcze raz moze to cos zmieni, jezeli nie to za 5 minut wrzuce zdjecie.
Niestety nic to nie pomoglo, zalaczam zdjecie.
Results of Boot Info Script
                Boot Info Script 0.55    dated February 15th, 2010
============================= Boot Info Summary: ==============================
=> Grub 0.97 is installed in the MBR of /dev/sda and looks at sector 298076
   on boot drive #1 for the stage2 file. A stage2 file is at this location on
   /dev/sda. Stage2 looks on partition #2 for /grub/grub.conf.
=> Grub 2 is installed in the MBR of /dev/sdb and looks on the same drive in
   partition #2 for (,msdos2)/boot/grub.
sda1: _________________________________________________________________________
   File system:       Extended Partition
   Boot sector type:  Unknown
   Boot sector info:
sda5: _________________________________________________________________________
   File system:       ntfs
   Boot sector type:  Windows Vista/7
   Boot sector info:  According to the info in the boot sector, sda5 starts
                      at sector 1970. But according to the info from fdisk,
                      sda5 starts at sector 204830720.
   Operating System:
   Boot files/dirs:
sda6: _________________________________________________________________________
   File system:       ntfs
   Boot sector type:  Windows XP
   Boot sector info:  According to the info in the boot sector, sda6 starts
                      at sector 63.
   Operating System:
   Boot files/dirs:
sda7: _________________________________________________________________________
   File system:       ntfs
   Boot sector info:  According to the info in the boot sector, sda7 starts
                      at sector 1507. But according to the info from fdisk,
                      sda7 starts at sector 486787072.
   Operating System:
   Boot files/dirs:
sda8: _________________________________________________________________________
   File system:       ext4
   Boot sector type:  -
   Boot sector info:
   Operating System:
   Boot files/dirs:
sda9: _________________________________________________________________________
   File system:       ext4
   Boot sector type:  -
   Boot sector info:
   Operating System:  Fedora release 14 (Laughlin)
                      Kernel on an ()
   Boot files/dirs:   /etc/fstab
sda2: _________________________________________________________________________
   File system:       ext4
   Boot sector type:  -
   Boot sector info:
   Operating System:
   Boot files/dirs:   /grub/menu.lst /grub/grub.conf
sda3: _________________________________________________________________________
   File system:       swap
   Boot sector type:  -
   Boot sector info:
sdb1: _________________________________________________________________________
   File system:       ntfs
   Boot sector info:  No errors found in the Boot Parameter Block.
   Operating System:  Windows 7
   Boot files/dirs:   /bootmgr /Boot/BCD /Windows/System32/winload.exe
sdb2: _________________________________________________________________________
   File system:       ntfs
   Operating System:
   Boot files/dirs:
=========================== Drive/Partition Info: =============================
Drive: sda ___________________ _____________________________________________________
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Partition  Boot         Start           End          Size  Id System
/dev/sda1          19,533,822   625,135,615   605,601,794   f W95 Ext d (LBA)
/dev/sda5         204,830,720   256,024,575    51,193,856   7 HPFS/NTFS
/dev/sda6         256,027,968   486,785,564   230,757,597   7 HPFS/NTFS
/dev/sda7         486,787,072   625,135,615   138,348,544   7 HPFS/NTFS
/dev/sda8          19,537,920   174,108,671   154,570,752  83 Linux
/dev/sda9         174,110,720   204,828,671    30,717,952  83 Linux
/dev/sda2    *          2,048       616,447       614,400  83 Linux
/dev/sda3             616,448     4,810,751     4,194,304  82 Linux swap / Solaris
Drive: sdb ___________________ _____________________________________________________
Disk /dev/sdb: 164.7 GB, 164696555520 bytes
255 heads, 63 sectors/track, 20023 cylinders, total 321672960 sectors
/dev/sdb1    *          2,048    58,595,797    58,593,750   7 HPFS/NTFS
/dev/sdb2          58,597,376   321,669,119   263,071,744   7 HPFS/NTFS
blkid -c /dev/null: ____________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/loop2                                              squashfs
/dev/loop3       5eee27a3-87a5-4f43-8072-a17fc25c3052   ext4       _Fedora-14-x86_6
/dev/mapper/live-osimg-min 5eee27a3-87a5-4f43-8072-a17fc25c3052   ext4       _Fedora-14-x86_6
/dev/mapper/live-rw 5eee27a3-87a5-4f43-8072-a17fc25c3052   ext4       _Fedora-14-x86_6
/dev/sda1: PTTYPE="dos" PART_ENTRY_SCHEME="dos" PART_ENTRY_TYPE="0xf" PART_ENTRY_NUMBER="1"
/dev/sda2        df0afc03-d24c-4ce8-b085-32db40205afd   ext4
/dev/sda3        b3279b75-8eb5-4ed6-91c2-15a289943abd   swap
/dev/sda5        8EC8E15CC8E14357                       ntfs       Music
/dev/sda6        90B8CC34B8CC1A9C                       ntfs       PROGRAMY
/dev/sda7        3C3CEC1A3CEBCCC8                       ntfs       DOWNLOADS
/dev/sda8        89f94225-cc21-427c-b237-2751ee10d940   ext4
/dev/sda9        ee377f97-15f6-494e-8893-441836276a8b   ext4       _Fedora-14-x86_6
/dev/sda: PTTYPE="dos"
/dev/sdb1        7230799B3079674F                       ntfs       Seven
/dev/sdb2        8AAC7158AC713FAD                       ntfs       HDD2
/dev/sdb: PTTYPE="dos"
=============================== "ls -R /dev/mapper/" output: ===============================
/dev/mapper:
control
live-osimg-min
live-rw
============================ "mount | grep ^/dev  output: ===========================
Device           Mount_Point              Type       Options
/dev/mapper/live-rw /                        ext4       (rw,noatime)
=============================== sda9/etc/fstab: ===============================
# /etc/fstab
# Created by anaconda on Fri Apr 22 11:20:09 2011
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
UUID=ee377f97-15f6-494e-8893-441836276a8b /                       ext4    defaults        1 1
UUID=df0afc03-d24c-4ce8-b085-32db40205afd /boot                   ext4    defaults        1 2
UUID=89f94225-cc21-427c-b237-2751ee10d940 /home                   ext4    defaults        1 2
UUID=b3279b75-8eb5-4ed6-91c2-15a289943abd swap                    swap    defaults        0 0
tmpfs                   /dev/shm                tmpfs   defaults        0 0
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
sysfs                   /sys                    sysfs   defaults        0 0
proc                    /proc                   proc    defaults        0 0
============================= sda2/grub/grub.conf: =============================
# grub.conf generated by anaconda
# Note that you do not have to rerun grub after making changes to this file
# NOTICE:  You have a /boot partition.  This means that
#          all kernel and initrd paths are relative to /boot/, eg.
#          root (hd0,1)
#          kernel /vmlinuz-version ro root=/dev/sda9
#          initrd /initrd-[generic-]version.img
#boot=/dev/sda
default=0
timeout=5
splashimage=(hd0,1)/grub/splash.xpm.gz
hiddenmenu
title Fedora (2.6.35.6-45.fc14.x86_64)
root (hd0,1)
kernel /vmlinuz-2.6.35.6-45.fc14.x86_64 ro root=UUID=ee377f97-15f6-494e-8893-441836276a8b rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=us rhgb quiet
initrd /initramfs-2.6.35.6-45.fc14.x86_64.img
title Other
rootnoverify (hd0,4)
chainloader +1
=================== sda2: Location of files loaded by Grub: ===================
   .1GB: grub/grub.conf
   .1GB: grub/menu.lst
   .1GB: grub/stage2
   .0GB: initramfs-2.6.35.6-45.fc14.x86_64.img
   .0GB: initrd-plymouth.img
   .0GB: vmlinuz-2.6.35.6-45.fc14.x86_64
=========================== Unknown MBRs/Boot Sectors/etc =======================
Unknown BootLoader  on sda1
00000000  a2 8c 41 42 a7 0c 1a 8f  80 b9 41 f0 08 00 30 4a  |..AB......A...0J|
00000010  53 cb 01 89 0b 76 3b e4  b2 32 53 c1 1c 00 f7 b4  |S....v;..2S.....|
00000020  3b 8d ff 71 f8 05 b6 c0  59 20 3f 9a 8a 2d 05 9a  |;..q....Y ?..-..|
00000030  a2 42 e4 1e c4 19 27 e4  10 22 87 5d bb 54 d3 52  |.B....'..".].T.R|
00000040  10 9c 93 c3 f9 d0 1e 41  81 cb 72 34 84 77 e4 55  |.......A..r4.w.U|
00000050  5f 52 08 a7 c3 bd c4 47  08 d7 cb 52 13 90 07 80  |_R.....G...R....|
00000060  f5 01 ec 45 31 84 f9 28  35 80 e0 1a 89 a5 62 52  |...E1..(5.....bR|
00000070  d3 c3 80 dc 02 da 28 a6  16 6a 28 f5 2c 8b e8 ec  |......(..j(.,...|
00000080  41 5f b6 01 ce 72 21 1e  34 e2 2c 6d 14 4a 0b 53  |A_...r!.4.,m.J.S|
00000090  04 11 a1 14 ed c0 d8 1a  8d 01 fd dd c6 15 a6 66  |...............f|
000000a0  59 b1 a6 10 21 f3 00 d6  35 55 19 e0 16 28 4c 62  |Y...!...5U...(Lb|
000000b0  89 c0 3f b0 0f 2c 40 00  f5 6f 2c c2 23 4e d4 25  |..?..,@..o,.#N.%|
000000c0  83 80 ba 00 fa c1 87 ff  c7 5b d4 78 f0 39 29 40  |.........[.x.9)@|
000000d0  03 da 28 96 06 00 e0 1c  42 6a 7a 12 81 4d 3a 00  |..(.....Bjz..M:.|
000000e0  fa 58 fb 37 ee 40 a1 30  1c 05 c0 6e 1e 04 20 17  |[email protected].. .|
000000f0  43 e8 49 31 d6 a2 70 ed  00 d1 36 8e 68 1a 94 60  |C.I1..p...6.h..`|
00000100  06 f0 0b e1 f7 18 18 20  04 41 ea b2 4b 93 80 8c  |....... .A..K...|
00000110  39 60 03 f9 d5 8f 0f 62  49 3f 42 a8 4a ea 61 e1  |9`.....bI?B.J.a.|
00000120  4c 46 ae 38 00 79 00 b3  bf 96 db 11 40 7d 42 5a  |LF.8.y......@}BZ|
00000130  1b 2a 00 f6 52 e1 d0 75  14 52 02 03 26 3a 16 07  |.*..R..u.R..&:..|
00000140  24 33 64 46 c3 a3 6e 50  a0 19 7f fe 58 b2 2c fa  |$3dF..nP....X.,.|
00000150  48 0c e5 1e 40 a1 35 0b  01 ac 1f 00 79 00 7d 08  |[email protected].}.|
00000160  9a 90 07 11 95 40 1a 00  06 01 98 10 a2 89 b1 b3  |.....@..........|
00000170  7d 09 d3 01 64 0c bf ff  42 56 03 37 ff d0 93 63  |}...d...BV.7...c|
00000180  e8 4c c0 0e a9 ac 40 00  00 01 12 42 a3 ad 8e 80  |[email protected]....|
00000190  5a aa 28 94 26 c8 1f 18  07 26 8c 83 ea 07 63 20  |Z.(.&....&....c |
000001a0  17 75 c3 80 7f 55 19 6c  a7 0a c3 82 e0 f8 cf c8  |.u...U.l........|
000001b0  80 75 af 65 f9 c0 67 5a  a3 04 f0 0d e0 ec 00 fe  |.u.e..gZ........|
000001c0  ff ff 07 fe ff ff 02 68  0b 0b 00 28 0d 03 00 fe  |.......h...(....|
000001d0  ff ff 05 fe ff ff 03 9d  18 0e 1c 15 c1 0d 00 00  |................|
000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |..............U.|
00000200
=============================== StdErr Messages: ===============================
 No volume groups found
mdadm: No arrays found in config file or automatically
Edytowane przez WalDo
zmiana znaczników code ? codebox
Jak jesteś w trybie rescue to jeszcze nie jest źle, bo można naprawić z jego poziomu bez większych kombinacji. Numeracja dysków jest odwrotna niż to opisałeś w pierwszym poście, czyli pierwszy jest dysk z linuksem, a drugi z windowsem. Zresztą z tego co pamiętam to w trybie rescue można wywołać fdisk, czyli możesz to sprawdzić (samo fdisk lub fdisk -l). Potem to już sobie przeczytaj na spokojnie https://wiki.archlinux.org/index.php/Grub#General_notes_about_bootloader_installation i powinieneś dać radę. Ciebie najbardziej interesuje https://wiki.archlinux.org/index.php/Grub#Finding_GRUB.27s_root a jak już będziesz wiedział, gdzie to trzeba wskazać roota np. root (hd1,0) i zainstalować do MBR np. setup (hd0)
Komunikat wydaje sie byc jasny i oczywisty: brak urzadzenia o UUID podanym w komunikacie. Prawdopodobnie partycja /boot zmienila UUID. Wystarczy ja namierzyc i w /etc/fstab zamiast UUID=xxxxxxx wpisac np. bezposrednio /dev/sda1 (oczywiscie nazwa urzadzenia przykladowa - trzeba zmienic na te wlasciwa)
Calosc operacji mozna wykonac uruchamiajac system w trybie rescue (patrz → http://wiki.fedora.pl/wiki/GRUB#GRUB_-_jak_odzyska.C4.87.3F - przejscie do rescue identyczne jak w przypadku odzyskiwania konfiguracji GRUBa)
[EDIT]
I jeszcze tylko prosba: takie tasiemcowe wklejki kodu to miedzy znaczniki codebox a nie code prosze wstawiac
[EDIT2]
Tak jeszcze popatrzylem: boot jest z /dev/sda2 chyba. Jakbys jeszcze wyciagnal i wkleil tutaj /etc/fstab, to bysmy pewnie byli "w domu".
[EDIT3]
I jeszcze komunikat "unknown bootloader on device" - moze po prostu trzeba odzyskac GRUBa i bedzie po zawodach. Link do instrukcji odzyskiwania powyzej.
  • Upvote 1
Z plyty live CD nie udalo mi sie wejsc w tryb rescue, po nacisnieciu Esc i wpisaniu "linux rescue" otrzymywalem odpowiedz linux command not found.
Znalazlem stara plyte do fedory 32 bitowej i z niej udalo mi sie wejsc do trybu rescue, wszystko zrobilem wedlug polecen ale po wpisaniu chroot /mnt/sysimage
chroot: nie udalo sie uruchomic polecenia '/bin/sh' : Exec format error
Ten blad wynika z tego ze system na plycie jest 32 bitowy?
Zamienilem kolejnosc bootowanych dyskow w biosie i dziala!!! :D Niestety jedyny system jaki jest dostepny w menu gruba to fedora, ale mysle ze z dodaniem windowsa nie bede mial juz problemow.
Pozdrawiam i dziekuje wszystkim za pomoc.
